Home » Language IDEs » C / C++ IDE (CDT) » Problem with ScannerConfigurationDiscoveryProfile extension implementation
Problem with ScannerConfigurationDiscoveryProfile extension implementation [message #199660] Fri, 17 August 2007 07:11
Originally posted by: mitja.kukovec.gmail.com
--------------020902090503070106080905
Hi people
I hope I will be clear enough. I am fairly new to eclipse and completely
new to eclipse plug-in development.
Recently I have decided to develop a plug-in which implements new
toolchain for ARM. Everything I have done was by example from
org.eclipse.cdt.managedbuilder.gnu.ui plug-in, especially
org.eclipse.cdt.managedbuilder.core.buildDefinitions extension
implementation.
Among other things I want to change the discovery profile so it will
invoke different compiler invocation command.
I want to change invocation from "gcc -E -P -v -dD
${plugin_state_location}/specs.c"
to the toolchain's compiler invocation like "ccarm -E -P -v -dD
I figured out that this is done by implementing
org.eclipse.cdt.make.core.ScannerConfigurationDiscoveryProfi le extension.
After that I just have to refer to this extension from compiler
(inputType)/scannerConfigDiscoveryProfileId.
But when I do that it seems that it has the same effect as if my
ScannerConfigurationDiscoveryProfile extension is not used at all. There
is no change to discovery profile invocation command! Even worse, I get
the same result if I enter completely bogus text to
scannerConfigDiscoveryProfileId field.
What am I doing wrong? I just can't figure it out.
Does any of you plug-in gurus know what I am missing?
I have attached my plug-in project if anyone is willing to take a look
at it.
Best regards, Mitja
Content-Type: application/octet-stream;
name="org.eclipse.cdt.managedbuilder.tornado.zip"
Content-Disposition: attachment;
filename="org.eclipse.cdt.managedbuilder.tornado.zip"
UEsDBAoAAAAAAAJADTcAAAAAAAAAAAAAAAAJAAAATUVUQS1JTkYvUEsDBBQA AAAIANBUETdC
KisH5gAAAPgBAAAUAAAATUVUQS1JTkYvTUFOSUZFU1QuTUadkUFrwzAMhe/+ FabQ22K67pbS
wwq7taOssLtia0HgyJ1iB9pfvyRe03a7jB3F0/v0eNoB0we2sXhHaSlwqR/N Qm0SO4/F7luc
tOVFeYUGSz3f+1QTD8NFOJyaKniyeSFIbdB6OrZorIumAYYaXZXIOxQTgzC4 sNItce0x9ieU
XkdJE+421TXXs43UQe/+6wUzOdQbfiYSLDLqHpDoQd0Tg6CRxJEaXFX5eJcj rWdPZmkWs5+O
3xkGyL/NNac+lnrJG8UWzqdDBImlvq1pGyx4OkMcuzqOX7lWyG5oar6X0FHP HN/1BVBLAwQK
AAAAAADZdA43AAAAAAAAAAAAAAAABAAAAHNyYy9QSwMECgAAAAAAAkANNwAA AAAAAAAAAAAA
AAgAAABzcmMvb3JnL1BLAwQKAAAAAAACQA03AAAAAAAAAAAAAAAAEAAAAHNy Yy9vcmcvZWNs
aXBzZS9QSwMECgAAAAAAAkANNwAAAAAAAAAAAAAAABQAAABzcmMvb3JnL2Vj bGlwc2UvY2R0
L1BLAwQKAAAAAAACQA03AAAAAAAAAAAAAAAAIwAAAHNyYy9vcmcvZWNsaXBz ZS9jZHQvbWFu
YWdlZGJ1aWxkZXIvUEsDBAoAAAAAAO9WETcAAAAAAAAAAAAAAAArAAAAc3Jj L29yZy9lY2xp
cHNlL2NkdC9tYW5hZ2VkYnVpbGRlci90b3JuYWRvL1BLAwQUAAAACABFSQ03 pCMOo6ABAABL
BAAAOQAAAHNyYy9vcmcvZWNsaXBzZS9jZHQvbWFuYWdlZGJ1aWxkZXIvdG9y bmFkby9BY3Rp
dmF0b3IuamF2Ya1T20rDQBB9TqH/MOhLWzD5gCB4qUhFRLw8y3YzTRe3u8vu bFXEf3c2SW+K
eMGXBCbnzDlnZuKEfBQ1gvV1jlIrFzCXFeULYbhcTaPSFfqcrDeismW/1++p hbOedhhR5U7H
Wpn8eBrIC0n3k+umUO7gbahVPvNigU/WP+Yn0VQaT60hfKamdzEa9Xswgrs5 AndRS8HKILUI
ASTjvNUBiD8muQNlQKsZgnyRGhOv6PdcnGolO8rxugULoKm48sEfvCbZrCga yVXXyZhrXadA
gvg1U0ZouCWvTA3Xl/fnk6uHyRgOYe9no9srt4XCXHisQBnubiQmNZ+c4kpu 49yt5pjYaTxZ
Nx+eB2eJkkFNsdh4XrMHwxQwe+vYLXlgrDm4EEt2JYdt6Sgg/nCj++zQ0+C7 dQ4/elpaVUHL
3QE2e00E3qu3TwHOniU6UrbZTZaF6HiKLXEFLdOH1h9vgOYqlP+f0ro/h2Tq rzKuo5iodbmd
mjtth37bPYMbpOhN+0d8PinoUEe+gX2JKj4d++b6aqQxzkTU1J1S1jVbn2Xr iR/vUEsDBBQA
AAAIAAJADTfVHJzSpQAAADMBAAAKAAAALmNsYXNzcGF0aJ2PPQvCMBRFZwX/ Q8huqptDaxGp
oEOVUmepyaONxpeYD9F/b1WKLjq4vXs5nMuL0+tJkQtYJzUmdMxGlAByLSTW Cd2Wi+GEptNB
P+aqcs5UvmlD750Avb2Ro0SRUGc5JY/ydUbfSa6xI7WtGXAljQN2EJ6pKiBv 2nW2KrLdfJ2X
s2WeFX/YjADGtQVm4RykBbFRoZbofql08Cb4zraX+ITj6PP7O1BLAwQUAAAA CAACQA03iWkD
X+8AAAC7AgAACAAAAC5wcm9qZWN0vZLBTgMhEIbPmvgOzd6FevNAt4kabzUm 1QcYYaQ0y0CA
bXx8AVnNZjXxYLzN/zM/3wRGbN/ssDphiMbRprti626FJJ0ypDfd89P95XW3 7S/OhQ/uiDLd
YZTB+JS7s3smCCz2LmiGcjA+IpMqMQsEGtXLaAaFgSUXCJQTvDaXlHTWIqVe 8KkqbkPEKvhM
1av2HmVRTd7mKJCqzjeDHPMg0oVcwAnaKF8j5AQEPRZ2bJrPDcEXlF9xvUK2 AzKvGNPN/2L3
8oAW/gTanOnJMy+NAVv3h1jgH4dRG3qoh4Vem34KzL6HFpmpLsTPXZgv3ztQ SwMEFAAAAAgA
wUANNyN49npKAAAAbQAAABAAAABidWlsZC5wcm9wZXJ0aWVzK84vLUpO1dNT sFUoLkrW5+XK
Ly0pKC0BCyRl5gEFgKReZl5yTmlKajFQ0Nc1xFHX089NXyeGl0sBFehhESvI KU0HmlCRm8PL
BQBQSwMEFAAAAAgAwUARN3TpJ7yFBgAAeRUAABEAAABwbHVnaW4ucHJvcGVy dGllc61YS2/b
OBC+F+h/IJBLgtZK2j0sUIAHx06KYOPYiN1NgcUeaIm22VCkQFJOvL9+Z0hR kfVofWiBWBzO
Nw8OhzNkz85+67/3787IRBcHI7Y7R87TC/L56upPMhPuByN/lc96z9MEQWMp iQdZYrjlZs+z
hKx2wpLC6K1hOWEqI27HCUtTnRdMHYTakpw5bgSTFnUww2EiA8ieCcnWkpNS Zdx4McDlluiN
J25SKQrLyaJcS5GSe5FyBeT+U3KFil52It3VhgS3IASeZMI6I9alE1p99P7A 5Jst5lB251zx
5fLy5eUl4cFKos32UvItk5e8kKP9p6tk53IJ4BAdFZRqY7/gBP5b8VdmyZ0C e2XOlcNxmpAR
EUo4WC4ZL+6CA3khOSIYOhXF765noNcU2sTp372r798tZLkV6oHlnK60USzT ZMYU2/KMXJdC
ZmTKN95brWBzFkbvBWyFxx/tPuo6q0RmOuOSIAZEVsxsuUMiccFANNTHS/gr p19VSW5eeVo6
3JBemNUetdxBsmSw8WvDzKEXKcU6QDG26U+hzOTe/vhx9iv7CAUfEHmCD4hG Pzy85QeGDWLM
SukwiTZiW4btjgE8I8vV+HFFHuYPo9Xj+GF5P16Nr+9v3r8LcG/pkUsKf5xZ fjQ/XW/plK/L
Leq5eZj2aEHOV67g/KXEaS1H6Y4JRVS1fTAzwYnaTEwT5BDPaqPQaB8KLMVp jETLWFtLI3i0
IXbscCGZ22iTR3cXFd0OComMFqSOTwPQ1L/GhIbSU6m/DmStHRNrxp75MQeV vnHa8W1G1sML
w6E4ptxabeiiQTQwWMKE5CZJ6QTSJBC9/KKgkw8f+jDMpDux54aOq0GDJ4V6 rrTf+2EPr9Lc
4b8IlUGxh1BbXZqUk7S2jWuPe9e79trvuNtpvdc/X2eNB69qif51V/73WRha 65D2Dj7GtF3b
SE+MmbU8X8s+cOT0npETgtY+JKcHryt5WhB7LJ4QzF5rvwxqR+qU4HaFjoJc H8kJXD222hxi
uZ0XWHzjbLI85GstLa2+HX51XlvntgWaCmMp/PAUnBM9VrwzDOpJ+Hb4SObi P06rQXUfaJvB
QhbKGfT0bYf/xIyi+APMrg8zYVOKP1xKprguuxBoWpaGztW3itAJkyV3Di3Q 485I4vxx/IOO
4+gnC23Fa4ztXMlDI75EA03ORzcXLfiDti4TKqVTTZR2xHJMJGIP1vEcbn11 +EFYVdgLdOZI
C/Ri2Gvqrz3gvA37DiLTtr1vcCn1WD9oob91NcPdTy6Y21mKoxIuuAVSAL7r goG453toMc0d
J36qi/S5AetXnOIPaJxftb2tYe1c8vBPg/CZNg1oDhTiP/8Eb10Tbx3i/xjE 30oGqTKH67wh
urnWDTJ6tgeyO0Qm9O2+kHjOWzx6uTOhINuVyOEafj7adgIQUJAGNN7OANUP mrFXCn8iL3ME
ddYaUH6J1UKzeEbjKnvwW8j3TVURHCeehIcD3lFCgM5HxYBDx5J9gt2Ew7oA 1Q6eIK90suPp
MyQzEvG4bQI5QrJt1csueAZPGQGlEAd4xwU71XBI4MYYeC+9SbxUxYnAs4l7 XkPJKMz06lIa
ReFg7cRaOMLgGVrrOh+99MoAyAuNj8FPMN+LdxocsHUBPfLxyY+6Uf2bm7W2 nFZfQO7fdPtc
aOZ/XzKMlRV0WRbwCnQE7u138SWNZhkwu0ZDQ4X8h7eGcbfQyW2siSX4YB3s EzMZDkDnBvlV
SQTak+311xrhLPgm0FCXVcdDxr7gdVWzMDmsbOkyr+xBB1fKgmjT1FdXahgP aFnCq7ug87za
9FCAW9k+5IGXTfxZDBr8sF/HclAHPuf8EkK3a4bBeuaA5PfwbZQ+eGKD0Pdw bSL/hKl/B8RD
3gSiN3GOmzUo7mQ1InyPpLFFVy0T+xII3Hc6nuVmvv5Rl+v1D2ipXbshMD4c 8Q4AsfCDoSjO
/f8oVOCg11978WjJjyOrkaAD0nd5ga9r+OAZiWtpiI906UYioAZ0QGJ7E9Ob W38i2uIFaIDM
pN3TFi+j1Y5EstO/4EWY1HfQCI50awePsVicEgslAF5Z1tcCHBzVrIsBUXDE wiwdK6VLBW+z
aqIqRHgRiw9fYgueig1U4ZB48dlR6X2CV55+sf4L5pO5j8mtPyI0ECQcmJNE konebGgKP+BK
DHCQJzh7cZqWxwk1aVeDSU+Vh9Jo/Oloa2gWwRlL58vvQ5mdHSBSIg016n9Q SwMEFAAAAAgA
zmMRN943X/FnFQAAGzABAAoAAABwbHVnaW4ueG1s7V1bc9s4sn7fqv0PLFV2 a3bHZnZnXk7V
2jMjy3JGpxTLZdnJ7FOKImGFE4pkkZTinKn57wfgnUSDBEiQIm3pIbEtXLo/ dAONbjRw8fPz
zlIOyPNNx76c/Fv910RBtu4Ypr29nDw+3Jz/z+Tnn/76l4ufkW6Zro+ysj+q P0RfudZ+a9r4
J0VRLtBzgGxSIPw1+pjG5UQ3AnWn2doWGepmb1qGatpPziRXytZ26HLyPiqj XJEyyoPjWL5y
jXzdM90At5qv4DqmHVxOHG+rxsSpuV7CTpCn6o6Hoh6v0ZNpm6QVf/JT0s5F XDzs7x4dzBLt
+PNkWuhDDiGMUVb9LVQ/+zrADBRb050droIR0fxJ8RvkeY53p3k+7otmK+Tj 3XQ9z0qV6pdg
jlAmBOB/PFszHFXzfbTbWHRNf7rxA0/TMZyBt0elr6OR+RsZjFv8Y9ZM0jBV Pth76Ma0AuRd
TjZO8LlUwNkH7j64sTQsY+dOhiZBzAnHeaYFaOt434r1YiYzdnaqHhdUt8hG nmZNqBox9atC
u+o7VnHnq02o5gWyQPvbIvEAX1R3Cf2iXOVxIAiH1aI+1CcMbFm4ykCo7+y9 Ok0H8gauctCs
PXr45uJ6WD7wnADyy8PnxnO++nFThukhHRP/je6wKRypVp0vxLAybd3aG0h1 teBzLWZ3jm8+
qwtc5Q4unsMrbpgUbAxaezQ+0l8a6EnbW8EHQurl5Emz/LK+10D2VfNsLAq+ ajvkRzFBIzVU
f++6HvKrAdxghUOafUTwDh2AFy+fYqAxKzWBy7Tx3EvqgHRzzntq2ApNkO/s PR3NHBtbAUFE
GLiQYUTWYVFWE3gF9M/WJW5S0ovjH64mIEchCx80z9Qw0ZeT1dX/ruHh4mU7 6gtYNcK/k2W7
PAApcTmbgTTOZSNsdb2BkbC8bmMk6Kpl2l/a2ghRG1mjlSaCHv0qYCWQGcTx AmTceY6LvMBE
/k/F2hdu9A1tQsQolLGLoMjMxSlu/gmzS8Zu8hPVykWoe1DjDdpX0TPYx9uw k6479z9rHjKW
5oabhIu3CbpFaa8ZlgtkH7A2hrYyWRip3sgqHE9npAz5FZPlaZCpcIjVemn6 WCSXi6v76f1/
P91NH34tqWCp06bWZqQXRzI4U6WUb29y85UtjLbjB5oXkI0RsIYLr5ExBfEK GTfOZ4sto2nm
1lmTOjcwQZ0aFY3giyGyzE0X+OEG4JYrEcTb4yVYa3jw+YGBGexE8owGyK0D YxzIyRc2sit0
heBawzUGB1WgBWbZammPFxaxcLEVhAympTlmjRY8Ds1IVztYH/pd6vIuB9ux gXGqlxSY50xM
ajwzxcEXmVpqppOwqd59MaLoLEXQEfDAEHiQ5ullvyKFUeSm6VIp8Pae2iqV qU614r3pA2o8
NAOQwVKFXBtcHsfCnNa5w7Exn5n4/hZBrrz548N0+Tj/UwQTHrkoIvLbEtp2 Q5iQHY8U5ScG
fBO9F5aQvY88Z/M7p4g84tIrsHQOin1SqEvt5lqsU/Veh6XVNQoC4h8dvqaz 2MuZQYwSbc3G
BkYQo0qNEaSEXgfiJ9ghO4A8JlqAlWqzD8himOOK7gl/0ujm1Ph97wekSSb3 +BOEZM1Wtw/T
xe38/tP04eF+cfX4MAdLHyIwQ+ca4IjRPyP9S+TFqPBs4U/imhF0cTFai6mS 6FCiGaG8S9mI
dTf91wv/R+vs3HcimRQR7rCKmHCvbsEqfS6HfHicO/vg3Ny52LgSAoVUEYZl EfYzFlhcjAye
QYRgweWFUblm1WkACzsYxBU6MZCLbAPZ+reZZul7S8Nc1p7I2GlfEN6Bq6Yd IIyJRRgi0y5x
QdHNNYnXJEsoK0q1w72ZroVWTxFaQDxD4YplQWdNsGC42K4ysHGCd1Y3oImV xrgcarHSDCM8
o6JZC0I8NCt/McPzI2nBkMtsKMCZPNxdXU7efPe4xgsRGc1/UF2/LfUti7Rq gpaLK0Fa2gcC
57/NZ48P06vlvFE8MJUvVjiQ6Cde3A6mgfj1YWvvSdyXaPkqbPc214qgURNZ HtPlkmlJrOAJ
MfpEM8VC2H6LPoe8Vci0AFbUbKRULv10IFURGvMoQrSQMuJ4je9l0OkdRFjm zkNP5nPo4agI
Rfv05DJ8oWFZv7JkRiT4/v33/QffXbeT8LtbdrmXAvCnCPwpAh9+Bh2Bj5Uj 54hyo+O8nA6a
ljH4TDc7cM3w89ZdHD6hYaSR+GYQSo7FUxiOKhrfVAplxeMBCRxRRL4Jel0I 3QCi8g0n9L5i
zPKm8kZRZk6++ePMJQEYf6RZGKG6WHMJoZFEm+kZpa94c8/GDkdEsTSC44g5 83LaOOpcQuVl
xZ1lyMloYs8Us0eJPver931GoMtG0ikGTZc+xaDTIp3EoBsoAH8UuizgI4lD N8REIBJdAmY8
segW0HBGo0vQnOLRncSj00X1FJFOP6eItMyIdCZhrygmzWnRRZ+XGJUuj/op Lg18JAnOkCLT
jdLCZ7N2aeHxMtIyMp20wpkaLnh7TA9R6a6i0eGuxUCb/ZY7CCytWw/hTStj Wjxy9HkR3aNS
F32ekbDz2ezT4na2fLyed5oHnopwapa7HsKAYPvJhwxE2F9zF9Vp6qfJ1LGL PAFRFkvRQNOW
kzqZkpF47XNEqOyeoM3KLbN0x6mnzaEEXDSyMcx+4UMxFtqVbYHnQTrOR6Wh 9L/tNo7FHTJc
s4oPU+eY3GUyct1q+LE4cUIYjz/eGmMMK4cet2nayEig7laVOBB6bIXQ3s4w 4owgkBp1IIXN
XjdCqrGuGKbHrSjXYNm+taRFojIv+9wXx9FyMqSr4xoLBam+M/9PI43wCscq qgOsPMOcRqt5
rB7kfF3VQgfEOQvgX5Zw6dxAI3u/Qx4m0wB2xMlXUbMfWGZ+JsCrf4E72CJ/ ND8qfGqF1PRj
T2hVfInBfCgg2OiyqU0FMcQB3mQA8O9mADhMea7jL9WE/nj8oRmPO4c63R3X zAYZdjrXYfCe
tNwf/z825d+Hvb41vJVOPIjwNqqAby12/USDJUSBax0ajWO/yssaVhuYnJVh DyvbPXa0pPIO
zQ2BE27pjCX7jFvz3UY4VLzbDbjwMM1JBmfVAxtW2mLgRYzIEJZ+zMgi9SVq OzARQ9Z6tg+3
PPZhmfWdaZs7KGeokrH3Jn0ErDu+GrAVL09STcKIdVy3R9Z5zEFqSLXnLoT5 PW62Y1vxMBBr
ApwfxmVKHN9CHOpg7mg5VoY9lqMwC1uaDQIH+6PpaAVX6PbuHG62syncBb6V EObKkNtigXwS
QY5Rofc4YT10HSMnCpxs3BpvPpInSnj3Hx/Bd0yGuf1g85YJxpP/zQ6053MH jNNKkJH0DZio
Iz4hISira0aF3rWLB0cXGZot6x5oJobsXpgo3pEqhtxLoXvA8Tw8pybnGvJa ONWwMzFQ5wz6
Bonq125x5HveKYcfq8IgwfuoWcCmvogfvPvlhA+3L4gfs8YwAWSol0wRDBzW hMEEMawiVYOb
x9Z7uxu874A6zFhx5M915fxph3wfU31uIXsbfL4EItTVkrDDqPBtfcLtzlFu FefGR+7Lcgyw
DsjbOFBdSGM+sAr3PuPUQqbZvtkdanDrEGRTsKTch/hapbGRzI3Yj/luNoNS 2IAjBLkea9/u
039FGpgEkjUyTxxY/uUEuDZDJNuAlTFnafZ2j2svgDPuIZl0kgT++Lpm4xkV M/lkbq/xyDtY
X77d4X0r7gtqCsqnw7DGzxS/x5jfIQ/XJ5l1cTMzoFvOZxH12kcR9YE8iZjX o57fRGx0LWPL
5BfX7Sz9ZZRXM56SYAacBHO3fFz3kQiTU4qjpsLklbMDA7gBm92kw+QJiY2X ESbEtIJTSkpM
HY4DSYrpHMy63JE6nDDyvNGBI2aNtIKoLnmkDqIwz4MPpGHkjYBo9ZU5InMi b3X1oPzsEUBQ
xpc/AiJTfdyxmwySY6z4Asc6gcGmz9/yjfhqmHkkZQ55U0pGli1Sw6bDFOM6 VlMFGFTiSA27
rymHpBaKoaaTDORUGQ9+4zpkdjowKDD3j2toh3d+sGsLZDypJbA13ltyyTEs TZ6TosAAjyrF
JE//6802qULhZSSeVHH4inJQKgf6lI4izyA5Zaa8TEPzlKTSk5HZ2vgYRaKK COuS8y0qwTt2
xkWH2ElJ86kE7/iJPi22NH2mrBxjU3OMtBVAWsaWuNIYS5mpK1U4jih5pTWW EtNXeCAdTwJL
Y2SlpLBUYTmSJJbGAEpKY6mCcDSJLM1BlJbKUoXjiJJZYPdzj08P9h/d7yql BfLEk74GntUi
ApLkvBYmYsdLbRltqsbzs2CyxtmvZ5+pE+mK6Bn55kkb1OF+paekjbs7oGPe tI3n5/rEjbPZ
ma6f4aJn5Mj/QLI4CrrWbx6HJp6GQR7hNQ9tUzCSVpJmqeLU+yN9Z1cU3kTs IN2h+FBioOG9
BuuhRJmJDwIWiGVusmUHT5XIgyJhsOnxjlWcy/pIZUy+5cHHVMnkqHntlshn 2HC8UgoE9qeJ
HsizL17m833phHF6vC/5nB7vy0vz9H726+JDszfcUuHq8d0+xhLP93ybJtUK 0HXNK6c88GSf
xs/e0ZXLq31cMKtJV8HrFrYuLc33efstQlCX0LdJvrlHvmMdOIaRDJ/+bfvV tNVZ+F++Nj02
QMYgXs89DUp4KGYMRs8P/lc4S5CtGmKDV290omdowhMesaSjWtmtYU/q8400 EOADjikWhmWd
aaoBefwaI6L6cs16vKVopNH5nUi9VkNp1O00m+l0GqJ295cPzLbomngEgCFS 2u/vk/4eov+n
9+8/mrb4Zr+RrMQ2YZ090Y8CNV4UJSjPaWFUWi+MhSHsfmmk3owe1OIIgdHH 8gi9qTwEi7fV
6tjS6n2pK+NRVsWBrontbMru1kPNb6IvmGi02/CpS1Y225Q315a0tUkjbr1G 3CZOBA5mS97v
drxSztIyq7E8FjvQ9oETKtaD5m0RVkf6EENYj8hl5M0Vjaq9s/dEygsNlHrQ SeivQEX4l3Kp
ZGBI66XvOO6dIkSIXjwVUpNCHHNXrrm1cfO45dmOxF2/lL+2dS88LaxZNTjX xE5MP1nOZ5qP
1iROGOABB8vuNN1zQu/atendo/CigtiL/eY7w/SUN3+3gv/8g1mL+DavcC9E TNN6G/wHIsLK
m+9sJ8haqW5m/hykLfj7pyfzWax+gYRCvcpqJaZJBah85JFjgfQL2EdUhxei X2D+skYqAaqt
DcJTR3eJ2V/AeSperhSiN8oVKPp4d4TFGEWCHYn/7/8slfEQVrYDWekwCYRa rJ/3q9XD2fX8
bn1G3NVn6j8/re9n67P5b/PZ48P0ajlfn60fr64X9+sz4kM+Sz3bpOji9u7x Ifxp9fhAfix1
mFgXN46307Aqvfnj8s/8pBhrcXEJmH3WzFLciEyokYVCq6oe2gJ7L8zgnNsH 03NsouPrveta
pph1hefHyMCa1TTKuxTphJf8mqISsWSvRSHv4YLEXoccP4ICk/lj+SBENEuS lgQ3EoSs/wj4
5TjKwyHDiMI7SwuesFBQxlXVSOPPxrTxLjVaNRhry3x5w7uxKi4pbkwTa5iy kUqoDwfqegNl
0RbGqGj2FREofAeaBZzkJ+LMpr7agIHX1yLpZX1VQKuNSTDTEm1EMNuuLeGd t7zaUJyzJtsT
nDdNxTLSouyx6XLZU6ZX4dgFozXOjC+BExYtsr9kDXjZ+d560Clvfkd0S6a6 H5pLi4uUWI5k
5cI2Hf1XRUTrFNmKp8jXPYVL/cJSNCD9aKVMWSkGCE7SMkBpiX4NbePsbwW7 H/BhzBIXhbdT
zr1yPiMoZ1GTtLlecu8yJSKXK655gUnwS08R00MikjQukDEeDzDx95fR5hM8 iSLXSNg+ax4y
AGGrEzOmMI1kxLSRjhdrcmg0XrhSXq+zv7uRW56OLlAUCdJPhwt5dltkbgBq 5tyGkFyY/gPy
0+8KYFRMZwmT2flhvrsVLgUuYKB65JhDWVAB0yiGquZ2qsjjwt5Ru3hWIOrW aNJW2K6lqiEH
HTgVrCgchgfDIwSslzWekirCKxwb1eTXclDnMoHWfbbDIy7Bcnvws5h3fkjl kPKqQAwCbpFk
DCEbt4qtyv1nS87q97awecc4yV/gpJ5mkSt/QYa4b/GLGmWYqvTx/K4Yrb14 TpjLcouCLNJ7
sPjv7aS0OxntRkI7l88hSGe3sjkWycz5CaTKZdn/0BtHRd+H5PXgWFwVQwES mQJiDJw8QR4H
hb07UY5pwCcX4/VgwjO7oo34e2hWGZQRz2RGGYkZX8VALQ8jMeQl8jg4U74V b0cz5mOqX4M5
X2L19Rr08iS1L5NeupQOQUa7ltCxyGfJBJYonQMy7KWuDsMx7aWx1ZtxH97r kcQeeghIZAGw
ZmEJKhnoFJVgbDF856UEJdicKCPYzFRSX8vACHYyMhkc1DamHWNH2cMkJL/0 DUyZz9e5e5Eo
oH1sXeQL5xBEs1PBHItY5kxwmUJZb9krwsNF2gSHKjJNhUcobK/YRBORY2fY F/hoMBDMSwVA
xhpdX8NiGLxNIPm2h62m3BW8A2mMW5Uoj0mLQ5FIeECkyiTr1ojBSGVxNy9P KE8hQLn75RcT
AaziRRnHnvmlx//ksji0ffP4on8Z0a9g73yK/ckW0572z68g8iddPMcinEUz ude4n9JqF10a
rhe4j045fM076Z5jtkrLvbQUqRz8broLyRzffvoUd+dPZCy2yxt3p++HPwXe GTt78jLHC4m8
V7CijMCNUE1+LQcj8CJI5XBQToSWnB3Fh5DS/NJdCBSjr9ODIFNG+3AgdCCf Q5DObmVzHJJZ
uL9NolzS98Idx8iXydIpaibX2H0xYbNKZpSRGLwvPXAmmcfBGb3jC53lqH4N hu8peCZdUvsy
fl9B+Ey+hI5DPikDWJ5PeEAm8ItwdF+8Te8ajP+Q/p5rkMDzEFEr+JJN8VkB XFmZvZ19/70S
o4H//4IUDJQSU6asZ9fkZ9KQ8h3uyXC++oWXDVzHJAYqfdf+FxTZ3ev80z0x BOUXfHJvA8Qv
/SzsJ2fmWBamwSmZR3o0iDW3+6fvH8cNxgZz/BryO3uPmVkDfZXkB9NJAgox HPk3DCBCQTaS
d2aLDbvxX8njRb6LdP+mgANpw9vT8xy20Pbk4kQMwPlcOb9Tzg/KuXGtvPnD tfZ44vlEohno
k+XoIdB/vg3bVnVos8OAEQ9cCl44ggUEf1DfzWZr0uj93l4v2I/oll74KioE Zq3whwKYtu9Y
KLrrXxbV0Ss4MeGFHkqEsQiBBz7hvjvlLT7NeFLfV6q+rntMBY6e4Hx1GvzX v+AVOhwW/O3/
A1BLAwQKAAAAAADkVBE3AAAAAAAAAAAAAAAABAAAAGJpbi9QSwECFAAKAAAA AAACQA03AAAA
AAAAAAAAAAAACQAAAAAAAAAAABAAwEEAAAAATUVUQS1JTkYvUEsBAhQAFAAA AAgA0FQRN0Iq
KwfmAAAA+AEAABQAAAAAAAAAAQAgAICBJwAAAE1FVEEtSU5GL01BTklGRVNU Lk1GUEsBAhQA
CgAAAAAA2XQONwAAAAAAAAAAAAAAAAQAAAAAAAAAAAAQAMBBPwEAAHNyYy9Q SwECFAAKAAAA
AAACQA03AAAAAAAAAAAAAAAACAAAAAAAAAAAABAAwEFhAQAAc3JjL29yZy9Q SwECFAAKAAAA
AAACQA03AAAAAAAAAAAAAAAAEAAAAAAAAAAAABAAwEGHAQAAc3JjL29yZy9l Y2xpcHNlL1BL
AQIUAAoAAAAAAAJADTcAAAAAAAAAAAAAAAAUAAAAAAAAAAAAEADAQbUBAABz cmMvb3JnL2Vj
bGlwc2UvY2R0L1BLAQIUAAoAAAAAAAJADTcAAAAAAAAAAAAAAAAjAAAAAAAA AAAAEADAQecB
AABzcmMvb3JnL2VjbGlwc2UvY2R0L21hbmFnZWRidWlsZGVyL1BLAQIUAAoA AAAAAO9WETcA
AAAAAAAAAAAAAAArAAAAAAAAAAAAEADAQSgCAABzcmMvb3JnL2VjbGlwc2Uv Y2R0L21hbmFn
ZWRidWlsZGVyL3Rvcm5hZG8vUEsBAhQAFAAAAAgARUkNN6QjDqOgAQAASwQA ADkAAAAAAAAA
AQAgAICBcQIAAHNyYy9vcmcvZWNsaXBzZS9jZHQvbWFuYWdlZGJ1aWxkZXIv dG9ybmFkby9B
Y3RpdmF0b3IuamF2YVBLAQIUABQAAAAIAAJADTfVHJzSpQAAADMBAAAKAAAA AAAAAAEAIACA
gWgEAAAuY2xhc3NwYXRoUEsBAhQAFAAAAAgAAkANN4lpA1/vAAAAuwIAAAgA AAAAAAAAAQAg
AICBNQUAAC5wcm9qZWN0UEsBAhQAFAAAAAgAwUANNyN49npKAAAAbQAAABAA AAAAAAAAAQAg
AICBSgYAAGJ1aWxkLnByb3BlcnRpZXNQSwECFAAUAAAACADBQBE3dOknvIUG AAB5FQAAEQAA
AAAAAAABACAAgIHCBgAAcGx1Z2luLnByb3BlcnRpZXNQSwECFAAUAAAACADO YxE33jdf8WcV
AAAbMAEACgAAAAAAAAABACAAgIF2DQAAcGx1Z2luLnhtbFBLAQIUAAoAAAAA AORUETcAAAAA
AAAAAAAAAAAEAAAAAAAAAAAAEADAQQUjAABiaW4vUEsFBgAAAAAPAA8AxwMA ACcjAAAAAA==
--------------020902090503070106080905--
Previous Topic:makefile includes file that is dynamically generated
Next Topic:C++ Refactoring Plug-in: Milestone 1 released
Current Time: Wed Jul 16 10:55:52 EDT 2025
Powered by FUDForum. Page generated in 0.52070 seconds
