Home » Eclipse Projects » Eclipse Platform » debug variables not showing up
debug variables not showing up [message #1593] Mon, 21 April 2003 20:53 Go to next message
Originally posted by: cboyd1472.hotmail.com
For some reason, when I debug my application, the debug variables are no
longer showing up in the variables window. I have all of the checkboxes
checked under the Java-->Compiler-->Compliance and Classfiles tab in the
classfile generation box. This used to work, so apparently I've done
something to mess it up. Anybody have a guess?
Re: debug variables not showing up [message #9080 is a reply to message #1593] Thu, 24 April 2003 05:49 Go to previous messageGo to next message
Originally posted by: yves.somewhere.com
This is a bug. Close and reopen the debug perspective and it should be ok.
Re: debug variables not showing up [message #10487 is a reply to message #9080] Thu, 24 April 2003 10:09 Go to previous messageGo to next message
This was a bug in the later days of preparing for 2.1 but I have no
knowledge of this bug existing in the 2.1 release.
Which bug report are you referring to Yves?
Darins
"Yves" <yves@somewhere.com> wrote in message
news:b88brn$kst$1@rogue.oti.com...
Re: debug variables not showing up [message #12122 is a reply to message #9080] Thu, 24 April 2003 13:36 Go to previous messageGo to next message
Originally posted by: cboyd.programmer.net
Thanks Yves. This worked. BTW, I'm using Build 200302061700.
> > classfile generation box. This used to work, so apparently I\\\'ve done
Re: debug variables not showing up [message #12135 is a reply to message #12122] Thu, 24 April 2003 13:43 Go to previous messageGo to next message
Any reason you have not moved to the 2.1 release where this bug is fixed?
There have been alot of changes since the 2.1 M5 build.
Darins
"cboyd" <cboyd@programmer.net> wrote in message
news:b897bg$ep5$1@rogue.oti.com...
ok.
no
checkboxes
the
done
Re: debug variables not showing up [message #68963 is a reply to message #12135] Tue, 10 June 2003 06:08 Go to previous messageGo to next message
Originally posted by: parora.veritas.com
------=_NextPart_000_00C0_01C32F66.5A996D80
Content-Type: text/plain;
charset="iso-8859-1"
I too see this bug quite often,Is this bug present in build 200303272130 =
too ??
thanks
~Parvinder
"Darin Swanson" <Darin_Swanson@us.ibm.com> wrote in message =
news:b897ob$f3u$1@rogue.oti.com...
> Any reason you have not moved to the 2.1 release where this bug is =
fixed?
>=20
> Darins
>=20
> > Yves wrote:
> > > This is a bug. Close and reopen the debug perspective and it =
should be
> ok.
> > > cboyd wrote:
> > > > For some reason, when I debug my application, the debug =
variables are
> no
> checkboxes
> > > > checked under the Java-->Compiler-->Compliance and Classfiles =
tab in
> the
> > > > classfile generation box. This used to work, so apparently =
I\\\'ve
> done
>=20
Content-Type: text/html;
<HTML><HEAD>
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2800.1106" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY style=3D"COLOR: #000000; FONT-FAMILY: Courier New">
<DIV><FONT face=3DVerdana size=3D2>I too see this bug quite often,Is =
this bug=20
present in </FONT><FONT face=3DVerdana size=3D2>build 200303272130 too=20
??</FONT></DIV>
<DIV>
<P><FONT face=3DVerdana size=3D2>thanks<BR></FONT><FONT face=3DVerdana=20
size=3D2>~Parvinder</FONT></P></DIV>
<DIV><FONT face=3DVerdana size=3D2>"Darin Swanson" &lt;</FONT><A=20
href=3D"mailto:Darin_Swanson@us.ibm.com"><FONT face=3DVerdana=20
size=3D2>Darin_Swanson@us.ibm.com</FONT></A><FONT face=3DVerdana =
size=3D2>&gt; wrote=20
in message </FONT><A href=3D"news:b897ob$f3u$1@rogue.oti.com"><FONT =
face=3DVerdana=20
size=3D2>news:b897ob$f3u$1@rogue.oti.com</FONT></A><FONT face=3DVerdana=20
size=3D2>...</FONT></DIV><FONT face=3DVerdana size=3D2>&gt; Any reason =
you have not=20
moved to the 2.1 release where this bug is fixed?<BR>&gt; There have =
been alot=20
of changes since the 2.1 M5 build.<BR>&gt; <BR>&gt; Darins<BR>&gt; =
<BR>&gt;=20
"cboyd" &lt;</FONT><A href=3D"mailto:cboyd@programmer.net"><FONT =
face=3DVerdana=20
size=3D2>cboyd@programmer.net</FONT></A><FONT face=3DVerdana =
size=3D2>&gt; wrote in=20
message<BR>&gt; </FONT><A href=3D"news:b897bg$ep5$1@rogue.oti.com"><FONT =
face=3DVerdana size=3D2>news:b897bg$ep5$1@rogue.oti.com</FONT></A><FONT =
face=3DVerdana=20
size=3D2>...<BR>&gt; &gt; Thanks Yves.&nbsp; This worked.&nbsp; BTW, I'm =
using=20
Build 200302061700.<BR>&gt; &gt;<BR>&gt; &gt; Yves wrote:<BR>&gt; =
&gt;<BR>&gt;=20
&gt; &gt; This is a bug. Close and reopen the debug perspective and it =
should=20
be<BR>&gt; ok.<BR>&gt; &gt;<BR>&gt; &gt; &gt; cboyd wrote:<BR>&gt; &gt; =
&gt;=20
&gt; For some reason, when I debug my application, the debug variables=20
are<BR>&gt; no<BR>&gt; &gt; &gt; &gt; longer showing up in the variables =
window.&nbsp; I have all of the<BR>&gt; checkboxes<BR>&gt; &gt; &gt; =
&gt;=20
checked under the Java--&gt;Compiler--&gt;Compliance and Classfiles tab=20
in<BR>&gt; the<BR>&gt; &gt; &gt; &gt; classfile generation box.&nbsp; =
This used=20
to work, so apparently I\\\'ve<BR>&gt; done<BR>&gt; &gt; &gt; &gt; =
something to=20
mess it up.&nbsp; Anybody have a guess?<BR>&gt; &gt; &gt; &gt;<BR>&gt;=20
&gt;<BR>&gt; &gt;<BR>&gt; &gt;<BR>&gt; &gt;<BR>&gt; <BR>&gt;=20
</FONT></BODY></HTML>
------=_NextPart_000_00C0_01C32F66.5A996D80--
Re: debug variables not showing up [message #69236 is a reply to message #68963] Tue, 10 June 2003 09:36 Go to previous messageGo to next message
------=_NextPart_000_002B_01C32F2B.5DA54FC0
200303272130 is the 2.1 release build.
Are you sure you are seeing the same bug?
The debug variables come and go in the same class?
You are compiling the classes to include the required debug information?
HTH
Darins
"Parvinder Singh Arora" <parora@veritas.com> wrote in message =
news:bc49pj$2fs$1@rogue.oti.com...
I too see this bug quite often,Is this bug present in build =
200303272130 too ??
thanks
~Parvinder
fixed?
>=20
> Darins
>=20
should be
> ok.
variables are
> no
> checkboxes
tab in
> the
I\\\'ve
> done
>=20
>=20
<HTML><HEAD>
<META content=3D"MSHTML 5.50.4522.1800" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY style=3D"COLOR: #000000; FONT-FAMILY: Courier New" =
bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>200303272130 is the 2.1 release =
build.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Are you sure you are seeing the same=20
bug?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>The debug variables come and go in the =
same=20
class?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>You are compiling the classes to =
include the=20
required debug information?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>HTH</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Darins</FONT></DIV>
<BLOCKQUOTE=20
<DIV>"Parvinder Singh Arora" &lt;<A=20
href=3D"mailto:parora@veritas.com">parora@veritas.com</A>&gt; wrote in =
message=20
<A=20
href=3D"news:bc49pj$2fs$1@rogue.oti.com">news:bc49pj$2fs$1@rogue.oti.com<=
/A>...</DIV>
this bug=20
present in </FONT><FONT face=3DVerdana size=3D2>build 200303272130 too =
??</FONT></DIV>
<DIV>
<P><FONT face=3DVerdana size=3D2>thanks<BR></FONT><FONT face=3DVerdana =
face=3DVerdana=20
size=3D2>news:b897ob$f3u$1@rogue.oti.com</FONT></A><FONT =
face=3DVerdana=20
you have not=20
been alot=20
<BR>&gt;=20
face=3DVerdana=20
message<BR>&gt; </FONT><A =
href=3D"news:b897bg$ep5$1@rogue.oti.com"><FONT=20
face=3DVerdana =
size=3D2>news:b897bg$ep5$1@rogue.oti.com</FONT></A><FONT=20
face=3DVerdana size=3D2>...<BR>&gt; &gt; Thanks Yves.&nbsp; This =
worked.&nbsp;=20
BTW, I'm using Build 200302061700.<BR>&gt; &gt;<BR>&gt; &gt; Yves=20
wrote:<BR>&gt; &gt;<BR>&gt; &gt; &gt; This is a bug. Close and reopen =
the=20
debug perspective and it should be<BR>&gt; ok.<BR>&gt; &gt;<BR>&gt; =
&gt; &gt;=20
cboyd wrote:<BR>&gt; &gt; &gt; &gt; For some reason, when I debug my=20
application, the debug variables are<BR>&gt; no<BR>&gt; &gt; &gt; &gt; =
longer=20
showing up in the variables window.&nbsp; I have all of the<BR>&gt;=20
checkboxes<BR>&gt; &gt; &gt; &gt; checked under the=20
Java--&gt;Compiler--&gt;Compliance and Classfiles tab in<BR>&gt; =
the<BR>&gt;=20
&gt; &gt; &gt; classfile generation box.&nbsp; This used to work, so=20
apparently I\\\'ve<BR>&gt; done<BR>&gt; &gt; &gt; &gt; something to =
mess it=20
up.&nbsp; Anybody have a guess?<BR>&gt; &gt; &gt; &gt;<BR>&gt; =
&gt;<BR>&gt;=20
</FONT></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_002B_01C32F2B.5DA54FC0--
Re: debug variables not showing up [message #69400 is a reply to message #69236] Tue, 10 June 2003 10:28 Go to previous messageGo to next message
------=_NextPart_000_012C_01C32F8A.AEED3780
Probably not because what happens is that i have jar files which i =
download, instantiate them and while debugging try to see the values of =
those instantiated objects..Anyways i will observe this next time i see =
the problem.
thanks
~Parvinder
"Darin Swanson" <darin_swanson@oti.com> wrote in message =
news:bc4mru$fj2$1@rogue.oti.com...
You are compiling the classes to include the required debug =
information?
HTH
Darins
200303272130 too ??
thanks
~Parvinder
fixed?
>=20
> Darins
>=20
should be
> ok.
variables are
> no
> > > > longer showing up in the variables window. I have all of =
the
> checkboxes
> > > > checked under the Java-->Compiler-->Compliance and =
Classfiles tab in
> the
I\\\'ve
> done
>=20
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
bgColor=3D#ffffff>
<DIV><FONT face=3DVerdana size=3D2>Probably not because what happens is =
that i have=20
jar files which i download, instantiate them and while debugging try to =
see the=20
values of those instantiated objects..Anyways i will observe this next =
time i=20
see the problem.</FONT></DIV>
<DIV><FONT face=3DVerdana size=3D2></FONT>&nbsp;</DIV>
<DIV><FONT face=3DVerdana size=3D2>thanks</FONT></DIV>
<DIV><FONT face=3DVerdana size=3D2>~Parvinder</FONT></DIV>
<BLOCKQUOTE dir=3Dltr=20
<DIV>"Darin Swanson" &lt;<A=20
href=3D"mailto:darin_swanson@oti.com">darin_swanson@oti.com</A>&gt; =
wrote in=20
message <A=20
href=3D"news:bc4mru$fj2$1@rogue.oti.com">news:bc4mru$fj2$1@rogue.oti.com<=
/A>...</DIV>
<DIV><FONT face=3DArial size=3D2>200303272130 is the 2.1 release=20
build.</FONT></DIV>
bug?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>The debug variables come and go in =
the same=20
class?</FONT></DIV>
include the=20
<BLOCKQUOTE=20
href=3D"mailto:parora@veritas.com">parora@veritas.com</A>&gt; wrote =
in message=20
<A=20
/A>...</DIV>
this bug=20
present in </FONT><FONT face=3DVerdana size=3D2>build 200303272130 =
too=20
??</FONT></DIV>
<DIV>
<P><FONT face=3DVerdana size=3D2>thanks<BR></FONT><FONT =
face=3DVerdana=20
size=3D2>&gt;=20
wrote in message </FONT><A =
href=3D"news:b897ob$f3u$1@rogue.oti.com"><FONT=20
face=3DVerdana =
size=3D2>news:b897ob$f3u$1@rogue.oti.com</FONT></A><FONT=20
face=3DVerdana size=3D2>...</FONT></DIV><FONT face=3DVerdana =
size=3D2>&gt; Any=20
reason you have not moved to the 2.1 release where this bug is=20
fixed?<BR>&gt; There have been alot of changes since the 2.1 M5=20
build.<BR>&gt; <BR>&gt; Darins<BR>&gt; <BR>&gt; "cboyd" =
&lt;</FONT><A=20
href=3D"mailto:cboyd@programmer.net"><FONT face=3DVerdana=20
in message<BR>&gt; </FONT><A =
face=3DVerdana =
worked.&nbsp;=20
wrote:<BR>&gt; &gt;<BR>&gt; &gt; &gt; This is a bug. Close and =
reopen the=20
&gt;=20
&gt; cboyd wrote:<BR>&gt; &gt; &gt; &gt; For some reason, when I =
debug my=20
application, the debug variables are<BR>&gt; no<BR>&gt; &gt; &gt; =
&gt;=20
longer showing up in the variables window.&nbsp; I have all of =
the<BR>&gt;=20
the<BR>&gt;=20
&gt; &gt; &gt; classfile generation box.&nbsp; This used to work, so =
mess it=20
&gt;<BR>&gt;=20
</FONT></BLOCKQUOTE></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_012C_01C32F8A.AEED3780--
Re: debug variables not showing up [message #69480 is a reply to message #69400] Tue, 10 June 2003 11:05 Go to previous message
------=_NextPart_000_0A69_01C32F37.D6AB1970
Most likely the classes in the JARs do not have the required debug =
information.
This is not a bug within Eclipse. You can recompile the JARs or request =
that the JAR providers include the debug information.
HTH
Darins
news:bc4p2s$iet$1@rogue.oti.com...
the problem.
thanks
~Parvinder
information?
HTH
Darins
200303272130 too ??
thanks
~Parvinder
> Any reason you have not moved to the 2.1 release where this bug =
is fixed?
>=20
> Darins
>=20
should be
> ok.
variables are
> no
the
> checkboxes
Classfiles tab in
> the
> > > > classfile generation box. This used to work, so =
apparently I\\\'ve
> done
>=20
>=20
<HTML><HEAD>
<META content=3D"MSHTML 5.50.4134.600" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>Most likely the classes in the JARs do =
not have the=20
required debug information.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>This is not a bug within Eclipse. You =
can recompile=20
the JARs or request that the JAR providers include the debug=20
message=20
<A=20
href=3D"news:bc4p2s$iet$1@rogue.oti.com">news:bc4p2s$iet$1@rogue.oti.com<=
/A>...</DIV>
<DIV><FONT face=3DVerdana size=3D2>Probably not because what happens =
is that i=20
have jar files which i download, instantiate them and while debugging =
try to=20
see the values of those instantiated objects..Anyways i will observe =
this next=20
time i see the problem.</FONT></DIV>
wrote in=20
message <A=20
/A>...</DIV>
build.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Are you sure you are seeing the =
same=20
bug?</FONT></DIV>
the same=20
class?</FONT></DIV>
include the=20
<BLOCKQUOTE=20
href=3D"mailto:parora@veritas.com">parora@veritas.com</A>&gt; =
wrote in=20
message <A=20
/A>...</DIV>
<DIV><FONT face=3DVerdana size=3D2>I too see this bug quite =
often,Is this bug=20
too=20
??</FONT></DIV>
<DIV>
face=3DVerdana=20
size=3D2>&gt;=20
face=3DVerdana =
&lt;</FONT><A=20
face=3DVerdana =
worked.&nbsp;=20
reopen the=20
debug perspective and it should be<BR>&gt; ok.<BR>&gt; =
&gt;<BR>&gt; &gt;=20
debug my=20
&gt;=20
the<BR>&gt;=20
Java--&gt;Compiler--&gt;Compliance and Classfiles tab in<BR>&gt;=20
the<BR>&gt; &gt; &gt; &gt; classfile generation box.&nbsp; This =
used to=20
something=20
to mess it up.&nbsp; Anybody have a guess?<BR>&gt; &gt; &gt; =
&gt;<BR>&gt;=20
</FONT></BLOCKQUOTE></BLOCKQUOTE></BLOCKQUOTE></BODY></HTML >
------=_NextPart_000_0A69_01C32F37.D6AB1970--
Previous Topic:[CVS] problems with CVSNT
Next Topic:Updating the toolbar with a new action
Current Time: Sat Jul 26 20:54:27 EDT 2025
Powered by FUDForum. Page generated in 0.07278 seconds
