Home » Language IDEs » Java Development Tools (JDT) » Using JDT outside the eclipse platform
Using JDT outside the eclipse platform [message #198164] Wed, 09 March 2005 20:07 Go to next message
Originally posted by: ori_calvo.hotmail.com
Hello All,
I am trying to write a simple application which analyzes a Java source code
file. I know that the eclipse platform already implements this kind of
functionality (for example the Package Explorer viewer). In the JDT Core
classes there is package called org.eclipse.jdt.core.dom which seems to be
the right thing for me (is it?).
1) Does any of the binaries provided by the JDT Core plugins can be used
outside of the eclipse platform (used by a simple java application which is
not an eclipse plugin) ?
2) If the above is possible than where can I find any documentation about
how to re-use the JDT source code in order to implement a java source code
simple analyzer?
Thanks, Ori
Re: Using JDT outside the eclipse platform [message #198172 is a reply to message #198164] Wed, 09 March 2005 22:10 Go to previous messageGo to next message
No, this doesn't work. You can however use JDT inside a RCP application.
The JDT/Core plugin needs to be initialized to access preferences.
A headless eclipse workbench could also be a solution.
Olivier
Re: Using JDT outside the eclipse platform [message #198314 is a reply to message #198172] Thu, 10 March 2005 15:31 Go to previous messageGo to next message
Originally posted by: wharley.bea.com
"Olivier Thomann" <olivier_thomannNOSPAM@ca.ibm.com> wrote in message
news:d0odqa$el8$1@www.eclipse.org...
> Ori Calvo a
Re: Using JDT outside the eclipse platform [message #198361 is a reply to message #198314] Thu, 10 March 2005 20:49 Go to previous message
Walter Harley a écrit :
> But, I think the batch compiler
> ( http://dev.eclipse.org/viewcvs/index.cgi/jdt-core-home/howto /batch%20compile/batchCompile.html?rev=1.6)
> works with just jdtcore.jar, not the rest of Eclipse. No?
The batch compiler, yes. But if you want to use the DOM/AST this is
different. It requires the JDT/Core plugin to be initialized.
Olivier
Previous Topic:How should I use classpath variables?
Next Topic:Using ASTParser
Current Time: Fri Jun 06 14:28:13 EDT 2025
Powered by FUDForum. Page generated in 0.07581 seconds
