Home » Modeling » GMF (Graphical Modeling Framework) » Package Hierarchy as Tree (Shadow Nodes not working as expected)
Package Hierarchy as Tree (Shadow Nodes not working as expected) [message #198448] Tue, 22 July 2008 17:26 Go to next message
Originally posted by: goetz.botterweck.lero.ie
--------------070603040005030902090301
I want to represent a hierarchy of packages as a tree.
The meta-model looks roughly like this
* Model contains Packages (via @rootpackages)
* Package contains Packages (via @subpackages)
* {see attachment containment3_Main.png}
Goal
* Although in the underlying model file (*.containment3) the
Packages are contained within each other, in the diagram
(*.containment3_diagram) I would like to represent this a tree
(nodes on the canvas connected by links). Like this
* (1) When a Package is first drawn on the canvas is should become a
member of Model.rootpackages.
* (2) Later, when a Package is connected via a link to another
Package it should become a member of that Package's .subpackages.
Challenge
* Lets say I've got two Packages P and Q which are on the Canvas and
are not connect in any way. So in the underlying model both P and
Q are members of Model.rootpackages.
* If I now perform step (2) by drawing a link [P] ---subpackage-->
[Q] then the underlying object "Package Q" should become a member
of P.subpackages.
* Tricky part: Nevertheless, I want Q to be represented *on the
canvas* as a graphical symbol. I assume I have to use "shadow
nodes" for this.
What I tried already
* I have simple examples with "recursive hierarchy" or "shadow
nodes" working properly.
* I tried to use two different "Top Node References". One for "Root"
Packages and one for Packages which "Subpackages".
Here is my current *.gmfmap model {also see attachment
containment3.gmfmap_annotations.png}
(A) Top Node Reference
@Containment Feature = rootpackages:Package
Node Mapping
Child Reference
@Containment Feature = subpackages:Package
@Referenced Child = B
(B) Top Node Reference
@Containment Feature = (undefined) since I want shadow nodes here
Node Mapping
@Element = Package
Child Reference
Problem: As soon as I connect two Packages [P] ---subpackage-->[Q] then
Q dissappears from the canvas and appears within the list view inside of
P. See 01-before-link.png and 02-after-link.png.
Any hints? Thanks in advance!
Goetz
Content-Type: image/png;
name="containment3_Main.png"
Content-Disposition: inline;
filename="containment3_Main.png"
iVBORw0KGgoAAAANSUhEUgAAAQwAAAG2CAIAAAAFvy/XAAAACXBIWXMAAA7E AAAOxAGVKw4b
AAAAB3RJTUUH2AcWExMiXwT97gAAAAd0RVh0QXV0aG9yAKmuzEgAAAAMdEVY dERlc2NyaXB0
aW9uABMJISMAAAAKdEVYdENvcHlyaWdodACsD8w6AAAADnRFWHRDcmVhdGlv biB0aW1lADX3
DwkAAAAJdEVYdFNvZnR3YXJlAF1w/zoAAAALdEVYdERpc2NsYWltZXIAt8C0 jwAAAAh0RVh0
V2FybmluZwDAG+aHAAAAB3RFWHRTb3VyY2UA9f+D6wAAAAh0RVh0Q29tbWVu dAD2zJa/AAAA
BnRFWHRUaXRsZQCo7tInAAABAElEQVR4nO3dXWwc1d3H8TNrL5sgB2fXka11 HaWOs42Itoop
3LQR0BcJixQRpeojVAn1hhahotIKIVFxU1rpUUUrIQpCaksvoRJqK5TmIoqg jwKUmwq1JIoc
grGdECuWTZL1Gsfxeu2d52Ka6bDz8p9d786c2f1+LqLZs2dmTpL5nXNmZnfH ME1TQScnT55c
W1uLuxUR2bZt28TERK1WS6VScbfFV2/cDUC9tbW1AwcOxN2KiExOTk5NTY2N jcXdkCCEREeG
YcTdhEiVSqWBgYG4W+GLkOio20KiOUKiozAT9BffuXxhblkpQynTVIahlGko K1v2aeboyI4n
7hluY0O7AyHRgybOlwAAAQBJREFUUZiQzF5afvHRe4Lr/PgPb6dSIy1qVPci JDoKM92qbdYy
t/RIlcx2zNz27NmjlLp48WIT7yYRIdFRyOuhvT1yNeemdu/erZS6dOlSXR2/ 8vBbbvTdZCEk
OgrZ/ff2yNXcm9q9e/fc3Jz9cmRkpKGdBmw5/LvJQkh0FLIbTjc4kthGRkYu X76slBoeHq6r
6SxRSlnV3OWe9e3KfvtNKEKio1DdsGmmpZGk5jonmZ+fz+fzynFw2yWGYVgL 8/Pz1lv5fH54
eNiu4Cx317crN/BXSAhCoqMw3bBp1npSwoFommbdplKp1MLCwtDQkPVyYWHB vVP3KuHL/Son
GiHRUchu+J1WbVAAAAEASURBVMFn/6aUYSplKNNa+M/qSpnKNJQyDKNuU9bL xcXFwcHBxcVF
z516rhJQbkcuoHKiERIdheyGX/vZ4eAKDz93wq/7v3Llit9OGx1J3JtyV040 QqKjFh5hfkd2
QM3gkORyOb/6uVzu2rVr4o4Sh5DoKORc5eHnTjS6qYAtG4ZRKpWy2awdA6VU qVSy/rTLrWXP
+lblhv4KiUBIdBTyCHv16fuDKzz83AnnppaWljyrOcsbreOu77eF5CIkOmrf dAtNICQ6CnNk
79s7IE639u0dICRbR0h0FGa69b//c0cELYEiJHqi+9cKIdFRJ10a6gCEREeM JFohJDpiJNEK
IdERI4l1em3uAAABAElEQVRWCImOjh8/HncT8F+EREdHjhyJuwkROXbsWNxN kDGsAwJCAggI
CSAgJICAkAACQgIICAkgICSAgJAAAu646ygR96G7ByHRER9L0QrTLUBASAAB IQEEhAQQEBJA
QEgAASEBBIQEEBASQMAdd+2k0+lE3IduiXQ6HXcTZIZpmnItRGt6erpWq8Xd iigUCoWpqalc
LjcwMBB3W3wxkuhobGzs6tWrke1uZWXl3Llzd911Vyy/HOl8sJaeCImmouxZ z5w5U6lUyuXy
2NhYZDu16TyGWDhx73alUml5eVkp9fHHH3fJHK9RhKTbffDBB9ZCT0/P7Oxs vI3REyHpavYw
opS6ixZBXAAAAQBJREFUfv06g4knQtLV7GHEwmDiiZB0L+cwYmEw8URIulfd MGJhMHEjJF3K
PYxYGEzcCEmX8hxGLAwmdQhJl1pZWfF7K5VKzczMRNkYzRGSLjU4OOj3Vjab zefzUTZGc4Sk
S42Pj3s+vrS/v//KlSuFQiH6JmmLkHSpTCbjOZj09/fn8/lMJhN9k7RFSLqX ezBhGPFESLqX
ezBhGPFESLqaczBhGPFDSLqaczBhGPFDSJLNcAhZv67EHkwYRvwQkgQzDMN0 CM6JX5DswYRh
xA8h6RZWkDzfGh8fV0oxjPghJFDWAMIw4oeQAAJCAggICSAgJB3IeRUrlt+b 6zD8OF2C1V32
DRKTlfoAAAEASURBVP7FWrumtcDP24ZHSJLN81h3FtrLpKJpTLcAASEBBIQE EBASQEBIAAEh
AQSEBBAQEkBASAABIQEEhAQQEBJAQEgAASEBBIQEEBASQEBIAAEhAQSEBBAQ EkBASAABIQEE
hAQQEBJAQEgAASEBBIQEEBASQEBIAAEhAQSEBBAQEkBASAABIQEEhAQQEBJA QEgAASEBBIQE
EBASQEBIAAEhAQSEBBAQEkBASAABIQEEhAQQEBJAQEgAASEBBIQEEBASQEBI AAEhAQSEBBAQ
EkBASAABIQEEhAQQEBJAQEgAASEBBIQEEBASQEBIAAEhAQSEBBAQEkBASAAB IQEEhAQQEBJJ
L4+qAAABAElEQVRAQEgAASEBBIQEEBASQEBIAAEhAQSEBBAQEkBASAABIQEE hAQQEBJAQEgA
ASEBBIQEEBCSjmUYRtxN6BCEpAM540FUto6QdCDTNK1sGIZhmmbczUk8QtKB 7GzYacFWEJIO
5Bw9umckaV93QEg6VoLioflwR0gAQW/cDUDy+F0PsMrtd53jg13fXWhfY1A3 T6Kcp1LuFQM2
5W5h8Fp1bfCrSUjQSs6j03ng1uXHWehXXrdcVxJw4c75VvBantcA3TWZbqGV WnIitJWNtOOq
NyMJwvK8RxnZ5YEwJ/fuhIS8JOCuZk/5TNMkJAjLPQWKTN0EzK9a3TQp5FrK J+r2vJHpWWBL
EAAAAQBJREFUFjpK+PunftXc5YwkaIu6g9XzEwDO02t7bqO8rjW5D32/TSnH eBK8lnOnftfc
FNMtNMdvrlVXHjCHCS4PuWLA7txXt7aycUKC7hJwd8UPIYFe2n1JoIntJ+nE XfNP+CTL2bNn
q9Wq51u1Wu3MmTMRt0dnyQgJ3yJque3bt58/f97zrdnZ2VQqGQdGNJLxb8G3 iFpudHR0fn6+
UqnUlVer1YsXLxYKhVhapadkhIRvEbVcKpUqFounT5+uKz9//vyePXsymUws rdJTMkLSnd8i
ard8Pr+6uloul+2SSqUyPz8/OjoaY6s0lIyQWIhHyx08eNB5jn769OliscgJ SR3+OesSp3oA
AAEASURBVLpaNpvNZDLz8/NKqXK5vLq6ms/n426UdjgP7nYrKyvvv/9+uVzO 5XLFYjGbzcbd
Iu0wknS7vr6+Xbt2GYaRyWRIiCdCAmVd8D1w4EDcDdEU063onDx5cm1tLe5W JM+2bdsmJiZq
tVpcVxT47FZ01tbW6K2bMDk5OTU1NTY2FlcDCEmkuBPatFKpNDAwEMuuCUmk CEkSEZJW+ve/
/z04OPiFL3zBrwL36ZKIkLTS/v37z507NzMzc/vtt+/atctdoemQvHBq7sLc slKGUqapDEMp
01DWqGRfeRkd2fHTr480t30EICStdOutt955552lUmlycnJmZqZYLN56663O Ck0jR7DnAAAB
AElEQVRPt2YvLb/46D3BdX78h7cNY3dz20cAQtJ62Wz20KFD8/Pz7733Xj6f 379/fzqdtt5q
eiSpbdYyt/RIlcwWTud2796tlLp06VKrNphchKRd8vl8Pp+fnp4+derUF7/4 ResK5lZO3Ht7
5AA4tz8yUj/1mpuba3SnXGlQSvWeOnXK+WFptMO5c+empqbU1k7ce3vk49W9 /cuXL1sLw8PD
IyMj9suQuNKglOotl8tHjhyJuxkdq1wunz17tqenp1gs/v3vf99Kx5xucCTx LLFf2p/2tT4C
7CxxFlr1rbfcNT3Xdb7luc3EYbrVLpVKZXJyslwuF4tF+0pX8x2zaaalkaTm kCBs4QAAAQBJ
REFUdU5SV2K9HBoaWlhYsBby+fzCwsLQ0JBSyiqsq1/3lriu9bJuRbtyw39x DRCS1qtWq9PT
05cuXdq/f/8dd9zhfKvpkcQ0az0pYV3P7zZ7jiSLi4ueddyrWwe6s37IdT3L E3qGQ0ha7MKF
CzMzM8PDw9/61rfEfr0hDz77N6UMUylDmdaCxVDKVKZh/bSza/uDg4P28pUr V6yFuns49lqe
zbPXamhd+6WzAQk9wyEkrfTee+/t2LHj0KFDfj+ksJWj5LWfHQ6u8PBzJ9zb v3btWl1JLpez
y63l4JDs2rXL3kj4de2X7gYkDiFppUOHDgVXaPd8Q5xueZYHTLdKpVI2m0Ma UxoAAAEASURB
VM3lcqVSKcy69te23NvMZrPOjSQIIYnUVkLy8HMnmti+u2RpaWnnzp3OLyEa hlFXuLS05H5r
aWlJXNdaDt5m4hCSSG1luvXq0/cHV6ibbi0vL/vV9HyrrtD50m85oNBqSUAb EoSQRKrdZ65x
nRn39fU5X66srMTSjDaJMySt/c3SRPwCatPTrX17B8Tp1r69A3FdY71+/Xos +40GI0mkmu7p
f/XQna1tCcIjJJFK6N20LrelkATPcOoeThfwNHu7mv2W+wnIASXK9Quo9vaD 13Lu1L2pdjyF
OaF307pcu0aSkGcIng8U9iysKwnYvvOt4LU8H+cgbn8rGEmSKObpVkOCxSBo AAABAElEQVTP
ngxD89N3RpIkaiYknjdc3Y9CdT50eOvC9MHuhDT9SO+Wt99y/PjxFm4N0Wgm JO65UEC1lnTt
nucwnnv0nKoFr6UCB7TWDk18dacJx44di7cBMYz+bZ2Xh38UVpgPNQGqrSfu 1oL7MW7O5eDL
Sp6ruzeiPj8U2ONJ8FrOCZV7U+24tNUx/P7XPP+tND9LDGNLIRHnWn4ldRes wmw2eIOe2w+z
VkPV2uHxV94NU+3lH97d7paEFHA131PSE6Jiv7oVvYC7K7GobtR+99i9wXUe +/3bdSUh7ybV
/WUbutfk3FFA25w7co7Mfn8GNMCvDbHTLiTt/mfS7b+hslHbNNUPWDl0GQAA AQBJREFUXv4/
pZQy1c1fZby5oNQfH//menXTvWKYu0meJcqRsYbGhABhthamAc3tvd20C0m3 WVvf2FBqbX3j
N4/f5yzv61Hbe9TkhU9Thnri2192rxhN2j0nomFG4xhnsC1HSGJ2o7KxUVM3 KptKqaz1v2Go
tKF6DfXMyd++8M+Tt+8amtg7/pW9PwmztUY74+Y671aNP0nBDeCYra5vrJtq tbqhlKqaat1U
KaV6DPWd155a/GzujaPf/dEd44ufzT346lPipuxreuGPWvPztvQ36VyMJDG7 sb5ZNdWNtY3v
/fINq+TX3//qX2f/tL1384HC7Tc2Nwa2b3+gsO/PH3745Innn5UPHnYAAAEA SURBVL//yfa1
xHNMCD61aO3eW77NViEkMbtR3dg01evPHjVunqwPpNW9r7/587u/dr706X8q Gao4mPvFu28G
hyT8jVTP+iEPfb+1mvggj9/dM90QkpitVzfve/p1Qyl189B6+dG7h/tuu3D1 Wn/mFqWsN4xy
ZX247zZ7Lb97RGHuHQXUdwt5Wylgs573xMI3QAeEJGZnX3jIXTjx0cGpxY/u H92rTGU9r+df
lxcn9h6MvnntptttK0+cuOvolaPP9PbueOeTuf50prJZe+eTud503ytHn4m7 Xa2XiMsGhERT
bz3yUmGw8MQ/3v7LhYuFwcJbj7wUd4u6F9OtSDX0qe9vqC8kgCR1AAABAElE QVR94+CXlFLK
jP/j4t2MkESK75M0IfYOgukWICAkgICQAAJCAggICSAgJICAkAACQgIICAkg 4I57dNLpdOw3
j5MonU7H2wBCEp3Dhw9PT0/XarW4G5IwhUJhamoqxgYQkkiNjY1dvXp1ZWXl 3Llzd911lybf
xdOtPW7WM+PjQkiiNjAwcObMmUqlUi6Xx8bG4m6OUkrp1h63gYGBGPfOiXvU SqWS9eDmjz/+
WIepl27t0RAhidoHH3xgLfT09MzOzsbbGKVfezRESCJld9tKqevXr8feeevW Hj0RkkjZ3bYl
9s5bt/boiZBEx9ltW+LtvHVrj7YISXTqum1LjJ23bu3RPJV03wAAAQBJREFU FiGJiLvbtsTV
eevWHp0Rkoh4dtuWWDpv3dqjM0ISkZWVFb+3UqnUzMxMlI1R+rVHZ4QkIoOD g35vZbPZfD4f
ZWOUfu3RGSGJyPj4eCrl8a/d399/5cqVQqHQ5e3RGSGJSCaT8ey8+/v78/l8 JpPp8vbojJBE
x915x9tt69YebRGS6Lg773i7bd3aoy1CEiln561Dt61be/RESCLl7Lxb0m0b DiHrt7U9HYmQ
RM3uvLfebTsftys+c9AvSC1sT6ciJFGzO++Iu22/p0nF1Z4EISQxGB8fV0rp 023r1h7dEJIY
WB22Pt22bu3RDSEBBIQEEBCSDuS8iqXtT2klCL+7lUIgJ+YAAAEASURBVGB1 l32DH4Vu17QW
dH5uum4ISbJ5HuvOQnuZVDSN6RYgICSAgJAAAkICCAgJICAkgICQAAJCAggI CSAgJICAkAAC
QgIICAkgICSAgJAAAkICCAgJICAkgICQAAJCAggICSAgJICAkAACQgIICAkg ICSAgJAAAkIC
CAgJICAkgICQAAJCAggICSDgSVdaCP9UN7s+T66KDCGJX90RHxwAHhQaPaZb CWOaJmNIxAgJ
ICAkgKA3nU4fO3Ys7mZ0nXQ6HXcTEFbv4cOH424DoDWmW/pyXsjiolaMuAQc P9M0w98nsWta
C1zpigAh0YLnse4stJdJRfSYbgECQgIICAkgICR4elVTAAABAElEQVSAgJAA AkICCAgJICAk
gICQAAJCAggICSAgJICAkAACQgIICAkgICSAgJAAAkICCAgJICAkgICQAAJC AggICSAgJICA
kAACQgIICAkgICSAgJAAAkICCAgJICAkgICQAAJCAggICSAgJICAkAACQgII CAkgICSAgJAA
AkICCAhJxzIMI4KNt3UvmiAkHch54LbpIDZNsx2b1VNv3A1A65mmaWXDMIyt HM0Bq1tv2XtR
N2PjzKRnif3S3rK7RDeEpAPZR7D9Z5t2VLf9un3ZLz0rRNC8VmG61YGch53+ h6D+GEk6VtPx
8DylCbm1Rk+B7AmYzmEmJKjnN31qaN1GV9F5BtKHzAAAAQBJREFU3sV0C+3S MVeHGUmwJc75
kvPilQo3quh/aUsREgQIOHD9rg24VwmuqXM2bEy3AAEhAQSEBBAQEkBASAAB IQEEhKRLnT17
tlqter5Vq9XOnDkTcXt0Rki61Pbt28+fP+/51uzsbCrFgfFf/Ft0qdHR0fn5 +UqlUlderVYv
XrxYKBRiaZWeCEmXSqVSxWLx9OnTdeXnz5/fs2dPJpOJpVV6IiTdK5/Pr66u lstlu6RSqczP
z4+OjsbYKg0Rkq528OBB5zn66dOni8UiJyR1+OfoatlsNpPJzM/PK6XK5fLq 6mo+n4+7UdrR
95suiMbKysr7779fLpdzuVyxWMxms3G3SKn/oNMAAAEASURBVDuMJN2ur69v 165dhmFkMhkS
4omQQFkXfA8cOBB3QzTFdCs6J0+eXFtbi7sVybNt27aJiYlarRbXFQW+mRid tbU1eusmTE5O
Tk1NjY2NxdUAQhKpjvlthOiVSqWBgYFYdk1IIkVIkoiQRIr7dElESCLVppC8 cGruwtyyUoZS
pqkMQynTUNaYZV+XGR3Z8dOvj7Rj7x2PkESqTdOt2UvLLz56T3CdH//hbcPY 3Y69dzxCEqk2
jSS1zVrmlh6pkslkrzmEJFLtO3Hv7ZED4Nz7yMh/p15zc3N2ibUMJ0ISqfb1 5b09cvyce798
+fLw8LC14FcHFkISqfaNJOkGR5K6Qvt2GL5AAAABAElEQVTDv1ZyrM8FOz8R 7C6xCu0Sq0JH
IiSRalc/bZppaSSp+ZyTWIULCwtDQ0PWglXufDk0NJTP5+233IV1FToMIYlU 2x7zWetJCVuu
+8l3vyYFvPR84m4EDzGNHSGJVPtm/A8++zelDFMpQ5nWgsVQylSmoZRhGAEj id/LwcFB91vO
On7LnYSQRKp9h9FrPzscXOHh5040EZJr164Fr0JI0GLxTki2Mt3KZrOlUsld h+kWWqx9h9HD
z51oaO87d+60FrLZ7NLSklJqaWlp586d1pcTl5aWnC+tEs/tEBK0WPsmJK8+ fX9whbrp1vLy
srtOXaG7jrPEb7nzEJJIxTtr79RzEeLV2QAAAQBJREFUhnYjJJFq04Rk394B cbq1b+9Ap06H
2o2QRKpNffmvHrqzHZuFhZBEir48iQhJpDgrSCJCEilGkiQiJJFiJEkiQhKp 48ePx90ENIyQ
ROrIkSNxNyF5jh07Fm8DGP0BASFBwwwHZ6Ff5aja1S5Mt2L2+Cvvhqn28g/v bndLQjKMz/3I
et1Ltw74RXZCErPqRu13j90bXOex379dV2IdmnYnbR+IdSXOXjy4vvI5mkNm wNqO9ae1I78/
Axrg14bYEZKYVTZqm6b6wcv/p5RSprr5u4s3F5T64+PfXK9uuld0Hr72cpgS 5chYQ2NCgDBb
C9OA5vbeboQkZmvrGxtKra1v/GuD6PAAAAEASURBVObx+5zlfT1qe4+avPBp ylBPfPvL7hWj
6XTde6n7rrxfMzxXbG3bIkNIYnajsrFRUzcqm0qprPW/Yai0oXoN9czJ377w z5O37xqa2Dv+
lb0/CbO1Rjvj5jrvVo0/ScHVrZitrm+sm2q1uqGUqppq3VQppXoM9Z3Xnlr8 bO6No9/90R3j
i5/NPfjqU+KmrOPVEnLv5udt6W/SuRhJYnZjfbNqqhtrG9/75RtWya+//9W/ zv5pe+/mA4Xb
b2xuDGzf/kBh358//PDJE88/f/+T7WuJ55gQfGrR2r23fJutQkhidqO6sWmq 1589atw8WR9I
q3tff/Pnd3/tfOnT/1QyVHFHnk1DAAABAElEQVQw94t33wwOid8va4WsH/LQ 91vLLm9oHHNe
79I2J4QkZuvVzfueft1QSt08tF5+9O7hvtsuXL3Wn7lFKesNo1xZH+67zV6r 7kB0Hqme5X7L
4gHtWUE8WXfvK2SD9URIYnb2hYfchRMfHZxa/Oj+0b3KVNYTef51eXFi78Ho m9duTQxl0ePE
XUevHH2mt3fHO5/M9aczlc3aO5/M9ab7Xjn6TNztar1EXDYgJJp665GXCoOF J/7x9l8uXCwM
Ft565KW4W9S9Ov8itz5i/8h3ch04cCCXy/GI6q7A90maEHvnwnQLEBASQEBI AAEhAQSEBBAQ
EkBASAABIQEEhAQQcMc9YJiKJQAAADtJREFUOul0Ovabx0mUTqfjbQCf3YrU 9PR0rVaLuxUJ
UygUpqam+OxWtxgbG7t69WrcrUieXC4X497/HxS3IIUFIuBSAAAAAElFTkSu QmCC
name="containment3.gmfmap_annotations.png"
filename="containment3.gmfmap_annotations.png"
iVBORw0KGgoAAAANSUhEUgAAA1sAAAJRCAIAAAA8sjqAAAAAAXNSR0IArs4c 6QAAAARnQU1B
AACxjwv8YQUAAAAgY0hSTQAAeiYAAICEAAD6AAAAgOgAAHUwAADqYAAAOpgA ABdwnLpRPAAA
/45JREFUeF7snQd4FNXXxmP57IqKCvbeK4IF7L2C2LArKAqKvf7tvYAgiF1R 6R1RBESk9wCh
995CekJCegJ8v90XDsOm7SabkJA7T57N7J1zzz33zOzMO+85997dtmzZEhH0 tmnTpuXLl2dl
ZW3evFkV99hjj7333nvzluyIzVu17LZ7xP/tdcApJ59iWmNi1j/auP6dV578 zeCYVo2O+/7v
1c82PP6bv1c/1/D4b/9e/UzD4ylp1fD477Z9PnP7cd8PXlNMCfItbz/uxyFr n779uB/+Xv10
w+N/GLym5W3H+kpuO/YHz+dPQ9Y+dduxfLbY9vkzJbce+9PQbSW3Hvvz0LVP 3nrsL57PTv+s
bX7LDiW//rPuiZuP6TRsbfObj9Xnr/+ue+KmozsNW7e9ZNi6Zjcd/fvw6Mdv PPq3bZ/Nbjj6
9/+im93oK9dn0xuO7jIiuun1R/8+IrrZ9Ud3HhH96PVHdR2x/rHrfeX6fOT6 o7qPjHnkuiO7
eT57jIp58Noje4yMeei6rZ89R8U8cM2RvUZv/+w9Oub+q4/sPcbzOTb2vqtq 9RkTd//VtXuP
ib3v6lp9x8bde2WtvuPi7ruyVp9xcU2urNV/fNzdl9fqPyHu3str9fN/sn/X ZbUGToy76/Ja
Ayb4jv4xMa5xg1p/TYpv3OCIgZPi72xwxJ+T4u9ocMSgyfGN6m//bHjpEYMj 42+/ZPvnbRcf
PmRawm0Xbf+8td7h/0xPuOWiw/+Ztu2z3uH/RiXcWPfwf6cn3MS+//O/qMTr L6z534ykG/yf
7I+amXTtBTVHzfJ8zk665ryao+ds/xw7N/nKcw8ZOzflKs/nFeccMnF+ymVn b/9scNYhkxek
1Pd8XnrmwZGLUi89o8aUbZ8Xn15j2pLUi07b/lnv1IOilm2se8qB9lnnlANn Ld9Y5+QDZ277
vODkA+es2HjuiQfOXbn9c96q9HOO33/e6gz7nL8648zj9l+4ZvvnorUZpx+z /+J12z+XRmec
fNT+y9dv/1wRk3FS7f1XxO7weULt/VbHZR1fa1/7PO7wfdcmZh3LZ8LWz6Nr 7hOTnHPkoXvb
Z+1D9o7bkFPr4K2f8RtyDq+xV0Ja3uEH/Z/3M2lj3iEH/l+K53NDen6N/fdI zdhknxszNx2w
7x7pWds/M7I27bfPHpnZ2z+zcjfvveduOflb7DNv05Y9dt9t0+YdPnfffTfu K7vtFmGf3Ea8
X9nn3hNQEVUByrNzNwcYkJEdaCQGH7jfDh2hUwcfsKe3s+zXPHAHh+CcI2rs FeC6Wodsd6w5
OTop23sKjj1s3zUJO5wmTtmq2MzAExqX/X+Zq7778eda594Z9I3ZCToPOA84 D4TDAwC74Lek
pKTDDjvs+OOPP+WUU87xbyeeeOJe/7fPAfuccuChpxxY8+QDDzl1/31POuqo o1NSUkztpoy4
X9++8ZJn/jv/mSl1n5144TMT+azj/9R+df9sVcADKnGfAR5o5feJ+6wKHuA0 Vba/KnHx1H1x
7nHnXDug2zfB35adpPOA84DzQFg8wLt4CNu6deuOPfbYUaNGLV68OC8vLz8/ /59hf++526EX
njPtkvuiLnpo4iX3zDjv2BGH1Kg9adI405sQs+aiC848+/HhdZ6ddv4zk+u0 mqzP856efOaT
E89/enuJ96j2L3jG93faExN8kp66FJoekwwo8ZZLXp9b2/WUeI9W4P6Uc1tO ol8V2OJWDwTf
Ihae9VQ4LcT5pz8xIbw67cwW1a9zwt2LElsM3sPlLXlOi0lnPzXJZ7B+TUF/ UuXswup6y3eQ
8f9Ud4W/oF2EM+WB05tP5JcS4OTSXSRnPDP3hRYPrZ3aOYT7shN1HnAecB4I hwci0rNy1iem
ro3fsG7bH/vRCakZWTkF9a9du/bkk0/28n/jxo068+y6Z9/c7dKHo+o/Ou2y ++ddeMLYww49
euLEsVY9J239L2/dUK/lcDhCqEH9XfD0xIuem9TwvShe3C/YVmiHzmw+Xvvn tZzA34NfzL7v
01lQDtQyDaXbQcMlz0+mXUi40mkIV63zn55Y/4XJt78XFS6FYdeDhZe9NOW2 d6eX3e3YhsPP
fmo8J/2hL2bf8UHU+S0nhN3gQhXS0JWvRN7yzvTzny7HFunduS0mnP3k+EKv q+KPls4P/Bx8
LT41nh2fe/1fz3hiHH/nbCvkt3PN61NvemsaO6G2QpVrX59645uBdSm/7o2p N/jLvfsh6cfa
c56aYHYG1PUfHV/U0ZAaMmF04isaNXexL3fhNxWG+kctql//v6kPtZ6NT0rh 5IItXujnCPt1
+Toct3enw3nAecB5IAQPRPQfNfubPya37TWmXe+x+vuS/V5j+4+eDQkYoAlE eNJJJ0VHR6sc
mnDBggVjRv934KGHXXDXv/Ufi2rwwKw6J4wGEXo5wng/R3ju48PqtIq0O+BZ T44Hlq2Jz7ri
lSnckb1I8eJtSBFEAhZp2m7OqrjMqKWpgInzPJKh3r4lD9Zs8ulMFNJKWO7g pTODWqc/Ma5Z
2zlkidHHcgUrpbbw1GbjXvhhwYLVG898cnzZQaH6+NZvS5bHZAycGMujtOw6 g+nayU3Hfth9
2dTFG05pNjYY+dLJgDuvejXy5renFYp0udLADY3ejwrjJedDe69FCu0BTbiw L395CtCEvxv+
Nw33UnjCo2N+HLyGHM0THx0Tar+o++uwtX9PiWfHW5evnYevGzQ5jh3t/znJ tx+Sfp9D3ph6
/f8Kh6ocveXt6YD48LoLFCvc5kNyzcdd+4YPyfF35auReK8UoBBVl74wucfI 9cvWZ7z9+xKu
tJCcUKjwGU/Pfv6pBx1HGMJDzIk6DzgPhMkDEW16jMrOY6DI1m2T/39KWmbr HqPSMwNpQrDg
cccdN2XKFLDggD969h/Qc968uV07d6l1xBV1moys3zTqiruW1z1xSgAiFEdY t8Xw056YpJdy
7r8gwkbvRa1LzAYR+l7Wm4+38sYfzFgdn3Vhq0nHPTzmjg9mgBovenbS6Y+P 4wYKhuBWLkl9
RQ9Qg0//Ib8S7W+TQQxkaaQjehp/GEUevU/nE+NUt6BmSB0p8ba19atfnoo0 5ONm/Ptmxg4K
/dU55NWm5igBoDz8xeyYpGwaOrelz3ITBlX4FPo/pV9HJRDwILGjPuFWE1Vr q2HSQOE2DQFf
4bR0yOp6GwIRvvjjgkVr0ukpWLwoA3wWttxuIUyMNWf76Ke/b3RaNHt5Gujh 7Cd3oKzQwMNV
+n00WyvfV+uF9lUYILP1Ky36D1ld6wUG8Jz+qMey6UtSMWC7Blg0/1kIKNlO KQUc8rbuZ+Cs
oq9dWnls7Jf9Voybk1T7/lHi7byaT3183Nudl/Qcvf6kx8Z6bfOJbSf2fJSb tPlsK8D5GQWI
DPzZSY+OYTAWaK/WfSP5UcA3fzdo9bLoDNBJr9Hr6784mbNw9IOjQITj5iUd 89BotYsStSK2
bMdWdig54r6RPw9dM2SqD0162McJfO3y37rBU+LYOerBUV2Grxs2PYFz6pXZ Qa2fgdvB+BYT
TnxsTO8x6/uMjaGVc3YU4CtnqsPAVd/8ter4R8aYu8TkcdQ6Ip0qDzjk/SoZ Wvxrctxv/66j
Ra5nbjs9Rq1n7A7uwm/1dnw/FIVpTeMxs9/2fTofHcPoqB+HrOGkcwWabV6Z rbY9tfUHvrUX
276a/dsvPMcRhunZ5tQ4DzgPhOqBCJBfTm4gFxifkNC6+8j0zNwAdevXxxxz zNGdO//0+6+/
HLDXqbVrnv91x9Y1DjzqlCO6X37PogaN55579NATa/xU89AjJ00a780jrHfB Gec3//fOj+cQ
/+Wl/N5PZp7SdOxt7/o4QogN7oYPfD6LYCLlPL/hDuNScp74au7t70aBCGOT c5q2nXPnhzO4
53I/9Um2nn3PJzMBefB8t74znep3fzSDWPBdH81ACfs8C6VNuGprmNgHjHw4 79nv5k+Yl0w8
FH6Fuvd8PJM7OGKy7e6PfbVoCEmUSA9fpRMBWuE+jk4FfNEJT0BolUfyzW9P 5wGAQm91vvKo
2Kqt9Ww6guU+S56Z+NrPi8bNTebZc8E25RwFp/I4R1XdZyf56j7lA09qmr4H xHD1NNVRkPRp
j4+74uUpaoKKsKp0h941eHGyZAjXIoPBlD/cejZdAHywc8f728slCaF1zIOj 4QgXrt7IE7pu
K1+0V+V034ucQDD1np0kuuX+z2bh1UtemIzlqOXsUJEdzino4bVfFvEAbvzh DL4al6ZoMqdS
GjjpIFHYL19DzcdzCG/gc7rDU1w24ARkOINq5ea3pmEAO77yx7eWIyYDjnxg 1Efdl01bvOG4
h0fTcSsHRaFcJajFJGOkMIlrgBNqhzgpVpdTQ+tct7QubVCDYILWfVbMWZF2 x/szbn93Opqv
fi0StTLv1GZjFb1t8NJkLl0K+eMreuiUSqCvaIIdArV0HAPooCQpQZLYN5ei lQAEv/lr9bQl
G3AUxnzcY1mvMSDOMVjy0+A1Y+Yk0V+GbcHz/TZ8XZ2nJ6ruNa9NxZ/swFni AVrBAOmEtKNd
0BIN+U7Z+1F/TYqD/0OhSmQk7YII4QiPfXg0QKrbiGhG63NyoUgRoMt4A2v1 lT9CzzqhZjwl
KOk5aj3DxmmF3mEGn3IXksjzlbaufGWK1cKfnFzc2MTfEbosqyjnaucPtWqR Ei5yvhINUAnG
1Lp/JGPnh05LoMWLn5/005A1Hf9aDZCld0Mi4zEG9KmrWrFgWlddDKAtdEpb g5emYCE7+M1f
N2HgpDguPJowGTyMn2Wk78cO5fnOdPWOEmzD+U0+nSX9kjGG0s8RPuA4wlCf ZE7eecB5oOwe
iCBGnJyaOjVy8oQJY/kbP37cxPGjFsyf06bnqLSM7NQNSfn5eakbkvlMS02J i4utcdCh++xx
4oEH16l/7qxLzpu+/97nM+L59FPrnnPkgDNrdTvxhNMhEWvWPHTSpEnePMJv X7vu5jfGpGZt
ZrYFMMHsFWk8xkCEzJdxyQuTiNrMXJbKbB1TFm7gwcwTJSM7f2Vs5vi5yYil ZeaxP2VBCqwe
0HDpOt9r/YxlqTzswTFgyjd/W/xfVMJdH83MyMpfHpM5aX5Ki6/nsYNOQBLP cm7lcSnZYDju
xQoZQ8zc+dEMdt76fcno2UlgLwDovFUbeaKPn5fS8L3p5z098akO8xasTieq O25OMugNnSti
fMZHLtpwA5lDX8ziK/dxnlLc1uev3sjnkugMqCCecyC8p7+ZjwDV+Xp+y4kt O86X/tGzEwVo
FDL2g9GJz3+/gFgqBA+TpPBc8XUzOuOdLkv/m5GIqb6j631H1ydlL1izEWwE oBRPySegDdeh
ecSMRDzJg4cI6W3vRJ355DhQwoiZiYDsez6eodaHRyVc9vIU9OfkbqKJodPi Uc7OmNlJoMZm
7Xzl9JESzObB9tx3C+atTOOB/cpPi9QKpAjdx2Y9PmXD/35drFpAeSo+1nZO du6mJesywBMv
/7SQHaaSAZ4+3XFell//HxO2R415XoLA3vp9Mcq5MAZNiedMITlhfjJPZaAV dNHfU+JguTCP
XiAD2QPQfOH7BVk5mxavS+87Ngasyc6QqfF1Wk186ceFlGMMfzzsMe/9rksn L0zh7L/fdYla
GTA+FugMTP+g29L5qzZyprqPXM+p3NopX2Bx0qc9l6OBQwRGuYo+8X/lj06d 12IiV11mdr5K
/pgYy2niWuK65evvw9eBFZ7FdX5rYcJ4Q2jTd4W8IRn++o+Lhep7v9tSShat TQe6vddlKTt9
x8Ve+uJkLGnddwXV+esxKho/wHSmZ22tywRDnJRPem4t+X7wakAn1xIXz+3v Tf/ln7W//LOm
5j0jFTI++K4RbfutpC7KKeGqYIf+Aoxw19d/rpI9YDtKuKQBmipJ2ZjbdUQ0 mr8euEqWMOkS
aAlTQYQ17vxP4WOgISeXOaHkrjb9VuCuHwZvVYI38Py3g1bzQ5ba34b5SpBP y/CV0M3Dm4z8
sPtSuQsLIfIxjx1Adqpfhj9wJ5aA5CjBfhjZr/5YyQ5EJsAXA34eskZGwvkh CR24IX1rXYzh
FRRLVEIWAS85nBRwJ+7qNy7m897LLearWDAdV7sbM/Pf67r0+7/XpKTn0tyn vZZjOTv47ZRm
44CSeAmxZ76ZzxxV7HMID2M8O+3/WMm7Cmwu17B6x4k4pem4vuNikv21+Gs3 ABkfo7z1LevF
ucefc12/ri6PsOxPN6fBecB5IDQPRLTvN2FN9LpLLr7otNNP82+nXlz3wilT xrfvNz4pJXXy
hGGpqSmTJwznc9rkkWvXLT/s0JMuOGPcpffPqP/o9Pp3zD7z6G6XN7h29epl Z5115tlnnTVn
zqxh//5z1FFHjR+/A0d4/jmn3/TamOjkPN6keVqA84A493/uA1WwJjzbRC+9 +ssikNwDn8+m
nFdnJBU11j7UF/OrXfYSg1XH3f3xDG6mAJ38TZtJMeTm7j+azV2VHar4dj6a sTouE3DGTX/S
gpSLn/Mhwvs+nbkmPvMcfxYjdacu2kDrkD1EbwEc7HD3XxmTCbxLSsvFJNqC SABmAR9hRE57
wof/Fq7Z+NiXcwwRPuIrSW/yyay8/M2gWKogA4rl4UrrMDGPtJkdnZTFJ8zc Z72WRSdmgQib
+jRk8KACnwEHL3hmAuY90X7unJVpD3wxG1UjZ/nA3BPt5gKhAF6nPT7Wh3TX Z/oJSx8aQ/7J
9nPxCewmDuEZSaMnPzaGhoBlb/y6aOTMxPNawsBNAPI+2mYObAcy4EXALrPf 0a9W383nucXO
c98vmL5kA/oXrk0HfPBAJV4Mr0YJCJhW8Ml9n82CfxVcOOOJrZmFPFlBOQBi uCX2X/9l0ZSF
Kc9+O3/e6o1gOE4o3Tn6odGvd1rEKQAk8VDEId7ANx4AzwGmMQ8ukAf8/NXp Rz84GpOGTk0A
MDHBodIMQIr0Apmfhq6hg7Q7Y1ka2AvAxxuCb6fb0lEzE2mUS+LUx8f6MwiX jpqViH6wNfLg
aRzFFdL1v+jRs5KwiusNygdP+sYxbBtbQGyXBz8gkh5xEtEDYqBffGUfBPPP 1ASg/+SFvtzE
k5r64sVDp8ZTAveMAIOl8AYM36Nf+rhtopPkTfo6MiWOT145kIHMAyVAwmHh uHnJNe8Z0fHP
VRB7h/p3/pwYy3XIGaF64w+iqA6aBGcwIyMV+SNeDKgFEYL4+eq/0iay8ybQ PDqD8DRoHqAG
fgIRHtT4v5//WTN8RuIhd49ghxJ2mFaz16j1oDcgPhFV/n77d22PkdFt+6+k L1tLhq0FGNG7
CfNSyLWAYGaqyO4jo78asEqIsKufLDyw8fBuI6OB6dTCEmKpfP1zUqyUdB8V DTjDYCg6lWDe
r/+sBVfRBVUBZV7zeiTuohVebDhEKJYrgc++Y7fqAbcx7SiFfcbEHHzXfwMm xBJ31g5w09/T
RBnJa9W3f63+/d91eF4tYkzHgatAhKBetcgPih0QG+4KiBrzcxg8JR5h1eVc A9oA5Sg8+O4R
OAfX4UD8hvdAhExfihi1cCxYnEPs4Gd2hs9IwDDi1EBP/8UQxW+K89hvfMyP g1frVPIzx35L
9HQcYWhPMCftPOA8ED4P+PIIE5KTUpJj42LXxMasXh+9Ys3y+TOjJn/RbUR6 FlFj30zU9hkX
G13ziOMuuHN4g6YzG9w/+8Ljxhx6yOEzZ01FYuHC+YsXL2Tn33//PfLII72I kDzC7167rtHb
Y1fF517+0hQeh5BkK9ZnggjBN6A98BO4BCYJyhB8c99nMwFbxOzACkKE2ufp uC4h69LnJ6GB
W/+y6MwHhSlfnMyDGbBFdaiaRu/PWBvv3/kgak0c8pPPaTFeKMSGlXAUeUDe Jc/5tKEZBObj
4fxEF0CEcCpYAfAEKCRQJUSIBh7/AFZS67i/I+zlCAEr1AVVkFL2WJs5sKG+ MLcfXYGl0I88
f0Af8q4oBFPSIljERxbGZJzbYjxApFm7uVBxj7ebC+MFbYCqJzv4EKEvb+yx MeBFmgAR8kdf
qIsSNFPo07wug3EASPJwAvNhMLhTQedXflqIzJJ16bCMAJ3m7eeCukBsEJl4 np1W3y6IWpL6
1NfzQHI8nnk+wR1OX5wqREhnc/N8rJta4RmswLqyA1/52YcIIdho9+WffMiv 1bfzZ6/0YTW+
gghr3T/q1Z8XTV6wAUQ4a0Wa8vksWZAzCxMJN4lmv/70XmNisIGgJzwcBB7p pL7g+DMT3+2y
BBkEYCKHTUt48ceFzCB92L0j3+3iQ4TaAee98vMiThwPaeKAgEVKhAjprJ+5 TKcV3Au0FRcL
poFvZtiBL6HT3ylOxGe9fYiQHnES+fyijw8RsoPOz/usoHUYQXASJcc9MsaP EX2IkPcBBFAC
BAdE0gp/iam5JPaB8GiIzzGzfTL0rv0fPlwFSQlLDbqChwMRHuTf+WtSLDbD HVKdi4RPGMrP
ei2nF1TkDwwBzwoiVIksVxolHYeg4hqDGjSOEAwNgjmw8X/sgFfYAbv0Hr3+ y/5g2QSwI38w
fz1HRYN+IFZVAtYBEYJZN2Zts2Rt+pu/L+n452ovR4jxfgjoIwtxF70DP4Fi pYRDUIkY3H/8
1hKA2m/DfIiw3zhfCZYrjCt3QQG27b8C8EcJn0zALj0wwZTwBwg74I7haMOr 2gFugu2oKHdx
SfM6AejHeNXFGHA2IK/Lf74SfhH+ccdb3UVfQHv4TYORufjxAChWdUGHoGRw MN44oPF/QyPj
cR0OxG94D2MgLxGj1/gcCMshPIyf2YGS/+HvNfxU6bJ6xznlqoYjBIbqVPLa hv2GCP1jja9z
Y43D94xzmpwHnAeC9UDE513/W71y4ZolUUvmTlw8Z8Ki2eMXRo2cNHbop12G Z2QH5hEKEZ5/
9z/1m02v/9DMumePr1WzXr9+fbytDR06NAARMh+hOMI1iXkXPTcZ/MEb87r4 rAe+mLVgTfrD
X8wCphD0OfbhMWRWAZgAiNGJ2TzbKBEihG4B/UBQAQXqPDMBDWBKyh8CU8Zk XvL8JN9RPyLk
0egbmKKdD2cAy6AGCSqR2oVCDSuJTc42RFjPH/Z98HPfCA+eTOKEIKuozi0e LAjrtjo+E7RH
c2AF6C6O8tQBulFyZvNxKgESCRFCCvr4v7Zz1yVkA2tOazYWPSA81pDgwQAQ JIrkS6NsNpa4
M2Shjxf8yqcKChBiDHqPxwbyi9alA2RRBSajO1RklADIjCaU/QbHyVFiVati fYwjvSAVD46T
oyCDD7ou9cWO342iFnjLxx02HYupYEEyzxQQx7Bnvp0Pu8kOWA32AkQ4d5Vv 5MdRD4wC1RFg
pfUpizbQCkDqxMfGntbMn4P40Qx8xUkh5++kpmNe6+SL2AKMyNh7/rsFQoQ+ avDB0YAzSMGj
HhwNvoG5EUcIh+obXt1yAi8DnEdiaozTJKYG8qMX4HtYQF8eZIsJ7fqvhHUj doxmejRn5cZj
HmY0w+g3fl1MmJvoMONFat03imArpKBvp+tSnq+gz8iFKWS2AUkBkWiANRwe lciTGOCIE/A5
TfMagKMwEq9yXU2Y74N3cNigQxwCyItcvIF2OYnIgFHwD1/RCTIbOTMJYESP 8CpuISIMbgDb
sQ4KAlgIZgJQ+uQfGA2C/NuPBYUIx85JBnGCAECEoChq+ajBu0cABIGGEEvs gPaApPSR6lhL
LJiMug4DV8IIUpE/ABZwqnXf5aNmJ2lkCdmKWI49Ne8dAQqBd9yv4XBinSiv cecIAIowou0A
axgk237gymHTEiGx+AMRgrpoHXSrEuAXoAq+jfElwHos4VxA0vvHIMft2/Bf gBSsIdCHKDYc
IVVwF54H8UDLSQmIsPuo9eBvXiQ0PBl4xBJBACxKEECe/rIoDql+tMJR4r+G CNGsWtimQoAg
GFSIUDsoB/9BPcpIbi9cpf3Hx9C06oIIO/yxqsfo9XTHN7KkuS9EQDKf3AV3 iyrdl+ggO1wt
GoPCH2cNlAwipNc17hoBWMR1eBJEKI6Qr2oFD+NeDtkO0JCrBSaYzE56x7XB oc97LYcjJOjM
ieOPM0itE7ZlMTqOMNhnl5NzHnAeCLcHIr7sOfK/MaOGDO4/8I+eA//o4f/r 3rtf7y97jMjM
zgtoLi52Xc3Dj7/wlglXNFl6eZP5V961ou4JkbWPODE1Lckkmb86IGosjrDh W2PXJeeBRYBu
L/ywkKddk89mgXXu/XgGz1EwEACOuB5LPyFALmDz9vO4a5MdyNMa8AGM4IEH yiGKevdHM5Ek
bghHCJokQAaSAGYhCdTgSb915yNGpWSDPAgux6dkAw3BMb5hJfN9gznu/XRm rK/QFwgGREYu
SgGNYQN4AtvQ6QuSfjzzf78tHjkrCaTFAx7ogD3kzJG2yGgASqhCCQ91aCfo OrhJqCxw570f
z4RaA9piIXQjtiHMPg29hcKZiYR9aWjs7CSlOcI/PfjFLFSBYAiS0ndgKEQa qqiluuAwQpmQ
ZOAJgBp0KbCSeDHeI0ud2CJog+cN/f2oOwHKeChYbOAh90jrOWjABgJqYJfZ K1Jb+qPPIDCo
FEhWdjgj4D84SALZTP2IDz/ttYxnLdgOzhLbwFV4g8RNsuuIox330GgyC4Gn 1AVlAqfQTy3w
xPh5yfCLYMSjHiBYvBjC5sgHRuM00But8FWIEPoTUg0xMOvTHeeDk3A+6QTK t4O/ATBBFoK8
J85PJosfVGoyPEF9OO9nX2rjEU1GfdhtGYDSt9N9GeW0wow5wEq8jT0QVCBO LMROIsg4geuK
chAG4V0cS6Oi3MhmI3Ft1rK0I5qMBEQCvzDJP9ZhKiQrZ42v6ARmQQt90M03 fhnO+IRHx341
YCWa6QWMHQJXvRZJf4l+0hBnH7QBjMA2mEU+iTWf+OhYEAA4BlQBzzdpYcoh d42ANJq4IAU8
wQ7n0R80j6c6LzMkBQIg8AzjkKjIH1wUOl/8YcE/0+I5KeREwobCArJPd+gy kU2wESCm83/r
gJtEhPm9AA1tB5mBE2LpJrwyVfgDP9ERkC4YSCUYwGgV+sIZAbvzR9QV7hNk RuvAKf+wkjWH
3zsSFo2gMFX8Yy8mg6cBYVKCBq5b7KEhoDZ/4EUA1ntdl4AIEeC3Rrvsqwk4 XXSCF+ERhRpV
C4UqBOqBQVk+0XZQ7h9YEyMNXLekpeL23mN940X4w1qgJCAb1EiLvEPiZAyT hfQO3/qivdMT
QMm+2PrQtSQycoirhSvqiz4ruFoIkR945wgyYnEdnhwxI4lERmLZfFUreBj3 csh2gPh0jfQA
ZDCMU0lyMw7EDIxHOeeLM/hB96Uw5VvHtTiOMNwPOafPecB5IEgPRIyOWvrt wMnteo/5qs/Y
r/tP5LNt7zHt+4wbM2Npfv6mAC2xsev22evQkw7+7ezaf51Va8A5Rw468eCf 9/q/A3/48dse
PXp06dKlZ8+ebdu2PfjggwvmEV7z0qiN2ZsJZQJBpi9N5fbHbGSwLLCDEDMA Bcr5g4nhEKQI
+5ELN3DTZGAHzwzgEewXVYBEvkOLNpzbcsKtb0/nSQ8fADPBEEKieECN296Z vnXn3elE8UBI
PJgnLUj28YL+0SS0CCiBLAS7MFoFAbK+bnlnGiAJzZhE4h1jA2WPb1jJ0765 A7mbby2Z6y95
fFzDd6NUwh9kABiRB4CmYoE7pFEdgqTxCW/7igyEny+JkOzAlv55YZr7UiQl TFKRD+d9Phsx
36AT5s3xAdYoOEjQD1QiiI0nMc9d4BE94qkPWlVdiA3qAlupK76zWVswUBKo BbhmpvIoojoP
Nn+Qeg7AhZ3Hv5pL7ho0J9FbQtgIA0yh/UBRwF/4D4Y5SwNYE64UshBUSou4 DhsAplgILwi5
C/oEHLNyMc9IxtMAU9ADniNpjFb4inNwILWgDHkG8xWHPN7Ol5fJHwiAGJzw EKeVXrz4w0L2
YW4gU60XjE7g7QKQAYEHWbh156eFQA2iw4wsAaMjTGAUog7sCIMF8QkUlgao HaipraN/fMNK
ommIgQK8AMDo8ILBE/rZb31wmT9wD+wOgXV9JfIIH0nUmB75JJuNA3HiVQqB wggQnYRbYsSP
WQtB9dJPC8FnfDLQhCroB1NCLxFzB7jAFQEWSYyj4tYdPyqVBhg1lAN64M+o yB84kn2QK6mQ
CADRAMSQoJInCgkKVBIh8JELhqg39BiQ13bAQJ2HRwPmwOWqBUrmSuBqIfhu loPLD7t3BC8b
JoMSUA6k6Tf+2LGG6FKR4LJkOHrYPSN4LdFXwCJfIU2xB0v40z5qeetAAPiI gPb1B54DvWEq
n4B11SLKrEI4S8wmIG47KEQDPVJ1ACgCwEqgmOpqHxnYPgQYe44AeE7yJHdi P2LgOYxXFfg/
3yW9gvF1+bRLOfmU9B1alIbYwXu4DifwVVXwMOZxyHYA2eA/2uKMWO/44XCF MLKEFEYKOYO8
HVlmreMIg3x0OTHnAeeBsHtg+yp2mzZt2pCStImV54vekpOTL7roohNY2Pi4 47b+HX8c31ja
zjbGGp977rmTJ082NXCEjDW+451xsambrn41UjlkGqOqOYrZ16xdSpD3lpiM jWzdKrltlKt3
lmPbL3SHmTWg/aAP6z23dWTfdjGvDX5Ip0kofH/+Q4w13m5kYSVSVbhC/6Is Vh0xwEfzr+bC
bgLpApTb6F1TpZGPYDUQJ2QkCE8jS6xFr2ab0sWn1jfx9VaXeo0PNHXbMjAn N2X2wYXEl0He
3nHEyJsqzZFh82lLlSLIWMigDZ6O8F6APBuMHHAuvOfLPFZQvwZ5qBf86cLQ jmwoqhfEcEFL
oGdQptdaVfdq8Plk21ku2CmvcMHWvVevzxi/Pd4qxVjrvUi8vZCSrdq2KbT+ aizRDnV3lNmh
9WfIuBhN3FNz0JiFgTsBGgr0wtu1rT9P/3RLlB/3yGhIOFjPrfo9vvX/ure7 WobtYLx/6iWv
wV55SfoEtjlWV+P2wm3advBegRbNn96rxS4AXVp2zzFVWj8Jipo5hrikeSMl Pg7OAzLqkMzY
bs+2rwUPee5vvip2KsHoY+cmw/uSL2GXlvrou+04jjDsTzmn0HnAeSA4D2xH hLk5WRPGDc3N
yS6+IsBx0aIF8+bPmT9/rv9v3oIF8+cxUfW2jX02Fj5GUqrII6xz7hlXvDRx 4pK8ei/MPOfp
6We2nFbn+RlnPz39/Gej+FrnuShK2Nent2S7zPMzvOVnBWjYUZvv6HM76Kfk 7JbTb31/3rgF
mRc8F0UrntYLaN5W12uP5Isq8bcYpc9znvH1aAd5f4nqIsPOPZ8tHDMvY6sN /qOU6+h2y/3l
pzwx9a5PFyxYl780dtPf09JwArXogrWl/fNbbS3x6rR9yZznl5GHfZ/PSI+v FUpObT710a+W
DJ+Vfkrzqec9E3WW/7zsKOnXoHLqYq1//6THIx9uu2RBdP6S2E19JqSc0WKa 2j3XL8P+dj1W
/twORyUpC7fLt/LJbK3r3/fLTPf3Yqv97FOusymrTn4i8oWfV/4ZmXZ8synb tT3jqyVJbFY5
fUde+zpqJZ59n7d9R1ttbYUdfLJdstX2/fO2ySBv+8hLg9rSJ4X0xVuCvO8o mreV85VzSl2M
kbclj6RXxuz3H9ouf+LjkR/3ju48KvGEZlN0LtSEbECDt0StyD9bZdSuz/Jt tTwyHMK9bf5Y
//O/CdIvw5BHufTIbGnwfW21tZxO2b7PmSbv39efT8D+/Nqk0Aq3ft3WkM6O tHkNoMTnxm2d
pWkZ6TNp276342YYnWo7MGbR+vzF6zf9r8sanOl319Zu6lLc8fT5Wtl2gnyt eGW8pwZXn9gs
ssuopI96rzvusSlqHW3yEp+ntVr8fMtH1kT+HtwN3Ek5DzgPOA+EzQPbEWHY VBZQlJ26vtPr
DW586qcTG3e6+qmup9318zVPdT3V/6n9Unz69NztqXv3z9tLVL7tU+X2SbsB Jd6jRe2fjoYn
/Xq2ffpLuhQsUXkxn1dx9J6f+fRZsm1fJTt+/uIv2fqJ5Bn+fWrxqf1CP69s 7isP6fPMe/3y
9/5yRXOf5eyrJOCTo4WWWPlZTX654glf63wiaZ9n+fft83L/fuBnE3+J5/Ps Jp0uf6LzWZ5P
X8njnQM+L/OX2Oc593Vq8Di1fvGV3Ocv939SXvxng2Y+mRI/z73fJ2Of9f37 JX6eh0zT33f4
fKDTpZTs8Pmrv2T75/n+/cDPx/wlns9L/PsBnxc8+OvFj/r0U+7bL/j5qL98 x886/pIdPh/6
9SJKAj9/q/PQb/Ue+Q0NFz3624UcfSTwk6OUb/982Cd/oeezrn8/4JOvwfwF VPSq3brvbXrb
fkEjMd7fNe/n9s7iCnXh/AJuCXRdEU6W8+3TTpP/1Gw9Zd5Tyf6FTfvsf8QZ vX5rX343ZKfZ
ecB5wHmgUA/sGDXeQNQ4MHewRMf5w82JrH1XlGR0TNxtNzQY2q7RrddcOKT9 nQ2vq/tP+ztv
93+yr5Khns8hXzUOquT6eqrr+2SfWgU+7/CXNNr2OdiveXC77SVD2jVGhhLv Z+MbAkvuvOGi
v9s1ptw+77yRkjt2KLnhor/a3kH5IM/nX1/ecdeNvnL7/PPLO+6+6SLKG99Y z3f0pov+bOP/
1L7/c2CbO+6+2VdunwO+aEStAa0b3XOz76g+773loj9a7/DZ5NaLBnxxh/fz vlsv7v9FIz4p
t/1+/hKVs3//bRf3/dz32e+zRk0o8e/3/azhA9vKOfrA7Rf3+bThg7df4iv3 f7Lf+9OGDzX0
fbLf8+Pbke/x8e0PN7qk1ycN7ZPyh++41PuJzCN3XBrw+VhjX8mj/nJ9Nm1c v/tHtz227bPb
R7c1u7N+1w93+Hz8rvpdPrjN+/nE3Q06v39rM8rfv/Vx/z6fv793a/N7dvj8 7b1bn7yngfez
07u3PnVvg189n7+8c2uLJg12+Hz7lpb3XfaL5/Ont255+v7LfvZ8UtLqgct+ fHOHz2cfuPyH
/93s/Xzuwcu//9/N3s/nH7riuzdu8n6++PAV37x+k/fzpUeu6PjaTQGfHV69 8eVHr9zh85Ub
X3nsyvav3PjyI1dQzv5XL9/wWtOrvJ9tX7rh9WZXtfN8fvni9W88flXA55tP XNXmheu9n281
v7r189fz+cXz1/3v8atbv3D9O82v/vz5HT+fvPqz565/x/P5XotrPm11nffz g5bXfPzMdQGf
Hz197YdPX+v9DPjKoYIVCyr3Nr11v6CR2zqi7uhzW2dv+N/jV33x/PVvNPN1 n32vWwq6rqB7
KcHtHTgRnJptn3aaODWcxK9f9X0GnFBO90dPXpK/fvt8riXegZ2A84DzgPNA WDywHRHm5GRN
mvBvTklR44KtZmVlUDE3N3AR5LDY55Q4DzgPOA84DzgPOA84DzgPlLcHduAI U1ISS8UR5lNx
8+aQycXy7pvT7zzgPOA84DzgPOA84DzgPBCMB3bgCFmtrhQc4ab8nKmThm/Z kh9Me14ZhjWv
jkkOtZaTdx5wHnAecB5wHnAecB5wHgivB3bkCJMTgucIN2Zmr45LWR2bbH+r YpPXxKWkZwYb
Pl65Nva6Z79L2ZAa3i45bc4DzgPOA84DzgPOA84DzgMheWBHjnDif0FyhNm5 eb1GzGzXe6ym
tm7fd5ymtuaz/5jZBae2LsSmzfk/dv/ruuaf9PwLfrG4LTc3d86cOQsWLNDg FX1duHBhMWNZ
ilGXkZExY8aM0tUNybNO2HnAecB5wHnAecB5wHmgqniglBzhho1ZrXuMysgK XPg4ZWMG5ZkF
FkQu6I4ZyxNveuqzJ179pNHzXy2LyyjGX2vWrImIiDjooIMkExcXx9datWoB DUvh5aVLl959
9935+SHHuEvRlqviPOA84DzgPOA84DzgPFAlPBDAEQabRyhEuDEzK6CTMXGx rXuMzMwJXBDZ
K5aVlTl1UUyz1n89/+G3z3Qc0eq9ji07DJu3Mj4vt/DJsVetWrXXXntdfPHF 0ISZmZnjxo07
6aSTjj766Ly8vJycHBZHmTRp0syZM2mCktmzZ/O10JJZs2Yhk52dDSjk0yRV rk11p0yZwgzb
VeL8OSOdB5wHnAecB5wHnAecB8rugdJzhG17jYlNSJg0cdyYMaP4Gz161Lix /82bP/vLnqPT
s7KZoTAvL9f/mecfiewP+Oblz1y85tsuA29o/vFzH3R889fxg0dMfPWnMU+/ 0w6+8Nc+Q+at
WL+pwLyGgLMLLrggKirq9NNPZzWU0047Dfx31llnkfIYHx/foEEDwOJNN90E zluxYsXee+99
xhlncPTKK69csmTJ8uXLKTnzzDOthKVV0Mbnvvvuq/Krr74aSbDm8OHD+cp2 4oknnnLKKS6y
XPbLy2lwHnAecB5wHnAecB6oEh4oZR4hHGGHfhOWLl920UX1zjjjdP5OP/20 +pdeNCVyQvt+
45M3pE6ZMDwtNZnBy2mpKRPG/QM6xB3JaRl3v/nrtc0/b/bi+0+2G9p/2MTJ E8Z1HzKx2Rd/
Pvb8u1c+8UXTj7rn5AbGc0GE5513HomDjRo1Gjhw4D333EMeIWAOghCd8Hmw ej179jznnHOm
T5+OHVlZPuYS7EhJZGQkABFGkBJQIAsuU3LhhRdOnTqVcmkAX6KfcuoqEg36 PPXUU8GyVeIU
OiOdB5wHnAecB5wHnAecB8rogR04wuSgxxpvSPdFjWPi1qemxCfEr42PXRO7 fuW6lQumT5/U
uvuIrKKjxps35Y+ZEPngWz+3fPurZ74e9tugSU+1G/zUm18+9v5v02cQvS1k 4RMQIfgMxm7Z
smWkD9JhdsBziiBD+IHnIA7h9sB2IEWhOkLM4D+QH+XCdvPnz0eSknr16k2b No1yZRMSPj7/
/POFHTXUGj2gQ4cIy3htuerOA84DzgPOA84DzgNVxQOl5QjTsz/rOnzZotmr F09fMmfC4tnj
Fs0atzBqxIQxgz/rMrwYRCi/pGVvfqPzlCdf/+KxT/vz+VHfOflFroG3RYgQ 9LZu3bpbb72V
6gSIAYJguGOPPVYKGX1CCTjv7LPPVgnxYmohA1OoEnAkwJESQ4TGEdapU4d8 RILFkoSPdIiw
qlzBzk7nAecB5wHnAecB54Gye6CUeYRpmTlteoz4e9g/gwb1G9C/54D+PQYM 6PFH/+49+/Zq
12tUdoHIb0FDk1IzG7/Yoenzbz/45k+5+cWtdwI+O+qoozZu3GhK4P9OPvlk OL+bb7559OjR
RI179OgB/oPbY9DJqFGjJkyY0Lt373vvvZcScB4yKmnSpAkcITwiseYTTjhB iFAxYqLMt9xy
y5gxY5D87bffQIRuPHLZLy+nwXmgWnng26HRLX5c4v6cB4r3wFM/LHryuwXO S84DFemBSYtK
nvu5lBxhXv6mUTOWdug3XpMR6u+rPuM69h8/fvaKTaxGUuK2OX/YqAkXP/ZF 5LSo4mUZa9yw
YUNixCa2cuVKcgr5mpiYSMAXXpDtrrvugk088MADAXx8ZawJAkhqBAklwEdx h+BC8N+dd96p
+PKiRYukLTY29tJLL73kkksIKMM+upElJZ5DJ+A84Dzg9UCjz+b+OzNp+rI0 9+c8UIwHpi1N
njR/rQlMXpj09/jF/I2MWl2gVrIO/Tet4CF3mTkPBOsBXlY/7LOqxNt1KTnC EvUGIxCfsvGZ
Nn2zssM2gIMRJ8xKo3Ek2sgRPOaYY8QFlrghptlnYBzvuOMOxxGW6DEn4Dzg PBCACNcnB3W3
CdVvvL7yfltwTSnuWpR7X18LloTalpMvbw/k5makp8VaK8OGDdvNv1122Y0z Z2bNnJk5c2aG
/y/7m28G6tBtt91WRqs2bNiwdu3aMiqpKtWTkpLWr18fFmsTEhJiYmJKoYqK 0EylqFgeVf6e
lhgaIszJyZoc9Jol5WFx2XWSKQib6B0RQsYh/F+Q2A4ykqEnjEcRZeg25wHn AeeBkDwARxhG
RMgLLXkvbOTJEAAhDdqbPMOrL/ENwh2kuLAUk9mpKbo05YLbKqcHAhDh4MGD WXaBbbfdLjz9
9OWnnz6fmdb8f6tq1eqoQ8yS5u1Leno6k6ZFR0erMDU1tUS098svv1x77bXF OISrC50GpAK+
hupJ5oYjIhdqrULlwbL8BPRbCBKcffzxx/fff39YWn/rrbcef/zxtLQ0s4Gu BaP51Vdfbd68
eTCSFSATMiLcvHkTM8XwWQHGuSacB5wHnAd2PQ+EERGSD036CmiP7cYbbyQA As7zcoRQgyTA
KA0afGDO5MWYdGqHCCvz1RWACJk048gjT95nn+ObNXs8N3ez92/EiNG1a5+8 774nBGALgUil
QrF17tz5qquuKr7LyDBNbzEy/fv3Ryf5V5L5448/+HrfffeVzpOE2p599tnS 1bVaKSkpDBsF
y5IPpt9Cq1atgiH/3n//fQYSlLF1Vf/f//5Ho7///nuNGjVkA1AvGPLvxRdf bNasWdltAOuz
VFsZ9YSMCDMz0//+s2tmZnELypXRpoDqUHfJSfEuXS+8XnXanAecB3aWB8KC CAkQM8Tt+uuv
hxphn424B+GO448/fuLEiaIM6SDlgD8YQRChEmNYfomjPNeZYN+bPLOzvOHa LcoDAYgQsV69
kurX57QWkoLfrVvi5ZcvDHhQMjXvPvvsA1wTNQheueyyy9jhvItLA0ipdSt5 7733rrvuOm9J
AK3Yq1cv0u4fe+wxIBeU2K+//nr44Yc3btyYKiAzqWXGD75ylBGfRZWIuSTL H2HYa5M0JEeh
6nL1FoV1YCgRePfdd99+++3vv/+e6J9+C5988okwK/qlxMAZVhmP+Nlnn/G+ hFhycjLvTuwQ
w9VRaxFiVSWMUhXtZyXGAtLKa6+99oV/e/DBB2UDJYJ6qJIGlMvb5igOvfHG G5CLalqnA1Ml
j1rJY57ZoEIrIfAtmQ8//PDpp5/21lJ5SFvIiJCo8ZSKjRqDQZnIWpNXu815 wHnAeaCqeyAs
iBDwB6TjweD1xurVq/fff3/AHxQFCzWR4oJY3bp1NbUqT33m1WIIHUeZRQGO sHTLvld1/1cV
+wsiwr59Uxs0WFKo/T17brjiiqUBh7p27Up2E+hfQBBEeM0114CiKBeP9fDD D4PAKOGQSpjN
FywFbOrSpQsTrrE9+eSTXlD4008/ATG7d+8OuzZgwACwIBN08GaC/n///VdV WrRogVqWhDjg
gAOkFtBDJJdaVgKdScm3334LbBo0aJCVUxdIBOrikOqCOAGgAV2D8Ab9fPXV VwjAz8Ecffrp
p4J3bCAzDRul7zLp5ZdfRi2vT+3atZPar7/+umPHjo8++ihtvfLKK3B1yPfp 00fyr7/+OnAN
6NamTRvJ16xZExl+cW3btpUM7Qq/gkfxJHAcePfEE0/IBvZFnZonEQNEooFo tXSCpwGvkIsU
gucQQJ5C6YfCBCaC+T744APJH3LIIUB2QCEaJAMQFNjFAx06dEAGJXjGkGJI V3vIiJB4REpy
YsHM5ZBaDUmYfqYkJziOMCSnOWHnAeeBSuuBsCBCcrmYM8ubGkh/KWTKLZ4u QD2YFTKeiRcz
0wKIEFzIPrhQnCJMIcDRRY0r7UWCYQURYe/eyfXrLyzU5u7dky6/fFFBRHj7 7bePHDmSESdQ
cQBBABzEIbFj8VhEWsF/ADsr+fHHH++++25kLrroIuZfYyP66Y01gwjBgkOH DgWlIfzCCy+A
CEUrgtJUBXoMhNStWzeQohoCrDz00EMYcMMNN6gEMPfII4+ARJEkVA2AU/mX X37ZtGlTyrFZ
JTB59MLbNTAQ1bmkgUoICB4A3cC7XORsZPUBsyjkapdJLVu2JDz9ww8/sJ6Z 1AJjxBGCETFY
AwmAgJIH2AEiv/nmG1Cd5MF/zz333HfffYepkqFHMILU4hC9YOedd97BVNkA fKScQsCZ5JFB
oHXr1nTQbAA4gonBhfRFNgD4JE+OI4UgXYyRPKiRroF3mQVFMiB+umbOQQau FM/QkBHAwV/k
ISPCih9Zsik3a9rk4YXy5MH300k6DzgPOA9UEg+EBREyiIQZEgLWTAIRQhxq Ei7YQfAfTyYW
5BQiZAFPsgwVKSZI5xBhJbkeijIjLIjwiiuuQD+z57Jww5AhQ0CEZP6pkA3g xYwZEGmWOwhB
BSKE7SM0rCnbWL4BCs2MBBGC6vgKWrr88svZARcCkmDafv75Z1WpXbs2zCI5 gkzfq4oQfuAb
MKLWj2CDnwNOwZ/B0vFpmE9IEYNt3DScXMA4zk6dOoHkILwVntYG2jOiETxE CdCqffv2Mgmi
EdoPPAcitCp04dBDDwU7igSFkKMtyR922GEoAchaiiTkHPAX8Eq2omQYYAp+ pSIoTYgQtHfQ
QQeJzwO3UQIpCKSTPG19/vnnwFAQodkAFqQtYLfoRsDuRx99JHkYQfTzFWdK /vnnn8cqzCZb
0Wyg46ZNvcAzVKGitzyY/ZARIbA6+FXsgrGgUBkQf2p61sqYpBXrk1byF5PM J/urYpLTM4ub
tSEra9PChb7Rczk52ePHjycVVxsTSvPGXEmIRl7rleJT9o0e0Ttu+mVXVeU0 QITw/KtUZvNT
JGcrLCYRsCidKm4oK1asCIsNTkk5eSAsiJCIME9xoJ7XSCFCjTVmiDFPLC8i RNiWXNJyTY4j
LKdTHBa1BRHhwIHZl11W+HRx/fplXXXV6oB24eQE/v766y8ILWAZaA/8R0aB JIFiQDRCpQor
s1EFGWg/oT02aDbvndYQITIK5oIIQXtUhKJTFUWWwX+G6oBiqKXEkB+wBq6R WkKEJgljB2CC
vLQBMcAyEgS9XQOH9O3blxeeZ555hitcWArgBd7lHYlNz3qiruBdVQSfEY8G htqYGAoJuT71
1FPEsh944AHunGiAe5M8cApGEGMsEo0wiBDIaCXcpZV9SKBWI1QgBYGzskF6 qEKJ9jkKI0jA
1xsEh4kEDuJDmEKeILCVdpRDaKYXNmCIEhAh2NRK6LtxgSBgvIEAnsG9pYjl howIfXmEk0aA
t7ynJ+z7zD7YY3hUe+a17jO2Q99xX/cbz6dvmus+4waMnpPvX1a40G3x4qza tWfNmZOZnh7H
mzE3RG3c+4qacZB74tixY8FV3C7J1AZchwQcqc45AG7KHtAe+afFa2ApPOwp xmnolDFsJAQU
Jcl9H7af3oVrtFTYz2PxCuHneWiVulF+xhdffHGpq5dYkfsgS9foLAQJPfkR Fj9xQ4mNmgCv
htw6ee3mgpQNQeI83jiV5e22SuuBsCBCegco5BnM666iVNyFYP640ZEExlFe O0GH3ElIHNSC
7NyaiOIxlyrCgACmZXWIsNJeJBgWgAiJyX711dQLLhi6fv12Ykz25+VlfPll ZN26/wSMAoFp
I/grmT///JNBwTws/vvvPwCWrhnuMzBkMIJW8uabbwLOmPuQ2wgTG7Eho6EP 2sB2RjGqhPse
NytyAa0KsAYqDsgI9FRDwCCIRm7aQE+VALkQE3aEmFTcmQ3oRl2ITEyVJKDK C+PMElAXlzFs
HPCIDFpufQHTMWIqUFW9AA4CNElthJiUWrAUMVlBQHIKCcjC3gFPJU+XAYtA WMg/ydMKgWDA
K4hNMpCOIDzBODb0gNgCprOhO0A9ydP0Sy+9BJOKcukEU1JCo9QFjwrwYark 8QBqoQBpWvIo
ZxgNcWGTIRQuLhBciD14A9QbEDoI/iIPGRH6OMKk+FJgz+BtQjIpNaN1D5a5 C5yVuqhyU756
dU5ExLQaNWbMmrV98RKOgjxIrwnIuVEtaGcWO+bWufvuu2vNkiAnJlR1NPMz IxtXX8EQNFS8
BmaI4LQV4xBQ4B577AFXz4Y93McLFdbEEyE5tpyEiVJxsYaqnB+z3a1CrYs8 NxcWjylFxSCr
cDvbe++9dRb4xQYDCrkzKsO67BvBDm6UvM3vt99+soHbUzCsIbdFe80tixm8 +xJ2LIsGV7co
D4QLEaIfBMA7oaJUzD5DKBnKRzc6XiF4zHP34HqYO3euonUQIdzlJM8zOKR7 nTuhFeyBgjNU
a9LBBg1ujIqCicjY9pfdsaNvChg2i8nKVFAg1KD2eauEiVDOGc8OXQNKtmMD JqqETdPBDB8+
XF+hyrzXCfftgNlSGH2sMChRaVMCowYxyTgnlYB1EABOWQnEGCUEYcExpC1y f5MloFjgDjtA
TGgdNh6vxcxuA/qBYINLwzDrjp0pbuNmEtQa5YBClYAC2deAEja+Aq3IjzR5 UCzl9E5mENtV
9JZeSAYMBxaykDGHYBDpTsB1QozbdCLAUUChSugs+2hQFRQSNO/Xr5/J8yCg HA2y4eCDD1YE
H7BrvRAew3gAbqmxoAwIGRFWzFhjIb/MrEAmcu36GB9SzPNlXxa6gQj32isq IiKyZk2Ywu3V
wW38GApFhNLDfRMBrzchDvkJKShDtqaRduTieJumIsP7ubcKtyFGpo4ERO14 oZJKgPy8tXtl
ZsyY4dXJ5BEG9dg3hVCPXuKQsDgDBmE3Vd2OkjPOV3gCnuhYLoO5aFSXNw++ 4grrkUrY6L5k
pNC+AmGLcjj6keeqhUiHVCMURZaSuqxDbEagMvmFSuQr7gLwFvqKPUbIGQIm IVfyFmSH0rAS
fv/169dHjyYgYMfkjXoEqkoeNwpOWQnPTnWKpr12QrwL/PFDNcKPF1nlVpMU ImEDiLRuJRZP
IaItp/EKqKMG5jgvKoGqUcQBIlAlNlMrtfhtEyzgTmcJNORN63bPAD3Jqzob bKtKAAG80Ot9
GiXyJK/COgqlJHnMUwl0tSIO5joLQBBg4o0WGV6+izr7rrx0HggjIsQAntaK UgUJ70ISLl0H
Xa2weCD4Gapr1y58huqCZlj8yhtdlZhKvHRPQZmi+hWgVkp4LpDY4FUCHmIO 7RLVShs3Jbht
NtAeBF7xLi2GpSqqXwWrqN0Aee75MgNQa/mU3rgw5d7cxELtDN6GQs8F93zZ AKAXrjU7rbmw
8HQhI0J/HmFFcIRte42JS4gfM3rE8OHD/vtv2PDh/44e8c+cubMoz8jKYfQx 89GQ0ej79MxW
uA0RTouImHrooTPHj9/oP8W+AEqJiBDgBYhBGNDwzz//8OYNMUNQhro8/vfc c0/l2FLiTUkE
/dSrVw90xRrH1AWaAOag99EgaockXEI5lPz9998qgUREOUiC1xEwDRtku5cI BL4wSFBnGv3H
HXccO8jzwid5HvmAHg4BRlEIGgNn2FGuTo6CFMFbwBqYZ45CwqsuRwFDQAF6 JHsg/ClBhtcp
lfBaCbwjUUNVeD8rmPgovMi7C/LKe6A7mA2hTU4G1eHwpA1rwabgHlJGVEJC CSUjRowQAQZt
jqr/+7//01EMFqRjIJUMgKJDHp0EFyTDexgvoCA28BzvVWLdwViS5xUWBAZO ovuSP+qoo4BT
ICE0SIbRW8hQQsIKVCUyelnk3YscfHYo1/wFbNQSH8moPVXnjRYAR3V4QTUB OUeIAQBHT4m8
6DWX92zJc0cDrnGPIydG8kcccQSQCwCKBsnwai5aDvCn8Ad5yvhKNnAzVWCF V2fJk2UMKCRm
gZh0ohz7CXPQEKEWHIs8yFvyfAXecYMju1nyzKfALQbsSIuS4ZZnwJSXY2Rg CDg7IMW0zPz+
k+NZUDUxzU0FZffh0uyEFxGWxgJXpyp4IDc307uKHekBZ555Fn9PPvkUY1K9 f6NHj9WhFi22
Dzvd6V3s3r2HMX8yhjtk8Bb+9dcgJX298+67O7EvPXr2lBlffNG6UDO46xI9 LlcLeZDJBl7U
y7WhkBFhBXGEaZkd+k9cvHTxRfXqnnXWmfydeeYZV11RP3LqpA79JqQwnnzi 8NTUZGZGTEtN
njh+GC/JcpMHEQIKI6+/fgk5ppSXiAiJqtgoPDgzi/xSDhCEvgLnCYNz1DuP F7CMoDP6GVQF
8oNdAyACZWB0ZRIUHbM/gMCsBPgIBAHvAyL5kbNxmsnpsTPNIcg/HsOwgDyV 9f4B3CFDSPLw
21jFUZpWLfCfaSMZlksHS/baay/lwKKKeWtVF2AB+UyJ1SVeQG4HcQSDoVQh j4QkdFUhu4Ko
uvdCBMdAdwvoWDkaCLMqfAAKMf3sA6OByEJabKQ/AuZoAg0qgfC75JJLtA9n Lkk4RRkAW0b0
HEht8hwVYAWAmg3Qk5KHhAeZAYItXRqenxRjQCQQRzK82KGTtjjX3vAotRQa IJwhR7ERPlC0
BQBq1QHKBB0s/YWjcIR85c1YIRI23gQkD64ivxgzCO3pEPcRSpQNKRmSRRR0 5hwJESJDF2QD
nRLCA3FKnrstVbw8IkfhCOk7CE9TW7GBpCUPUCaqouxyHSKyQ2o2pDWv8pIh TyUg6IyL8DP4
ctzU+Z8PWNPixyU3fTSn3mtRD7ZfyP5Pw9f/PioGmLgyzq2HJqeWvDX6bM66 xIz8/Bz35zxQ
jAeys1M3psZ4BTbl5/r+NvFKtuPfZn+5/69SubSgPcFbmJeXnZOTyR892rwZ Cnzn/F6CMWNT
OduWl7vVFXiv/FxBKHHQ1ITQ1jWuII4wLZPocFx8TFpqYlLi+sT46PjY1etX L5o6dWKbHiNz
ckuMGk8FDt5yy1IbghISIiTeZxFk9sFJYDgQmIIymsdLbCIbiFBQD6TIDgiS BzyIEAwrCpq6
AAtKLBAMvgQRogfEhnI2BLyDjzikDDbYQfCKGgJZeuV5tPP8BmvqKDq9R3l+ gxftKHgUhdYW
eAWEweSWqgsiJFMYPGclFAIxrQr4LIC0J6QOnMIAL7UJdwUalk5QoOE/9sFJ 4D8bCAIiBPpQ
YomAwDvbFwQBxzAzgmzGD4AYVmQyhEcTfGWcP5AXIM5XWDEIS8kDjuEpIU0t AxooBhErVlIy
mErOL2cH5AqphossCKsuYBJzGYhLU8oLbBwMnKqD4EFj4HVNxKCN2RbI8wB4 CWLCvZHkK3lI
SnwIS+odQAe1iZG0IhmuCsA3FcH0GpEHT0kfZQOwmBLywMCLkmeKB04lMNQ7 lASIDPMnShJ5
QsYwiJInHYfBbt75F0CEXEigUlqRDOeI9w3rETvwoJxowCg51N7yxdEZAEEQ 4bdDo4GG93w5
H5gI+8V+u0FrKZ+0KHXO6u3LpnnrVvP9hp/MWrk+dmPqevfnPFCMB9JSo1NT 1ppAelpMZkY8
fxnpcQG1ijm0Ez2cvjE2wNSMAiXFmEf1rf3duDN/LCWa4evUxsAzEl6300QF uGLLlqy/psSE
hggrZqxxUlrmZ12Hr1g8a+XCqYtnj180a+zCmWMXTv9v3KjBn3cdkVNsHuEe e0yPiJhy2207
TAJCsKz4qLGXIwSQKVDLRryYiuAtWDeVENCEqyuICAEBhEd55PNcB17AI0oe TAk6JBDsLREt
5CXevGOKoQNBANTFKpCTDo0ePdrQodQCy8wqopmmDdTOUeR5wMsGsJcxlBxF LSjQ8CKRTXI7
QEvecSrAO/tKgFi5id4NBIx+sAjgEoUcooqhQIZEmG1CciQdG2sIV8fUBpQb BiVgbWhPE6jC
1Zk87CAULODJO7hYk12BXPnkpIAjAdayEMSpmfoNZaIfU5GxaRdg72Q2G2gb EKlF4kGWwnOg
sYBhIkAlL8TU9Ao24QJVoN9AqLCh8JGEpGHvbJYvaH9wJ8Sq6QS6gQhBsRab 1krt6IEaFPUI
4WezJ8hU0aXaxx5i3yA879QMxNCBqngAapnEQVCvTfeANpAitWzgHuFjECG5 zJYHA+q1DEsl
F4IaOdGadqvEbX1yDjCx57g4EOFznZY2+2YRMPGa92YBE9/qsZLCf2cmIUAA ukRVu7CAixrv
wic3jF0rOPtMGJU7Vc4DBT0QctS4YsYab0jPbtNjxN/Dhv75V99+/Xr269eD v/79u3fr3bt9
7zG5+UXOPsPABjIIb755CfPjjBs3Bt5LG3lgECqauLXQDXwD66O5WwEE5JyB k6jII59kL/AQ
IVSVwDbxQLUxKIBFmyeWRymjvUB+PNd5DIOxkIfoIjgI+CAOCG6jBN6IDD9A Gw9yBQQxzzu6
XkNGZCcVCbASR8ZCNEgesIJOdgwjQlVis44CRGAcQYSGEaludQkRMvQd22zA Cvl/IDNQEfbI
XWgDwpp5JLoFjKg3H4JWgQt0lh0QoXfEjGkDcAA7QMmAG+mHA6ME4KsS+ghG BIDqKBwYMVag
HkctYApGxC0ENCUDNwkiFGQE74LDFAyVPCP2AV7s4FXJw2+BCPGJyQg5AYAQ A1tDzinlBT3C
tTjK4KP6K5ilJrAQ0MklQdajmuDsU1eQkSA4+I9uQlVKnqAzTeNqcKTk8QCn CViMbyVDnJfU
QFhAhpUoqREjvRwkJVxOppMAPRmfQGc+pZMUQKpoAApYE7yo2VClH5PgL4HF XDySxwCSF7EW
bCoZSEdxgVCM2MPJJQBdxlsn+A8UCBYEEYILQYdgRJAiO6BGCpWeCJosY0NV pbpDhFXlTO1c
Ox0i3Ln+r4ath4wIK4YjzM3bNDpqWcd+Ezr0G9+x/8Tv/ozs2N+3/+0fkybP XbVJo0UK21at
yrnzTh87mJgY652PUKilmIHZMDqgB60Ez8bQHig0WC7xKzxomcAd3o6SgKky CVnypFdAGUqG
RpWGRbROqaCWlUVuvkowRul9mjmCzfK61Drgz+bA5CvYUWFBHtKS11EyBb1j 8gGyOgpi4Cio
znsUvKKjWnUHjCgxNiLaKqQvktH066AufdW4jWI2sBrgA3BsU3EiDEZUdZtv 3Uos3RgjESAi
Cf4jnit5W5NH1Cwb50ITImC2ShhZQqM2Sxa0HIFykKXJC1GhAVTHBqAXmQc1 Kxnl5IGK2OeM
2CAyAJbMg5IsOMBN8myAUSEnsLVKGFnCtF42/QEwi8w/Mxh5TaPPW4FM4kVC p1XDmNiYaIqv
NqaYfShnS0k0/4O8zQbNj4CpKoH/g2G16Q8AhQBEcLDJQwoijwbZwGuSTi4w UTKEmNUQ1GNA
mLj4a6AUR0GBRJZBhEpPBCdZeiKRaKUnEpsuheZKXqX8ECF3MG5lBUcdFizn 7RfJkOZereRe
3fXMc4hw1zunlbxHISPCiuEId/Da5k0bkhN2rh/BXkQV3d2z/M4ChJ9FscPY CsONAY5sAB0D
pmHUXwpVsJIyifgvjGBBDbB64ZrmuijzeOGRDWBHrbxZeTalJwIHlZ7I+BVg ImNZ2Ac4Ah9H
z0tBoPIYXApLwosIea0iHZaNNyJNs6U1S7QxYROvdkyPEJA2o5JSz1BN2gxq 1a6aDsYPNGcj
2YORr+YyDhFW8wug4rsfMiKsGI7Q64iszPRJ4/6x0cQV7yNaJJuQcGFY5vvZ KfZX/kbJawyY
9TQsNhMOBmiyiRGsDBv5lDLJppUKsIpxHjZpajkZDH8pG4wRLKeGwqWW+W5A gQSXQYSvdl4O
OgQmNnhzpqUnciOrQumJYUSE5C3A7JKtwUaCqWa/9767ErggGgBqBP+RO2tn BGRGfotFRUI9
U0BPRp6R/aKmAyZGLkoblLklloTaYjWUd4iwGp70ndvlkBEhqCgtNcVho517 2lzrzgPOAzl5
myw9kfFxlp7IcBalJzLApXKmJ4YFEQLmyEAgzRRGkBsyG0CQQDCj4sgHJV9C c6RD5pFPIkZQ
+A9Kj6OMtSKTmMFMQEYq2iz0OirOjzQbKvLVSuyqI2xiicjeS1HCNik9pKBK NCmBhnCRpsJX
srpt2nb2SYlhaieGAGrom3SqbrhWga9yPxmHCKvcKavqBoeMCDMz0wcN7JKZ WXHJPaToJSXG
lSJiC61YuopV/aQ6+50HqrMHmPJG6YlMgmPpiUyOY9PiABN37rQ4YUGE4DwG ljE5pfdcg6iY
zAiaEPaOwftALuIb5LBq/izwGSPG2OEoBCGJ0aQss0/OBiPPNJ0nUyUwMRPj 3yERaQIiUNoY
2oUquw9TkSlO4fy03CopyKA6ECqjsqiONiUpMqMTX9lIyAbzAQTFLJIJ7Z2Q i31kGHyGSeTO
kquNNuIGqquR+9XwknaIsBqe9J3b5ZARIWN4IyeP5LPC7CZqHDlpBGuThNpi RsbGyEkjN22q
1vNchOo0J+88sEt6gAm0bVocoKGmxVF6IvyipSfCO1ZA98OFCEF13kAwlgPa mGGA9Ydg2qDW
AFjQckKEYDWgG2hMnCI8HGkDkHmsXQTaA70RCIbAI7sUfMYcC5p1CzgIjkSe YWHGMtKQRY1R
yMawPASYIQHESXUmT9AaTmx8ZWPeJQwAQYJHoR5pzjtpP/schXdk4SLQJEcx GG2qy6h/RoZV
wHmpbE04RFjZzsgub0/IiLDiR5bAEXrXqQv+lMARBlORN+NtgZKty/t6mshV 2MJW/g2+dSfp
POA8UMk9oPREboKWnkhuotITyVakUOmJYV+1LyyIkNkDbN4r87MQoabZYh/4 BQpkAgQhQtAh
CE9zbIEXQYSUkNgneRhBZrlnEihqkZsIjac1OTWRAggSStLyDjkkVRawRqGW +lR1MKJYQ5UA
XjGDeyn7hhQtpxDYBzcJmqSiaEj0gw5NW1GzX1XyC6yM5jlEWEYHuuqheiBk RLhTRpaUjiPM
z82cPmVEiR4hOMIkgmw1ax41fHjKiBFp2/7Su3SZoUOk5rjUyRI96QScB3YB Dyg9kRHNIEKl
J2rVPmjFcK3aFxZESICYOdXBUl6fCxFqrDE0HgDLiwhFvEmeGK4hQuE83nuN 2OMrEV7BPjtK
4mAAIvTeFVFOHFnKKac6tlkJeYrEf8F8NoUq+8b80bQQoU2qD1VpU/ornXEX uLRC7YJDhKF6
zMmX0QMhI8JKzhHyepmyMXPZusSl6xL4XL4+ybe/NmHF+qSNmYVHuslQEeyL iKhx7rmsWbfo
vPPm+/+WnXrqEB1g+a+wIEJCPJbBXcYzV/mrs/qZd427shjM4hmlU8X6y9U2 Lb0sDnd1C3qA
1MNwrdoXFkSIhUxxyto2zDep6CoT6ZPPx0z7RI05ypUP/AKoQcURrgXb8SNi PDID8BFmSLvi
woA2zUEDmmRed2AZVZiMnanXdVQoEHQIJWmIEKAJfLSlm4QgqU78l+oMW2Ey VO51lNAWJUSN
CS6D/MhQZGp6TGWfYTGynBV9CHCDAg0vIsBRTW2Dqd51GqvPxekQYfU515Wk pyEjwkrOEWZk
5XQdNr1933Ed+o77ut94/bXvM46SAWPmMBqvoN+jo6PPP//iffY55447mC54 B4GYGGaQvohD
jRvfWRARahidBZQZKMcdsPgRMNz7ePEtBlwSZ/EO60NnwVF+wV86YLIACiH4 ugGSsA7c65mN
ma3ginaFqmWqZ3vjL3W7qtizZ89LLrkEPG02BMkZsMKHLWRXRhtcdeeBgh4o ZtU+pSdq1b6A
9MRwIULsYSZ8qD6bfQZUx1I63Dc4xKgOpscHqIHt+L1oav34+HjNVkM4mBEb 8IiUK47Mtm7d
OpAZR2+88UaNXCarT7CPILXt8xXoWXDOf4YtyxLlAsoGldAchlEiGc1W4z3K JPncS20+f44S
xVZd4GApRhbuAperQ4S7wEmsWl0IGRFWco4wLiW9dc/ReZsC08PjN2ykPLeI BZEXL950+ukM
oyvk3C1c6DtU6Enlngh9ePjhh+so77K84CrnpqiNuzORl2IQIfdEdPIuLg1q otBZHoK5zniP
L3G5kRL1AHxJNmJNEZKEQHhayzgYQMbiGbbQcImtFC8AY8ECwcypQWqRbCDJ KRjyr3PnzrZc
clls4ElZfcjdsjjK1cUDWrVP6YlatY/cRK3ap/TEGz6YXX2W7HOXRKk94BBh qV3nKpbOAyEj
QjjCih9rPHXyyCDHGsenpLfpMSpr22J05pRV66Lb9ByVV8SCyPPnZ5922gL/ m3DgNneu71Be
XiGHgHcsbcfLtGhC4BdxGckxbSybl59TCeveEjrxyhDN8aomNMNibrxAo5zQ D6CKV2TlYsPS
SQmsIV9hEwm+qAQwSgnEgJWA4VSFN3vKiQRJUuVspOaohGXZioJ3cAMIsCox K9RBDWq1XzYW
54VIYIcVQaQEs3WIoJJK4BH//vtvVYHbUzfhLHXUiFXICZUQ+QL+IgMAVYkh MCK/HTp0YNJm
1j6+/PLL1VCvXr1IS2KHJUAkb3OY0V8rgVxUFeZdk5fgSHTUwtCYpxIQJxSL 19UGOvv37w8O
RiYYGOo9oW7fecA8YOmJLOu8OsEXqHWb80AxHsjNzUxPi3Uuch6oMA+EjAjh t5KS4sKSVBdk
J/1jjZmPMKhZIRJS0tv2HhOXED9s2NAhQ/7mb/Dgv/8b9ves2bPa9R6bmZ3D DIUAHX0mJsQq
GDF3buZpp83Lzi6EJJw923coJ6eQQ0BAQAkY66ijjkIJGAjoBggDCUFiEcoh hwaYQgnATktE
kLgDlgLqsbDsFf6NKIl3IDOQjignUFLTRhBq4ZMoD/qJ4KgKiyCD4Wh99913 l1oQJCUgHish
agPiAWYRbAVBWjmBHsqZwwyopLpkmhdcPk54keQeDj322GO0Dgq8+OKLdcqY J4yOsANok0kP
PfQQUAnU1aVLF6lllWEW+QWNgfC++OILrZvM7BKSZ/ljyTNLheTJSSJNHsgI qycZ2hVUZbI0
NU1yEtNkyAYgmkLSxJElz5InhMDQwFwV0vn2229DLgLZOQUsEKJFkJlxTfLN mzcHLpOhyAK+
kj/yyCOJoAFAf/zxR8mwwLFBQJyJDJbjGYFXtzkPlM4DjT6bsy4xIz8/x/05 DxTjgezs1I2p
Mc5FzgMV4wGGhA2amkC6S4m3tQiT8HGEkyp+PsJgOcKEDelf95+4aPHCevUu POdcYNU5oLTr
r70ycurkr/tP2JC6YerkEampKQxe5nPS+H8FbUuNCJnoS/k0ID/gDsPlAChC S2wwZ2AIQJ63
RBOxkv0NI8XWsWNHhq2YexFGAG3kZTMlGOScZm2VgKp8/fXXcG8gG0NyZGRT wqfl7ZE8jh5K
wGRUwU5pANaAruAFTSf7Qpy2AYk6deoEHnrmmWesEBhEL8SlwdgpGA1wlEmf fPIJWI1DXnA5
ePDgOnXqfP/9908//bT0gMIl/8EHHwCXQZnGOwLdSDkfNmwYrUiG9XZlJEBQ uYDIcDZlAygT
SEchiFPyb775Jjj4zz//bNCggZkN8K1fvz4eA6GqEG5V8q+99hq0X79+/Yx3 JPmdKTNohXYl
06pVq4A0RKLnQp8gcq/T3L7zQPAeaPjJrJXrYzemxbg/54FiPJCWGp2asta5 yHmgYjzA4/Sv
KTGhIcLKzhFuSG/dfWRCYmzGxqSU5NjkpPWJ8Wtj1yyeEjnhy6KjxitWbDnj jJWF3tCZKr+o
QxYmhsoig5BP0XsQe6IeofeAZd6p+aHxKAEp7rPPPqAlNkAksM+aBhFSna/U AjWyQwk4D1oR
pKIqYCZy4yg3+AX+o2kwoiFCkB9ICEQIfOGoIUKmB6OuFyNC+AVwhISYGZCI jDdzDiREiFxc
msg2QsasLiCTGC4DT+mNLCPA1wMPPBASVPFc2DjGeUgeYpKsdvAfFKb6DjKj UQwmaC4ZDgEK
OcQivPSFHRDk/vvvLxueffZZSgCvP/30k+QZFAmMJrJMl82fAMQaNWrAUIrq I2QMQpU8MwpB
+OFV4x3BwfCvUJu0Ihm8+tFHH3kvDELSQrTQh8EjACfpPOD1QBhHljjH7sIe cHmEu/DJrZxd
CzlqXOk5woxPu/y7YsmsFQumLJo1buHMMQtmjFowbfiYEYM/7z6y0DxCUtl6 9hx33HE9p0+f
WeAk5fboMZZD06YVPLQ1cVAj8u655x4YJug3KD2bRguMCLwDYFkJEVsgILiH OcOsLcvtE/4T
IqSuJmVVHBkU4p27ixKU2LgN4CNYkBJDfjQKbCqICEFpACZwoc0N6+UazSTw E3gI0AYbB/cp
NKa8PdsYSmzcJ+Zde+21IDyjHhEjVn7NNdfQO6AekfEhQ4ZYo6AugrkiEaWQ UDtiBNONNeS8
KD3RxiwDDY3PUy18bhrAgsR8EfayekSxYXCBs0rNJABt+vv27QtaRadxipCy IEJoRUaxSL93
tiDlcbZt25YWBVXd5jxQOg84RFg6v1W3Wg4RVrczvtP7GzIi9HGEiRWdR+hf njioPMLktKzW
3UcMGjpkwJ888Xv08f/17de9S69eHfqOzc8vJB3QZqg+9NAjhw1j6EPa8OGp /r+Nv/++dYZq
stwKpk6SnweNR+SUs8hECQwKBrQRRBb7BXqAc2ratKnmfVAJ8VYGDsO9IaOZ XH755RcilXYd
gOHgrryXBQwfQApExdwNqvLll1+C/zSRjUKo8F6EUAVGVUJuHCUwhaBG4sIG 3TCDGDEgT2hP
4VcDVQGXI5YDK8FSUJsgQhsTIzGgJP2SSe+//z5oGIeYWsCchsUgSafAXphE TyX/1ltvQVVi
MOUy45133gERAn9NBsNIJYRZJOarADHTkgWYCrJEg3S++uqroFLaAtVJJ9wk iFAQEPthEFHF
IGXJE0cmTo2LQPOSf+mll9gHLjNbh/WrRYsWVF+7di324I3XX399p/9onQFV 3QMOEVb1M1gx
9lc5REjQhpnPK8Y5pW4lLi6O2d1LXX3XrhgyItwZ6xpnBD/WmPllRs9Y9s2A ib6/PyZ96//r
2H/iD39OnrpgdaHzy3hnqL7ggrl16iyqUweGjL9lZ5yxdYbqI444oiAiZBwD IEPTzTBVLFFO
kAT7sbGxijkCTXT1MHeJSsBnDzzwgLdEVWwDxEjANrCghmUwj5eUAHFatmzJ QBbCuCphYAcC
sHEWjCYeSgnIj+Am4MzmoAHbPfzwwxzid0u0lI3MPLGSRW0MEwaQESIneS5A BtbNTFKyoJWA
rmhL8WU2WDpy8hjJYfLPPfcc5fRXZgCUFUHGZskoLgxj5x3RUjBWi3mm8+WX X6YKWFkloEwA
omUxAgpBjcBxHYXyfOONN5BHg2wAT5PdSAm1JCMBNgaymJ5ifOUOOQ8E44Hw IkIueF6l2LgD
BDPmD/ade1dRkuRF8BsMRk8wPZUMybv89gPkMYObmCxns/kKileLeZoQoDps hSLCvJyMxOgF
cWvmxK2Zu+1vTtzqWRuT16ZnZMUnJJbFM4zMKwukYzIN3UIrbMNgLlddQjyF g2mXnB97NAcj
X61kQkaEmzblVzhHmBc8R1iKk8cM1cQiyVS75x4A3A4kYlzcOkKKHAK3hfcW WQo7A6rA/Nn8
/joErRX8evDEQKHH2BiZK/i4UzaGG8sM5rgRERiwEckNGPgSdjt5r5UNn376 KbA17PqdQueB
AA+EERH+888//EB4qWODI7c1RYrxOa9t3qyVAEnekHleKvQRro3oQUCEAc28 6zLFqSy3+atL
bJG3NVsZuUThqi5QKCJcs3j8z2+eOeDrW/t3uKVfh1v+6HjrkB9u79fmstn/ fhI1a2HL516L
jYsrdceJWbEKTqmrf/PNNxWMCHl+kfatS4iXdniTEo13iLAYF4WMCCv5fIQl Xg27jACv1GL7
bONVSWRhMBvkHIQlG3HtYOTLSQZ+TmaIESy4MfDlySefLKfWpVaxdTZjBMu1 OafceSAsiFBz
f5L5oBVKvJtYQ2UAE8QAe3l5OOg60l14pdR4ebg671HUkgNDIWy6yrVGERMF iNLTQLEAVk+S
mkgLDUb+qQRLSLwhz8RLBJI0YonFXuOlyoa1kcurErVLLcal6auXL0QMLMsn 66AAZ2UzSd6q
G8yM+pXwsiwUES6Z9V+fb+7atGVxds7s3LzZSakzZq2aOn76kDFj/h70z+iL L7+hWctWK7cB
Iyg0Ml7gaOUBZmaQQ/CV+qt5ba1Eg//0FfdyvnSU3CrJ8/6sEqMSNQ+uZBjn x9qDiPGqrwlf
mS9WRzkv0gAZoRKCSGL1rMTwHCMpJcOl6D0vDA0MwHyff/65FuNh45WetCV2 CNOpOn3XIexR
CS1+9tlnZAfJNlHXMTExOko0T/KMm1QJvDucESV4UiX6uqtuISNCqLLUDckV SZjBStJi9VzF
aFe97Fy/nAeqswfCggh5WBIT4Gnq9SRIThNnQqQxhowHHilTpJdoonuGTFHC M1W0CmiSuqRV
kdTLeCwyhjnKg5wBagAIRv0jQy3Gh1FOc3vttRdfmeMJYpIdJhAl+qwJ4Un5 QAPPZiTJpWZt
IQTYIJwI8lJCQgtftZCdNgAB2A6Epw2EB55j/Bl62JgZCuWIUV0lZAyzD9ST KjJhGD9nfKHm
XuWBzeA2ZjmF5sQzjDZTXRBAwbB15b8CC0WEC2aM7P4NeURgHdDS8vnRs5v/ +G+L7/588qMf
mr/4/k23N7ns2lu+aPeVesdYOk4uwVxyssE0pLbrvMAdANHASUw6qxL4BUqY nIFrg69M4MpZ
5srRUbwtUEiatVxKAg/yICey2CXz8ccfE9LhFON5MnaU4UOqt+RF4GEDE65J nmnXSJHSjLCS
IUTD5QrohGskOQoZMs69p4kmAihMEKHgHRup3rqk6YUUkrwEBERhmzZt1Cia MYDuYAmrHijR
iJkuJP/KK68AIkGKoEbJH3bYYVgFEm3durVkSCUPhoms/FdXoRaGjAgzM9P/ +qNzZmbgW2n5
9X9j2oZBf3TOzd268mb5NWSa8/JyE+NjHAatAFe7JpwHqqEHwoUIyXwFRXkd CO4BJqqQfU1x
z1pK4hFBZjzkoAYBiJBDVhFABrrica6J8WGJgGvUUgwano/AtEV+gW4KOrPD EDfkAXYkCqMB
wMEgNoh/2hVrgB7wJSVoDrijwgLuvffeeu6yAQ5oAlXoYQNnQCvKQpUQH2Si BjCfd9YtYxmF
CCEjAaPKEsMk09a+ffuAHJsqcdUVigjnTB/5xdu3Ll3yz8IFf+lv6ZIhk8Z2 mjHpz6iZ8y65
8sY27TtY7xjeB4BWDjST/9tcDXCBwHetDiphYDRgjhJyD1QCWLSZuZi0X/ta AYsN8MRsGKwd
xQuDNQdHSNQYyPX888+rkEtR8sAvQCcTlgm0sTHOjxR5xgty4iRDfjw6tWxB oaiLySWUgG5b
u3btePOBfmZjCgggIIdYgkEKyUSi71xL3vWyAZF8BSMa3ATXSp5cefRjPwMQ 1cS7774LIgSz
gkQlg4WGQavEVRSSkSEjQkaWTJsyms+QmimLcFZmBi2GN6+leHvS01OnTh5V kTxoWfzj6joP
OA9ULQ+EBREq+BuwkDosGjBR+I/9APwH6wYyEyIkgIgMn+Qf8wAG8wHmkAdU Qc+A85AhUoyM
kB/YTkPQIBE1dwE7VOQobCJq0cBXuCj0G/5jH3wpRBhwjghtB0SNiVGC59DD Bo6Ex6IjzFGl
EvoFQwN4NUQI5sNgqWUCLBK+vXOyoh9S07TZKLcqdKkUiggTYpa0/eiRT999 7ON3mvr+3m36
yXtNP37z/rHDOs1fuOTHn37zdhAEZvOzgggN/zEJg/AfRK/kwYiEXCkxEo6c Qi86BOqBnICG
cikrdYG3QIRe0g5K8uCDD+YaULQXag16UvKsCMW8DdjDnBJqEeAFRoTPO+CA AyRD6g6FnEr2
oRi5CC2MW9RZA4My661eKj788EPE4LyZI0wKGRIKpce7hHdCD5qoWbMm6y8I dBIyhlw0eWAi
PCJjRtUi02iAETGbeW0lw6+DOUOq0FUUkqkhI8Jdb2RJQX/BEfrHshQyVY1X mLcfhq96N+5Q
JqCjzB0T0vlwws4DzgO7vAfCgggJh/GQZqSF111gPmCi7l0E4CDGhO3EGjLP qLAd5Jlqwf/x
qNY+mWHgMOQNERKDlgzlhgiBgFrAnR3QHhDNO06FQi2/KaiqOfkh9gqOZSmI COmLTd1KF4hc
c0e10XLgRcgkSmz5eHhBY/4AnQGIkBRkZjBQ1zDGO99+VbnACiLC2OTsybOW L1yZmLvj0yk5
NXPxqnj6lbwxZ8mq7UshA2UMBcLgaqp/Npg5kBkztBlriOQtt9zC/KyGIEX4 SZ66cIqKQasE
BAlsQo/xiBSC/xiFSbgZuEmU2ZhFDoEvYQSppURDNo6CCNFsrCFRbKUKsBGe rl27NskD3pNF
PDeAOwTMKXfQNuLdJDboKzO1AUNBeF49AEfgJj2FCORHxIJbdhT6EEYQRtnm AOEoiBAmUtMD
swFzA7Ibva1X9f2QEWEln30mLOcjPT0NVrJEjpAsCv9cMHWuuqreFVfUZR8u OjNz08SJG6Oi
MnQ04IIOi3lOifOA80CV9kBYECEegEGBoYHkU9QM+AUK5PmqErKjiJ9qVIfS DcFYQC5woVYY
Qp5nG099XlwBbWACyD9CtyBIPlkESIgQKAa0AsAJRwIQFc9lB3l08gAGzKGB uaJ4yiIJjBMi
ZB8AB0ykRcCcd+1HAnA04T2P5AhivPL3IbEAEJRomlI25atRgioNUkEb8uo7 tA33W5ow6EkX
rC6woypG+gIQ4ZqEzFbtRl9490e3P99lwMQYr+umzl1158tdB01a+9YPY15t O9AOEYG1lQWY
/5/nkdwFkCKMC+rimaUSwBAhV64K6DS+cmGQRQBpp6MAI6bu0vyvOh1UB/Yx wS3XmGQYjAIi
FABl6VEoXmaQAEhJHlyFZhhfwJbkmRGWaS6wCmQpGQg5qDsgl74qYuvtJitI BeQRUmKAUpJA
TzIQpIEoMIQlPwSMUaP8QBhrrMEoQFKGLdI1hldKHnsgPjGeHcmjgQg4FzZ6 JEO4fBcegxgy
InQcYcFH0fTpeQsXbp1Ae/78rIiIKcce6xthVxU34gIaplfMRk5uiTIV3Hei SzCyPOEKtksQ
QaMU3eY8UEk8EC5ESHc0+6miZnpY8vNUiQgeMuVZtkdZg9A2ehaSa2/yPIAh DqWBpzskDU9x
IsKgB+UREp4G54H8lIwFVhArw45GijD6UtXFzSBPXb1RU0vCkDEmoLMAaVfw hRkLpcoO0YpK
iDuLuQF58FXGaF9HiQtzX/IiP+VNsllaWCW5AII0IwAR/jli5q0tv6XuwJGz bn/6G1OyIS1z
/MwVr3T49//ObdHgkQ4Dxy5fvHIrTchaUN7ZJID+cohl48GzqsRWfmcQOl9B Y6A9jTJh0wgM
NiCjORyMSAlcrEoY9gE7SC6gJMFVICcglMkLSCEP18sGma1rA5goGdam5ytx ZJ1QbAhwVME8
QkrMchNm5SopJMiLVZQzoaxK4AthRmU5G6CQQSQMjTJ5vkpeRhJ31kS88KOS AUwHefqqoljI
iNBxhAGnuUeP5IiIyfvuO2P2bF9ezqJFIMLI004rDoJwd+Zd1sLNAXGfoi4j smU1nURZNmj5
4meCZaxfwZnDAlpkBJ93Umul8VpQhib4WmoQpokAQuojjzQyRXgKBiQdSwm3 DNKPQlLohJ0H
ytUDYUSE5WqnU75zPRCACAcMj7q1RUdMGjp+7o3N25ttsxetrf9gmwvvbb3v Bc8ce92blz7Y
9n/tB5bdckjZ8rhz8jYi+g2urtLO/8pjSEaCHXdhRrDgRRIyInQcoTmRAHGP HokREdPr1194
/vnzjjiCF1Sm5s/ebbdpRx01+99/N/C10J8lcix5p1Ux2IIMZ/AyZ2kxpf61 8zJUvBJe8jCp
eP28d3plSASmO9AMqsWviK9agKQUG90MdXUQMqZtbeKCLXrzqUthj6viPBB2 DzhEGHaX7pIK
c/My09O2JwWOmLKk0fO/TZyxrH33sU9+2Dc5NWPxqriUtKwlq+KTN2a/+d2Y sxt/0ujFzqNn
bq9SFrf88cfAp57yreEZ3m3IkKGMDWJ7++13wqs5jNp69uwlI9u0+TKMaiu/ qpAR4c7jCMM5
h37xJ0Z5hCUNLCFN2xcgFh2YkpIPNXjGGfMWLszafffp++0XdcYZc2rVmjVj RiHT9JCLDfkc
YAOZ1GINjSFjlk6VII8w5aTv6CuHjOqDooOf45P0IMYGAsgQJmSjuiRcexuC 84dI95YQJpYk
aTeUI0CmkUosCItabwkkP/klpoRklIMOOohIExEitJF9Qh6SEpCZa0oVlT+E kYQtVCK+E0LR
StQjYl7EiUh7CijnENyq6hJ3oLNmAOEJOEtiHKS0U0iYWGKaHdcQoY0EkhhN SKwqppxX/juL
s7AYDzT6dM66hPT8vGz35zxQjAeyszZsTI0xgeT0nHa9Z1xwx9v3v9F1cWzu yMlzXvuy9/jp
C95o22fyzIVN3+68Jjnv54HTXvi026b8nLI7dvMmRprnl11PgAZs27w5T3+b NuWGXX9YFFYJ
I8PSU68SgMOgqQkf9il53ZcIu7vBESYmxJY46iKMzwMuSVrcvHlrol4YNRel yjfWOCk+Nzcn
MSHG8xlr+wnx66m7aFF2RMRU6MChQzd06pTA/gUXLAARsnPhhQuWL+do5PHH zynYCkhL2E4b
UA+oROICEzuxkSsj/ESKjEpIgoFWBEIxXyjDAEl9BfYZ1UfaB/gMJQy7Y1w9 SbXALECS6gLU
vLFmAJ+ReTIMaCVJ8ri1tgFzSdAKG6k8oCWBPMmQn0sJ2MuLCAkiM3wMXMgC xPCFfALmmDkM
5ShURWYEJY4MkmPdKimnm5SQqmwlylUiC5h0KPQwD4UkyTumHKRIzodKjjvu OBtARyvkJjN/
AeWaBAvErEafeOIJKpL/gUIGqVGdYXSIkUBNUICYiMRILhZ2dJvzQMV4oOGn s1atj92YFuP+
nAeK80BqdGrKWhNIT4vJTI/VX8bGWL56P72HwuLV9I20EhcWVV4lqM1Mj+MP 48OuPFwKq4SR
4eqs6WE2qr+mxISGCOEImauvgucjpMWKnY8wbca08ampyVOnjGK5FH3CGtr+ lAn/8eRYvDiH
kPHee0eB/84+ez5AsG7drYiwbt2F0dG5IMIjjywEagCqmDVUK6exMYgJJo85 IABVbAx0J5tV
TyaVMBie2R9AgXyqHMhlmXyAJ7I9gH1M96pV7Dhq2hhBZhO9cqggIgTcqxUy apmbgKCtjU3T
UgToB4FJhoH9GAwGBVfZsxNAxgQEoFimEmCcF2PQwHlSwlmzimAvzV+vikyd Si2C1DYhAlNh
IQNEZoQg6Yw2LQIYkWmxaEUok01TzJsBAFYvQIRKVKOvvfYaqe4AVvLlAdzH HHOMTW1AciHp
khJjAT0vwK0YTOBaqc4ecFHj6nz2g+97ofMRBl/dSToPhOqBkKPGPo4wsaI5 wqTECucIE0te
LHzBgkzGlAjzrVoFOmRernkaa0xO4fffx4ERH3xwRcFTwowM3pEZCBAwBc+J ANOCP7CGDIlS
CdM3AJtg74zeK3RqVpu4Ff0gTtWlIhDNbAhAhPB/TDkhSSaS0DwUBo+AayAt 0Kq4STbS9UgH
huoLQISqQjRZ04mB3oCSKAd4qSL8JcMSBTFlDPgPZhG60bAdOI95BECETIvF p018xcRRwoiG
HZkW1Zs4yJxYBh8ZZcL88mqUyTJgTEGEjK/Ew1SHB8V4otLgUdGKbNRlAoJQ fzlO3nmg1B5w
iLDUrqtWFR0irFanuzJ0NmREWE04Qn8eYQkzVK9dm3fbbdFPPZXIiWS2L/Zf eCE5JWVLw4ax
t9wSfe21a1u1Sir0HBecmhWEZ1OzUoVEN7g6BuerOoFdgBRYTUsFsMHS2cSt xKADpmYFeJkk
wkoQ1AYe8g4KYYyIzVUL8iOoimaj4uDPoPrQZusNQChCRgLXvKQa+E8AEcyq hQEAYYBLlNtc
sqilBPxnSI5aYD5KDPkx6QAGAEMDECERcGYgQ6fBUCQNHdKcFxFCUloHhQWl Vt1nTg36C3GI
TgORcIplH8RdGX7Mzoaq4gGHCKvKmdq5djpEuHP9Xw1bDxkRVh+OsEREmJGR PmrU0JEjh8KN
DR06hP0RIwBLvh2V8zduXCFrljA5izeSy2VHRh0zMymtEIqLOLIm61IJEyAx VoMSzfAJfCSt
EHn22eC3YAfBi4YpCeCaNtaOhCezKxuOkKW7VZEwNGDRWmF2ULAgMWJmipcA 8WsiqmijXVmi
KeABbQb10MzkT96vlMD2ASVRbhUZwA/dCMxFUsrpFHNcATeJ3qqEADeTf8Le IQletBA5QWFw
JHCTQdmSJBzsDRMzD76hQALTiMla0gohF4kXAx81xgUASissf0k3SVuUGB3X ouxucx6oGA84
RFgxfq7qrThEWNXPYJWzP2REWH04whJHz7CcTt26F/Knzfa1o79CZ5aBqVLC n3djIlnpsdVy
mF1dJaArzTLKLK981ZKL2tdRcBuYEhxpCpnoVUcZ0uFthSlbQVfeQyYJHASQ EVE1AUZmqC7p
d6rCIAy+MnTDu0goyNIkJc8Miyqhp6qIctaLRJJhKyrRTFQAOCZBVYlmE4RN xAyasDloQLHA
UA7RR40FYVSNN2qMEma6t26CRKWQMS7AZYx5++23oV1VCJqUJBBTJSx8WeV+ t87gKu0Bhwir
9OmrMOMdIqwwV7uG5IGQEWF1GWscxLrG7hoK1QPEagOm3WF1oIDZcIrRyXBj jQWBqrSZ8UO1
wck7D+x0DzhEuNNPQZUwwCHCKnGadiUjQ0aEPo5wSkWPNZ42paLHGk+PHFMi R7grXQcV0xdC
2wHxWaK3wWM7iEO4RjZbUqlizHatOA+E1wMOEYbXn7uqNocId9UzW2n7FTIi BCdt2JBUkWhp
U34+LZaY1RdGFzMDYuqGwgeFhLEVp8p5wHmgenrAIcLqed5D7bVDhKF6zMmX 0QMhI8LMzPQ/
B/yemVnIUhxlNKWo6hvTNvw14PeKnAExJSVh0B9dKhL1lpPrnFrnAeeBSugB hwgr4UmphCY5
RFgJT8qubVLIiBBkNn3q2JycnArzS1ZWRtTUsRU+Q/W4imQlK8yZriHnAeeB ne4Bhwh3+imo
EgY4RFglTtOuZGTIiNDNPrMrnX7XF+cB54GK94BDhBXv86rYokOEVfGsVWmb Q0aE1WdkieMI
q/SV7Yx3Hqi0HnCIsNKemkplmEOElep0VAdjQkaEcIQJCTEVmWPHOI/EhJjN mzdV2PnIy8tN
TGDdvBLWLJE9aWn506f7sirT0zeyPIZtrNjBKiDB28yydd7FRazihg0bAsoL lgTZCpF3zGN4
b5DyO1csLi6u7EuJxMbGsn7dzu1IQOvr1q1jsvGwmMSMlaVTxVSaTBUZFhuc klJ4wCHCUjit
GlZxiLAanvSd2+WQEaGfIxxdkeM8sjIzWFOugvMImX0mSEQYFZVx2GEzp03L SElZy2TRtrE4
x3HHHVeMEg4ZfGQZEmZvtoXpdE2wzAbTtQQscEc5K394l7zbuHEjU/RJFbMx F3U9MZlfly5d
MO+RRx7ZuddckK2zNp0tWxJklYJiLKxMl0tdvcSKCQkJLAwo58+e7VvhusSt bdu2TLJdolgw
Ah9//PHtt9+emJhoNjADeTAV33nnHdb3C0bSyZSHBxwiLA+v7qI603fRfrlu VUYPhIwI/TNU
O45w+7lctCgrImLqIYfMiIrK9J5hFtgAFObn5xd62gG4rMBr8JElQJhsL2Cu ZjSwGAlL3gXM
6syycmeddZapZZXkiIgIqQIfsMxxoS2ygJu31k68GGFDQbolGsDk1bbkcYnC RQkAgm394lIr
KaYi+vfaay85nzVjggGF7du3Z229sBjDTN0PPvhgr1699t13X9nAdI/z5s0r UfkHH3xQ6Go6
JVYMEGDFba7SUGs5eYcI3TUQjAfy8hhX6eZBC8ZVTiY8HggZEVYnjjAoF/sR 4fSIiMjDDpvl
BYUsm8aKvYUiQiAR3JUWo7ON0DCLHYttghekHPKP0B7coRAhkXod/eyzz7zY EcrQvgIfTz31
VOlUjJiNQr4SLD7++OP/+usvKQ84Ch/Joz0rK0sx5dzcXNUFp/IVg1lKzltC IePNvcSkfS0m
Vp6ZmUkVVpbTonz6ykbfoTAtRhwfHw+0ohxILQHBXGTMDNyrbhIXlgxAWSX4 zUpAS0KEdFAE
akxMjI5aNDktLU0lrHEsOEV/VcL60dJJpN5M5Wt0dLQOff/99wbvfvjhB622 zIKEEraQLpZb
CWKqgiVyLwsS6qiBOWg/lbCENEsIImMlgDCZRMiYhQHbtGnz7bff3n333Spk 1eZbbrmFnZUr
V0qDsYZE4a2ERaWFCGlavl2xYoWOLlmyRKrMUbxLsLaht0Rf2ViDG0hKLStR uduK98A9X85v
9s2iFj8ucX/OA84DzgOVxwPcmj4fsKbEG3iESVQTjjApMS43Nychfn1uTnbB z/jYaAsHb0OE
02AKDz105siRafIVD9qiECEr6nrDvpIHYRjTc+utt4JvwIKETRHmE4wCuBEP hNrzzz/fzgiI
0L6Cxk444QQOpaSkEHW9zr898MADgC1QF2sKU52VjoFHdpQnOkdBWieffPJX X3318MMPc7Rb
t26qy/rLICcovd12202t33nnnZiK/k6dOhkvRfC0c+fOqoJ+g2tmJFgT3NCh QweqaA1iAAos
6dVXX00JKwsDVS1GDDtIOY0ecMABagL0DLoaMmTInnvuaSVCkHRZ7cKzIgNy 6tixo2Tee++9
AQMG3HTTTXjvf//7n5ZLwZ+SZ41mQDCWyyq2o48++rbbbsOwb775RjKspwxK o+Trr7++6qqr
kEEPStq1a1enTh12QIRUUTd/+uknrbbM0syqztLMYHowa+vWrdUEIWNeBgBw 2Pn888+/8MIL
yBPzlTyUMIAPKAawk3ytWrU4QevXrwf5SYbVnwU0FTJmB4TdpEkT2QDUu/HG G9khjVXyNAGm
BMJ++OGH0vnjjz/SHUA5DeGTN998E3nOjuRZD2bx4sUkO77//vuSP+yww+gI 2JEWJfPqq69a
GmL//v2RwXI0LFu2zM642ynGA+uTc6YvS3N/zgPOA84Dlc0DaZmFBza9N7Tt iLA6cIQbN6ay
Ul9qajIZk/ZJLqPtT5n4n42t8SBCQGHkPfcsl+OKQYTEeUF1AQ8MkMo555yj QhAVIA9u79JL
L6UcnAGxZ1XAdt44MsCRhEWex4MHD/71118BRmgATtWuXXu4f+NBTrwYDRde eKH0A0GOPPJI
HQUooA1rwaOqy9GjjjpKRwFV5513HhCHp77qwhjVr1+fQ2at8AcEp6qAMALw LoAGCHL99de/
9tpr1mvWOAZqWMyRr5dccomO9u3bFxiHTgv49uvXj9w7Sq644grJ9OnTRwgS rKl2gSnQYwMH
DsRp1gowGrXgMECnCiEmJf/iiy82atSItiw2TQj4rrvuAkTiaskAmODzUIKH wUmmFm9rJT0c
jhli195++21soBDSUdUBlPfffz9Y+YYbbrC6gEjwLhgRyKVCAKvkn3jiCfA0 QNl4R0LMQDc0
cO4kAzgGk1EL1HjHHXewQ+/osmzAAHIEKYSVlDwQn16Acema2SAqkQsDBKlC EKrpB3QCee+9
914dIsQMeAVn4yjJgER5MTBt7NA05xcxY2q9R92+84DzgPOA88Au44EdOMKE ePIIS0aR4eo8
Y41psSLHGodk+TZEOBWOsFmzlVa3GEQI1COAG9AKyM/y/AgmgmMQA3tRzif7 IDNVIfrpRYQA
RMDcxRdfDMlnY1MAnRSihI1QJsAOjGgkHNq8R3nkMzalbt26pt97FNzgPQpR B6ChxPAltfgK
Aanm4NLeffddb+9gMcFeQEnv2GGgA4ZBbgFk4eHAYYbkQGlAIspFubGBF1Vi GBEeEXQIjiFm
qnbpPmhp0KBBhhqpCEA89NBDQUUK8oJNYQQlD2xlkA3tYrBagfWEvfv3338P PPBAyQBDYf4w
G1PBaoSVA4boYkaNGjVwPpsQHuwafJ6qc5YBhdCxiuRqA94dfvjhzZs3V4yY 4C+wTPLgTtDY
77//LvKPjUzBZs2awcMdfPDBkgEOgik5RC0hQr4ecsghsgF5SggZf/TRR5I/ 5phjQMOEqg3h
IQC844WBthSSXr58OdeA5CFKwZQgeLCsbOBsQjRids2aNSUD+MNI6xE78KCc XxSiZ2v5P/9s
ufrqEv4gXHGa/lA4erTvz23OA84DzgPOA5XYAztwhNMiK3yscWSFjjUO6UQs XkweoY8dfPzx
HaLv5G8VFTUmMghCgnjzNuRFhOwDjwwRAozAc5YgCEDxIkLwlsAiJBYDSJUm CJFj8nwFNQLa
LLgMqvOSlBwFBikMygYVd+aZZ5ptQFse9ob/gGXXXnst8t5xKuAqowxhT8Gj AT4E/YAkyF37
448/lDynDTx02mmngfNo1AygCXGESstjoxb7lANGVQJIAq7BHRrMpVN0H0to yPSDYyikRQXi
e/ToYa2gs3HjxmBNALfkgW4gQmSs3fT0dBupA50JwtMhbx6hF+1xCDhokLRr 166E7AkTi9XT
Bu1HLJ6zzzWATsCZQVLYQXAnGJTuS5ijIELwnGFEyD9lQAL+QGbsfPrppwHD RN544w2LZaMB
jpBPL6sHbmvZsiWReohDQCHwEWPUImoJAfNpOolKgwgBoMSvJUMY3VIkcQWe JJiO27HTurmF
s1wUIoQgj4go4Y+6jRv7kCLIMrgB1NubdnvOA84DzgPOA+XmAccRFunaOXMy YQcffXTl5s0Z
AwfycNy6EZiDbilq4kZYGUgvE2Y8B8wfFJGaYR+ABQpkyAj74DMQFXSa5Inz KllQGymAxjgC
QwlQUgIlBriBIWPj6Q4mABHCoqkKUWk7CoLhKAjPECQA0Y6CA4AOIEJwm+qi EFAFKoVzkj1g
UCAsAELNAVAYdVuov+jFRRddBPgA7IJsEIbSI0BJNJl0QOsg+AO0B8KD31IT gBIwBxQdrlAJ
zCXhadqFF1S7rVq1ohYlkFuSoZsEggUB8Qn6CbDCF0oe9o6UO4w3eRIc6QXn AhgnGZpALaBH
ptLoK6+8gjZsFhKFSwsYEE38FOSk6sA7QCdReCCgTGLEDCSlICNfMYZxQmA+ yVMRr+JtyiWP
BkL5jC+BzpTMSy+9RGgYJI1tChDDTRqClNtJA6Wi5DmV7GM8J0U6eSHhEgIi IwlmRT9fuQYk
D+8If4kY0WrJYxIRdiC42YmjRIjCmBI955wyxKTQMx5sIZhPBGH79j4UCD0J Itxnn+2oERC5
IysZrGYn5zzgPOA84DwQVg84jrBId8IRNm26ksNr167m0WgbJF9Rw
Re: Package Hierarchy as Tree (Shadow Nodes not working as expected) [message #198480 is a reply to message #198448] Wed, 23 July 2008 05:39 Go to previous messageGo to next message
Hello Goetz,
Try to remove all the ChidReferences - AFAIU you'd like to have only top-level
diagram nodes connected with the links. In this case you do not need any
child references.
In addition I suppose the problem is:
1. You create using toolbar instance of "A" = A1.
2. You connect A1 using containment link with another top-level element A2.
3. As a result A2 should be deleted and new element B2 created. (A2 is not
contained in diagram element anymore, so can not be recognized as top-level
element A).
Can you try following: create separate palette tool for creating "B" elements.
As a result GMF-generated code will create B instances and temporary store
them in the root of diagram ResourceSet. Then you can connect existing instance
of B with existing parent (A) using a link. The difference is: existing top-level
diagram element (link destination) will not change it's type on link creation.
Later we can try to develop solution for this problem without creating separate
tool for B elements, but first I have to know if the reason of link creation
problem is in top-level node type change.
BTW, to my understanding whole diagram structure should be reconstructed
on diagram reopening even in case you are using A element and then changing
element type to B by creating incoming link.
Alex Shatalin
Re: Package Hierarchy as Tree (Shadow Nodes not working as expected) [message #198675 is a reply to message #198480] Wed, 23 July 2008 12:28 Go to previous messageGo to next message
--------------010809030006070707070506
Content-Type: text/plain; charset=UTF-8; format=flowed
Hello Alex,
I greatly appreciate your fast and detailed response.
> top-level diagram nodes connected with the links. In this case you do
> not need any child references.
Done.
> not contained in diagram element anymore, so can not be recognized as
> top-level element A).
Yes right.
> elements. As a result GMF-generated code will create B instances and
> temporary store them in the root of diagram ResourceSet.
I tried that. So *.gmfmap looks like this (also see attachments)
Node Mapping
Element = Package
Diagram Node = PackageFigure
Tool = Creation Tool "Package (Root package)"
Node Mapping
Element = Package
Tool = Creation Tool "Package (Subpackage)"
The observed effects:
1) Using tool A "Package (Root package)"
Drawing on canvas: ok
Storage in model: ok -- as intended, contained in
Model.rootpackages
2) Using tool B "Package (Subpackage)
Drawing on canvas: FAIL -- after release of mouse button,
the figure disappears
Storage in model: ok -- sibling of Model node
> Then you can
> connect existing instance of B with existing parent (A) using a link.
I could not perform this part, since the figure for B disappeared.
> The difference is: existing top-level diagram element (link destination)
> will not change it's type on link creation. Later we can try to develop
> solution for this problem without creating separate tool for B elements,
> but first I have to know if the reason of link creation problem is in
Sounds good. But as you say, let's solve the other problem first.
> changing element type to B by creating incoming link.
Thanks so far,
Any suggestions for further experiments?
Goetz
Content-Type: text/xml;
name="containment3.gmfmap"
filename="containment3.gmfmap"
<gmfmap:Mapping xmi:version="2.0"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore"
xmlns:gmfmap="http://www.eclipse.org/gmf/2008/mappings"
xmlns:gmftool="http://www.eclipse.org/gmf/2005/ToolDefinition">
<nodes>
<containmentFeature
href="containment3.ecore#//Model/rootpackages"/>
<ownedChild>
<domainMetaElement
href="containment3.ecore#//Package"/>
<labelMappings
xsi:type="gmfmap:FeatureLabelMapping">
<diagramLabel
href="containment3.gmfgraph#PackageName"/>
<features
href="containment3.ecore#//Package/name"/>
</labelMappings>
<tool
xsi:type="gmftool:CreationTool"
href="containment3.gmftool#//@palette/@tools.0/@tools.0"/>
<diagramNode
href="containment3.gmfgraph#Package"/>
</ownedChild>
</nodes>
<nodes>
<ownedChild>
<domainMetaElement
<labelMappings
<diagramLabel
<features
</labelMappings>
<tool
href="containment3.gmftool#//@palette/@tools.0/@tools.1"/>
<diagramNode
</ownedChild>
</nodes>
<nodes>
<ownedChild>
<domainMetaElement
href="containment3.ecore#//Item"/>
<labelMappings
editPattern="">
<diagramLabel
href="containment3.gmfgraph#ItemName"/>
<features
href="containment3.ecore#//Item/name"/>
</labelMappings>
<tool
href="containment3.gmftool#//@palette/@tools.0/@tools.4"/>
<diagramNode
href="containment3.gmfgraph#Item"/>
</ownedChild>
</nodes>
<links>
<tool
href="containment3.gmftool#//@palette/@tools.0/@tools.3"/>
<diagramLink
href="containment3.gmfgraph#PackageSubpackages"/>
<linkMetaFeature
xsi:type="ecore:EReference"
href="containment3.ecore#//Package/subpackages"/>
</links>
<links>
<tool
href="containment3.gmftool#//@palette/@tools.0/@tools.2"/>
<diagramLink
href="containment3.gmfgraph#PackageItems"/>
<linkMetaFeature
href="containment3.ecore#//Package/items"/>
</links>
<diagram>
<diagramCanvas
href="containment3.gmfgraph#containment3"/>
<domainModel
href="containment3.ecore#/"/>
<domainMetaElement
href="containment3.ecore#//Model"/>
<palette
href="containment3.gmftool#//@palette"/>
</diagram>
</gmfmap:Mapping>
Content-Type: image/png;
Content-Disposition: inline;
iVBORw0KGgoAAAANSUhEUgAAA5QAAAHzCAIAAADQOsXUAAAAAXNSR0IArs4c 6QAAAARnQU1B
/45JREFUeF7snQWYVcX7x9GfDXZ3t39bBBUVC6RFVGyxO8AOFJFO6c6lu7u7 lu5m2V2W2u76
f+79wni4d+Nu32XnPPvsc+6cd96Zec+cme98552ZU9LT00vZy1rAWsBawFqg xFggKSWt+eig
kPCkElNiW9A8WSAtLeXUU0/Lkwob2Vog/yzw7tOXlwK82stawFrAWsBaoORY IORoYqW/163c
EWX/rAV8sEDkovV7jdiK7ZGjZq0fMWPtmDkbvOPq0ejZGTzyISFbIa0FsrdA p8nBjYbtseC1
5HRYtqTWAtYC1gIuCwBeazRdX3C22Lx5c3x8vLd+j/C0tLTMJAsub1ZzTi2Q mpoSHRmSlpaq
iGFhYWeffTYk2rnnXjh9eujChTELF0a7/2LHj995+uln8ujiiy+Ojo7OaUJO +YSEBOpGauqx
RPOiyv/jxsXFbdmyhc8h71mNjY3FbrnQExMTQx5yEbHwo0xYcdiC18I3u03R WsBawFqgiC2Q
7+B19erVC93XokWLIiMjb7311jVr1phC0isHBgYeOXKE8HXr1plwAMrNN9/s DCliu9jkM7KA
B3g9cODA8enf0+64Y9ndd2+9++4N7r+tt946V4/OOeecqKgooyw5OXnt2rUb NmwQGE1MTARg
paSkZGHvbdu23XjjjU4lHsJJSUnUsY0bNwrzodP5M6dvEsy3atWqfMHK5MR8 Dtz4kpOVK1fe
dtttWRvEFz3ILFmy5I477uDL4ovTJ4nlfYm7YMECIvoiWeQyFrwW+SuwGbAW sBawFigCC+Qv
eKWbfPLJJ+92X/fff//27dvvuece/puCgTPq1q0LdiHcA6rSZ1vwWgQ1ICdJ eoBXBiEPP1zu
jDNur1Dh6bi4WKemo0cPP/TQozx68smKwEHzKDQ0FER7xhlnCGju2LHjhhtu CA8PzyIXwcHB
N910EwOhzGT27duHzjJlykgAPpifl156KdgxJ4U7Jrtz586XX36ZipqLuM4o AOhNmzadfvrp
d911F59DxYoVgenZUqqA19tvvz1fwCtw+c477yQb5EGf5AsvvOALpQp4JWIe i0/0iIgIH+Fy
rtOy4DXXprMRrQWsBawFirEF8gu80iuvX7/+mWeecfaOIAAY1v79+4uIlZm2 bt1Krwa1A4Tl
p2ihOXPmXHfddZBnxdiUJSDrHuCVEgcHp95yy6aIiAwKHxTkeuSBOUGiZ511 1kMPPQS0os7s
2rUL8Mo8NfFhCqkJoDeja/HixYQMHToU8CrnE4U4ZQjcs2cPaPjRRx+lBjLt Pm/ePFj8q666
iuoHfqXiEQUyFUl4X0OFeodQFZEhClwvhCWwT4SlwnVJG9kAmGb2whEYNGhQ nTp1VqxYQT0n
USTRdsstt3BPQaTWycUqBBlyJeCIcZRDSmSemhQVgsXM5+bBrTJgGDFixBtv vIEMA0VFJNsg
Y254KnkzXCQ5E0IZQbqIgaFVdl6QhzzMtMkDX7QyrBDegpJbtmzZc88950wl M4vlOtyC11yb
zka0FrAWsBYoxhbIL/AKUKBvdnoIYBR6OAJBEiJ+Zs2aRU/MzfLlyx944AGg Kt3eU089RQgd
Nt6TTo62GNv05M26N3jdvz/55ps3Hj2agUPqvn2uRxERJ7hv7t69GywFbrv6 6quxU1BQEDUE
VhVcBVVPTXjssceoRdST+fPn33fffYQw/mFgQwg47PHHHwekVqpUCUrPzOyD Ne+99150Ikml
gsIX6QhSPHTo0BNPPKEoVDZSBzrzCLUVKlTwCGHSgBBQKekyssLhQZJUUUhT MjBz5kwyTwhV
+vrrrxcqdV4AtVGjRkG1wnESDjQ0FCaawdMgvP3795crV44sVatWjUBw5NSp U8XOgnfB5diB
og0ePLhq1aoogVdGWPKUFPlJkyZJHm8KwDHIcvr06ZKpUaOG4OzSpUuxgxAk xlEmMcu1117L
DWMGyb/00kvoRMO4ceP0kb711lvY+cEHHwS59unTB4XI82F6yI8ZM0by2IEM o2HChAmSgbc2
kJrXgUzlypWdoDYfvw8LXvPRmFaVtYC1gLVAsbFAPoJXoIPHLCEklnEGAN3C +gBb6Rf5//DD
D9NP/9///Z/4V0kazqbYmK+EZdQbvO7bl3jzzesPH/aEcRhmzx7Xo6NHT/Bn BT4CvAA3VapU
AaSCoqgDUIxUHjkGEALgI4TaIj9XXAuEd8FJ06ZNE695ySWXmHVgwC8E0Fmr Vi2w42uvvQZq
lLsn0UXWEgW1mpQHhhIOHgVXOUNAWuiBLmVkxX8kpYEqSiYJoYrKFYEQMLee 6gK9geeAbrVr
1zaBZAPYPXv2bIB4QEAA2RPgFkPZu3dvUDLfgtNPAJuQcyYr3nzzTeNjIPme PXvy7YBKEdAj
sqSviVRIApkuXbpoVKD8c4Mlwbg85erbt6/JnnR27tz5kUcewUS8FJNtwCs/ EX777bcVaFjV
Tp06lS1bloiGzYXnptRogEGXzrZt25Ki88vg1ZQvX57ii0vOx8uC13w0plVl LWAtYC1QbCyQ
j+AVUsdjdbMTkkJT0ekKthrwCickVwGgrQWv/l9p8gW8QlsC+0JCQoBcVBjg F5iGty+oKnRL
CLVF8BQnVKASePGCCy4AblJnoPpAQsYtFfAKlAQX4j9w2WWXEQUEjEIAJYgN JEoUkJxhZOWB
AKJCrabpFQLnCkgFzuLVwH/CBVWpomgQHFSi4ned4BUO9dlnn8X7xeljQBJn nnmmGErRqOBm
eFa0cYHXKQgJUVLDIpMHpiDggDUORB6elVwhTxnJGN+OYXOJy9eEJKlIJ4WF OiWiEcNuJg9C
rphl/PjxkuddQAODVuUnoIsiwDoz4y+nAuFyyeO/ATUOVCVLEsbCAFOi4Llh 8vDBBx94VGZA
bY8ePZzIPl9quwWv+WJGq8RawFrAWqCYWSC/wCvYtGbNmvBbziUpBBo6FhwA KAEBGPAqKgte
TSajC7cLtvy89niD1yNH0m+9dWdGm6GlHzzoeuSxaApsCmACkzGhX716dSbH QTwgSICsZuFZ
0QVCApbB3gnSAXNFfMLtGftAxJpVTQKvREeSuXVqIJUKtQC4a665RlHwtVWI QWnkhFgkZEJA
yVRXEjLgVaCWCQFQJvPvJgNIeoBXxPAHIAl8DObOnSuvXGhUj9VXhOM8oCyB d0kI4OjkKTEF
aB5wjOOBtmUwRQDow3rikIp9pIGnfE2EYFJjGbnuEBeTcuMssmSAm3qkHMKb skKLghsNAE3o
WDSQBz5JNJiCA1IBu7CtonWlH/BKiLwUuHhrZgaGe5IbOHAgloERN0nk140F r/llSavHWsBa
wFqgOFkgv8Crygx0oKPSHCU9Iguz6Ca1MAXwyrQvk55AWDpszeHSnw0ZMgRh vAnZENS6Dfh5
1fEAr+DF6dNXXnPNiEWL/tsN7XgRUqdO1aP/nFN5BOy74oorjh49yr22BTj/ /PNxqaTmQElS
E5j3h58DqBGCkwAhjIhE6hNCPZFfKV4HZhMDCM4rr7zSuZcW/CWIkP+I4WlN FGbtwXxgL/7j
IYpa1oG9+uqrgDMkFUJVJERUKFCVqivwChQDHRptSDKtD9rLcDcDvHhBw/jm kpZ8TJ1bB5DV
559/HqgnNwCUAEDJJJQtaokCFuQzIVGg7YsvvjhgwAC8dfmUxFxqgIc8+Bh5 QkC6CpEMGWMM
iWVGjhyJPyt6PMCxACuoVFP8uAGQWwqIBn22POW/8DThEMb9+vUjJ5Lv0KGD XDgIlzwhwFmF
GPcG3F6JziYS5B/9r7zySgFVbAteC8iwVq21gLWAtYBfWyB/wStFpQ/TPClk FQQY8BRijHDm
WwElUEqsgKbDJhzqi3AWcyBMj0g3DHfl18Yq8ZnL6JCCs9yHFFwwdWrI/PlM 00e7/2LGjs34
kAIYUAhXAU122qKSPP3009wTAolITWDDClGwPKVKqG5o/RNOsQphRtu5WGrv 3r3odG7IRdUi
BAoWlMxMupTgaQAiBCtrtZN0shyKKXKFUBUJwfcACAtUBfzJMQBsDSLk5vDh w6BSsBpMMBDc
e8GWqSBEAbFRz6nzHmJUcq36UpaIgk30yRCFdFm2JcqZe30m0JaS17Q78uSB i2wL6Qoxc0kh
yNvwoEBbQUnnhVuF5CkIheWRCcHrgCgGboKn8b5lyGHkRaAirzyAp5UWRZaM YVjJhgB0wV0W
vBacba1mawFrAWsB/7VAvoNX/y2qzVmeLeDDIQWsLudv2223mUMKzs7ifIE8 5yhnCkCTzNo7
j3zzDslCozbe4ho2bBjL8HO3j2zOcpyRNPlXNpjlAB167x3LI+0qUHAXQwXl gWVnoO2CSyhr
zRa8FpXlbbrWAtYC1gJFaQELXovS+sUtbQ6G5XhYVp8r40ePhj/+xBMPPPDg s88+l5DgWsJv
rvDwo5CUPIIljYvL4HzgIin6rt27a9Zkpdd/eyPs2uUZkkXGIE0p0b333Ve1 arUiyb8S3blz
F3ngr3ZtT0pVAuvXw/hm/Ci/so0Xh/Lw+uuv55fOXOix4DUXRrNRrAWsBawF ir0F3OB1XVpa
Ukpygv2zFsjaAklJcVERwclJ8cfEUphVZ4Lb9ZeWlpiWmpCWyn/3TRrr9PUo xY+smkKuTsyP
d0iWH0JaWvKxv9Si+2RSMG9W2UjNYaFy84JSEovcFOlpyeOXH2w0bE+pYt8M 2wJYC1gLWAtY
C+TEAoDX6k3WpCSHR0eF2j9rgWwsEBkSGR5kZGKiQuNiwviLjQnziJjFoyI0 MrnyyKp3SBbZ
85NCZZuNHBUqd68j2zzkTm2OYqWnRo1dEmzBa07aeytrLWAtYC1wUljAug2c FK+xkArhvVVW
ISVsk7EWyMgC1m3A1gtrAWsBa4GSaAELXkviW89tmS14za3lbLwCsYAFrwVi VqvUWsBawFrA
zy1Q0OCV1dw6jdPj8ghnxTS7aGUo6ecGLFHZs+C1RL1u/y+sBa/+/45sDq0F rAWsBfLfAvkO
XtnjnR3UtYk6hxRwiJGO/NHFBpZsw85+mYQ7z9NiQ032Rc/1CVtgXw44IEWT tPPozsysRmbA
0L5I5r/di6dGC16L53s7aXNtwetJ+2ptwawFrAWsBbKwQP6CV47W5HhMdlPn YnN49i3nhv8m
AxxVoEMKCPeAqmx1nmvwyo6bV199NecVmaQ5KTTb987+oyBmtnzPVtIKHB97 pLBVFhtmWYNY
C/iDBSx49Ye3YPNgLWAtYC1Q2BbIL/AK98lhks8++6zO09IFVAVQso05hChH YiqQEzJhZDmY
BwjLT/AuT2fMmMFpnITwlEBOeJcLATStSFzFNfSqCVE4W6aTkDdg5YwfZ3So Vk7LNCGiezl9
lKM1SY4DjcTCcp4nPgzoVGbgkhXO2bbERbiwX5LfpGeZV795FTYjLgtY8Grr gbWAtYC1QEm0
QH6BV3Aqp8aDX51GBCziHsAFIcpBlCBUEOGdd94JpoSXBSCCFzkdVKdlnnvu uYBXTsLs1q0b
p9hzSicCHLlevnx5trvn8PeYmBgOw5Q2xNBmjkoCehIODNV56xz8Q0LwuBz4 SfQnnnhi9uzZ
CEPQcn6mQsCgyNxwww0wvo8++ij0MDdC3jCyaANAg7A5Pp4Db4HF5I0DRYn7 5JNPAmFLprOB
Ba8lsY3w4zJb8OrHL8dmzVrAWsBaoMAskI/gFe7T6d5KlgGLIEIxrNCZ3MOk cjw9/znIHkYT
zApC5SnnvwNqOUgdvIiegwcPEghUHTBgwMKFC2fNmnXRRRfB0d53330cT88j kaaKq4SAocZt
4JFHHtmxYwc/gbNEnz59OshY3gskqhDOzyQ5QDCntAuwAr4lw/3tt98OEIcM 5gaeGP3XXHMN
h4ISd8qUKeedd55ilbTLgteS9sb9vLyFCl5xl0lLS7F/1gLWAtYC1gI+WODY UZwF1IvkI3gF
3mme3VwCr8z1C54CTAGgwFYDXsGOgrYQt4BXnsLIcvKkQkSLIgNmrVixIniR eyUBjXrzzTdD
3CotOFQknc61oFvgKdBT0eF3Dx06RFq45BICd3v++eeL6N25c6cAK2yrAa9k BuYVMQhgnkL6
XnXVVeRf2jjy9MiRIwX0RvxZrQWv/vx2SmDecglecQCaNm0aw9CJ7mvq1GkL Fy6YN3/qvDlT
5s1x/18wlcbIw6BJ8SGJsUGJcfvtn7WAtYC1gLVAFhaIj9kLMCvQPim/wCvY 9KWXXoIoxfnV
ZJhA6E/5EgBk77rrLid45Z6nUKSSh4UF1AJeBUnxBAAvCjtyrV69mj0KgI96 KidXD/DqdLcF
bl555ZVmMRbRw8LCLrvsMuMXS3KwsCBgyQBenfJkVeB19+7dPA0PD7/iiivE B3NB2RqPhQJ9
O/6m3IJXf3sjJTw/uQGvfMZnnnmm3I9wSOK6447bS5UqdWqpe/5X5v/+d+7d /ytz7yml7jz7
rNLBwfuNfaFdjx7afiRsy5GDW+2ftYC1gLWAtUAWFjh0YFNsdFiB9k/5BV6V yRo1avTr1w8H
Uy4cQ5lwh/4EOAq84gYA5QGpyaopYCjYkZ0HAgICEIYHufTSS4GzZs8B+acO HjxYy7lwfsVJ
AKwpplZUqO71k90GDJYV9q1ZsyYT/USfOnUq0SF069SpM3z4cELgXEgOVF23 bt0hQ4aQAeAp
yQ0dOpR7uJjLL7+c7OGZIC42Ojq6evXqI0eOVFycX/fv/69fK9AX5FfKLXj1 q9dhM5Mb8Mpo
lTkdjYZlwUWL5p526kWPlt1S4d3tj72/7om3djx00/KLLrh6/vzZxsRU/SMH tx0+sPlw2Bbn
39FD26AfaMQ9wp0/Dx3YcvTQ1uSEkKT44CMHT4ieRawsFW72Jd3cKc9RrEMH Nocf3o4FchSr
MIXzPYdSyNtMiA0qtIKQaMSRHYWZYqEVLduEKHvk0Z2UnZtshT0EiBIVvjMh xjOuMzwzmZym
VXzlZQGqdGzU3lwYOcOCHwzdGBN1oEC7qPwFr2SVtVaszeLCt5UZeeCpCFHc AF555RUA6Ntv
v81/wkVqAislX65cORwD3nzzTc3j63rxxRd5BB3LpD8/a9euLWdTiE+IXuN4 yk8eGZrWRK9U
qRLRH3roIUXnAnea5NR54VFAiNwA8AfQU1Zlofy1114zIBWfXfZS4FHZsmVL ps8A9rHgtUA/
Rqs8pxY4Bl4PR8Ss33Vg9fbgNcf/uF+7I4Rwb68rwCu0K6NVk9iihfOfqvjC 7c+0fvSNZeXe
XvFY3XUP3Djv4guvXrTo2A4pqvre4BUEuX/v2vFjB4bu3+CBXw24dHe9O/jr 2b1tvz4dwkI2
AmTz2M+hfN/u1RPGBqAta9ycx4SyjQ6M27Nz1YRxARSzaHOSWVbJ4c5tyyeO H4RA3nNIMWMi
d2P27l1bDxvSkxeRd53ZGhmBiCPbt25aPHniYFL0RT53MqqrmcHErJ/mIcX/ gKkwOiiKv/iY
fQJSkUd2bFg7f9rkYRghp6lQnPVr5k2bMhy1zriEr1szd7o73HmfI/1uzLfL 5DMj3Jzp0xwl
ZIRJMTriP50GdGKuuOhc4k6UJMYFb96wsFuXVhiKEuUubx6xiiN4zWn3Y+WL kQUseC1GL6sk
ZPUYeB04ZWXPSSu7jFnUdexi/XHfefSiAVNXJiQlexgC8MqUihkiM8WDH33g qqVlzj/zvlqT
y7+36rE31zxw41xfwGt0xO5VK2Zdeukl27cshRwyzTcII2jPGkDtgeANgCfa cWDrQw/e+8Lz
TwfvW5eLPtijY4iJ3LNk0eQrLr9s765Aj145Xzoe35XER+2dM2vMVVdeAXyn pL5HLDRJoNjE
8QHXXns1KDPvyI8yBu9b+2+7Jo+WffCN12uDe/Ku0xdTwNkPGtj1ppuvp8oV HFymLm3euGjK
xCEZvkpq+LrVc0cM6x2Rfy+aFDeuWzB18jBSBEUBBKnS3bq2BkhNnjgkNTEU 4/C/47/N/u+e
O90TFzkb+KUmHWjX5u/777sHeOec9CC8Tau/Hrj//whPS/7v3pd3YWR4+2tX z50xdUSG3yAo
cPnSaWNH94fUzJHaLIR5BYErZ82aPoobN+jcz5AGW/E3e+ZoCpUL3hRVNF8/ /fjV44+V/f23
+hg5X3JrwWtJ6ICLURlx/OOQgvT0gl1EWIwMYrNatBY4Bl6bB/w3v28yFJ+Y RHh0nGuLZueF
2zvbiLBdX0JCfLv2Tdr923T9+rWtW7a99qrXH3ptTvn3Vj5VI+iRG1ddfOE1 3swrPq/0dinu
P1p5QGTgqtnXX38trT99lR4pfOXS6Zdddil9SXp65Mpl06+84nJQFA5O9KB0 wEaSfkIcrWvy
PXY/93pEiO7Vl6DHSeXGxwRtWDf/0ksuBiLTY5mJ+6MnalasE9M6nrR7ov+4 Tpf+8MPHskE+
/1PoyI/kTfaUq6TY/SuWTQdGhwStjzq6U5Yh88cUxrrLdTwtPZWAs4NUPk+M eyyWmfT3ljFR
yLDuTbrOhMBDUyYNuf32W1wcniOH3jwZWTUR3UY4liVzj37uR43oe/NNN7gX o4Q7sYKyKg0i
L8E0Kqm595YxUcin7hXXIzOsFBw2pMc999xBNYOJdKbiVn5Cuk6izuNRZj+V LpWtT6/2d955
a3p6hNuYmyjCsbRigmKj9kydNPTzT+sxC5+SGGrCnWJx0cdKIT5SBZekO+Q/ hQrhf+eOLe67
/x588wCRWzcv+fnHr594/NEnnnj05drV5s0eR4bT0w/36fXvnXfcmpYcBpAl CiyjCmJSAUc6
UnGlqxAcCPv0bF++3MNJcfujwv+TSUkM6dC+yWPlHyE8Pf1I184t7/2/uyi+ qSHx0a7cZvbT
lXT0vrTk0OZNfy/36EMuN8UT5fmZELsPbv77+p8pz/pz86P/qcWkso94U3e2 j31EkjTflGTS
Uw788VuDp596nA2XeAXr18775quPnqxQvsIT5d58o87SxVOdQ2jxsiZpGiVj JXPv1hn24w9f
VKnyHI0kOs37MjLyJRDNLG3ukE3m5/GQE5w6Cgu8rktLS0pOTrB/1gJZWyAp MTYqIjg5Kc4a
ylqgyC2QnpY8fvnBRsP2lGoxaE58oifDGhoW2iJgVnRckgd4PXAg7Kqrrvyn ya+N/2p4TqlH
Lzq7ws+/fP2/U8696tz2T9bY/UTVLTee3+XyM/+48MLLFy/+7zwSJh3CD+8I CVpHh8SUMb1d
/76dUhMPrFsz74Ybrtu1fUVYyKZePdoSPqBfJwAlk5WXX35Z29Z/Dx/aa9Xy GVdfdUW7No0D
BnQGZkWH7zou2RlQApM3ecLgg6Gbhg7usWdXIPrhUaDZjh7cRkL9+3Wihwav 7N0dOG7MACas
4b1Cgzd069rq7Tdf2b5l2bQpww6GbEL+yKFtdE49urUhDwEDuhKLCW4QmELI Ld0Sf/qJfHJ8
8L49q9FJ0kCBPbtWMbe+c/sKaDBSQQD8xJ+7sK0G9u9Mv3j8Z8vBAd3IOdrA rB07NCMn3POU
nKN8yKDu9Ge4E4B1DuzfgCriHjm0VU9xnxg/ZiAASyyaZkK50VOMgPUYDHAD nKIIcLrKzO4d
KyWDiZDBcWLQgK78HDWiD77IJhzqjnBJYnwg5tTJQwGvAAWTyohhvZw0HnmQ M0DX4znECOgJ
GNAFJZBnB0Nd+onFUARi8qorL8eMI4b2Mm4Dbg17INoRc2epb3rKwY3rF7gT 2k/SQXtWDwno
Rn+/bctS5W30SGTCqDmk0qVTywljB5IBbtzhBxUubaNH9WNJscAr8AKbK3zM qH7yU9y/by0/
UTtyWG9DmpIloAluLXpETuJj90uSv3GjB6SlHNy+dZlJZfyYAQyuhg7uft11 1/Tu+S/ZiI7c
s3nDIuWWaYTU5IPbNi9ZOH8ilcTEwmMkLeUQ78tdihbURr4RbgjXXDZmVIrU LiSBpyYuIYwB
mJS46aYb+vbuMHPaSGrjh++/CXTmm0XsumuvTk4M473//ut33333OdVVqcyY NoKCcAM7i0HA
kcgolWMhMfswoD7Gd995DXiHzt07XCFdOrfk5eJ5+G+7f+Aa0Y/kLz99Xf/b T0HJO7Ytl7mw
RmL8ARxOFIVypSYf3rR+IR/C8ZDhKIESvv32m/m4YPejI4PWrJpNXOSnTx2e knQIb4eli6dQ
ZBOLnKOHkSch5H/+3PF8JtxQdgpChcfCLv2dWs6cPjI1+QgaXJLHQ8CsLZr9 cc/ddxC4cP4E
0v3m64+1qL9Fs4bgb2qOhi7iZbdsXKS4fXv/u3TRlC0bFw/o50p30YJJFI2b OTPHsB6p8d8/
33ff3dgW+nbrpiWSWYzMVpfM3Nlj+dyA0SuWTneVrlNLQlKSjqwJnIN5+cnf vDnjPHjfwgGv
1ZusSUkOj44KtX/WAtlYIDI0MjzIWslawB8skJ4aNXZJsAu8th4679DRo0MH D+rbtzd/ffr2
Hti/97p1ga2GzImIjg0N2ZuYmKD/B0KDwsJCLzj/ktNK3XfOhU8+UW77E+W2 nXXqM+w2gJ/7
jee3vf7c5o888tBDD9998cUXcdiJAb6AV9AJvc7pp5/+4IP30u099eRjY0b1 X71y1o03Xk8P
DZaqUaPyi5WfrVGtEuBs3dp5F154/sMP3fdSrSowr2jjvnq1FxCjb3jssUfQ 8PTTj4MJgLYX
XXQBE3av1629ZNEU9Jd95IHKlZ/p1rkVjNFTTz3GRG1c1J7FCyedddaZdHVw RfgMXH75pS7e
d+WsCy44r+FvDeq8XB10279vx8qVKlat+nzNmi+OHT0AjNu3178vPP8UemrV fBEcA69WrtxD
JP3sMxWmThq2YN74K664jHCQHP3oTTdeP3P6KAjdP35v8OorNffvXQPIfvTR h4gCDQZc6N2z
/QsvuPRTKCAd+NjlM3DVFTFRew664SOT6Sh//rmnZk4dMX/OuIsvvvCP3+rX fa0WAJ254LLu
p3fdeRuJilykl9VEPJ0iPhVorv1S1elTR2CxZyo+QcFBvX81/JHUmS5nPFCJ 1Ks89/LL1UiX
HpS3BnlWq2aVzh2bY1LyNm/22DkzRxP+6KOutCpXemburLF48t1zz52AKnKI hmpVn69Tp8ak
CS7/UQFo5aF9u39g0R5/vOztt92M/OwZo9DDT1Lv1KEZdOCLlZ9ZMG/C7Bmj zznnbCTfevMV
4zaABljwf9s3IUX0v/pqzflzxi+cN4FSTBg3kKdMy75RtzbvjqlkVymqPv/a q7V4p2SDVCAa
X32lRof2TaHQqlV5YfHiKYAhwnlxTzxetlrVFxYvmoI1Hnjg/w6EbGzX9h+q GYEYlsLiiMIY
Ceth/Pfrvc5IQIViQAJibtm8ISbiJX7y0TshwZtatviTn5SlRvVKS5fOAPef csopCqlZo/KS
JdOBj2XKlC5f/pGPPno7KTFswdzxstgbr7+MfL++HckSMiYWxl+2bBaDBEIq VCj/9luvMEjj
hhoCuqIKAap4ZdT8t96sgyTDnlNPPZVXQ4ovvVSVEMp17rllyAOcLvUQDAdi AxX99st3v/3y
bVpqOGZhfh+3cxAYcStUeAw82qZVI26o9nwLWP7vv36SThPS6K8feXcEQpNj rqCgLU0a/0JB
yAnRly+fD+TiKcivdcu/+OKgfndtX/nnHz+gBEv++MOXe3Zv+rPh9y4a+PFH X3ul5qpVCxmx
nHbaacdCXq21csVCMPd5552Lnu/rf56YeHTS+MGYq3q1SvXee50d5Vu1+LPK i8/yvfNRK9br
r70UGLgEREhIhQqPf/LxO82b/sHN63VfWrlsBl/3nw1/IIdo+KDem6tWLen4 b9MzzjhDVDRu
KoGrXND2ggvOJ8Wff/qawQ8UMg0IuJMMNG3yG5+kwKucAZBRXL64d9+p27N7 GzZaqVDhic8/
r9ek8a/cvP1mndWrl0NCX3jhBZjr37ZNqOq0Mzz64vMPmvz9CzfvvP0qsJW0 GP9QOtq3jz96
e82aFc2a/n722WehvMITj2JSZmCcvG/hgNcaTV37sNrLWiBbC1if12xNZAUK 0wLH3AbaDV8Q
FBJcufIL5co/Wq4cB+aVfe6Zp5ctmd92+PwjEVErl82Jjo7Q/9Ur5wfv333Z JTc//MDKJ97d
Wv695eWqrrrr2h4v1XotMvLI0xXLPfnUI/v27WXbV3YzMUdaa8EWYHFN4GxY Igg2+DwIlWuv
uQqu4tZbb6LXgTWBEeQPJHHllVeArm677Wa4tPT0o4ErZtKDQnByD3a57NJL YPLQsGnDQnwx
gTjnnlv6+eefpucGjN500/WxkXu2bFrihqe74U4uu+wSgBc3dP8AzYSYfcuW TL3xxutQCJ47
88wz6JuZmqTzO+/cMuBLOLOm//x60YUXQPOcUuoUKEwYNfgVwMTlV1wKkIKF IksQxrA7ZBKd
kDQwavfcfSfgjK6LvhMKh4zh7UCHlJoUmp56GDQGyAC+jB7ZD6xw9jlnw7Yu mj/x5ptvQAYo
iecrOUc5HA/lnT933FlnnQUYhdCaNWM0GNc1R8nTxVOIgmUEXtkPEh8+EABk Epob/t6gTOnS
UJVbNiyimwRs1X3tJSISAiaDUh05vPeff3x/2603w5/dfdftmHT+3AnXXnuV 62bOOHAnzOjd
d98B30laEEsUcMqkoY+WfQjnAWwCiQthSacOAgC8ymOV4o8d1Q/3D8hCOE5g Kw7KwEogLD9x
arzh+msBNzOmjWRKHb4Q/0vxZGaC3qVhdP+LLroQ1hn99b/79JJLLqK/B1gA CunmQQC8X1hS
Cg7UGD2i7w/ffwHdxeiF/8w7g1ZvueVGyLzxYwPuvfdutOGpyVsgA7Ck9917 F2qBtoRTH6hm
3Hz91YcwyqOG9wFMU3aUYGrjyQCzPqBvpztuvzU97TBJU9/gOJFHhrIARB5+ 6P4Rw/o89NB9
zJsTQj3hfuTwPg8/7AqRzWF5Xbkd2e+rLz4sX+4hjM+wBw74ERfaO0osOP6y jzwIeHWHpADU
4AX5XAb274L88CE9ee/oBO9+8P6bDz7wf6RS3jXPHk6d7Ne3A1AYiz3mApHh 7onyLViVtVmA
s9deqQUeSk06yMAGNEla4Dbk+Rgh7+93GS29R7e2sKoMyXhfbr42Bnz51JPl e/Vo5y5FFCEM
wKq8+Bxo+PrrrqEg5OTNN14GK5NV4BoCgGODYqknJMTbRBu4n+EWPwG4gMjn n3uSj6vi008o
BL/n5579L4TBFcCRdoCCM24ExFer+hzZoP4zd4Gk+xuMBXMzvCST7pB0qjeD E26AuXzFSNKY
8GapFbVrVWXYSdnBi4oLzGUYwDiNQRQ/aRxcfjvxwcOH9qQgwGU8ko33LXUP 9O/OLbxsHHwt
Y2PI5qpVnic5kP0zz1Tg5u9GPzGsbd/2HwYzbsmI33/7rnr1F3gEjH7uOVcm GcoyhEYJkwZ8
pHDSL9Wq+uYbtVu3avRSrRfdtS7ut1+/o2IY3pfvwoLXwuwIbVrZWsCC12xN ZAUK0wLHwCvu
AYeOHE5OjI6NORITdTgqIuzIgV2rVy1uNmB6TLynO8HBsJBLLrv+3tpTXGuz 2FjgqrnnnXfm
1m2uXfcO4FIQ5tqbkK372PY5Q/AKz8qMG93b6lWzgUqAVAABc22DB3alH6IX fOD+e8CFkJr0
Q8xIIglShNRkZpP7lctn3HD9dbt3rtI9cYFK+PMdPLAJWg6GA1QKvkG5btwo 81o6RaAzHTwA
Ljpij8Arjgorls+45eYbCUyKcwFfODMwBKQgdMuXn3/AUhhIUPhden0Q2KIF E8GU4lkBnXfd
dfusGaOc4BVMBt7ljEO6QGQoAvLAF/hFZmbxqDv77LPpzqHxQFGfffoeWQLg gkSRB/WSEzJM
xLmzxqCKmdM777gNIpAQID7IDLTN/ZxZrnsGAMyhYwQgC0qAuajl78kK5b78 4oPDYZvTUw/i
N3zRxRcCpEAGIfvWderYzMWMPlYWePTgA/e69d+K+y+YklIAelg8DkWHr8Kd d97m2pssPhjY
Sgj/AVi8KYgiNICEnnyy/LfffIIMsFuerBPHBVBw7YHFPTQ5E9CYyPVz/CAS Aq1yQzigFtDs
cpM4tM04s7og15Rh2Ad0hX5Y+e8bfO4eJxxhhICbgWsr8fCdMJFtWjcCOVEK dFJYptf/7//u
pNdnyIHR0lMPAfXKudlNZoEpOA4Y+CegFvDKa6XUpc85B2aUF/H0U481+vNH Bi2Vnn8aIhaU
SR7chdqB/3RSbBCOCiDguKi9bmdl15IvgDIGpyzcA/tICzYXB01CwCUVKpQz IeSW+QR8Oskq
2IjRAqhL4BW0BMzF85UhE9QjLpiAVzcIjsA5FRPhXMHNMxUrYEnqJKQ4uQVI tWvdeOCALtCc
2JxZ5p492qIN8Mp7l3Mwr0O+v5gLntU9OIk+Dl6jDIo1N7CnlV54hpy7vFrj g9EJqQn5zXw6
iboWYyUdgEoEvGJehl6UhdTBbZ07tQDUngheXSiWio0p+KAoGpAOWpGf+Nq2 b9u4RvXKgFeM
phDGqNWr/RdCznduWwHOE8N64w3XMdQUeAWqVnz6cfKWnhwGIDYh+AA0b/YH 3LzrpukfEPy8
lPPPP4/oZBJ0CygXRMYbGDDa9J/fXqlTA/DKR00G5G/jcv91mSu22T+/UTok tR0B/riMMOHj
kaR2cQ93DsOKcdj66a8/fzA3hFNSGGKSQLjhHw1e5D49qeEf3+uGSSEA7q5d W378/kvsQ/YY
cn/x+fuAV0hi1/gq9eCvv3xLDSS6Gc5Z8FqYHaFNK1sLFDvwyh5q7Oabmpqa bdGKUIATN9at
w+/cLoPL8Us4Bl6b9p+xe8f6nRsWbVo5a+PKmRtWzFi/dMqiORP+6Tc1Jt7T 5/U4eJ1c/v2V
5d8OfPjhRVdfWqVDhw6sRjTps5lzZuAV5vWQi0ONwl8QT1ZgGSADzHfe+efC VKEhdP/6u+68
Hchy5ZWX44tJR45rAeAVIAvEWbZkGvPyhw9yyHXUlk2Lr776SsArIHjPrpV4 kQq8AuwEXrkB
vHLDxCggEkBzIHgjSvBegNjjHviLZmaHAa/gURZOufpINtWO2w/WoSOh74Gh AbFBZ5Klq6+6
EsgIIMA577rrrwXrkAEQEiGsmwY8iYuF6HVh0NljUOgCzanwf0dBuldeBQiD t0ukd0Q/iBZm
ESIQJAfzCk1LOKqWg61vuA6Ydfttt4SFbEAVngBYw71kLZoyAl6Bp2AjGCZ6 36lThl1zNdQp
zBlO9XvGjmKBtmtZEr010+uwjDwCODKziTGx8OpVs1wgdfIw8B/AS+CVpAGv gFqYVxjT1EQ4
1Oi5s8fdestNYl5hjLCVmzZLQD/0mHbRYscxN/PaH19PF0pIjwF8G/BK5gVe hWIfefh+gVfi
ggj5Dx0FAEWM6e+bb0J/PPoJhz+jaKzwY+oZCpmfJA06gYlEgFLgJohvAxYA vNLrHwOvKQeB
j2BT5N1z5XCiMbjD8mrEvAIcyQyvFSVgLMTctS6F4Q3+GNdcc5V7BfqSSRMG gbFgXnkFjHmA
YpgOOIih3KxnLKlgK3xzAa/wwZQOCAjBNjig+x3uBVvUT4AgdQ/l5Hbi+MEw mvC1Brzy9gHW
gFdQ6XHwGn4cvLpQLKiLDLh5Zb6sBCozw6E+vf/FhtQEsgd4BYfh63IfHHN6 FMZftWIGxXTX
t7h+fTre4eKJE1FF0TJCseSwJYRl757t4HTdbzYOUpZZbP67wTSEZRwQEPDK jLnbN4ArniEE
Dp2UjlEElgQKu7xF0+NatcB/AKo11r3SK6pF09/ddDJ8ZDwImIKTE8ArtuIr A7zWrPEiStwL
tpCJafh7/YceJFHXRZbgMsmGgaouyJt04ETwGn8cvMYDXnF4AES6F2NxJTDW 5TuCkX32mSeZ
+sA4fA4487Rt3YhBC1lC4eIFE9k9zf1JJjRr4lo6lpZydNWKmXjQcvPrz98A mlUhWzX/E+b1
OHhNPA5eXTcGvJKEA7wmHgeviYDX996p+9efDRiNqHStWv4FNOe/e16FypyA jCut4x63xZR5
5RiCme5r1qxZnBSQbXdEn03PnZkksGPx4sWcQZCtHt8F2LEVQONxRBbZYNty TihQ5rnhgNls
dUqVL5LZqioWAhmC1zQ80IM3huxcHrJzhfkL3rH80P71OBnu3Zen0xyEPrFz 7uzDyRSsLM/f
+pN1TqgMfAJUfmoRN75kW8dhcBydL8JWxmmB424DQ+eMnjp9yMhhAwYP6j84 gL8BgwP6DBrS
duicuISMmNdLb3jo2WVP1dpXoeaOp2sFl71p83llrjxy1MW5agwxf/78DN0G 2BsSlwDm/piB
pV95753XmIu/5uorly2eitcas3L01o0b/QQ8ZcaTEHo4sBfT6CA8cBJoBsBa p3Y1nCPpm1s0
b8hkHxO+eKTt2rEC5hU9blS6gR5IN3h/cgOjSU/GhD4us+AhVmuhnBO/YENJ CxQIkoBnhbxh
BQkzpLgNcL9j63I6UcABnRYJAYhhbhAgpFmT396v94YzhIk/5lVBnKBM3CjB ghSWzqlTh+ZQ
R6AT1megk7Xh6GeFR5061YHUdN50Y4BXFq4x0QkthHKcCz/75L0ZqLricooA vgRuvvRSFegu
Sg1JA3gFcuGKCi3n3m9oDnG1vIYJTfwEKGajP39gqp01T8899xSYKXDlTDID zkAGUhNICjOK
5WFeQbFCxsBWwum5r7r6SiTJCcTkV19+CPAiHNAMPmBmFpQGQ4bLKSgE8AfX xXvhfeGm6Voh
17cjK8TLln0ASArD5JYZQEJgBW4AjuPGDGQhkcArSJE5dLwRuMEdAg3gFfRT RrwAIbnxT/gE
B8HAObB9KFy6cAql6N2jHXPWX3z2PsAOrHbDjdfS64NKXc4JqYeYWAd8UzpS 6Ylk304sV/rh
+y+pSIBm3jhvAQoQnvXnn76qV+91rWOD+P/n718+/eRdnAQAlJddfklqchj4 mORYbq+dp+bO
Ge/62as9qYNsfv75W8A070LMK8js/+69a9HCyejnHgJ71syxyKONEjHpj+vz kEHdQEiDA7oy
YyDmlboB4MOT1e2QEIEB3YgzihtcwxfMm4SDMh9LwMCu3333af3vvkAbSFTM a5fOLYCY8+dN
pC5RMRiETJwwlDlxXgEp4lbx3bef792zgeK7liWlRcCMurlYF0Wqm/Ztm8Da zpk9njerWLh+
/vF7fQZa6KSqBPTvzJcC7J49yyVDwSny119++NNP37EM8eGH79+/f+svP33T 4LvPEhMPM5Dg
A0EGc+FMPH7sELeSzpi6/ref/NP4d9KlUGJe4aQBsjOmj1EUBm+jRwVwT4q4 UpAWE/Sigfko
wM1iXvlwTAi4vNFfP7k9IhIb/fkT4HjK5FHAU5LDnp9+8l7Dhr+0bvUXpLKY V/xxwfqTJo54
7VWXDC3PwAE94T4pET/x68BQQHDsxoAEPD1kcHcqOY/wZKDN4XunyWL8k56e /MvPX5sbvJaB
1JiIJKiHP/34JfMSyOClrRsUukZfY4bwYZIWNY0BAw64nTo2JyGUE8g8DOSu cxeRYse80luz
5/+97uv+++/fuxcfp2wu0Ann3TgPJnBGAApwCJY5jCA7ZT495yRYAI3HEVmg Zw6P5XwvZf6R
Rx7R/GHW19GjRzlCzBwbm514sX+eIXiNiz7cr9Gjw9s+N7pjtVEdqo7uWHVK 9+oTOr0wrWfd
o4fD3vvo29Vr1+W65Fu3buVgtlyzkuzgedNNN3FAWq4zkNOIpMiiAg6zoBY9 88wzIO9sM89B
xJx1bMFrTk2N/DHwumLTvn7TVveYsLzXpJX9pq3lf48JK3pPWrli877UVE9C O+xgyP9OKX35
6X/dUKbDdaXbXl+mw2Vn/VGq1Bk//fz9P//889dffzVp0qRBgwalS5cGwpo8 yecVLAX/R49L
F04LTgiQlE1qgGjM4jFBz/QonU2d2tVhxZglh9phPg7mtd67dQFkrP2HBwUa 0lUgCa0IbmB9
MR5ysKc4jAJAwYJA1c0bFx+72bCQG1Sxizg3qF2+ZBrusG5v0X14ubHSH4UA KTLDcmwmOtHM
gi24QBi4xx97hN6R/gl6la4FmMtUKQK1alUhJ4TA2LnmUsl2+Ufef+8NQPN7 79ZlgT8KwZe7
d650LfdxaXgR/USndAiDb+jnwEZXXXV5ZLhrFwLwH6bALDyl54ZkotTvvPWq +1CGbTwFneO9
hzXQdvlllzIrTVrAU4rGHDeLS0AhxKXzRjNwnxtikcO1btDM/Y6tyyBQkSFL gGN8J95/j/VJ
uyGzyTPFWbZ4CrOZrNDCPQBSU1uxAuaAlQi4F18vJhANvDKcYtEJXc0jub3y 1J3D53CgvO32
W4gFYnN5NcyfSEJYm5vPP6vHSm3CtdgLE2EEnvITg4PgpR+dEJxAKNwrSYhH rCsCc4D2YLgl
g9kbfPfpwnkTP/rwLVIH/Xz0ATfB+Ol+9+2nkOLn4B7gdkIgOXhTtH34wZts EYB/iDTwk3Ac
NvjJ38cfvQPKcVPRI9DJqADkDSjXU7BLetoRqHrFZf0WEBPcz5oh7bTPngws xElLPYRbtitR
lKcdXb546rHcPl6W5VNAOkYO5MTlNOL28oSHBvkpJDHxACuWPnfdhHHz2Sfv pqUdZVGaNHz1
1YduFjkAG1KXGHWA5omVnhaO3wgCvFMQKuws9/y519EnMe5yM9BHSYuRxpef v5+YeNDcsGLy
iy8+SE+LZKGeYuFtzAAAqhIvEYUwzc32W8iYkB8afAHIgynHrRN8yUDFvevZ JiotIx+XY0zZ
B7/9htSjZ013/QSd//TDl0RhXPHdN5+QEzm4f+uC1FFYGxmMQOkYj0keaAgi pID4Z4OJeUp5
mVrBkcOEsMBrUEDXBvXBzUfBf1QGNOCZLQ2Mr2A0XXC8wRcklxgXFNC/S4P6 n4NKccZAwLVg
Kz2OJCSPWnh6xPr36cj8Pht18R3xfvEcYEIfBp1FhBgfUyQmhvft08HcsHIL vxTgLHGph4xt
fuY+0UWi64aREvgeBpfJAVA4f7i7wGQzFmWlqas9eeQB1oqRunPnuGIEXumh AwMDOaFqx44d
Hp2QuFi4KIXTnc+ZM8eEQKpx6GvPnj0REBvKGl9xn5Ln0FeQ5fr16xXLhIso JRAZJWHShaz1
liREwgBi4HL//v2JbvhXEC3ZMAdxGVXKDKfCKoTcLliwwIRA6YGDOeEWASZ/ yaRYWIAIdDIh
nCWm7LEVOjcLFy4krtOVLhcddhFGyRC8RkeE9W/xYnTk4pT0LcmpG+IS1wfu XrFo0/wJkwbN
X7KyRp23n3mxxrKVKzV3j31kE44IFqrDdNjEubDbGcIxbBz8O2HCBN4pL4sD hEVq8lN2IFB8
uQkh0IRQecCFeikS4F5PyYCxpEKoHmvWrFGgt4zSJZ9OMOo9448GUpQMdUCU KhVYjL6Ti1UI
+40CXm+/HR7BxfopV6g1T00mFUImUatAhSxfvrwIq0TRJp3B8bBHDmZD9fOp v/xy7bKP3vvw
I3c/XNb190jZ/2ONFwOOe45fGnlQY8zLpuq7V/fPvOTSS3AMgHqhR9HR3s4b Wn/5ULp2RT24
lXs6LZANHZ7ZX52f7t7IJebeOX8rJBY32sqUe/eOqq5Aba3qvGGGFzTAKn4d T6CnZvd1FxcY
68qAFh2j0/w0+jMIcedZsfDjNAuWlbp55PETrheXiUsvvThk/3otvfIWNqoQ 2LfbtfMUTpOw
0cKscnDUtj7aZdbk3FhMmxJIjLxJ5lhW3eFGQDf0oHTnEKVARp3SpM0Ejkue kIpTOWvzoTDJ
ITPpLZv9AdRzucPGasNaR0LufUxNuZwadK/sadtOIynXWPdWoP/JSMwox3NR mXTvbBo+eEDX
G3FCSDmEr6q0EW7K65GK+SljkpZbUvcnZMnrpySPbchqMuDKm3t3TyNPCHWP n9pj1b0N6rFY
zhBX0u5Hzptj2XMrxBvExAVeyybaEJeRgLlXcmB9kaza7fi4PDVHEXWjfLo0 KJYxgqkt2qnU
IeNKiPcL9G/VouF9995NVVEsl7vwMT2S8fi507khq+4lw8jTKU8IoykeUSiT SQQYszlC2CpV
Cv+7kRO2UXhcQNusHhOWjHvBlusjkjytk4rAUETvDnkGt1Rpoefff60P9Wu2 aDU37v1cydV/
m7l6y7hfjWvTWWNSRj54jb/wwtN0wcczUyT7vObDbgOc/ko/bbpVdWm0/PTl 9AKiM6dOnQra
AzhyOiM/77vvvunTp9NP09lDecLUsn04sThF9oknnqhQoQIdM/L068BiBBAT oUs4sa655hoC
4QxANoBmHqENeUAtR86iga1v6OkJAf2IUuWYWUKISx5Q+/DDD4eG4gvkuiDn oOgGDhwIauGC
c0GM+dzKlSujCjpZ2JqrZs2aCgGJ0g+SjTvuuOPxxx/fvn078FckMefHoo2c UNJu3bpVr14d
HpdScDgtcStWrAg+E5wtXleG4DXyaFi3JjXj4wPT03enp++ITtzyw8BZn/WY /GHTXp/92gLw
+sSzVT/79jshSI7w5XX06NGjRo0a2Bwcz+G9vBrMAjDF5thZIVQABgMQ5Oed dx6YgmOHOWcY
Ouzuu+/mKS+Xt8NYgjU22JPovHQszOumGvCikSEJNBAX3DxixAiOGqZCQpM/ 9dRTkqdyIs/i
HCoV8lQw+RhQwUgdmapVqyJDPpHhFSNDLKcHLbjzkksucfqNIE990GuFNmby mUQ51AltXNQE
skQSVFqxsxxBTEG4Qe2AAQMQIGJQUJDkqWwbNmxAfvz48ZKnjlGZydKkSZPI EjK1atUqsS6z
nuAVP5Vli2fyP9vvig+S5iY01PyF8tN5UfMYOZmXTdWnV9iyaRHAS8DRgFGD HYVl9aeFC+be
ebqPCffW4H7kipjZDXlYv3b+O2+/wpS0IGMmmo0S5efYT0fS3iFbcUjwXSG7 1QaumMXkOKyz
1ux7Kzfp0tFCoELuQiUylQlIUpQsMnbiI4/iHDevO1GnHhJasnAyVKjO01KJ XAL/Sf73dpxx
6Z5hHJXDd99+jcVeplDO6Iri8WeUO994hpInWinTw6IANGzIxWZVoIoMDxN2 1rFsE82RsMmh
yb9Hlc6iXJk98shAxjZ0HJ1l5IG5+HkzIa69JrJO2jsV75x7yLiOnBjeBwIV g3uUN7OfPmY+
29xmWz2yLWy2OWT8Bj2sKs2uAh7MaC7eo+MDZ4XofpajsREecwUZFrYYMa+A V/p+Q1yp7wCf
ARPpfQVkEYAlArOKe6NfANsBWYAO+Caa7oa+HOw4Y8YMUA7g4MEHH1TvzoQs MiRELELoy4UU
SUI3hCNP1w4GRQNY+YILLlBcuSUAMuj7kTFxTaJwYzgAADuEs8uXLw8YBYAO GTIEVQAFYJNS
oQgKAbYCT8FS8kDgsHTgO/0d97gTkA1gCkUAPIHJuMAxw4YNIy5ApEyZMr74 VGTbBReyQIbg
NeJo2N8Nnl++pP+G9WPXrR25fu2oLRvHrF45aMa4TocPHQK8fv5dg+SUY56H wDh2mgN1kfN9
+/YBFrEM91gDi/FqsLlCsKRC7rrrLhHkGh7onnfB+9I9owisOmjQICqYpuDN wAC8y0vp3bv3
G2+8Yebl4c6Rh3pnAIM81YZKhR4qGK+eEN4a1Q+ZPn36kArkKADayQ0bs6O/ du3aiq6L2k4U
6h4IuF+/fnXq1BH+QRtXr169qDBUIVGtukTWksm3337bBEq+e/fu1FX4Wkyh RwB0wD0ayCRD
IGQ6d+58+eWX+/mitAKqqBkwrwWUElUfMuPwgU3x0Xv4T9N8qCj+SPfIwc3k ASKkqPKggrtz
skU5ydYULuGwzUxl8hfnW5RsdWYoQEJHD21xJZHDt6PiHMthlIvTyqmGfJQn M+GHtlKKon3F
+Vii3Kmi+BGHcV/ZXUB2OBi6IeJIAerPXanzK9bBkA1YT1U6OmJn/toQ5TDK MZG7uMkww2HB
69yncRbgFXI0MV/2eaX/BswJX5oLDAEyEB0LdLjzzjsFVUF1hBAFsAi4JERw VqumYGrFhJ17
7rlAAbpqZIC8TAEjA14hFggDAbkokIRuCMcnAVjADRqg3ypVqgTKofsH9yAA KuIR3T8hHu4N
cKjogRc0mRfcJM9SBWkKnwrOgPMjBA0XX3wx2QaLCIYCXoFWBrySkKAtcI2n 6L/iiivAYdIG
C4h8Ab7XglGdIXhlkNKv8/fN/3qvScMPXH9/ftD0zw+a/PHukF6/Hzl8sO2/ XZx5wT7YWSuo
eDVAVSyje4zDq+H1KYQXpBBegeR5iSau7iEgodKpIVgVMSAgFYAbs/6P5Ni+ ho0/AaBoYPQC
rGQ4hDwviEtEqUAwFYxqRpWj4onjR3O9evV4v9zAtUPJoz9r08K2su2PWFKo X9W6iRMnoo2L
0pEEtZeKYeAm6eLeBh9MYSU/btw4xJAHs5JbvhpMoRlsvgVmDMgGqUgnP997 772CeeH+rtUT
vKakJLONay7W9yki9TuzErMXAYfLRYUHRUXst3/WAtYChWGB8AL+1gpaf9G2 FR6ly9/CGm2Z
qI04ui8+rmAhTn6BV7Dpyy+/DJvl9AgEnoL/YKfUI0CRwiEB3YQAQBKCs2AO MaOAXVZNGUqS
Dp6nBryKwaVrJ5bAqzQTHShDuoTTtYOH5H7ABXxkmhjEAKTgJ1hHcZHxWLAl 8OpcNwa4BG4e
Psw2FMdU4WPAHLHxiwVPkByF0oIt5CHAdC+kLvAKv0gIwBdtBrCSh+K4R4E3 eA2PTVsYuGPZ
+qCYE3ckSk5NX7M1ODktnb/Vm4NSUo5tQwSaBOJHRrp2vAGeUj2ENLAtFCmv Gy5WIYB+hbBg
S6+At8y71j2vj5cIAYkGhWB5qgQhvBGFcDGagvkmIu4fPCJ13pEeUUkAiAQa /TwFCwJznRp4
xZKn4qEfCta5skre2M46r+GTM4Qi8OqlBIwOGMWxFSOYTFIZ+CioogyQSI56 bgpFDQeb4ntJ
YSXPeInVhNDAHhqyXRZmkjuZbjJwG1i1Yn4uPHISE+OJmJRU/Fx5TqbXacti LWAtYC3gowXy
C7wqOVz0mGnVOhIu99IIF6LlHsYLIgqSiW5YDBPojQlWeus333xTMmAaJmFZ /wTFxU6Ll156
KU8hxsAThsGFhCMWmIPOW0QvGzLS8dN5Q/2i+fXXX2euHw2TJ0/GZ5EUwUBy S5CLKmQbMswy
k6JZsEXSIAxhXF0gXTI8fPhwVMGc4eyIEmaBmfonBG6M7AFcXn311aFDh+Kp CTzF+5CnqB09
ejQonMwYlwb0ow3PS+LiNgAlbNxtfXxT/iDmAV7jElMa9V9dsV67Zz/s2HLo huMA1ZXT+ISk
lxv06z5+Y6eRa+v+yKHZxy6GB8BH3Cr4DTzlBeH9icWwIb7OvFCspBBeIrYl hEqFxfANAIMC
bbnn6eDBg/EW5SlOorxorMocPRWDd8RbwKkDGTCfgCAcJ9aG7aZy8h6pisgz TQ9sRR79kmdO
H6RLCHnAyRUZ/E+4593B7/KTRF966SUnNPL2eeWlM6HvBLhUKpLGExcNOEBT bwGgJEoSJErd
pjJTLTEI0JbskUnMwiPkO3XqBF6nFGQDDQTiJAD8peJRcMlQEIps3QZcNYxx T9iB/bliXl0R
s2Be/eHzs3mwFrAWsBawFpAF8he8Cr9qNhMySTPm9Lv6Kc4S/KdJfEAAeEUz 9fTuyAjPsTRH
GliMAhn27rvvgifeeust0aLATaEWIK9ITRSywAXwClAWnyptEFQwnYQjIDYX ngwZ8bKs8TIp
8hNejUfocVYMAAFkGGLlypUT3jIhBDLPKwaRCWXwREQE+zofU8tT9FM0ULIB qQCaZ599lkd4
fGpmvNhdHuB1/4HwR15tmpiUcjQipuxrTcOjjm3rSwh0bNshyy994vtrnvml y6jVS9bsSnG7
fmJ8xiem+BgN22IT7Cz4ZULA92ITeYkI8E6pNhdeeCEz8vyESZX1GDOwaE8V TKudeCm8ekKo
ikShtsiLgLrBPf+VIvIISB5PFbxBCGHIQaLolCsCIBIB3qA8DeQG4LzQT7Vx +rwSQq12hkgD
ypUotZEQ1pmpkrMTHJWZ/0JcRFfFVorIg+AJZ30ROeSC/QXBE8LHJQ1koNhV pPzKcL4xr+De
tavm4bmU05wlp6Yt27g3x9FymoyVtxawFrAWsBZwWCDfwau17klsAS/wevTB lxtT3vj4xIfq
NI44Dl4TkpJrftnlsbfbnl/2m4vKf/f42+1erd8DLjaPloHChGX3OF0ijzqJ ziCKZU8sfoJY
BQjmYs4573nIVgOlJodczFEAZ0umk4C3lbx9XnPAvLr2ngiPXr0teNXW/YHb gtftCgvctp/7
1duDD0X4eCxK2o7dQeU+aHsgzOUtZC9rAWsBawFrgcKxgAWvhWPnkyMVVq24 VxAeI5oOHo2p
/Hmv6Ys2T5i7vsbXfQ+Fx67auC8mLilwU1BScmqXMesee6fDU/U6953sWmmX 9yto//46dV6J
j89+H6QcpQUt6tqk/cEHvYnVHOkpUOHdu/eQQ65XXnERsfaSBfLEvMYnJvWb vLzLmMVdxy7u
Nm5J93FL+M89IQOnrUxK9uFUt7SUFt2HV/moUYf+47J+JQw+8IbBU0QEu8fP nL5OJgvGjBlj
j7XIqd2svLWAtcBJYwEXeG3CuepJycnx9s9aIGsLJHH0eERwUlKcxBKTEkYt DKr4bovnPmg7
ffWh/QcO1fu1x+ad+z78vfe23UFv/dRj5fajC9aHvvlDt6joyLzbNiUF2JqW kpyQd1VODSh0
H77t+ktNScxf5fmlzV12f89kfhXWRz3pacnjlx9sNGxPKdMc58jnNTwmvnnA 7GSvo4fjEhKb
D5odE5/94q3Z6w9U+fif939qVf3z5ku3h2fRK+CtUsp9SQbnGO7POOOM3J1c jMvIJ5984p9z
BCdN12gLYi1gLVDkFjgclbRyRxR/3aeH8Edz/0m3bfw9/MMq/qo0XpOaHB4T FWr/rAWytkB0
VGhkeBD/jVh8bFhi/CH+uImJPpAQdzD2+P/EuIPxMWEugbiDMVEH8sO2B2Kj w/JDj0dVPxAb
E+b6KxDl+fVZFYtM5ldhfdKTnho1dknwCeA1KSkhcOUCHzcNiIiJbzFodlSM a1dh5xUcGkJ4
XOKxrYkzbL4jI8LHL9r8zt9Dvmrcs0H3uV806l6v6fBpy7bFRmfszI4XMxtV 4JQN+QpyZUUn
LvOsJdTBJywMZL3hyJEjSQt3aVaD8tOEAFJNyKhRo5BhrSt7WLCklNWLklS4 LmnjxAuW+Fn/
kiLvfW0GrAWsBbKwQFRciuDp4PlhwNNmo/YJnj72y2rgaaW/1+mnwCtzbRJG oXUbsPXKdwuw
pgq3Adsh+m4xK1mgFsjA5/VAKBuz+TDjz0q9mPg2Q+cFhx4YOKBfz57d+evR o3u/Pj3WrQ1s
PWRuVExcSPAeDusK2e/6b3aBTUhMHj9v7R/tBz7/fsMv/+7eOGDRrLkL/hyw 8LM/O7/w/p+N
Ow+ZsniT2RnOFJ5t4bRVNV7brD/VziZstsdaQnwAWEjIhhH8Z1cL1qj+73// e+yxx1idx7JE
QtiE4tRTT2WZJyGsWyQEDWzawrYpp59+ugkHqgKL2aQDWIwkLibsRF0cN+Qr 0BpjlVsLWAsU
sgUSk1OFOEcuOQgAbTM+SHi0YsM1wFP+6yfhPEVGwsTKOp8WvBbyeyzWyWVy SEGxLpPNfDG2
QAY+rzCvPs6nA17bDV+wY/euFytXevxx4GL5xx4rV/mFZ5cuXUj40YioVcvn RkdHrlzm+r98
6WwRusT6qOmQql+0euPLhh+3HBMwafHihfP7jl/8YfMRr3/xR5UvWn/VZiQr Fj2MylYp7PwM
hGW6n8ORv/76a/ZL4wgKnSaHOyw+rOyLpt3+ALWKzt4c2uuY/aIVgsMA2+/p 4EGdXaFw9kkh
nE3XtBWFQthlTfrtZS1gLWAtUKAWEOKkRRZFKjwKbwo8hUPVT1hVHsGwShjO NS9ZsuA1L9Yr
iXHTiuUmXyXxTZWAMueVeW0eMCskNCQlKTou9mhs9OHoyINHD+xetWJR84Ez 4xOzaljXrd/4
ZathH/z676etx3UcueijFqM//LV9/XYjtx8/kcUbvMKVQgmzXyBnvvEUL1jA JYegMOPPVm3Q
pSwbJIQDCYG5uAQgw8ZpOrDYnDLHqRXsFQfA1anZhAuest0a4ZJUCCyvBa8l 4BOwRbQWKCQL
rNsbA+KctvqI4OlXvbaDR+u02ij3U8FTvLj0VPAUj9WCy5wFrwVn25NPM7sN xMUcsm4DJ9+b
LaYlyhvzGpvQpP/0rZtW7tywcNPKWRtWzNiwYvr6pZMXzh5HeNY+r9iLLTea jVr/zrf/vNMo
4J3vmrSfeOwgwQxNCfPK6RQ4CQBeP/74YzYKYBdo4CZHDp5//vmKgvOrAKjh WdkNGD7Vybyy
NQZHa4h5FXjVki/Aq86X03EXXHC0FrwW02pts20tUCQW2B0WD+KcsyFcAPT7 fjvBo2+02yx4
Wq/jFn7+Omi3ni7eEokwUYokqyQKMjacrqCz/bMWsBawFigWFmDYz0zUCbsN +O7zGhOf1HbI
7MFjJwwaMaz/oEH9Bge4/gYN7BUwuP2wud5T/95tdEJi4ls/d3nzi18/+Kt3 uvtEjcwuOFSO
ltZJJ7rgUFmwRXi9evW6d+/OEqtmzZpxOBvMK/C0a9euhPz77784GMChcnYc h7Mp5KuvvuIM
YnhcgC8axNHihEBc3BLQhlsCkk2bNgUu5/uuyEXVUdl0rQWsBfJuAdhK5+J9 kCgNPahU8JT2
lJ9gVsFTUCzCW4P91/WIvKk49s9awFrAWqB4WQC/qf/AKyurfPd55cy3FZv3 9Z60sufEFfzX
X89JK/tOWRW4NSg1SzB6rBdJS128PPDBt5uv27Ax69O5YEwhXJ0eqAphCSS+ BJwmxxKrihUr
EgIAveiii7QMi7PaxKGyU4FCzHlrQFgkP//8c8FTnBCIyw2cLrFY/oU29NgF W3nv760Ga4Fi
ZAGzt1Tf2aHee0vVaLreuXgfHwCae/wBilEBbVatBawFrAVODgvkknnNl8JH xCY06jU124Wx
vqfFLgQcUuyUZ2+Byy+/3EcNeCawrxbLv3r27AmcteDVR7tZMWuB4mIBj72l zOJ9j72lOk0O
9thbqrgU0ObTWsBawFqgJFggl8yrf5qGHQbYkQAMarKnIwl8dADATfbZZ59l +dfrr7/unwW0
ubIWsBbI2gIee0sBQ7PYW8os3s/HIbR9QdYC1gLWAtYCBW2B/8Ark/BHDocx F1/QSVr91gLW
AtYCebGAFu977C3FtL733lI4AOTL3lJ5ya2Nay1gLWAtYC2Qvxb4D7zGxcWM Ht4rLq7wVhgk
JycF7dsJaM7fIllt1gLWAsXdAlpOlNneUlq877G3FAuqinupbf6tBawFrAWs BXyxwH/glXME
1q1Z6uPxsL6ozlYmIT6eJWJA2GwlrYC1gLXASWYB7S3FplEZ7i3FJlN+tbfU SWZ8WxxrAWsB
a4FibYGiXLCVkpzM5lzWUaFYVyCbeWuBzCzgsbcURKn33lJs119c9payL9pa wFrAWsBawE8s
4GReXVtlFSbzmp6WvC5wvp8YwmbDWsBaIKcW8Nhbio2jtTpKW5967C2Fi6rd WyqnFrby1gLW
AtYC1gLeFihs5pUj5sKORK3cEsQ2sfxfs+OA7gO37j8UntWOiTExqTNnuo5X TkiI69+/f+/j
F2cKTJkyxU/o28jIyBkzZuRXZvr06TNixIgSWGsPHjw4e/Zsvyo4WwvPmTMn X7LEDhi5U8WG
xPPmzcuXPPiuxCzeZ2E+FKnZW6piwzXA00p/rxNa1d5SI5cc1Ooo3/VbSWsB awFrAWsBa4Gc
WqCwmde4hKQ+k5Z1G7u4+7glPcYv1V+3cUu6jl08cOrK5JRM9zrYuTPhnHMC J0yITE4Or1y5
0tPHr4cffphDYp1HGBgTcPor0JZr1KhRAMFhw4ZxqIHvBkIne75OnTpVYDQq KgpgmrWGNWvW
XHHFFVlsEEuWlBmw9+jRozPLTEREBNnmYIU33njD9wz7j+Thw4dnzZqV6/xg 8xtvvDHX0bON
yGltI0eO1PBn+vTp2cojwFu77bbbfJHMVmbIkCH33XcfeWBkojz4aKsBAwZw BnK2+nMhIMQJ
9ASAmr2lAKbOxfvAVp6avaXYMDUXCdko1gLWAtYC1gLWAnm3QGEzr0ej4poF zPbmJmPiEpoH
zI5PzHTxVnBw0imnrCxVagX41VlsNme95ZZbQJbetggLC3v++edBt6VKlXri iSc4PSspKQeL
w3bv3k1ELmlev349wDRDlGyS3rdvHxAni21lOa4WhaBSsHe1atVAThnStCtW rLjuuuvy/nbz
rgEgngXIzkw/aCwv6JNBQgGhNGV45syZvAUNf6gVvvCgnF7x0EMP5d2eaJg4 ceJjjz02d+7c
U089VXmoW7euL5QqqLd8+fJ5zwPHywmym/l9sadM+gNPzd5SuATkPS2rwT8t wNhDO4vZP2sB
awFrgWJnAWiUwmZew6PjWgyaHR373zkCatyDgoMJT0jKlM4BvMK8liq17LTT Vo4fH2G6hO3b
t2cGXiXDhK8HZyavA7g3niYmJkKvigpViLl27tzJ0bK1a9eeNm0agRzWdeut t4p5hRZFHjbO
CCvk77//JjO4RhDet29fb3oVavaOO+5QLHLupGmVBzLDo40bN/KIg75MEno6 duxYnsLLLliw
gJwbWOl8CrlLQRQC5FJaZMlJ9/JTnN/48eMz61xB1Qg0btz4vffeO3LkyMKF CwGyyp4ecYHD
FJ2TdZ0hS5YsueqqqwiZPHlydHS0oTknTZok+UOHDkkeAYUwrlAITiCgyXvv vZdAyqIUjTxP
JU9mJA8fCRB0hkDcSoZRhDNXDGaEU0mUIY1kAMq8Vm4YBUnYcLEMVBSCDFEe fPBBxDC+rEq9
Mk+lysgPHDiQF6T8Swa4LBl8Bpo1a/bXX39NmDCBU4sVyFu4++679VTyxmuC UZlCyDmVoVy5
cohBbBOdGxwJzFOpwnFFIQEBAYsXL1aGFSIrqcicgSydCrFXSbMAa+kAryWt 1La8ubdA6gmc
Ue712JjWAnm2AMsnWP5b2Mwr4LXN0HnBoSH9+vbu3r0rf926de3Xu/vaNYGt h84F1Ibs352Y
kBDs/r8/aJchJo+D1xWlSi0/9dSV/fodTk52YcRsweu2bdsAlEAohPk/aNCg ihUrQndVqVIF
ghCEesopp8DLKgSMYhwDQJDgFf7jlqCE7rzzTqDA4MGDRZhVrVoVHBAeHg5Y UcgjjzwCUCZk
6NChL730EsCXeX+wrykF4BUlenckzWG2wD4ABwgMPIH8m2++CaTYsmVL6dKl IWjffvtt6dfT
t956i6erV6++5JJLBCu9n5IEtCLnhJGfmjVrIs8MNUhFIUKiQG20caHf4CpT o4RNW7dujfwH
H3xAOGCUrJJivXr1iN6rVy+Vl1xBGRLSo0cPhVBqQgIDA8uUKcPPb775Zvny 5Ybm5KmmyDGm
MkB+kAeNde3aVRrq168PzAKlcVLan3/++f777yMPWWjk58+fD5bt3Lmz5O+6 66577rkHN9nu
3btLhkwiQ0i3bt1q1KiBzBdffIESsL5ODwYB86ZUXvJz8803c8PgRNFJEehJ 9H///VdJ/PLL
L7zEChUqUH+45+hg5KkYksdEyIOM27dvL3nqQNmyZUHDnTp1MjJCirCn999/ Pzf4DBjwyhiA
UhC4du1ayX/00UeLFi1CQ5s2baSzUaNGgObnnnuOGtigQYPPP/8ceWqC5MkS UBU8rbfGRZ3n
P2fOtWvXzsgYfnfdunU8pbLxon0hffPc2lgF/mUBC1796334d27Yiz06MiQt zR5g5N/vqcTk
zhO8JiUlrF61sKB3GwC8thuxYMeunVVerPzkk+CBJypUeLx61UrLli1qN3xB eGRk4Ip50VGR
q9z/VyybA7bTG3GAV/Drstq1dyQkuL6lHIFXQCGMphQGBQXdcMMNTNCL9FLI 5ZdfLpjLxRQ/
j4CYgCEQnrDssmXLrr32WgngV3DTTTcRYqb49+zZ88ADD6xateqCCy4A4wJQ oNnOPvts464g
ShWgBg8K2BKowiHh3HPPBe8i36RJk0svvRTAZ+bNBQT1FPhIDpEH2r777ruC L8TFnZen8L4o
B2jiUqkcbtiw4fbbbwcGUVJTsckwjDLyXKBDojvrPCCsbdu2derUASGZcEp0 zjnnCLSBC402
wsknWBOoJGHZE5oWOyjE0KjcG1tB/SoDv//+O2AODaI/dQGn+Nm0adOff/5Z IYwoJA92hDQF
cVIuPaJ0VCM0YDfJkHPobWTOPPNMcuIshQrFI14ZxDYXJOj3339PIO9I0X/4 4Qdm50GrYGIT
F7zLqIMs/fbbbwqE+pU8aJvBD8MeIw/1i78KDO6VV14pGV709ddfTyzY00cf fZQbqFMqj/Lw
xx9/qKTgdcl//fXXzzzzDIysMaPiYm1qCHlWHuB6jX5ShKU2vg2Q9NWrVwcW U10lA8g2RlN0
8DovGrAuHtdeJccCFrz68q5pE2hbaNBoFX2RP1llLHg9Wd9sMS1XBsxraMi+ HC1pykXJw6Pj
mwfMCg0LSUmOiY89GhdzJCbqYHjY7hXLF7YImJm120Dp0rgNQOMtq1dvt0k6 R+DVycICZIEC
wC9ACdO7KCQEEKZ7LsCrMBmgFqZz69at0HUrV65EXl6tQENgojMEWAkU4z9k LcwW+KNy5crg
LTkSKAlwJ+GAEoMawRBAQyMPNAGSkoogL3iXp7DF0gZCJc+aVVcenE9BtwBf WltxvdwD9ZYu
XWpCCITeIwrauF588cWGDRs636MIRbCOk5GFWTQpAgcN3OcenMd/8xRoC2kK oDQhwEqD6rjH
PvCscKLKAHaAEkaDAdxkBhIR9P/yyy9rphsSFJ5V8kR/9tlnQbcG1YER6WCA xUB8ycCIQ5oy
tIB2BZzhJWJmzFVSomN8TMolOAtnSRRFJ+fYmYl7w84iAN696KKLcE6lgPyE 0QTiS55ahPsy
HLyRh+IFSlIoBgmSQQBOlIgGvAKOeao8CLniA4CM5LEYLDWI2enkChKlHkKW Y15Vy1atWkme
N4LzLgKGzWXsBHilFFRFyWCNDh06ON814zReNAMYCHJnuL0/6S2QBXhdvmlv x1ELmR9rN+zY
X9uh8/ibumxzfOIxKsHYh5aNakb104XTfx5Nx5iQj4WZljzqITpDO1TxmWSt igafFmPv3r0e
YnwdNI8MCKED8NHKe37QwEQZaQkKM4XCXB8tT75oLlAlFrwWqHmt8pxaoKiY 1/gm/adv27Ry
x/oFG1fM3LBi+obl0zcsnTR/1jjCswCvISFJp5++qlSppR98cEIrA7KBpctw wZYs4gSswESY
S4XjXwj95mReCYG9czKvcnIFqXzyyScABZATcPCaa66RBto7liUBDU0IbTeg ihDncisPtwH5
vNJyvf7668OHD+ce+GvYXH6CGoGniAm8OrlePSXPzDJrmEHD6kyLp8gDfA14 BVGBokT76QKJ
On/Ko9d5MSkP1sHlAFJQXragJQNYAYImOqww4YRo5l1lIW+gQxMC82qAKdYD loHzrr76asnz
Rli9hIzhbglEABAG+qTvgcUk/1CYkmdgAFRFwPgxYwFCEDM5RMz4rfI2ISP1 gugz5LTg9HmV
Wl6EMSNFAFB6KMQOBDKAka+Icz8EMoC5cOc1GSB1wCt0pkHYvA4NBhCT3wh+ wBTcaXbIeFMo
DFipUiX8BORjoAs8CqpmuEIeQKV0q4ZJRTkdIaBZjrlcsLagCrCpiF4uYIFx cqUTFetMzgGv
zmzY+5JggczAK2C048iF7F24O/ToHsffrpAjbYfODT3iuS6WmTE+LpxP+Ehp BxhY0t7mxYBk
AMcnpiDyokRx+fZpN7LNDw0pKXqvsuUbITquO3nPidFA08rkmCA+poOkyC9Y nI+Z9FZlwWuB
mtcqz6kFioZ5jY5LbDtk9qAxEwYOG9p30KC+gwLcfwN7DBzy7/B5bCqZWTH2 7Elkq4F3392d
lhbfr19fzbdywTVeeOGFBnF6RwceAUmFboGhzLZ36dKFiHgTfvvtt9CrNL4Q ewr59NNPTSsG
TsJFUkQsuAfHTbg3EBXTrMz7Iw+cRQMkAX4FCmH+F22EIAO5iG9o8+bNocqM 8wNoD/SsBouG
DHAGvAAEkyu8CJDHzYDZeQAoC54EXvFbQIOeMm0NjBZcFnglLZ7icspTJpR5 CtDkqcArFCbw
muYb11JkyCGYiZ/vvPMO8lz//PMPjzK0OdkDrgGJgFDQjQZeY09SlPE1s08I ChVCHgiBYFYI
AA5sB1TVU5LjKTY3GcCAgF2FSAZkCfgTPqZ0UKctWrTAPsrwV199BdMJgDPy 3333HbP2vCyj
k7eAzyijGuRZNsdrFb0KtqMmcEOuDLZW2QGs+BMric8++wwIiFeoSQJ8jxEE r0maLPGaeOmS
530xQqD/M2bBIRXwSs9ksgT7jlqt1vrpp5/Qg/Or8X5WHnhxaJBO6g/QljGM yQOwmyjCx4xe
Xn31VYyPmOSxDwiecCOPBQCvCpEM7hB4IxCdyQqcH3i5HqR7TlsQK198LZAF eG01eG7o4f9W
xKqMaSmJLQfN3n/Qc9UObRQjKAZ1EqO+4ZYt3hTakurKYFX4j7aOnwzGoEJF 1tIaE047hiQf
NY9ocwjBFVs+8WJzmQlx0pO0pQzhCGdQymSFUhGXSaP3wgsvoIrvF0d/fjIi 5bM1mvkqeUpE
JaQLgpaVCTSzyqE0sw6BjNFwwV/wE21I8snwlLksuhvacIb3NHS0BuRW2WCe hG+cOTTyDPaV
cn6SKPNR3DOABLwyRuXr3rVrF22O8kkLRnTGmfQ+mJTJKOWEkCy6tkKrfha8 FpqpbUK+WKBo
mNeU1FSG9X2nrOw9eWXfqYEBMzf0nRLYe/Kq/tMC12wLNtPr3gUIDU368kvX gDUi4ggtheZb
uRjr48yXxR5YNJGACQNJaT7gtIioLVRpSZlBZmmUCTFJ8whXRW3aChJiGhdA wD2qaASRp+mR
MABXITTcwF9CYA64JwQ44iwLTrHoNFgWtXJdRQMcGPKCkgzNv/zyS+PCAU2r wgKYeAqABsOZ
RWC0knqqtU20wjyVJWlV0eM22gkaaDEVRSXK4iInZBh4Cso0YmRb0VVYLjoP hQDRnCHMR4PX
8ZTQUy0z4uKlKAS7AaoIoX9SCECT5HAklST9IvdGP52TwB8h+BVw0WHIX5b3 JQ3KKoBYP0G3
UgUWFIoFVjo9evWUVyN5kvj1118Jwc4K4SfgWPnkAtcCwek4jTxwmXBspSzR vYlspheXjAGs
hoRmXKFA50VfKHmqqBxbKb5CcBfBkoBgycNh4y7MsMfII0A4b1x5gPTV1gT4 gUjGQFWYY+/i
e+TE/jy5LZAFeMVhYNf+sPRU2lSAVHxiYnx8XOSB4N3NB84IOezJvAq88kEZ c+HJrcEVYy3R
sQyAGfIxXGRZKtWeTx7nGR7xoVFdiUjFJlySVFcUUr0BnTj8IMYkA5I0a0qC phVClFkIotDG
Mv/AVBI9At87eJfBOeFEAeCiioExqwUIUQfBGJV7xoEoNB4O4FQwLo0DrvzK M4NnckIrxPQX
czJEocFkuoPRL08ZynIPBXDxxRdTWGYzaIGBpDxlwoT+iNkVJUErRzuMNdBA LCA7OkGuSEJA
8JQhOk5cgGDmSdCMmxAyFATQLBOhiqaA9rZoa6MFr0Vrf5u6hwWKhnn1yMSh A56eRoX8nmhV
tQLdXgVkAXoC53Kx/EqFLQ60DgnfUwNP80t57vTQxyhLUMUG6TpV0eN6sK25 SyiLWLBcygMU
uCC4vawFvC2QBXhl4eyOfSE1a1Sjruq668475s2e0m743JDDxxazGoUe4JXx NvJATyCaoWPl
W8VoitEgEZnDMTc0v4QAOqEYmb44/fTTGRnCdIIyGebBTSohokiSC/6SwSoE J/dMMTGG5IYW
BgANBoXjRBWjxzPOOANcCAMqSS5G+7h96+lpp51mnFyZlAOkAqAhiUUGQy4A K8kD2kQbM/gH
nuopRRbYBWRrK0M0AM1FtTJjhjA3IGzlDWBNopDBsCSMgeFTabsI5z+2IhUy rxBwOemiGRlx
vZAaRk8RVmMLXovQ+DZpbwsUDfPqzEdCfNzyJbOTk4tyL3TaF+jALM7EslUn jxag13GytnnU
ZqLDT2gdkv8sNqL7VJa8KVVlGw+KzB7ll1nADcqDyGB7WQtkaIEswGvbYfO3 7Qlasnj+5MkT
Jk0aN3HCmLGjh65fvbjFwOkhRzIGr8BEpQJ4BQhSCUGNADVCAIIKYe4eKpQQ cC0EJDeCjEy7
i92EeYXIJMSAVwFWIB1R+N6VhMCrPFm5gbuF3QQFEtHwrHxogGDwH/StfBiI BRcL5SnmFYxo
qFwneBUTDPo0cFZihADBhblhaskPEFM79BECbAW80pWQVW7AuCQHtMUCYlVJ FC95MqN9vgVq
WbdKtrW8QQgbCCsam4JonRnzSyg0+LuoKrMFr0VleZtuhhbwBK9U0MOHD2R4 4JO1oLWAtYC1
gLXASWOBzMFreush89ZsWB95eO+B/dtDg7aE7N0ctGPtupVzm/SdHJoReAVB gsmEXJltZ8sL
oBtADfhIoKhZwVmBVx4JvBLOlDrgzOwtAJgjBI6W/3JtF3glihO8EkXglRuB V1RpqajZW4Dl
sEQHFwqPglCZYRNqVB7MQi4eCYwS3YBXE2LAK/yomGCALEXWNjWCs4BXoK3A KzcCr9IARyv/
WnxkBYjJqjIJeFW2+W/gLLGQQdKAVxRa8HrSfHe2IPliAU/wGhcXM2p4z7i4 2HzR7osSONeg
fTsBzb4IO2WSkxLdEe2eyTm1nJW3FrAWsBZIzxS8pgNe586dN3P14kmLZoxc OGM4fwumD5s/
bXjjXhNCjx7bRtBYkEYYupSLmW7AnznzD5zKQiWtOoLpFJwVGAVxColyQwje BVqfBBZkCz/t
Ngh4hdcUdys6U8CXC1UkJ58EbsCggFcQHiFcWvkE8AVDM+eOBjy/taILxKyn QEP23jY+r4BX
A0aFaJ3wVMAaXA6mZJUV0bWfjACr4Cz3QFuBV24EXrnBM4FsKwMgVLbGIxsU GWoZ1wVyC1QF
pILyOdNEC8XAsoBdNBvwih4LXu0Xay3gtIC320DihnXLs1j5lO/mS0iI51iE XLgN4G+wZtXC
lBTPTQfzPYdWobWAtYC1wMlngSz2eZ2waGOzfpMb9xrXuOdY/f3t/us3aVlU XAbbnQIKmRZn
dZHzQBAsxvQ3IdqTmAsxrZrlRm5a5gZcqOgwuDwCQYICwXaSBx+buOanhwYE tIULZCd6dDCy
LnAwIWbBlrJEQqanQz8LJUmR/1ILVDUhzq2sQJZExydBmoHgeoo8GUChsqob nmrFrTJAojhX
aB0tm8mgRClKBmYaGTAx98gQV9nD6UIKi7YGWreBorW/Td3DAkW/YCslOZlj EXJBoIJ3fYnI
8BcmgMUrU6ZM8nr9CaNHj+IRyzlzkQFbmawFrAWsBYqvBbIAr3EJScGHo4MO Ru0/FO38i4xN
OH7WSvEtt815bixgwWturGbjFJgF/GDBVm6ZV7Zx2bB6QbaWYfMjNmflOvXU Mp077+/e/XD3
7ofcf0eaNOG8A9fF+UPFYpvobAtrBawFrAWsBXy0gD0e1kdDWTEsYMGrrQZ+ ZYFixrwy6A89
HLV8075lm/Yu37wvcHvosk37lm7au3JL0KFwT08sGdqA11Klznr66fXPPrvj 2We3uv92lS8/
W+AVP6R8Aa8sQWU9aQkhcVlqYI6wymOdZrmu9xFfvuhkCxv2K/VF0spYC1gL eFgA8Fq9yZqU
5PDoqFD7Zy2QjQUiQyLDg6IjQ6yhrAWK3ALpqVFjlwQ3GranlGnUkpIS8EBN SsqfQ5x96S1y
5PMaG5/Ya8KyHuOW9By/tOeEZdzzv8f4pd3GLgmYujI5o8Vb7iOsXi1T5vmP PvoEVyJnlhIT
2XT6FR59+OEn5sgAI4C/AR4FuPwLjOLRDzA1RwZkWDScqNgIMIstt3SOPMdH ye3J46cv5nLK
gPmGDRuWxZkOviukdOzjzQleXOz47UtENrVxnmfrS5TMZADBrMYA+ps8cPyV Lwrx92BZgy+S
VsZawFrAG7zWaLouLS05JTnB/lkLZG2BpKS46Mjg5OT4E8RSElNT6Xgz/EtK SU60VrUWKAgL
4Ao+fvnBE8Ar4AxH0qwhWv72ATnyeT0cEds8YPYJCNSdm6jY+OYBsxKSMl68 xQ7Tt92W8TkI
bDid2SM2QBEvq/KyZJUzXXVObGYXa1dZOup9QLaRZ/0BCtmFWyEsIOXnBRdc kDuyljWwed/f
FKiNTzBLHMgJB8NwcYqYLzwoawtYG5svlYE1CiwrZgWDyQP7PvpCqZJPc1pV XnLCimCOfs2L
BhvXWqDYWcC6DRS7V1aEGU5LS4V29SCAijA/NukSboFi5vN6JDK2xaDZsXGu 9afOa09QEOGJ
yRnvt7VtW8Itt6yPjs5gU60tW+J5FBOTwSP29sMX9pVXXoEoJS3We7LPi2A9 Z8TDULKrtslD
z549Cfnzzz+RERWqEKcMgSwsRWfdunVBZuyeHRAQwE7ykI5EgXfs0aMHUaBm kYT3hVVVCKcd
EgJuhph0hkDcskAV0pRURJrqrBcu0LBCevfunRkSlUyjRo04oAH4yBaMigt/ zKE13JBDDy4W
flohQD0W8wq8AtaVZ7bXNk+lysj36dNHYNSEsGu3ZOCPOR/rt99+41hFNqBR IMtydSIXxLl0
Gi4WtK0QHcAo8IopZCW2oTFPpYrsKYQ8cGKkM0Rvlovi16pVSzoVYi9rgZPe Aha8nvSvOB8L
mKHPa0JcxPjub49sV2NUh9rOvxFtq0/u/UFykmdPnY/5sapKuAWKmc8r4JVD t4NDQ3r26Na5
c0f+OnXq2Ltnl9VrVhEeExsXHLQrMSF+v/u/2QU2d+CVzfk4zY//wE1qCTtX szUgm/mBOMVQ
cgI1jgQgPE7fVggHAMK8EjJo0CC4Q4DvW2+9BUIyTDa4kL39IHE5t5r/nCII nAUCgiNx30Se
6+233545cyYbAUJDchg9ajmghRDkPUJArmwcyBYzhAOCjSQgEuisEOAgaXm4 Fgi2tmzZEoEP
P/yQ0sF6wn3qY2AzFzLGDbsMKkvvvvsusA8n165du6qkX3/9NeCVsgANgb8f fPAB8rgXS/69
994DVjrlQcZkFSQK+JZMvXr15DIrnwFuOB+czR2VB5Rz/g03DCGMPAJo6Nix o/Lw448/ElK+
fHlgPdj3o48+Qp4ddiRPlngKMu7QoYPksTNIF3TbpUsXI2P4XTKPDKexYxkD avk8KjZc80m3
bc1G7es+PWTljqjdYbY5LuFt5slTfD8ErwxNq1atag4sOHlsXfxLkiF4jYk4 ENDk8Z0b+wbv
Hh20c7j+QvaM2ba626BmTyXEReWx3MyJUR+ynvDMYxI2ejG1QHFjXqPi2o9Y uH3njhdfrPTU
U08++WSFJys8Uat6laXLFrcbsTAiMipwxfzoqIhV7v8rls3BJ8ENaHLDvLLN HnCHDaiBQUAc
fgKtAHkcl6KXDdzB4ZIQ4/rJlwZYZAoevAt+hRBt1qzZmWeeaVaDgQvZOpum +dNPP+3cuTPw
i30QwcQCl8grCmAOYGrQJAAXQteJLxXCNoHsaw1riE5lCajNVtvQlsYTFMIY /U63BNBbmzZt
QG8NGjQwtZY8c3y2GMomTZqYo1yVJeApmZk/fz77gZso5IefCJvDTimF5Bs2 bEiWkBcq5WJz
RFAmGbvwwgsl8/PPP1988cU8wndW+ecpOFt5IMX69esTCO6X/C+//MJYAgxN cUwegKeU959/
/vn1118VCLMreXLFOemAfiNPftgInSiXXnqpZCgmPsrOT5c9xrHMO++8Yzjs qLgUMOvIJQcB
r6DYOq02PvzDqjfabf6q13ZC+H54mphsT8oopg1gic52kYNX2qUXX3yRcw10 0XjCEdBo6Fyu
/LqYxQIAmWO38kttSdOTCXgNG9bmxbj4lenpu1LTt+kvPX13VMTCYW2reIBX qAc6LL1rOm9f
FknjaAeTwrRkSbO2LW+2FsiAeQ0J3lvIPq+k6KPT55GoOHxbw8JCUpJi4uOO xsUciYk8GB62
e9myBS0CZiZlgiHCwjiEcF+GtggNzfQRaBWASCxaPWAWrarOPuHDY2dpwiFH YfII4VQY+bnq
YBj+48YKjff888/TaEIKGuIT8ArYQhJCsXTp0tyQCtHhSvv27fvcc88RhbNY UKKDCrUxNffg
NuAsIVpYphBgK20BIBKQbbbCJpOCuTIpsTzAK3AWVhgPBKc7ARkjP2SA67PP PiOieFPywwUK
5FwZsLJBycoDxcRBVuQl8sBxycPIPv7447CnxhUBhAp4JUoZ1se5L3hrYDoR QZNSS7Z5qjwI
PYOz4U0lT7ngoQGgFNy8SvxuQcPQpRC9BMJet2/fXvKIoYd0jTx8KuAVo517 7rmSgdJu1aqV
s2LQnmIZELmMkNm1NTh28ZZIwCsO4yDax35ZbQnabNsaK+BvFihy8ArPyniV uSy+fS6dWcUU
jU7hyq8LnyLNceWXwpKpJ0PwGh1xYFDLFyOOLk1M3pqQuNH1l7AxOXXb4QNz B7X0BK8sI6En
pd+haxg7dmzlypV5NVkbk26XXhjXuJJpc1vqLCyQAfO6JnBRIe82QIo+nrAF eG3Sf9qOzSu3
r1uwccWMDcunr18+bcOSSfNmjmvaf0aGPq8Muzt2HHLFFa1HjTrmZOkwR0KH DoN5NHLkeG/0
DKwEaLpWsIWGAmWaN28OFAMLOnlW/DJpcOUhysWCLR0baNhZAp1uA2BE/ApI C0DMzDtPdU4g
7p6AMCkBBaKEptwgRUafsBHeIWJePcArwNE4jKKNuB7glUAcG4Bu4E7gqVxF ybPH6is4zosu
ukhZglEGUpNJ59L+BQsWkDoFqVGjBg6pHCEDoyl5oLnkDVOrYxVFlBr743TB vSGznW4DkkGt
YUZ5HZzrCJNK3+bUQCDsOFAYd1WgKn2hnmJqBvf4JBh5Mgx4JVFDaSOmPHBR T7BG48aNscwP
P/xgkvDxxhK0PhrKivmPBfwBvNIe0lwYmzB6BKwIaAJu+FTl6sPPSpUqMc6n baSZ5RH3tMyE
05y+8MILSPKIxpMQRq085aLFJgQBGmSaUFQpir1yYYEMwWts1KFefz8zYsAP o4f9OXroH66/
IX+MGfbXsL7f9mlaKSnhhPXNgFderrpaHLpo26GB6Izos3h9+LmJi4WghXHg 9fHG6R+5gbJh
cTM/udFT5HnLonKoHrxZvXECCVEfigyNeWEycbmwqo2SawsUM+aV813aDpk9 aPSEAUOH9gkY
1DsggL8+AQO7DRjSceSCpJQMZm/NPq//+1/pjh2DunaFUDzo/jvSuHFWhxRA oILG5G3Dl6Zt
AYBxH3/8MW6XAB3gLDPvtLz4FSiEyWvAEyH4X3bq1IkQODwcRs3JfmC4yy67 zLmXFmQkDSvj
S5TAXBKF+XQwH+4EqJKSpk2bMgkOGmNmXzIKAbzS9ANVQc/6RAkBT0sbnp3S xied4XZatBp8
6tWqVWOKnKGwgX2qTKBeco4GLmbwSYgeBUdVhbCdFthUqF2usdCo5il7IHjI owGHYKcGXAuw
JIZt166dHBhgcJ2gnxBmD5nBV4pffPEF8BoIa1IB2gI9ta4LTwzygFnef/99 yeOYQddF24cD
rkK+/PJL4KwzhPeFGNGpJH/99RfWcLpS5PqjMhEtQZt3G1oNBWeBIgevgA8w Jc0dbRRQIyQk
hJaKwTbtZO3atVkGSoNGOwME4bNFkjWs0AegHBaMMt4GzdAgMAhnBI4ko19Q LK5TtAlDhgxB
gNEsbgnIMGeFNsbJvkxVF5zBi7XmTJjXg72aVtm1fUxo6Ozg/TP0Fxo6Z9um Yb2bVfdwGwC8
8hIh17EDvSTvHUoVLMs75fXxTuFBeFm8VmbSeH0sEaEbomIokJ6O6kFPp5N1 6YOYOtMjXj3y
TJqhkxDGNoQgQ9dGldBMqb1OMgsUM+Y1JSV1xeagflNW9Z2yqt/U1frrOzVw 4PQ163aEpJ24
jatelfOQgmeeWf/cczufe26b+2/3Y48dO6SAeWTvRg33R8hRAU1Ge2CjTz5h p9h0Qvg2ADpg
OyUBaacQviIwlmS4JwTk5KwxZAZg59xTlhBRsCihjZYSmD++QI5OwPeAEK2p Yrr/nHPOcYYQ
FwgLVAUaajhrNs8Cc7/mvphqZ8osi71gGdGSZ9oIb9zG+FWT+JTu+++/Rz/u DQqhFKRrotAq
fffdd1jJyIu8pJ1SNkCNQpmgVcl89dVX/ASwGr9Y+ifvPNCfSZ5OCCBOFBNC 2bEJfsOyMEUg
BM8BI4/DBuGMy5UHqF/5v4K2JWOSo+FTfgr6sgRtQVvY6vfdAkUOXml1mYph eQAfIBfNJiEA
WYbuoBAQJw5LTEyxtyDjWLg02mRKx9wX5Cs3TAQBc2lYGNYiCSHHAgMkGbVK QDJMChGiuPbK
tQUyBK9R4WHdm1aPjVnOkubU9M36oyMKPzK/R9Oa8bEnTPfTdLMahKkwXjFT c2BTkCi9TIUK
FXh9zDTSVRHIUl3TRdJW80559bxE5ZweBJ805AG11ASqChVAHRzCeNxRAYhC ZUCGiuHBFuW6
+Daiv1mgmDGvuTAf38Ybb7wB9PziC7wYT9giNinp6BtvvM4jvAK8DynIRVr5 GIVvVUv+zUXj
7hGSRXLa8J8Ln1H8R/PlIINclA7wqmywGZYWYHlc+D95sK25SCXrKFQA5YHd FXLhD5Dv+fFW
aAnaQjCyTcLbAkUOXkGrTNEw9DV5Y/EAyIb5KKAJ3yzNIBeTYDRojDzZSwRJ 8K5ukAS8AlBY
fClJBsC0OZr2QYAxPAgYbcjYHQzy+AlkCF4jw8M6/V3z6NGlSQ6f15TUbQdD 53X+u5YHeGXe
ktYewoK+jBcnuAm9AkHOu8MLlpcFGOX1GSdXEbSDBw9mnQZ9NF4f8O6sfEAe VpXXih7QsLhV
+BT8BzSekQwrUqgJRdX95dHgNnrWFihmzGvJeZ006LCbTn8dPDsJ8XFlG6Ss yEWxxUV10WE4
eVbvbGTItuZvbplGVB5EHheLyxK0xeI1FfdM+gN4xQnSubcA4BUsAuyAhzO+ sEyb0FAAZ4VZ
mavRDZKgE8IN/EWS7x1Qa8ArkBcZUA4zM8X9fRVt/jN2G4g81OznF//t2LRz 9387d2vn+uva
rkv3f9u1a9Tqt+qJ8Sf4vNKFgUSNE53gJp6vCoGX1UgD8CrXAi5eNGMVYOuU KVNY2AC0Bf6q
EwT48lqRpxoI7PKKtYTa7DADTYv/iXUbKNqaU0Cpe4JXKujhQ6E+IqR8yZNr 4qBwU8yXbFsl
1gKFbAFL0BaywU/65IocvAJKmNaXzysXc76gGfk4Mu5lNplAAAqu7XCoYBoP 8ArwxXGIKKza
lNcsCzpZwG6WfBGLewS48Lk3a7xO+jdbEAXMhHk92OJ3HE8n7t03f9eeOfrb F7Rw7dpRLf+o
HR93wmYCjDF43QaYkkm8RNgxRsutGJOw7gKgiUurQrRgi/eOTx3CLHLAs47K gBeB5AGyjHbw
baXm8PaBubgcoIElHPxEBlcxBkKFiWcKwvJWZ4YW8ASvcXExo4b3jItz1ZXC uWKiIkkxIaHw
9n5nL4V9e7bbCl0479emUnAWsARtwdm2JGgucvAqtoz1OvJ5BbWAPICtWoHA ElUF6l2AXBXu
fYOjJJLokSQ6tVaBRh5hEXuQdsjYBVu5rtgZgtfwoweb/fFybCyWh9jedPxv +9GjC5r/8Upc
7AnglRfBq/Fe/g++1ItmKKLsKYTXCjZl4GGiaA81I2+2P9MSLtbzAY716lWp 0JDr8tqIfm4B
b7eBxA3rVjiJ/YIuQGJCAikWpstpfFzsmlWL7A4aBf1mrf4isYAlaIvE7MUx UX8Ar8XRbiUz
z5mB179/rn3kCD6vW8w+r/i8hobM+/uXOrEngtcCshuLdLWEy70rxUZLSxWQ nf1NrfeCreSQ
4D2FCeyAraRYmBUuOSmJFNPSsjkVCTca9ldiaypzDRgwgMG8XmFUVCThHAxb mDn3t9pj81Ms
LGAJ2mLxmgo/kxa8Fr7Ni2+KGe82EHn0x6+q/PFj7b9/q9tIf7/W/fu3139r UPPX+rXi4wtj
Chc2XSdcWJ61+NauXOQ8wwVbiwv9kILFPh5SkIsSekeBeV0buDhbgM54ju2Z Kld+oW7dF199
9UW2i3vrrbciIzmB6cj48REhIaGEvPnmm9nqyZc8WyXWAvlrAUvQ5q89i6M2 wGv1JmtSksOj
I0Ptn7VAdhYIiQwPio4McYpFRuzfsXXphrVzvf92blseFRGcnc58qHix0QfS U6P4S0uJjI7K
B4WFkGebRB4tkJ4aOXZJMCdcljItb0qKZV49u6Fp09IXLjwWuGtXYqlSS849 d7V7vWPxu9g3
ihO/ss4327VmK1PIJceNCZ6bDXG802XzFHNKViHn6iRLzhK0J9kLzbY4buZ1 XVpackpKov2z
FsjaAklJ8dGRwcnJ8U6x1BSXP3FmlzWptUABWSA9PWX88oMngNekpIQ1gZZ5 /e9j7NCBs7UW
liq1dNy4CEL37QO8rrj++nVZfLEscWVfOg64kr/BwIEDfdlnjjWYHHCaRycE DhFASRbJcUgJ
Kzqzzg875DlP24qIiGDDRXYqUZG1dav5mW0H6SHAmQgcfpOjWFDg//77Lzy3 DoDwuCiv89Da
HGm2wtlawBK02Zqo+ApYt4Hi++4KP+epaanQrh57pRd+NmyK1gKygPV5zbQm xMSk/vtvGFD1
tdd2Vqu27fTTV02cGLF3b+Jpp6284ILVnTuHTZrkgrPeF0smOUuWo7DAW1wc cOoLJGUFpccB
rbmoo6y45AjZLDwZcAxiA8WsNbPPCPvtGRkciSjORRddpBAWePKTo01ykT2i sAlOTvdbhQZm
t5TMkps+fTr7quQuMzZWLixgCdpcGM0/o1jw6p/vxT9zlaHPq39m1eaqJFig hPq8rglclC2g
3LUrAcL1uuuOkayg2Msu46jlhDPPXFW6dGD58pvOOCNwzJhw97l0J1zsuc3e hN61R1ys4R1h
NJ0h7K19+eWXcyAW+30cPXoUxKYccs8xVEz3z549G890OF1pFq2LsDMhEDD7 MzvBK9ElqTl3
9othU+hOnToRwmHfiktCkuGIcH6CgJ3glQNLQK6cc8seingU9OrVC1zOLnpI QvQqIoed8JMS
BQQEZBYyevRoFQfneqckR1QrG5ROcXv06AEkNeUSE2wyzHGvEuMsbGSQ5OxH buRaYDLDHiv6
OX78+JLwJRdtGS1BW7T2z13q2YJXGjePv5wm5MukU051WvkisYAFr0Vidpto ZhYooczrgZB9
iQnx+/ftZH/ZIK//+/ZuZ3Jkz56kU0+FZA3s3Plg06ahgNfbblu/bRuIduWd d24MC0sm5Lzz
Vicne6JXmFdgKDPdAk9MsoPY+vbty+kvdevWfffdd9lsGXyJsybn1ioEeEqs MmXKcBAUZ9Xq
bFhtWMZ+deyzTQgIsmHDhh9++CET93369JE2MKXTT8AbvHKiN2Jc9erVIxUO WiQVthSBEubo
EZAfeLRnz55GhhDYWSf4xtOAjUjQzF7iHGfCyXtstif6lgPEFfH9998nIlmF lBXfzGl+HAMI
TvUImTNnDsDXGc7xvMBijkIBuCsuTCrbTZsqCxN87rnnEv7ll18SyDaQShRT EHHWrFkPP/ww
rgWMBEgUMc4h47AWALoRy7WTg204cm0BS9Dm2nSFFjEL8Lp0454OIxe0HjK3 zdB57UcsaDts
Xpsh89oMnTt5yab4xGSPHIJQ+e4YNtMg6BHtGFvE86m+/PLL9mirQnuhBZqQ Ba8Fal6rPKcW
KInMKwcxBK6YHx0dsXrlAv4Hev1fuXwu4HXv3iQ8BOBZX3hh25NPbi1Vavkd d2ww4PXgQRd4
LVMmA/DKttiALZpvQbGPP/6Y3bbPO+88dtqCN23cuPEZZ5whQgJcS0jTpk05 LATkZyb04Uc5
8k7gFbz44IMPwuaec845YERC0MY9HCdxgbNnn322YZG9wSvycL1INmrUiMl3 gCmHkaiWAGRJ
hRDyhgDXr7/+CscJ8ypiVRfYkQzQA33++ecg8j/++IMQg24V8bfffiMKMJez TxSLM/qgbxcs
WEBchVBAYnGeClCYcCOp5AC1YHRJUgqRqboAwUaYn+ytpkR//PHHhx56aN68 eZyODYT93//+
x72isITrwgsvlBhY9rLLLjPa7E0RWsAStEVofO+kMwOvtE4g11Vb9+8LCw86 GLH/UCT/g8Ii
9oaFtx06N/SI6yhO54U88zkMUw1OZfTOT1yMmFDS4ZzI0EyZlsrjp1+ZxWYm QwtY8Gorhl9Z
wJt5TSnkfV5TCn2fVx9fgNttYEmZMoHIR0Wlcn/ppWs2b44vVWrZGWes+v33 /YDXzz7bm5Li
ybwCNM3ZykoLOCtWFSxbrVo1ECfz5r179xYDWr58eQAlIBW0Zw6D8QCvUJUG 2tIfAF4Vl+Oe
QaWmRB7glWl9tqqVJKcjwlAKIgs6A1vZ2BmXVvImnF2jRo3WrVt7MK9AVUgU 5MkhiJAbQiBH
oWxRrojoAZISbkAnc/3lypXT0X/K3ty5cympwCv/jSTuEBziB5w1koQ43Vih V40wDGv79u2V
KMgVBwYAK9H37NkD7frqq6/ickBCwGgQucRq1apFoXx86VaskC2QIUFbp9XG T7pt6z49ZOSS
gyt3RCFTyLkqIcllAV5bDZ4bcviYT/9LtWrs2L7FBUBTElsOmr3/YKSHfRhP 0kTgwkQDQuvE
l4gfESNSPI7YTJAT7ZGvUqUKMjRxzAXxk0aJRpLRrCFrS4jNi28xLXgtvu/u pMx5BidsrV1d
qLsNMH1PioW5z6uPL/LIkdQvv4xo2DBG8tz/808sZGiDBlGffRb+9tuH//nH xSh4XzCacJw6
pE4Xjfg111xjfjKLDUCEnVUIbgDgMJCfWQUltwE9ZeoN8hLQSbuvc8gAss71 UjghGMcysZsm
IRDk+eefr594KQBedQy0QnRsNDLwviYKnKWTWCXcrN/imL4ffviBEKAhMBSI eemllyoi/RPg
GEhqKFKQLn2VB/NKETIEr8BZmFeTDVjbzMArDqzGMuSfM82BqkYYjgfEDO6H rHW67eJZYQpo
b/zfArvD4sGsgNdmo/aBYis2XPPYL6u5YWMUAhdviYTB9f9S+H8OswCveAvs 2h/GRkiRkeG0
XQsWzE9Jigvdv6v5wBkhhz2ZV4bcfG60ewyMadmArQyJy5Ytq1aL1qxmzZrM MvFd0yxER0cD
ZHGv5ymXs530f4uV5Bxa8FqS374flj0Dn9fg/YV9whYp8mH4m3ViYqKGDOk+ cGCXjh07du7c
cdCgrgMG4FfZMSCgC/f88SjDE7ZouJmnZsGQKRHswgcffABliCqIUrxad+7c +dFHHykERAgY
JQQHA0LQCY+IQ6ee1q9fH1QH6AS0CbyCFPEfYAafp3/++SeSZjKO7uHMM8/U o0GDBgF8kcSX
lJ/fffcdjqT0FqVLl1YIOfn999+BpGjgJxcuAV9//TWI0wm1QbcGL6pEAprQ ySYim1gBmkkd
rwOp+uuvvyCYSc6EkFVC5PMK4rz++uulDU9cMDQzjJhIcb/66ivjbIAAWN8I 00HivCsxzIUY
vCwUDi6zhMAEt2zZknJB/1Bwif388884PPhb7bL5yZEFEpNTgbO0VoDXr3pt f6Pd5od/WGUJ
2hzZ0Fs4C/DafsTCHfuCq1erwreJmxMf4F133D5v9pR2w+eFHD7hwHrUAl4Z MTLjtHv37ief
fJIvmmEknzmwlQEzQ3c2s9NHijDrMmleaHbymHkbvZAtYMFrIRvcJpe1BTJg XtcUOvNKin7I
vLKqvWrVqpWyvFhr5b0vFVAVxCkHAHOx+SvndaEMwKdAEwIP8e233xJCi1+5 cmXWYJl75MkD
rqj0CmBckxZH1ypfn376qTMVFioxda5HgGMeGUn0AFURYKWXBAykg/pViFkR 5dzNCpAqwtVc
eLZJgIVoiohyICOuunggKAQQjABEiwlRGVmXBoRFw08//SSFAE28V7nByYEV bFxPPfWU8X8l
HMBqhPlJEZQEDhjNmjVDIW7EwHQFmqwyO+kRYtuCk8wClqDN4wvNAry2HTZ/ 256gNYHLZsyY
fPXVV3Xu/O+cmZPXr1nSYuD0kCMZg1e+U/IDzKXF4EacK1Mx+OgzGqdx4LsG CvPtg2v56vOY
eRu9kC1gwWshG9wml7UFLPNqa0i+WQAS9LrrrnOqI8T3EwQAr7DFXLioOtFq vuXPKjrZLWAJ
2hy94czBa3rrIfPWbFgfdXjf/t0bb7npxqkTRxzav3ntijn/9JkcmhF4ZbQJ PCV1ZpDwBBAX
Kw97c+I8MzMs5CIQzyUQLUNxe7Z2jt5X0Qpb8Fq09repe1jAMq+2SuSbBSBB PThaQnyHoRA2
4krxcMi3PFlFJd4ClqDNrApkCl7TAa9zZ8+dGbho4oJpIwb3bT9jQsCCGcPm TR3WuNfE0KPH
lgEYtYKqAq+68A0Q84o3P+H4vOI2gJMPyyuZX2KepEKFCoQgYxdsFZcP1ILX 4vKmSkg+PcEr
FfTQwZDC9EBl8O1O0bUhv72sBawFrAUK2gKWoJWFs9jnddLiTU37T/m71/jG vca1HDjtnz4T
GvUc93fPcQOmLI+OS/R4QSwYhXB1evmbEPydCMdJACAL82oistpSIXbBVkHX 9vzSb8FrflnS
6skXC3iCV/ZAHTWsR1xc4S3mjYmKJEUOC8iX8lgl1gLWAtYCubBACSRoswCv nERw4GhMyJGY
0ON/3PMHcvU+UzAX1rZRip0FLHgtdq/s5M5wBm4DGzes9FhsVKAmSExMIMWU FM9TWwo0Uavc
WsBawFogawuc9ARttsfD2hpiLWAsYMGrrQx+ZQG7YMuvXofNjLWAtYBfW+Bk ImgBr9WbrElJ
Do+ODLV/1gLZWSAkMjwoOjIkOzFbl6wFCtwC6amRY5cEs/N3KdNdJCUlrl29 hP+F2IGkbFq7
uBCTs0lZC1gLWAvkmwWKL0HrZl7XpaUlp6Qk2j9rgawtkJwUHx0ZnJycYA1l LVDkFkhPTxm/
/OAJ4JXp++D9uwt6BxPc+YMPRSxev3vhut2L1u9ZviV4kft+yYY9B7wOznZ2 MlFRKRMmuA4t
jI+P6czeg8cv9qLnQMKCzraP3R3bpo4bNy6/MkMR+/Xr52PS/izGya4TJ07M lxyy1WvuVAUH
B9vTtvLlFVglWVugWBC01m3AVmPfLZCalgrtyiHBvkexktYCBWeBDI+HLXDm NS4hqdeEpb0m
LuszaXnfycf+ek9a3nPC0v6TVyQnZ3raFnsInnHGqmHDwlNTI156qRbb/uvi mFDOso+NzWCd
Gbv0d3JfnFzFyVK9e/fOEazkKIGAgIDRo0drP4SIiIhsgan3CVse748DEgcM GCDgjfLM3i5H
AHBkFFtHcVhUwdWA3GkGoGNPFWH48OG+KOHIVueptr5EyUwGAMppYeQBWK88 8IJ8Uci7u+mm
m3yRtDLWAvlrAT8kaC14zd9XfHJrsz6vJ/f7LXaly9DntcCZ16NRcc0CZsO/ etgrNj6hecCs
+MQTzqZyyoSEJJ166spSpZaDX53hhw4dYpdscKr3C+BMwho1aoBuS5Uq9dxz z7399ts5Wo7G
WaxE5JJmTpHh6NcMUbJJOigoiINknBvHeOSKjWNQCCoFdteuXXvs2LEZ7hTG bt75hfbyWC/Z
mnHgwIFOJZxgThE0cnjllVd84UF1MGwec6LoCxcuvO+++xYvXmzywLFhvlCq yHDkT97zQK0Y
MWJE3vVYDSXcAkVL0GYNXlPT0lJh20788/19wRF4t/DZRmfnrBdeeKGYHh6b I1okW1P4m4AF
r/72Rkp4foqGeQ2PjmsxaHa0F1G6b/9+whOSMmVeg4OTSpcOLFVq2SmnrBg6 9Kh5eTR2mYFX
yXDWK4DS+bLldQB9SCAtJuAMXtaEGEn2077gggs4s3TMmDEEsus+nJ+wJr4K yMOhGmGF/Pzz
z2RGDbdCPJAf1CwbdCsW+yNy6ozZ7FB5EB0LxgUot23b1iQhlpEzqHgKLzt9 +nTlXKr0dPDg
wdyD4w0zOmTIEAmQbckoivlpBLw/huTkZOQ5n/aTTz7hKSOBCRMmcAN8vPfe eyXPJuQC2Qwh
PLhYxgkKGTly5IIFCwReRWZLm3kqVRRHIV26dJk8ebIzBLcQyeAz0Lx587// /nvWrFmcnK5A
lN9www3chIaGSoPeFxfIWyEMErCYwCsMugyFNvNU8mTP5IFT2p0hELeSAbsz 6pBOhdjLWiBf
LFCYBG0W4BUPrn9HLGg1eG6bocf+OLaAv0mLN8Yleu4MQyvBudabNm3CAtxz 3jUHaL388suc
BJtTmzDmv+aaa9atW5fTiAUkT0P6/PPP426Uof7IyEie0ubwFEmMwKnUBZST IldrwWuRvwKb
AacFioZ5Bby2GTpvf0hwp47/tmnTir/WrVt17th2zepVrYfOjY6J3bd3Ozu/ 6v/e3dvMoQmA
13POAbyugHzlf5cuB5OTXRgxW/DK6U0ASubr1cr06tVLrGGtWrVgDYl+yimn 0AwpBKRFEywz
gSA5GIZ2+dxzz1VCd955JweZ9unTRxpeeuml8ePHE9KzZ0/jw8B5M4Qwqf3m m2++9dZb9erV
c9KrgFeUSD8cHgiV5JgE79GjBygZefwE4AgByiQKQfvRRx8dPnwY/eYpwA7I CKoWrFTqSou4
egorSWNKlurUqUMIyBK8rhCiABy7deuGPNcHH3xAETw+DMHWxo0bI//FF1/o KVP/ZcqU4WbR
okVO8Ep/QyCH5Ujhhx9+OGXKFJIAi8smP/74I/iybNmykNa//PLLp59+ijwn nkueAk6dOpUB
Rrt27SQPxMREuMni72FkxO9SFsYPygyvRhkDTHOoOjcMNiT/8ccfAz3R0KZN G+n8448/OK4W
Dp4K8P3333/55Zd6oUYeaEs/1KpVK8lTQM6xBN22b99eMtjN8Lt79+5F5vXX X8dKBtTaxsVa
oCAsUEAEbebHw6aBXFdv27//UETwoUjzF3QwAiwb6rUsgTHq1VdfrRO2YB9p DTiAgOaLcaNC
aEy4MiNijQDCDF/5ujnCwMOMhsd1CiODToV4sJ4e8s6nHho8onsoZJR75ZVX btmyxfQITnka
bZ7SuSiQbHO0mCmySTSzTBZEVSk4nRa8FpxtreZcWKDImNd2Ixbs2LWrVq0a zz3/7HPPPfvs
s8/UrlV92bJF7YYviIiMWrNqYUx05Gr3/1Ur5puGwwFewa/L6tblHO0cg1da VfCijMWQ+rrr
rqOpvfvuu03IpZdeKpjLBWzlEefEgLcAT8KyEG+Ca1yAGDg/ZwgYDuy1atUq oCcYF5rzr7/+
OuOMM4y7gihVQBXIDGq2QYMG6MEh4ZxzzgHvIt+wYcOLLrpIJ4MrlcDAwLPP PltPf//990su
uQRyAhwJROMp3QZxoVp5+ttvv5H/JUuWMLGuuCRHf2DgnQKXLVtWunRp5LlA k0R31h4QW9Om
TYFrgGNnOFSKjnslb1dccYUYyj///FOBULlSCPcMyTp//nyngyl498Ybb8QU lE46adwlD7Ql
t3PnzmWAYbIHygTvAtAl880332ATngJAVTT002UqD9iEUhCIkSXPGbPwsgBc BhKmCMTFFOQB
4laBdDZGf7ly5cC7ZlzBUZYVK
Re: Package Hierarchy as Tree (Shadow Nodes not working as expected) [message #198791 is a reply to message #198675] Thu, 24 July 2008 06:06 Go to previous messageGo to next message
Hello Goetz,
So, it looks like domain model element creation command was executed successfully,
but view was not and I can suppose the reason for it.
You can put a breakpoint into generated ???VisualIDRegistry.getNodeVisualID()
and try to create element B using corresponding toolbar tool. As a result,
I suppose getNodeVisualID() will return visualID of node "A" and this value
will not be matched with the required visualID inside generated ???ViewProvider.getNodeViewClass()
method. If this is true then you can try adding corresponding constraint
to the node mapping for node A. Like:
"not self.containingPackage().oclIsUndefined()" in ocl
"return domainElement.eContainer() != null" in java
in case of using java constraint you have to set GenJavaExpressionProvider.injectExpressionBody
to "true" in generated .gmfgen model prior to the code generation.
Alex Shatalin
Re: Package Hierarchy as Tree (Shadow Nodes not working as expected) [message #199775 is a reply to message #198791] Fri, 01 August 2008 06:39 Go to previous messageGo to next message
Originally posted by: goetz.botterweck.lero.ie
Hello Alex,
> Hello Goetz,
> successfully, but view was not and I can suppose the reason for it.
> ???VisualIDRegistry.getNodeVisualID() and try to create element B using
> corresponding toolbar tool. As a result, I suppose getNodeVisualID()
> will return visualID of node "A" and this value will not be matched with
> ???ViewProvider.getNodeViewClass() method. If this is true then you can
> try adding corresponding constraint to the node mapping for node A.
> Like: "not self.containingPackage().oclIsUndefined()" in ocl
> GenJavaExpressionProvider.injectExpressionBody to "true" in generated
I tried your suggestion with the constraints:
(A = Root packages, B = Sub Packages)
* I extended the metamodel with Package.containingPackage (opposite of
Package.subpackages)
* The nodes of type A now have an OCL constraint
"self.containingPackage.oclIsUndefined()"
* To simplify debugging I also introduced different figures for
A (red) and B (green).
These are the results
* When creating a model and then generating a diagram from that,
the graphical representation appears as expected A=red,
B=green.
* I can add nodes for A.
* If I try to add nodes for B, they disappear as soon as I release the
mouse. In the model, I then find a "Package" as a sibling parallel to
the "Model". See (HERE) in model file below.
I assume that somehow the second Top Node Reference for B and the
related shadow node mechanism is not working properly.
Any suggestions would greatly be appreciated.
Goetz
<xmi:XMI xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:containment3="http:///containment3.ecore">
<containment3:Model>
<rootpackages name="a">
<subpackages name="a.1">
<subpackages name="a.1.1"/>
</subpackages>
<subpackages name="a.2"/>
</rootpackages>
<rootpackages name="b">
<subpackages name="b.1"/>
<subpackages name="b.2"/>
</rootpackages>
</containment3:Model>
<containment3:Package/> <---(HERE)
</xmi:XMI>
Re: Package Hierarchy as Tree (Shadow Nodes not working as expected) [message #199805 is a reply to message #199775] Fri, 01 August 2008 08:04 Go to previous message
Hello Goetz,
Try to debug generated code placing break point into ???VisualIDRegistry.getNodeVisualID()
.. We have to see the reason why incorrect visualID was returned from this
method (i suppose it was).
Alex Shatalin
Previous Topic:NULL with ArrangeAll
Next Topic:Properties view
Current Time: Thu Nov 27 19:00:30 EST 2025
Powered by FUDForum. Page generated in 0.04649 seconds
