| Re: [buckminster-dev] Strange resolver behaviour when resolving PDE plugins - using "native&quo [message #18863] |
Tue, 27 May 2008 10:31 |
Hi Mikhail,
What platform are you using? Is it an Eclipse 3.3.x or 3.4.x? And what
is the version on your org.eclipse.buckminster.core.feature?
Thomas Hallgren
Mikhail Kadan wrote:
> Hi.
> Found another strange issue.
> In my target platform I have two versions of "org.eclipse.emf.common":
> 1) 2.3.0
> 2) 2.3.2
> Issue #1: When I try to resolve "org.eclipse.emf.common" w/o version
> specification, Buckminster gives me "2.3.0" version. Strange, cause it
> has to give me the latest version, am I right?
> Issue #2: When I try to resolve "org.eclipse.emf.common" with version
> specification set to "[2.3.1,3.0.0)", Buckminster returns an error.
> Log says:
> org.eclipse.emf.common:osgi.bundle/[2.3.1,3.0.0)#OSGi: Using resolver rmap
> org.eclipse.emf.common:osgi.bundle/[2.3.1,3.0.0)#OSGi: Version
> 2.3.0.v200709252135 rejected: not designated by [2.3.1,3.0.0)
> org.eclipse.emf.common:osgi.bundle/[2.3.1,3.0.0)#OSGi: Rejecting
> provider eclipse.platform(plugin/${buckminster.component}): No
> component match was found
> org.eclipse.emf.common:osgi.bundle/[2.3.1,3.0.0)#OSGi: Using resource
> map file:/C:/Work/workspaces/xdoc/bm/xdoc.rmap
> org.eclipse.emf.common:osgi.bundle/[2.3.1,3.0.0)#OSGi: No searchPath
> was found with a matching pattern
> cloudsmith
> So, based on this two issues, I think Buckminster ignores my second
> plugin. I guess Buckminster's "eclipse.platform" support only one
> version of plugin, and he takes the first one in lexicographical order?
> What can be done to fix this issue? Or I just have to remove old
> plugins from my target platform? :-)
> Thanks.
> ps I've used "Refresh Meta-data" button from Buckminster preferences,
> but it didn't help too :'(
> 2008/5/26, Thomas Hallgren <thomas@tada.se <mailto:thomas@tada.se>>:
> Hi Mikhail,
> So I can made a conclusion, that Buckminster also searches his
> "native" target platform (target platform which was used to
> start Eclipse), and if it finds a match here, which has bigger
> version than others, it will try to materialize this plugin
> from "native" platform.
> Yes, your conclusion is correct.
> How can I set Buckminster not to look in his "native" target
> platform for plugins?
> You declare an advisory node in the component query where you omit
> the target platform from the resolution scope (see the "Resolution
> Scope" pane under the "Advisor node" tab in the CQUERY editor.
> ps By the way, can anyone provide example how
> "eclipse.platform" reader works? I've tried such RMAP but
> couldn't get it to work:
> The "eclipse.platform" reader type is for internal use only. You
> should not use it in an RMAP.
> Thomas Hallgren
> _______________________________________________
> buckminster-dev mailing list
> buckminster-dev@eclipse.org <mailto:buckminster-dev@eclipse.org>
> https://dev.eclipse.org/mailman/listinfo/buckminster-dev
FUDForum. Page generated in 0.03609 seconds
