Differences between cdt-master-4.0.0.zip and update manager release [message #199692] |
Sat, 18 August 2007 07:37  |
There seems to be a difference between installing cdt-master-4.0.0.zip and
the release installed via the update managed.
When using cdt-master-4.0.0.zip, the PATH environment variable does not get
set when you create a project, the scanner info generator fails to start and
you get Exec errors: when trying to build. Adding the PATH variable manually
doesn't seem to fix these failures.
Also, I've notices that when using the cdt-master-4.0.0.zip version, when
creating a new C project, a Test Page appears at the end of the wizzard,
which doesn't happen in the update manager version.
Jon
FUDForum. Page generated in 0.04118 seconds
