Home » Archived » BIRT » Retrieve data within a chart's scripting context
Retrieve data within a chart's scripting context [message #198432] Tue, 31 October 2006 12:59 Go to next message
Originally posted by: arentsch.fzi.de
I want to add units to a line chart's axes dynamically, e.g. "time [ns]".
The type is available from my data set bound to the chart, but it seems to
me that I can't dynamically set it with an expression like: row["TimeUnit"]
Now I tried this:
function beforeDrawAxisTitle( axis, label, context ) {
if(label.getCaption().getValue() == "time")
label.getCaption().setValue(label.getCaption().getValue() +
DataSetRow[TimeUnit]);
It results in an error since DataSetRow is not available.
How can I retrieve data within a chart's scripting context?
Thanks in advance,
Andreas
Re: Retrieve data within a chart's scripting context [message #198846 is a reply to message #198432] Thu, 02 November 2006 15:23 Go to previous message
You need to bind this column to a series, and make the series invisible.
Then you can access the data from the series.
David
"Andreas Rentschler" <arentsch@fzi.de> wrote in message
news:ei82um$mjq$1@utils.eclipse.org...
> row["TimeUnit"]
> Now I tried this:
> Thanks in advance,
> Andreas
Previous Topic:Is Paging Available If Don't User BirtViewer or Servlet? [2.1.1]
Next Topic:Chart Fonts
Current Time: Mon Jul 21 23:59:17 EDT 2025
Powered by FUDForum. Page generated in 0.04863 seconds
