Home » Archived » BIRT » How to advise db result=0 rows to Task object?
How to advise db result=0 rows to Task object? [message #199134] Sat, 04 November 2006 01:16 Go to next message
Originally posted by: kamaljeet.sandhu.gmail.com
Hi all,
I need to communicate report has 0 rows as result of db query ( so the
blank report is not emailed in my case) to the task object .
basically the row count of the result needs to be advised back to the
report invoking appln.
Cannot seem to modify params or even object put into appContext from the
script - so can be read after task is run.
Any preferred way.
Pls advise as it is something obvious I am missing.
Re: How to advise db result=0 rows to Task object? [message #199542 is a reply to message #199134] Mon, 06 November 2006 20:52 Go to previous messageGo to next message
One way to do this is to modify the application context in script and then
after the report is executed get the appcontext and look for your value.
--beforeFactory
rwc =0;
--afterFactory
appcon = reportContext.getAppContext();
appcon.put("TESTCOUNT", rwc );
--Table row onCreate
rwc+=1;
----java--
task.run();
HashMap hm = (HashMap)task.getAppContext();
hm.get("TESTCOUNT");
May be a similar way but this works in 2.1.1
Jason
"Sandhu" <kamaljeet.sandhu@gmail.com> wrote in message
news:eihb8i$qhu$1@utils.eclipse.org...
> Hi all,
> Any preferred way.
> Thanks
Re: How to advise db result=0 rows to Task object? [message #199606 is a reply to message #199542] Tue, 07 November 2006 06:24 Go to previous messageGo to next message
Hi Jason,
Tks for reply and this is what i'e been trying but in 2.0.0
In the dataSource(open) script was able to access
TestCount directly from appContext -
count=TestCount;
So I tried the same in DataSource(fetch)-
TestCount= rowCount;
but this did not change the TestCount in appContext
after running. :(
I think reportContext not avaible in 2.0.0 ?
Can you advise if this works ( or any other )in 2.0.0 ..
as I really would like to avoid an upgrade if possible .
Best Regards,
Sandhu
> --beforeFactory
> rwc =0;
> --afterFactory
> rwc+=1;
> ----java--
> task.run();
> Jason
>>Hi all,
>>Any preferred way.
>>Thanks
Re: How to advise db result=0 rows to Task object? [message #199607 is a reply to message #199606] Tue, 07 November 2006 06:29 Go to previous messageGo to next message
Sorry DataSet(fetch) not DataSource(fetch).
Sandhu wrote:
> Hi Jason,
> count=TestCount;
> after running. :(
> Best Regards,
> Sandhu
>> then after the report is executed get the appcontext and look for your
>> value.
>> --beforeFactory
>> rwc =0;
>> --afterFactory
>> rwc+=1;
>> ----java--
>> task.run();
>> Jason
>>> Hi all,
>>> the blank report is not emailed in my case) to the task object .
>>> the script - so can be read after task is run.
>>> Any preferred way.
>>> Thanks
Re: How to advise db result=0 rows to Task object? [message #199611 is a reply to message #199606] Tue, 07 November 2006 11:19 Go to previous messageGo to next message
reportContext is available in 2.0.0.
The example code I posted should work in 2.0.0.
Try building the same example. Notice I incremented the count on the table
where the row was created.
I did this because this is the actual output. A data set can be called
multiple times and filtered out, so I put it on the
output. If you have issues with the source I posted send me your report and
I can look at it.
Jason
news:eipqer$bqj$1@utils.eclipse.org...
> Hi Jason,
> count=TestCount;
> after running. :(
> Best Regards,
> Sandhu
>> value.
>> --beforeFactory
>> rwc =0;
>> --afterFactory
>> rwc+=1;
>> ----java--
>> task.run();
>> Jason
>>>Hi all,
>>>Any preferred way.
>>>Thanks
Re: How to advise db result=0 rows to Task object? [message #199944 is a reply to message #199611] Thu, 09 November 2006 05:06 Go to previous message
Thanks a ton Jason....it just Works.
> I can look at it.
> Jason
>>Hi Jason,
>>count=TestCount;
>>after running. :(
>>Best Regards,
>>Sandhu
>>>value.
>>>--beforeFactory
>>>rwc =0;
>>>--afterFactory
>>>rwc+=1;
>>>----java--
>>>task.run();
>>>Jason
>>>>Hi all,
>>>>Any preferred way.
>>>>Thanks
Previous Topic:Urgent problem with BIRD'S background image - please HELP
Next Topic:How to add properties and structure to a DataSet object ??
Current Time: Sat Nov 08 22:28:42 EST 2025
Powered by FUDForum. Page generated in 0.04064 seconds
