Home » Modeling » GMF (Graphical Modeling Framework) » href of elements changes when saving GMF editor
href of elements changes when saving GMF editor [message #198166] Mon, 21 July 2008 14:46
I have a metamodel A which refers to another metamodel B (here:
UML.ecore; one of the classes of A has an EReference of type
UML.ecore#Activity).
In addition, I have a metamodel C which contains a reference of type
EPackage, which shall hold references to other metamodels (here: A and
B). In addition, classes of C have a reference of type EClass which
shall hold classes contained in the mentioned packages.
Finally, I have a GMF editor for C. When creating a diagram, I choose
"Load resource" and load A. This then allows me to add A and B to the
packages reference of c. I can then type my elements accordingly.
Now the problem is that GMF saves the instance of C such like this:
<type
href=" ../../../plugin/org.eclipse.uml2.uml/model/UML.ecore#//Activ ityNode "/>
Unfortunately, I run into problems with other code also working on
models of type C. If I replace all occurences of the href attribute with
<type
href=" platform:/plugin/org.eclipse.uml2.uml/model/UML.ecore#//Acti vityNode "/>
, my other code works fine. But working again on such a model with my
GMF editor (and finally saving) changes everything back to the above.
I guess that my other code does not find the UML.ecore metamodel since
it is linked in a relative way. Any way around this?
And since I'm not very comfortable with the whole resource stuff: Does
anybody know a good link or two with information about that?
Thanks in advance,
Christian
John Lennon: "Life is what happens to you while you're busy making other
plans."
Previous Topic:Deleting connections
Next Topic:Accessing Underlying Objects from outside the Canvas
Current Time: Sun Jul 13 18:11:45 EDT 2025
Powered by FUDForum. Page generated in 0.03223 seconds
