| Eclipse CDT linker issue [message #199119] |
Mon, 12 March 2007 14:34  |
Originally posted by: eduzea.gmail.com
Eclipse using CDT C++ plugin.
Is there any way to add external source files into a project, and have
eclipse generate the corresponding object files automatically?
Right now I include the external sources (.h and .cpp) from a directory
outside of the project's working directory. It compiles, but the linker
complains about the objects defined in those files. I was able to have it
link by including the .o files for the objects in the
Linker->Miscellaneous setting. Can this step be automated? Shouldn't
eclipse just generate the objects that are required from the source files
in the included directories?
Eduardo
| Re: Eclipse CDT linker issue [message #199171 is a reply to message #199119] |
Tue, 13 March 2007 04:10  |
Originally posted by: jakub.jurkiewicz.gmail.com
I believe you would get more answers if you post this question on the
CDT newsgroup.
regards,
Jakub Jurkiewicz
Eduardo wrote:
> it link by including the .o files for the objects in the
> files in the included directories?
> Eduardo
FUDForum. Page generated in 0.07504 seconds
