Home » Archived » BIRT » using report library and report engine API
using report library and report engine API [message #198413] Tue, 31 October 2006 12:17 Go to next message
Originally posted by: lingtai.earthlink.net
I have created a simple report and a report library
- The report library has a report item which is an embedded image
- The simple report takes no parameter and has a master page that uses
the image report item of the report library
I have modified the sample ExcuteReport.java posted on BIRT WIKI RE API
to run my report. The output HTML file looks good except that the image
is not included in the report. How do I tell the report engine where to
find the report library? Note that I am not running in a Web
Application server.
Many thanks,
Ling
Re: using report library and report engine API [message #198471 is a reply to message #198413] Tue, 31 October 2006 14:58 Go to previous messageGo to next message
Using the EngineConfig class do this:
config.setResourcePath("c:/mybirtresources/");
Jason
"Ling Tai" <lingtai@earthlink.net> wrote in message
news:ei80g8$41i$1@utils.eclipse.org...
> - The simple report takes no parameter and has a master page that uses the
> I have modified the sample ExcuteReport.java posted on BIRT WIKI RE API to
> run my report. The output HTML file looks good except that the image is
> not included in the report. How do I tell the report engine where to find
> the report library? Note that I am not running in a Web Application
> server.
> Many thanks,
> Ling
Re: using report library and report engine API [message #198557 is a reply to message #198471] Tue, 31 October 2006 16:31 Go to previous messageGo to next message
Jason:
Thanks for your prompt response. It works after I set the resource path.
I have another report which uses charts created in the same library.
When I run this report, none of the charts is shown in the report. What
do I have to do to make this report work?
Many thanks,
Ling
> Jason
>> server.
>> Many thanks,
>> Ling
Re: using report library and report engine API (Resolved) [message #198659 is a reply to message #198557] Wed, 01 November 2006 14:55 Go to previous messageGo to next message
Jason:
I am using IE 6.0 which does not support a native SVG plugin. If I
switch to Firefox 1.5.x, my report with charts can be displayed correctly.
Many thanks,
Ling
Ling Tai wrote:
> Jason:
> Many thanks,
> Ling
>> Jason
>>> uses the image report item of the report library
>>> API to run my report. The output HTML file looks good except that
>>> the image is not included in the report. How do I tell the report
>>> engine where to find the report library? Note that I am not running
>>> in a Web Application server.
>>> Many thanks,
>>> Ling
Re: using report library and report engine API (Resolved) [message #198793 is a reply to message #198659] Thu, 02 November 2006 14:59 Go to previous message
You can also set the chart output to something else or download the SVG
viewer from Adobe.
Jason
news:4548FBB6.20309@earthlink.net...
> Jason:
> I am using IE 6.0 which does not support a native SVG plugin. If I switch
> Many thanks,
> Ling
> Ling Tai wrote:
>> Jason:
>> Many thanks,
>> Ling
>>> Jason
>>>> image is not included in the report. How do I tell the report engine
>>>> where to find the report library? Note that I am not running in a Web
>>>> Application server.
>>>> Many thanks,
>>>> Ling
Previous Topic:Page Size
Next Topic:Error running the Report Engine in BIRT 2.1.1
Current Time: Fri Jul 18 04:20:02 EDT 2025
Powered by FUDForum. Page generated in 0.12114 seconds
