Home » Eclipse Projects » Plugin Development Environment (PDE) » How can I force the workbench to switch to a perspective
How can I force the workbench to switch to a perspective [message #18812] Tue, 02 September 2008 09:21 Go to next message
Originally posted by: yeronimuz.aol.com
I have an RCP with a boring perspective. So when my fancy plugin is activated, I want to switch to
the perspective of the plugin when the editor of this plugin is activated.
How should I do that?
Jeroen.
Re: How can I force the workbench to switch to a perspective [message #18881 is a reply to message #18812] Wed, 03 September 2008 03:29 Go to previous messageGo to next message
> activated, I want to switch to the perspective of the plugin when the
> Jeroen.
After some workbench errors and other 'challenges', I found a solution:
In my plugin.java I write in the constructor:
getWorkbench().getPerspectiveRegistry().setDefaultPerspectiv e( "designer.perspective1");
I'm not sure if this is the best place, but anyhow, it works.
Jeroen.
Re: How can I force the workbench to switch to a perspective [message #18904 is a reply to message #18881] Wed, 03 September 2008 07:12 Go to previous message
>> Thanks,
>> Jeroen.
> Jeroen.
I was cheering to soon. Now every time I start the RCP, it gives an error about not being able to
restore the "designer" perspective. That's probably because the designer is not known at that
specific moment.
Where should I put this switch perspective?
Re: How can I force the workbench to switch to a perspective [message #578180 is a reply to message #18812] Wed, 03 September 2008 03:29 Go to previous message
> Jeroen.
Jeroen.
Re: How can I force the workbench to switch to a perspective [message #578242 is a reply to message #18881] Wed, 03 September 2008 07:12 Go to previous message
>> Thanks,
>> Jeroen.
> Jeroen.
specific moment.
Previous Topic:import existing project into workspace extension point
Next Topic:[P2] Problem creating repository with .product when exporting for multiple platforms
Current Time: Sun Nov 16 14:29:55 EST 2025
Powered by FUDForum. Page generated in 0.04051 seconds
