Home » Modeling » GMF (Graphical Modeling Framework) » NULL with ArrangeAll
NULL with ArrangeAll [message #199121] Mon, 28 July 2008 06:27 Go to next message
Originally posted by: youchy.gmail.com
Hi everyone!
I have a problem!
The ArrangeAll Operation is getting me a NULL when I open the editor with
the a diagram and click on the ArrangeAll button on the Toolbar.
The null dissapear when I click on the diagram before click on ArrangeAll,
only one click makes the ArrangeAll execute normally.
How can I simulate this click in code??What can I do??
Please help me!
Re: NULL with ArrangeAll [message #199143 is a reply to message #199121] Mon, 28 July 2008 06:35 Go to previous messageGo to next message
Hello Carlos,
You can file a bugzilla request if this problem is repeatable on other GMF
diagrams (ecore diagram example).
Alex Shatalin
Re: NULL with ArrangeAll [message #199176 is a reply to message #199143] Mon, 28 July 2008 06:57 Go to previous messageGo to next message
hi!
i've tested in many diagrams with many transitions...and always when i
open it the null is there.
with my ecore_diagram there are not problem.
there are any problem if my diagrams are opened in the same editor always??
i've a "windows" with all the diagrams and i can open it, but always
reusing the same editor.
when i open the application with de default diagram , i can do the
Arrange, but if i change the diagram the arrange is getting bad, until i
click on the diagram.
the null is here:
DefaultProvider.class
line 489:
for (Iterator iter = sourceConnections.iterator();
iter.hasNext();) {
ConnectionEditPart connectionEP = (ConnectionEditPart)
iter.next();
EditPart target = connectionEP.getTarget();
// check to see if the toView is in the shapesDict, if yes,
// the associated connectionView should be included on
graph
if (target instanceof IBorderItemEditPart)
target = target.getParent();
Object o = editPartToNodeDict.get(target);
the variable 'target' is null
Re: NULL with ArrangeAll [message #199182 is a reply to message #199176] Mon, 28 July 2008 07:21 Go to previous messageGo to next message
Sorry, the null is when the code call:
then in the next step:
Hashtable<K,V>.get(Object) line: not available
here is the null...
Re: NULL with ArrangeAll [message #199767 is a reply to message #199182] Fri, 01 August 2008 04:49 Go to previous message
can anyone help me please??
Previous Topic:2 GMF Diagrams based on the same model at runtime
Next Topic:Package Hierarchy as Tree (Shadow Nodes not working as expected)
Current Time: Sun Nov 23 09:27:43 EST 2025
Powered by FUDForum. Page generated in 0.03759 seconds
