| org.eclipse.core.resources cannot be imported (M7) [message #197653] |
Thu, 19 February 2004 08:08  |
Originally posted by: kleine_matthias.gmx.de
Hi there,
I created a plugin-project with a tree-view (with 3.0 M7).
The code generation wizard generates some code in which
the method ResourcesPlugin.getWorkspace() is called. However,
it "forgot" to generate an adequate import, so I get the
error message "ResourcesPlugin cannot be resolved".
When I try to import the plugin by using
import org.eclipse.core.resources
this does not work also. Obviously, this plugin cannot be
found in the installation of Eclipse3.0 M7 (Linux/gtk).
Any ideas of what could be the problem?
Best regards
Matthias
http://gnogito.berlios.de
FUDForum. Page generated in 0.04234 seconds
