Home » Modeling » GMF (Graphical Modeling Framework) » audit rule doesn't work
audit rule doesn't work [message #198472] Wed, 23 July 2008 02:30 Go to next message
I have added audit rule according to instructions in GMF tutorial 3.But
it doesn't work.
My case:I want the node Kernel can have only 1 incoming arrow and 1
outgoing arrow.so I add OCL in Constraint liks this:
self.incoming->size() and self.outgoing->size()=1
and set the the right properties related Validation in .gmfgen.
What's do you think is the problem?
Many thanks!
Ye
Re: audit rule doesn't work [message #198496 is a reply to message #198472] Wed, 23 July 2008 05:40 Go to previous messageGo to next message
Hello Ye,
try (self.incoming->size() = 1) and (self.outgoing->size() = 1)
Alex Shatalin
Re: audit rule doesn't work [message #198577 is a reply to message #198496] Wed, 23 July 2008 09:31 Go to previous messageGo to next message
Hello Alex,
However, this still doesn't work.Where else can be the reason?
Thanks a lot!
Ye
Re: audit rule doesn't work [message #198600 is a reply to message #198577] Wed, 23 July 2008 09:53 Go to previous messageGo to next message
Hello Ye,
Try placing a breakpoint into the appropriate place in a code to see if constraint
was actually violated for any passed parameters..
Alex Shatalin
Re: audit rule doesn't work [message #198622 is a reply to message #198472] Wed, 23 July 2008 10:12 Go to previous messageGo to next message
Ye Liu <yeliu@abo.fi> ha scritto:
> Hello,
> it doesn't work.
Hi Ye Liu. IMO Alex wrote the constraint you need in the right form... so,
it's hard to understand where the problem is. What do you mean by "it
doesn't work"? What's the way you run your plugins?
The wind in my heart
The dust in my head
Re: audit rule doesn't work [message #198773 is a reply to message #198622] Thu, 24 July 2008 05:18 Go to previous messageGo to next message
By 'It doesn't work' I mean,when I regenerate the .gmfgen file,then
generate the diagram package.And run the Eclipse application,the node
Kernel still can be connected by more than one incoming channels and
outgoing channels.
Ye
Re: audit rule doesn't work [message #198911 is a reply to message #198600] Fri, 25 July 2008 04:29 Go to previous messageGo to next message
I can't find a right way to set the breakpoint.But rather I found the
extension points in the plugin.xml in the diagram code a little bit
different from the GMF tutorial.The item under clientContext is selector
instead of enablement.I wonder if this show clue to the problem.
org.eclipse.emf.validation.constraintProviders
org.eclipse.emf.validation.constraintBindings
-com.eclipse.xxx.diagram.DefaultCtx(clientContext)
--com.eclipse.xxx.diagram.providers.xxxValidationProvider$De faultCtx1(selector)
Many thanks!
ye
Re: audit rule doesn't work [message #198984 is a reply to message #198911] Fri, 25 July 2008 08:55 Go to previous message
Originally posted by: cdamus.zeligsoft.com
Hi, Ye,
The <selector> element is nothing but a Java alternative to the XML
expression of the <enablement> element. They are mutually exclusive and
serve the same function.
Luckily for you, the <selector> is easier to debug because you just put
a breakpoint in the referenced class :-)
Christian
Ye Liu wrote:
> Hello,
> Many thanks!
> ye
Previous Topic:Saving in XML
Next Topic:configure palette dynamically
Current Time: Fri Jul 18 00:43:08 EDT 2025
Powered by FUDForum. Page generated in 0.09860 seconds
