Home » Eclipse Projects » Eclipse Platform » Showing dialogs before workbench window is created.
Showing dialogs before workbench window is created. [message #198391] Fri, 20 February 2004 08:07 Go to next message
Originally posted by: eostroukhov.hotmail.com
Hi all!
I need to show login dialog to esteblish connection to the server - then
views/editors can be filled with data. But the problem is that this dialog
is often obscured by the splash screen - so user has to use Alt+Tab to find
it. I've tried to refactor my application to show the dialog after the
workbench is shown but I've had bad luck - things like content providers for
the views must be filled while the workbench is not shown. How can I make my
dialog modal when the splash screen is shown? I've tried to shut down the
splash screen - but my dialog still doesn't get the taskbar button...
Eugene
Re: Showing dialogs before workbench window is created. [message #198465 is a reply to message #198391] Fri, 20 February 2004 09:43 Go to previous messageGo to next message
Are you writing an RCP Application? Then you should consider to write an
application and a workbench advisor class which will give you callbacks at
various point during the startup process (preWindowOpen, postWindowOpen,
To get a taskbar button, you could use a trick and make a top level shell
which you place off the screen (x=-500,y=-500) and make your dialog a child
of it.
Martin
"Eugene Ostroukhov" <eostroukhov@hotmail.com> schrieb im Newsbeitrag
news:c150kn$ns4$1@eclipse.org...
> Hi all!
find
for
my
> Eugene
Re: Showing dialogs before workbench window is created. [message #199551 is a reply to message #198465] Mon, 23 February 2004 02:31 Go to previous message
I'm planning to migrate to the Eclipse 3 (and RCP) in April, so I am still
on 2.1.2. I've found one way that is ok for me - using Display.findDisplay
(Thread.currentThread) creates toolbar button if I need one.
"Martin Klinke" <martin-klinke@gmx.de> wrote in message
news:c1565b$vk4$1@eclipse.org...
child
> of it.
> Martin
> > Hi all!
dialog
> find
> for
make
> my
the
> > Eugene
Previous Topic:Table widget
Next Topic:Error finding plugin action in M7
Current Time: Thu Jul 24 21:14:11 EDT 2025
Powered by FUDForum. Page generated in 0.06796 seconds
