| Getting value from a reference [message #1598] |
Mon, 18 December 2006 15:44   |
Eclipse User  |
Originally posted by: dorazio.nicola.yahoo.it
Hi all,
I have this km3 classes:
class ServiceCall extends Activity {
        reference calledService[0-1] : Service oppositeOf serviceCall;
class State {
        attribute name[0-1] : String;
        attribute refersTo: String;
now I need to modify this rule:
rule activity2state
    from
      astep: Klaper!Activity (astep.internalFailProb='0')
      using{
               list: Sequence(Klaper!Behavior) = astep.getSCBehaviorType();
         to
      state: DTMP!State (name<-astep.name,
                         refersTo<-'TEST',
                         dtmp<-thisModule.resolveTemp(astep.behavior,
'dtmp'),
because I want to write inside the refersTo variable the value of the
reference calledService. How can I do this?
Thanks to all
Best regard
Nicola D'Orazio
| Re: [ATL] Getting value from a reference [message #4505 is a reply to message #1598] |
Fri, 29 December 2006 03:40   |
Eclipse User  |
Since your rule transforms an Activity and not a ServiceCall, you cannot
do astep.calledService. You should do this in a rule matching a ServiceCall.
If you use ATL 2006 (see http://wiki.eclipse.org/index.php/ATL_2006),
then you can use rule inheritance:
rule ServiceCAll2State extends activity2state {
	from
		astep : Klaper!ServiceCall
	to
	      state: DTMP!State (
                         refersTo<- astep.calledService
If you do not want to use ATL 2006 or rule inheritance, then you will
have to modify your rule after having copied and pasted it if you want
to keep a rule matching activities.
Frédéric Jouault
Nicola D'Orazio wrote:
> Hi all,
> class State {
> rule activity2state
>    from
>      using{
>         to
>                         refersTo<-'TEST',
> 'dtmp'),
> Thanks to all
> Best regard
> Nicola D'Orazio
FUDForum. Page generated in 0.03991 seconds
