Home » Language IDEs » ServerTools (WTP) » BUILD FAILED: java.lang.ExceptionInInitializerError
BUILD FAILED: java.lang.ExceptionInInitializerError [message #19010] Wed, 17 March 2004 06:11 Go to next message
Originally posted by: eclipse.geos.kiev.ua
Please help.
I have this
Buildfile: C:\Work\workspace\Lomboz Test2\lt2\WEB-INF\build.xml
Total time: 1 second
then run ant to build project in Eclipse 2.1.2. As I understand it depends
from Easy Struts 'cose when I start Eclipse and makes build all work OK
but if I go to EasyStruts show view (tree) I have this problem. How can I
fix it?
Re: BUILD FAILED: java.lang.ExceptionInInitializerError [message #19033 is a reply to message #19010] Wed, 17 March 2004 13:57 Go to previous messageGo to next message
Geos wrote:
> Please help.
> I have this
> Buildfile: C:WorkworkspaceLomboz Test2lt2WEB-INFbuild.xml
> fix it?
I fix it. I change ant from eclipse plugin to external ant1.4.1
Re: BUILD FAILED: java.lang.ExceptionInInitializerError [message #20122 is a reply to message #19010] Mon, 29 March 2004 03:07 Go to previous message
Originally posted by: christophe.ney.objectweb.org
May I suggest you use lomboz@objectweb.org list for such question
thanks,
christophe
"Geos" <eclipse@geos.kiev.ua> a
Previous Topic:Stop the politics and get to work
Next Topic:Can future webtools developer work on Lomboz?
Current Time: Fri Nov 07 14:05:59 EST 2025
Powered by FUDForum. Page generated in 0.04411 seconds
