Home » Newcomers » Newcomers » Killing Eclipse does not start even after -clean option
Killing Eclipse does not start even after -clean option [message #198227] Wed, 07 March 2007 06:14 Go to next message
I was updating eclipse and its started some background process. It
almost hanged my system so i needed to force kill eclipse. Now, when i
started eclipse with -clean option it still throws exception about some
plugin and shuts down. So i delete eclipse/configuration/org.eclipse.*
Still it was failing to start.
So deleted .metadata from workspace..then it worked. But all
customization and everything was lost. Is there any safer alternative to
this?
Re: Killing Eclipse does not start even after -clean option [message #198242 is a reply to message #198227] Wed, 07 March 2007 06:16 Go to previous message
> this?
i belief it is ;) if you know where the problems lays you can find
proper way to solve it. you can look for errors in .log file.
best regards
bartek michalik
Previous Topic:external configuration for bookmark or tasks
Next Topic:running editor programatically
Current Time: Sat Nov 15 11:15:39 EST 2025
Powered by FUDForum. Page generated in 0.08657 seconds
