Home » Language IDEs » C / C++ IDE (CDT) » Differences between cdt-master-4.0.0.zip and update manager release
Differences between cdt-master-4.0.0.zip and update manager release [message #199692] Sat, 18 August 2007 07:37 Go to next message
There seems to be a difference between installing cdt-master-4.0.0.zip and
the release installed via the update managed.
When using cdt-master-4.0.0.zip, the PATH environment variable does not get
set when you create a project, the scanner info generator fails to start and
you get Exec errors: when trying to build. Adding the PATH variable manually
doesn't seem to fix these failures.
Also, I've notices that when using the cdt-master-4.0.0.zip version, when
creating a new C project, a Test Page appears at the end of the wizzard,
which doesn't happen in the update manager version.
Jon
Re: Differences between cdt-master-4.0.0.zip and update manager release [message #199700 is a reply to message #199692] Sat, 18 August 2007 08:21 Go to previous messageGo to next message
> get set when you create a project, the scanner info generator fails to
> start and you get Exec errors: when trying to build. Adding the PATH
> variable manually doesn't seem to fix these failures.
It seems you need to unpack then delete:
org.eclipse.cdt.core.win32_4.0.0.200706261300.jar
This is just a result of having the extra cdt-test plugins.
Jon
Re: Differences between cdt-master-4.0.0.zip and update manager release [message #199707 is a reply to message #199700] Sat, 18 August 2007 08:47 Go to previous messageGo to next message
Originally posted by: eclipsenews.richardmiskin.plus.com
Did you use the update manager to install from the cdt-master-4.0.0.zip?
That zip is an archived update site, so shouldn't just be extracted into
your eclipse installation.
Richard
"Jon Beniston" <jon@beniston.com> wrote in message
news:fa6o8c$tgf$1@build.eclipse.org...
> Cheers,
> Jon
Re: Differences between cdt-master-4.0.0.zip and update manager release [message #200059 is a reply to message #199707] Wed, 22 August 2007 10:17 Go to previous message
"Richard Miskin" <eclipsenews@richardmiskin.plus.com> wrote in message
news:fa6pp6$vvo$1@build.eclipse.org...
I just unziped it. My mistake.
Jon
Previous Topic:indexer missing whole directories
Next Topic:cdt doesn't detect cvs in project
Current Time: Tue Jul 22 00:43:38 EDT 2025
Powered by FUDForum. Page generated in 0.06023 seconds
