Home » Archived » BIRT » DataSource from an external factory
DataSource from an external factory [message #198084] Fri, 27 October 2006 16:53 Go to next message
Originally posted by: trevor.l.torrez.accenture.com
Is there an easy way to have birt use a DataSource from an external
factory without using a 'scripted datasource' which requires me to hand
code the column retrieval (think 200+ columns)? I use spring for a lot
of configuration, so ideally I would like to be able to hand birt a
DataSource and just say 'use this'. Any thoughts? How about having the
factory create the data source and binding it to JDNI; and having birt
retrieve it from JNDI?
-t.
Re: DataSource from an external factory [message #198517 is a reply to message #198084] Tue, 31 October 2006 15:13 Go to previous messageGo to next message
Trevor,
There are ways to pass preloaded objects into Birt, but you still may have
the same problem if you want all 200 columns to show up in your data set
view.
A custom ODA may work in this situation. Let me know if you try the JNDI
approach.
Jason
"Trevor Torrez" <trevor.l.torrez@accenture.com> wrote in message
news:ehtric$rpt$1@utils.eclipse.org...
> code the column retrieval (think 200+ columns)? I use spring for a lot of
> -t.
Re: DataSource from an external factory [message #198737 is a reply to message #198517] Thu, 02 November 2006 11:45 Go to previous messageGo to next message
I have the same issue. I do have access to the datasource in spring, and would prefer to pass it in
at runtime, as we are trying to centralize all our configuration. Examples of how to do this would
be great. We would be ok with a way to pass in the jndi name if it didnt have the error below.
I attempted to use the jndi datasource (java:comp/env/MyDataSource) but I get the following WARNING
from my jboss pool:
WARN org.jboss.resource.connectionmanager.JBossManagedConnectionP ool - Destroying connection that
could not be successfully matched
The following is from my jboss JCA config:
<no-tx-datasource>
<jndi-name>${jdbc.datasource.name}</jndi-name>
<connection-url>${jdbc.datasource.url}</connection-url>
<driver-class>${jdbc.datasource.driver.class}</driver-class >
<user-name>${jdbc.datasource.username}</user-name>
<password>${jdbc.datasource.password}</password>
<min-pool-size>${jdbc.datasource.poolsize.min}</min-pool-size >
<max-pool-size>${jdbc.datasource.poolsize.max}</max-pool-size >
<idle-timeout-minutes>30</idle-timeout-minutes>
<blocking-timeout-millis>5000</blocking-timeout-millis>
<check-valid-connection-sql>${jdbc.datasource.validationsql} </check-valid-connection-sql>
<exception-sorter-class-name>${jdbc.datasource.exceptionsorter} </exception-sorter-class-name>
</no-tx-datasource>
Ryan
Jason Weathersby wrote:
> Trevor,
> view.
> approach.
> Jason
>>-t.
Re: DataSource from an external factory [message #198830 is a reply to message #198737] Thu, 02 November 2006 15:09 Go to previous messageGo to next message
Ryan,
I wish you would log a bug for the warning.
How do you have the report deployed?
Jason
"Ryan Barker" <barker@itgssi.com> wrote in message
news:eid7bh$dqo$1@utils.eclipse.org...
>would prefer to pass it in at runtime, as we are trying to centralize all
>our configuration. Examples of how to do this would be great. We would be
> get the following WARNING from my jboss pool:
> Destroying connection that could not be successfully matched
> <no-tx-datasource>
> </no-tx-datasource>
> Ryan
>> Trevor,
>> have the same problem if you want all 200 columns to show up in your data
>> set view.
>> approach.
>> Jason
>>>-t.
Re: DataSource from an external factory [message #198881 is a reply to message #198830] Thu, 02 November 2006 15:49 Go to previous messageGo to next message
--------------040305030701020108070209
Content-Type: text/plain; charset=us-ascii; format=flowed
I am using a servlet with the attached files.
I am very happy with BIRT from a report design perspective but from an integration perspective it is
far more complicated than I thought it would be.
> Ryan,
> Jason
>> <no-tx-datasource>
>> </no-tx-datasource>
>>Thanks,
>>Ryan
>>>Trevor,
>>>set view.
>>>approach.
>>>Jason
>>>>-t.
Content-Type: text/x-java;
name="BirtReportServlet.java"
Content-Disposition: inline;
filename="BirtReportServlet.java"
package com.itgssi.apr.logic.report.birt;
import java.io.ByteArrayOutputStream;
import java.io.IOException;
import java.io.InputStream;
import javax.servlet.ServletConfig;
import javax.servlet.ServletContext;
import javax.servlet.ServletException;
import javax.servlet.http.HttpServlet;
import javax.servlet.http.HttpServletRequest;
import javax.servlet.http.HttpServletResponse;
import javax.servlet.http.HttpSession;
import org.apache.log4j.Logger;
import org.eclipse.birt.report.engine.api.EngineException;
import org.eclipse.birt.report.engine.api.HTMLRenderOption;
import org.eclipse.birt.report.engine.api.IReportEngine;
import org.eclipse.birt.report.engine.api.IReportRunnable;
import org.eclipse.birt.report.engine.api.IRunAndRenderTask;
import org.springframework.web.context.support.WebApplicationContex tUtils;
public class BirtReportServlet extends HttpServlet {
private static final long serialVersionUID = 1L;
* Constructor of the object.
private BirtPlatformListener birtPlatformFactory = null;
protected static Logger log = Logger.getLogger(BirtReportServlet.class);
public BirtReportServlet() {
super();
public void init(ServletConfig arg0) throws ServletException {
super.init(arg0);
this.birtPlatformFactory = (BirtPlatformListener) WebApplicationContextUtils.
getWebApplicationContext(getServletContext()).getBean("platformListener ");
* Destruction of the servlet.
public void destroy() {
super.destroy();
* The doGet method of the servlet.
public void doGet(HttpServletRequest req, HttpServletResponse resp) throws ServletException, IOException {
long startTime = System.currentTimeMillis();
log.debug("obtaining engine");
// get report name and launch the engine
// resp.setContentType("text/html");
// resp.setContentType( "application/pdf" );
// resp.setHeader ("Content-Disposition","inline; filename=test.pdf");
IReportEngine birtReportEngine = birtPlatformFactory.getReportEngine();
String reportName = req.getParameter("ReportName");
if (log.isDebugEnabled()) {
log.debug("opening design: " + reportName);
IReportRunnable design = null;
IRunAndRenderTask task = null;
try {
// Open report design
design = openReportDesign(reportName, birtReportEngine);
log.debug("design opened");
// create task to run and render report
task = birtReportEngine.createRunAndRenderTask(design);
autoAnswerPrompt(req,task);
task.setAppContext(birtPlatformFactory.getBirtConfig().getAp pContext());
log.debug("renderTask created");
// set output options
ByteArrayOutputStream baos = new ByteArrayOutputStream(2048);
HTMLRenderOption options = getRenderOptions(baos);
task.setRenderOption(options);
log.debug("options set");
// run report
task.run();
log.debug("task run");
task.close();
resp.getWriter().write(baos.toString());
log.debug("task close");
catch (Exception e) {
e.printStackTrace();
throw new ServletException(e);
} finally {
if (task != null) {
task.close();
long endTime = System.currentTimeMillis();
log.info(reportName + " generated in " + (endTime - startTime)/1000.0 + "s");
private IReportRunnable openReportDesign(String reportName, IReportEngine birtReportEngine) throws EngineException {
IReportRunnable design;
ServletContext sc = getServletContext();
InputStream stream = sc.getResourceAsStream("/WEB-INF/reports/" + reportName);
design = birtReportEngine.openReportDesign(reportName, stream);
return design;
private HTMLRenderOption getRenderOptions(ByteArrayOutputStream baos) {
HTMLRenderOption options = new HTMLRenderOption();
// options.setOutputFormat(HTMLRenderOption.OUTPUT_FORMAT_PDF);
options.setOutputFormat(HTMLRenderOption.OUTPUT_FORMAT_HTML) ;
options.setEmbeddable(true);
// can not directly call getOutputStream because its already been written to!
options.setOutputStream(baos);
return options;
private void autoAnswerPrompt(HttpServletRequest req, IRunAndRenderTask task) {
HttpSession session = req.getSession();
Object value = session.getAttribute("calculationResultsID");
task.setParameterValue("calculationResultsID", value);
// Below shows how to iterate over prompts. Its overkill for what we do though.
// protected Map answerPrompts(HttpServletRequest req, IReportEngine birtReportEngine, IReportRunnable design) {
// // answer the prompts
// IGetParameterDefinitionTask task = birtReportEngine.createGetParameterDefinitionTask(design);
// Collection params = task.getParameterDefns(true);
// Map promptAnswers = new HashMap();
// Iterator i = params.iterator();
// while (i.hasNext()) {
// IParameterDefnBase param = (IParameterDefnBase) i.next();
// if (param instanceof IParameterGroupDefn) {
// answerPrompts(req, promptAnswers, (IParameterGroupDefn) param);
// } else if (param instanceof IScalarParameterDefn) {
// answerPrompt(req, promptAnswers, (IScalarParameterDefn) param);
// } else {
// log.error("Unknown parameter!" + com.itgssi.util.FormatUtils.toString(param));
// return promptAnswers;
// private void answerPrompts(HttpServletRequest req, Map promptAnswers, IParameterGroupDefn group) {
// Iterator i = group.getContents().iterator();
// while (i.hasNext()){
// answerPrompt(req, promptAnswers, (IScalarParameterDefn) i.next());
// private void answerPrompt(HttpServletRequest req,Map promptAnswers, IScalarParameterDefn defn) {
// String promptText =defn.getPromptText();
// HttpSession session = req.getSession();
// if (promptText != null) {
// if (promptText.equals("Result Id")) {
// Object value = session.getAttribute("calculationResultsID");
// if (value != null) {
// promptAnswers.put(defn.getName(),value);
* The doPost method of the servlet.
public void doPost(HttpServletRequest request, HttpServletResponse response) throws ServletException, IOException {
doPost(request,response);
name="BirtConfig.java"
filename="BirtConfig.java"
import java.lang.reflect.InvocationTargetException;
import java.util.Map;
import java.util.logging.Level;
import org.apache.commons.beanutils.PropertyUtils;
import org.eclipse.birt.core.framework.IPlatformContext;
import org.eclipse.birt.core.framework.PlatformServletContext;
import org.eclipse.birt.report.engine.api.EngineConfig;
import org.eclipse.birt.report.engine.api.HTMLActionHandler;
import org.eclipse.birt.report.engine.api.HTMLEmitterConfig;
import org.eclipse.birt.report.engine.api.HTMLServerImageHandler;
import org.springframework.web.context.ServletContextAware;
public class BirtConfig implements ServletContextAware {
private Logger log = Logger.getLogger(BirtConfig.class);
private Map engineProperties;
private Map appContext;
private ServletContext sc;
private String logDirectory;
private Level logLevel;
private EngineConfig engineConfig;
public void initialize() throws IllegalAccessException, InvocationTargetException, NoSuchMethodException {
engineConfig = new EngineConfig();
PropertyUtils.copyProperties(engineProperties,engineConfig);
engineConfig.setLogConfig(logDirectory,logLevel);
HTMLEmitterConfig htmlConfig = new HTMLEmitterConfig();
htmlConfig.setActionHandler(new HTMLActionHandler());
htmlConfig.setImageHandler(new HTMLServerImageHandler());
engineConfig.getEmitterConfigs().put("html", htmlConfig);
IPlatformContext context = new PlatformServletContext(sc);
engineConfig.setPlatformContext(context);
public void setServletContext(ServletContext servletContext) {
this.sc = servletContext;
public Map getEngineProperties() {
return engineProperties;
public void setEngineProperties(Map config) {
this.engineProperties = config;
public void setLogDirectory(String logDirectory) {
this.logDirectory = logDirectory;
public void setLogLevel(String logLevel) {
this.logLevel = java.util.logging.Level.parse(logLevel);
public EngineConfig getEngineConfig() {
return engineConfig;
public Map getAppContext() {
return appContext;
public void setAppContext(Map renderOptions) {
this.appContext = renderOptions;
name="BirtImageServlet.java"
filename="BirtImageServlet.java"
import java.io.File;
import java.io.FileInputStream;
import java.io.OutputStream;
import org.eclipse.birt.report.engine.api.EngineConstants;
import org.eclipse.birt.report.engine.api.HTMLRenderContext;
import org.springframework.util.FileCopyUtils;
public class BirtImageServlet extends HttpServlet {
protected static Logger log = Logger.getLogger(BirtImageServlet.class);
public BirtImageServlet() {
super();
super.init(arg0);
super.destroy();
public void doGet(HttpServletRequest request, HttpServletResponse response) throws ServletException, IOException {
String imageName = request.getParameter("id");
if (imageName == null)
throw new ServletException("Missing id parameters");
// Cast to file, so we can extract just the filename
File imageFile = new File(imageName);
imageName = imageFile.getName();
Map appContext = birtPlatformFactory.getBirtConfig().getAppContext();
HTMLRenderContext htmlContext = (HTMLRenderContext) appContext.get(EngineConstants.APPCONTEXT_HTML_RENDER_CONTEX T);
String imageDirectory = htmlContext.getImageDirectory();
imageFile = new File(imageDirectory + File.separator + imageName);
FileInputStream fis = new FileInputStream(imageFile);
OutputStream os = response.getOutputStream();
try {
FileCopyUtils.copy(fis, os);
// file is only requested once
imageFile.delete();
finally {
fis.close();
doGet(request,response);
name="BirtPlatformListener.java"
filename="BirtPlatformListener.java"
* Copyright 2006, Xebia BV, the Netherlands
* info@inspiring.nl
import org.eclipse.birt.core.exception.BirtException;
import org.eclipse.birt.core.framework.Platform;
import org.eclipse.birt.report.engine.api.IReportEngineFactory;
* Helper class to start and stop Eclipse BIRT.
* @author Silvester van der Bijl
public class BirtPlatformListener {
protected static Logger log = Logger.getLogger(BirtPlatformListener.class);
/** Eclipse {@link EngineConfig}. */
private BirtConfig birtConfig;
/** Instance of the {@link IReportEngine}. */
private IReportEngine reportEngine;
* Must be called before using the BIRT APIs. After retrieving the configuration from
* {@link XReportConfiguration} will start the BIRT {@link Platform}.
public void start() {
log.debug("Starting Eclipse BIRT platform");
EngineConfig engineConfig = birtConfig.getEngineConfig();
try {
Platform.startup(engineConfig);
} catch (BirtException be) {
throw new IllegalArgumentException("Failure starting BIRT platform", be);
log.debug("Creating new instance of report engine.");
IReportEngineFactory factory = (IReportEngineFactory) Platform.createFactoryObject(IReportEngineFactory.EXTENSION_ REPORT_ENGINE_FACTORY);
reportEngine = factory.createReportEngine(engineConfig);
reportEngine.changeLogLevel(engineConfig.getLogLevel());
* Must be called after finishing use of the Eclipse BIRT APIs. E.g. at application shutdown
* (hint, look at the destroy-method property of spring beans).
public void shutdown() {
log.debug("Shutting down Eclipse BIRT platform");
if (reportEngine != null) {
log.debug("Shutting down report engine instance.");
reportEngine.shutdown();
// Just call shutdown
Platform.shutdown();
* Create or return the cached instance of the {@link IReportEngine}.
* @return instance of {@link IReportEngine}
public IReportEngine getReportEngine() {
return reportEngine;
* Sets the engineConfig.
* @param engineConfig The engineConfig to set.
public void setBirtConfig(BirtConfig birtConfig) {
this.birtConfig = birtConfig;
public BirtConfig getBirtConfig() {
return birtConfig;
--------------040305030701020108070209--
Re: DataSource from an external factory [message #199051 is a reply to message #198881] Fri, 03 November 2006 15:07 Go to previous message
Ryan,
Here is the plugin.
Here is an example of setting the connection.
Jason
import java.util.HashMap;
import org.eclipse.birt.report.engine.api.ReportEngine;
import java.sql.*;
public class ExecuteConnectionPool {
private java.sql.Connection setupJdbcConnection(){
java.sql.Connection conn = null;
try{
Class.forName( "com.mysql.jdbc.Driver" );
conn = java.sql.DriverManager.getConnection(
"jdbc:mysql://localhost/classicmodels", "root", "root");
catch ( Exception e )
System.exit(0);
return( conn );
public void executeReport() throws EngineException
//Engine Configuration - set and get temp dir, BIRT home, Servlet context
EngineConfig config = new EngineConfig();
config.setEngineHome(
"C:\\birt-runtime-2.1RC5\\birt-runtime-2_1_0\\ReportEngine" );
//Create the report engine
ReportEngine engine = new ReportEngine( config );
//Open a report design - use design to modify design, retrieve embedded
images etc.
engine.openReportDesign("C:/xport/appcontext.rptdesign");
//Create task to run the report - use the task to execute and run the
report,
//retrieve report parameter values from ParameterDefinitionTask();
IRunAndRenderTask task = engine.createRunAndRenderTask(design);
//Set Render context to handle url and image locataions
HTMLRenderContext renderContext = new HTMLRenderContext();
renderContext.setImageDirectory("image");
HashMap contextMap = new HashMap();
contextMap.put( EngineConstants.APPCONTEXT_HTML_RENDER_CONTEXT,
renderContext );
//add the connection object to the map
contextMap.put(
"org.eclipse.birt.report.data.oda.subjdbc.SubOdaJdbcDriver",
setupJdbcConnection() );
task.setAppContext( contextMap );
//Set rendering options - such as file or stream output,
//output format, whether it is embeddable, etc
//options.setOutputStream(System.out);
options.setOutputFileName("C:/work/birt/connectionpool/AppContextTest.html ");
options.setOutputFormat("html");
//run the report and destroy the engine
task.run();
engine.destroy();
* @param args
try
ExecuteConnectionPool ecp = new ExecuteConnectionPool();
ecp.executeReport( );
news:eidlkp$874$1@utils.eclipse.org...
>> Ryan,
>> Jason
>>>be
>>> <no-tx-datasource>
>>> </no-tx-datasource>
>>>Thanks,
>>>Ryan
>>>>Trevor,
>>>>data
>>>>set view.
>>>>JNDI
>>>>approach.
>>>>Jason
>>>>>the
>>>>>-t.
> super();
> super.init(arg0);
> super.destroy();
> try {
> // run report
> task.run();
> task.close();
> } finally {
> if (task != null) {
> task.close();
> + "s");
> reportName);
> return design;
> written to!
> return options;
> task) {
> though.
> param);
> param);
> // } else {
> i.next());
> return appContext;
> super();
> super.init(arg0);
> super.destroy();
> try {
> imageFile.delete();
> finally {
> fis.close();
> * info@inspiring.nl
> configuration from
> try {
> be);
> return birtConfig;
Previous Topic:Run charts with BIRT viewer on Linux
Next Topic:IRR Financial script
Current Time: Sun Nov 09 04:56:31 EST 2025
Powered by FUDForum. Page generated in 0.03734 seconds
