Home » Archived » BIRT » FlatFile error on latest runtime engine
FlatFile error on latest runtime engine [message #198139] Sat, 28 October 2006 14:37 Go to next message
Originally posted by: stuart.polonious.com.au
I have been debugging this for hours. Any help greatly appreciated.
We are using the flatfile datasource to merge data from many hibernated
tables to one flat file. This makes birt's life easy (or used to). Now
we are getting an error that is causing problems:
java.lang.ArrayIndexOutOfBoundsException: 461
org.eclipse.datatools.connectivity.oda.flatfile.FlatFileQuer y.splitSt
ringWithDoubleQuotes(FlatFileQuery.java:901)
org.eclipse.datatools.connectivity.oda.flatfile.FlatFileQuer y.fetchQu
eriedDataFromRow(FlatFileQuery.java:850)
eriedDataFromFileToVector(FlatFileQuery.java:822)
org.eclipse.datatools.connectivity.oda.flatfile.FlatFileQuer y.execute
Query(FlatFileQuery.java:161)
To debug this myself, I have tried to download a compatible version of
org.eclipse.datatools.connectivity.oda.flatfile. Would anyone know how
to get the source? The CVS is there for datatools but I'm not sure that
the release tags are? Alternatively, has anyone had this error and fixed
it?
TIA
Stuart
Re: FlatFile error on latest runtime engine [message #198161 is a reply to message #198139] Sat, 28 October 2006 17:21 Go to previous messageGo to next message
Oh yes, I am talking about 2.1.1. Should I bugzilla this or solve it
then bugzilla it?
Stuart
Re: FlatFile error on latest runtime engine [message #198169 is a reply to message #198139] Sat, 28 October 2006 17:25 Go to previous messageGo to next message
This is the line that is stuffing up:
if(i < chars.length - 1 && chars[i + 2] == '"')
with this:
Anyone?
> at
> at
> at
> at
> it?
> TIA
> Stuart
Re: FlatFile error on latest runtime engine [message #198247 is a reply to message #198139] Mon, 30 October 2006 01:06 Go to previous messageGo to next message
Hi Stuart,
Can you provide the flat file you used which can reproduce the bug? Or it
would be preferable if you can log a bugzilla entry for it.
Thanks.
Lin
"Stuart Guthrie" <stuart@polonious.com.au> wrote in message
news:ei0bgd$oap$1@utils.eclipse.org...
> at
> at
> at
> at
> it?
> TIA
> Stuart
Re: FlatFile error on latest runtime engine [message #200503 is a reply to message #198247] Mon, 13 November 2006 06:19 Go to previous messageGo to next message
I will try to find it.
Stuart
lzhu wrote:
> Hi Stuart,
> Thanks.
> Lin
>> at
>> at
>> at
>> at
>> it?
>> TIA
>> Stuart
Re: FlatFile error on latest runtime engine [message #201205 is a reply to message #200503] Thu, 16 November 2006 06:13 Go to previous message
I cannot locate this file now. Sorry.
Stuart
> Stuart
> lzhu wrote:
>> Hi Stuart,
>> Thanks.
>> Lin
>>> at
>>> at
>>> at
>>> at
>>> it?
>>> TIA
>>> Stuart
Previous Topic:Arrange two report items side by side HTML vs. PDF
Next Topic:Maven POM Details
Current Time: Thu Jul 24 09:20:27 EDT 2025
Powered by FUDForum. Page generated in 0.32520 seconds
