| CDT for Windows - default install, "launch failed no binaries" [message #197694] |
Wed, 18 July 2007 15:33  |
So I've installed CDT for Windows to take for a test drive before
we teach CDT and PTP at OSCON next week.
Great work Doug! No longer do we need to tell Windows folks to install
all of Cygwin, etc.
I did the default install on a machine without Eclipse or Cygwin.
I did everything using the defaults.
However when I create and build the 'hello world' C project I get
"Launch failed no binaries."
No binaries are under the Debug config.
When I change source and save i get in the Console view:
**** Build of configuration Debug for project ****
then nothing else except for
(Exec error:Launching failed)
I tried to force the build a couple of other ways too
(nice new little "hammer" action icon)
but no luck.
What's wrong?
....Beth Tibbitts
Parallel Tools Platform http://eclipse.org/ptp
| Re: CDT for Windows - default install, "launch failed no binaries" [message #201791 is a reply to message #201606] |
Mon, 17 September 2007 13:54   |
Originally posted by: dschaefer.qnx.com
Levente wrote:
> Beth Tibbitts wrote:
>> There was no PATH variable in Project Properties, C/C++ Build,
>> Environment. Setting it (to MinGW\bin path) doesn't help
>> The Project Properties, C/C++ Build, Settings has Cygwin C Compiler
>> and Cygwin C Linker! Not MinGW!
>> The Toolchain editor (Project properties, C/C++ Build, Tool Chain
>> Editor) was set to Cygwin GCC. Changed to MinGW GCC.
>> It works now!
>> Why was the default set to Cygwin?
>> ...Beth
> My question is rather: why does it compile a MinGW project with default
> settings, but not a Cygwin project?
Because the MinGW project settings adds the mingw/bin directory to your
path.
In Wascana 0.9.3, if you don't have cygwin installed, it won't be
offered as a choice in the New Project wizard by default.
Doug.
| Re: CDT for Windows - default install, "launch failed no binaries" [message #201980 is a reply to message #201791] |
Fri, 21 September 2007 02:12  |
Hi, I'm new with Eclipse, I read this thread, but I couldn't get the tip to
compile a Cygwin console project under windows (XP, btw). I have makefile
errors working with Cygwin C++ compiler, so I have no the binaries.
I've tryed everything, but nothing seems to work. The cygwin folders (bin,
lib, etc are in the PATH environment variable).
I choose the correct toolchains, etc. What set value I've missed?
Thanks for any tip (sorry for my english)
greets, rossana
"Doug Schaefer" <dschaefer@qnx.com> escribi
FUDForum. Page generated in 0.05324 seconds
