Home » Archived » DSDP - Mobile Tools for Java (MTJ) » Bad Stack Map error
Bad Stack Map error [message #18829] Sun, 18 February 2007 13:17 Go to next message
Hello there. I've recently decided to switch over from Netbeans to Eclipse
becuse of the on device debugging Nokia talks about with Eclipse, however
simply trying to move the project over is giving me problems. My setup:
Windows XP
Eclipse 3.2
MTJ 0.7
emf-sdo-xsd-SDK-2.2.0
I know the project runs because it is fine with netbeans, but when I try to
run it in Eclipse i get a
ALERT: java/lang/ClassFormatError: Bad stack map.
I have no idea what this means and the only thing I could find was about not
using long or float types, none of which I am using in the project. Is
there something I'm missing? The project doesn't use any Nokia SDK's at
this point either, I wanted to just use the simple Java WTK 2.2 to start off
simple without bringing in Nokia's notorously flaky SDK's. Any help would
be appreciated.
Thank you
Mike
Re: Bad Stack Map error [message #18852 is a reply to message #18829] Fri, 23 February 2007 11:07 Go to previous messageGo to next message
Have you configured the WTK 2.2 runtime yet, and set that as the library
for your project?
You can do this by selecting Preferences > Mobile Tools ... > Runtime
Platform and pointing at the root directory of your WTK 2.2 installation.
Once you have done this create a new MTJ project, with the runtime you
created, and copy your source files into the project.
Good luck,
kevin
> Windows XP
> Eclipse 3.2
> MTJ 0.7
> be appreciated.
> Thank you
> Mike
Re: Bad Stack Map error [message #18898 is a reply to message #18852] Wed, 28 February 2007 13:54 Go to previous message
Actually I'm going to try using EclipseME for a while. Something about
version 0.7 of new tools makes me nervous. Thanks though.
"Kevin Horowitz" <khorowit@us.ibm.com> wrote in message
news:45DF115E.4090804@us.ibm.com...
> for your project?
> Good luck,
> kevin
>> Eclipse becuse of the on device debugging Nokia talks about with Eclipse,
>> however simply trying to move the project over is giving me problems. My
>> setup:
>> Windows XP
>> Eclipse 3.2
>> MTJ 0.7
>> to run it in Eclipse i get a
>> not using long or float types, none of which I am using in the project.
>> Is there something I'm missing? The project doesn't use any Nokia SDK's
>> at this point either, I wanted to just use the simple Java WTK 2.2 to
>> start off simple without bringing in Nokia's notorously flaky SDK's. Any
>> help would be appreciated.
>> Thank you
>> Mike
Re: Bad Stack Map error [message #565900 is a reply to message #18829] Fri, 23 February 2007 11:07 Go to previous message
for your project?
Good luck,
kevin
> Windows XP
> Eclipse 3.2
> MTJ 0.7
> be appreciated.
> Thank you
> Mike
Re: Bad Stack Map error [message #565973 is a reply to message #18852] Wed, 28 February 2007 13:54 Go to previous message
> for your project?
> Good luck,
> kevin
>> setup:
>> Windows XP
>> Eclipse 3.2
>> MTJ 0.7
>> Thank you
>> Mike
Previous Topic:cannot load files from res folder
Next Topic:cannot load files from res folder
Current Time: Sat Nov 08 23:05:07 EST 2025
Powered by FUDForum. Page generated in 0.04992 seconds
