| Further problems running jetty:run and jetty:stop in q4e 0.9 [message #18857] |
Wed, 13 May 2009 23:52 |
I having some problems running jetty:run and jetty:stop in q4e 0.9, beyond
the problem I reported earlier that jetty:run never terminates.
1. I was needed to kill Eclipse to get jetty to stop. After restarting,
adding parameter "daemon=true" to the jetty:run command (launched from
q4e) stops the task from showing as ongoing in Progress view. However,
Jetty doesnt seem to be running as the web app is down.
2. Then running jetty:stop from the command line results in:
"[jetty:stop]
Jetty not running!"
3. In Eclipse's Debug view, I see 5 entries, none of which I can get to go
away:
Run Jetty [Maven 2]
Run Jetty [Maven 2]
Stop Jetty [Maven 2]
Run Jetty [Maven 2]
Run Jetty [Maven 2]
5. Relaunching jetty with "daemon=false" adds an entry to the above list,
but doesnt bring the web app back. Contrast with previously, when it ran
web app fine, but never terminated.
5. The OS reports no Jetty process is running.
-Ben
FUDForum. Page generated in 0.06843 seconds
