Home » Archived » IAM (Eclipse Integration for Apache Maven) » Classpath container suddenly vanished and I cannot get it back
Classpath container suddenly vanished and I cannot get it back [message #18966] Wed, 20 May 2009 20:05 Go to next message
Classpath container suddenly vanished and I cannot get it back. Ie, my
project has no dependencies in its classpath and thus every source file
has errors.
The change happened immediately after made a change to my pom.xml that was
invalid according to the schema (leaving out 'version' of a dependency).
Since then, I have Re-Enabled "Maven Dependency Management", Re-Installed
the IAM 0.9 plugin, and Deleted and Imported my project again, but the
issue remains.
This effectively renders me unable to proceed using the plugin, so unless
I can quickly find a workaround, Im going to have to install m2eclipse to
keep working while I get this resolved.
I have looked in Error Log view and do not see anything that seems related
to it.
One thing I did notice is double entries in .project and .classpath:
<nature>org.devzuz.q.maven.jdt.core.mavenNature</nature>
<nature>org.eclipse.iam.jdt.core.mavenNature</nature>
<classpathentry kind="con"
path="org.eclipse.iam.jdt.core.mavenClasspathContainer"/>
path="org.devzuz.q.maven.jdt.core.mavenClasspathContainer"/ >
-Ben
Re: Classpath container suddenly vanished and I cannot get it back [message #18989 is a reply to message #18966] Wed, 20 May 2009 20:19 Go to previous messageGo to next message
I have been able to work around my problem by deleting all IAM metadata
from .classpath and .project files, then re-opening project and
re-enabling Maven dependency mgt.
-Ben
Re: Classpath container suddenly vanished and I cannot get it back [message #19011 is a reply to message #18989] Wed, 20 May 2009 22:59 Go to previous messageGo to next message
If you delete .classpth .project and .settings folder, and reimport the
project you should get a completely clean status
> -Ben
Re: Classpath container suddenly vanished and I cannot get it back [message #19052 is a reply to message #18966] Thu, 21 May 2009 03:58 Go to previous message
> has errors.
Invalid POMs will prevent the maven classpath container from being
properly built.
Once you fix the pom, you need to manually clean your project through the
Eclipse menus (Project > Clean...). If you have dependent projects,
cleaning all projects will be the safest option.
Yours,
Abel Muiño
Re: Classpath container suddenly vanished and I cannot get it back [message #569105 is a reply to message #18966] Wed, 20 May 2009 20:19 Go to previous message
-Ben
Re: Classpath container suddenly vanished and I cannot get it back [message #569132 is a reply to message #18989] Wed, 20 May 2009 22:59 Go to previous message
> -Ben
Re: Classpath container suddenly vanished and I cannot get it back [message #569171 is a reply to message #18966] Thu, 21 May 2009 03:58 Go to previous message
> has errors.
properly built.
Yours,
Abel Muiño
Previous Topic:IAM looking for Java tools in wrong place?
Next Topic:Apparent Maven / JUnit clash in eclipse
Current Time: Fri Nov 21 04:13:01 EST 2025
Powered by FUDForum. Page generated in 0.04875 seconds
