Home » Language IDEs » C / C++ IDE (CDT) » Setting Libraries and Library Path API?
Setting Libraries and Library Path API? [message #198090] Tue, 24 July 2007 09:13 Go to next message
Hi, I need API to set Library Paths and used Libraries for C/C++ Project.
Does such API exist, I'd tried to investigate ICProject but have failed.
Sergey Gomanyuk
Re: Setting Libraries and Library Path API? [message #198145 is a reply to message #198090] Tue, 24 July 2007 11:22 Go to previous messageGo to next message
Originally posted by: dmsubs.NOSPAM.consertum.com
I suggest you start by looking in the Managed Build System Extensibility
Document. This is provided in the CDT SDK help (which you should have installed).
Also, look at the source to the class ManagedBuildManager.
There is not a lot of documentation in this area...
Derek
> Sergey Gomanyuk
Re: Setting Libraries and Library Path API? [message #198202 is a reply to message #198145] Wed, 25 July 2007 06:08 Go to previous messageGo to next message
I've already read Managed Build System Extensibility Document. But it
contains info about how to made your own tool-chain configuration. I need
only change Library Path and used Libraries of already created C project. I
tried to investigate ManagedBuildManager but to my mind it contains
interface for reading already defined managed build configurations but not
for customizing C project. So I still need some points....
"Derek Morris" <dmsubs@NOSPAM.consertum.com> wrote in message
news:f855fc$nds$1@build.eclipse.org...
>installed).
> Derek
>> Sergey Gomanyuk
Re: Setting Libraries and Library Path API? [message #198226 is a reply to message #198202] Wed, 25 July 2007 11:15 Go to previous message
Finally, I understood how to do it. See attached sample.
Sergey Gomanyuk
"Sergey Gomanyuk" <sergg@ispras.ru> wrote in message
news:f877jq$53e$1@build.eclipse.org...
> I tried to investigate ManagedBuildManager but to my mind it contains
>>installed).
>> Derek
>>> Project. Does such API exist, I'd tried to investigate ICProject but
>>> have failed.
>>> Sergey Gomanyuk
  • Attachment: sample.java
    (Size: 1.53KB, Downloaded 154 times)
Previous Topic:define compiler parametrs per file.
Next Topic:problem debugging socket using eclipse IDE
Current Time: Fri Jul 18 00:48:26 EDT 2025
Powered by FUDForum. Page generated in 0.05766 seconds
