Home » Archived » M2M (model-to-model transformation) » Getting value from a reference
Getting value from a reference [message #1598] Mon, 18 December 2006 15:44 Go to next message
Originally posted by: dorazio.nicola.yahoo.it
Hi all,
I have this km3 classes:
class ServiceCall extends Activity {
reference calledService[0-1] : Service oppositeOf serviceCall;
class State {
attribute name[0-1] : String;
attribute refersTo: String;
now I need to modify this rule:
rule activity2state
from
astep: Klaper!Activity (astep.internalFailProb='0')
using{
list: Sequence(Klaper!Behavior) = astep.getSCBehaviorType();
to
state: DTMP!State (name<-astep.name,
refersTo<-'TEST',
dtmp<-thisModule.resolveTemp(astep.behavior,
'dtmp'),
because I want to write inside the refersTo variable the value of the
reference calledService. How can I do this?
Thanks to all
Best regard
Nicola D'Orazio
Re: [ATL] Getting value from a reference [message #4505 is a reply to message #1598] Fri, 29 December 2006 03:40 Go to previous message
Since your rule transforms an Activity and not a ServiceCall, you cannot
do astep.calledService. You should do this in a rule matching a ServiceCall.
If you use ATL 2006 (see http://wiki.eclipse.org/index.php/ATL_2006),
then you can use rule inheritance:
rule ServiceCAll2State extends activity2state {
from
astep : Klaper!ServiceCall
to
state: DTMP!State (
refersTo<- astep.calledService
If you do not want to use ATL 2006 or rule inheritance, then you will
have to modify your rule after having copied and pasted it if you want
to keep a rule matching activities.
Frédéric Jouault
Nicola D'Orazio wrote:
> Hi all,
> class State {
> rule activity2state
> from
> using{
> to
> refersTo<-'TEST',
> 'dtmp'),
> Thanks to all
> Best regard
> Nicola D'Orazio
Previous Topic:[ATL] problem at launching ATL
Next Topic:[ATL] multiple references to an unique target model element
Current Time: Wed Nov 12 20:16:54 EST 2025
Powered by FUDForum. Page generated in 0.07958 seconds
