Home » Language IDEs » C / C++ IDE (CDT) » [ANN] JBoss plug-in for Eclipse now available
| [ANN] JBoss plug-in for Eclipse now available [message #18808] |
Mon, 18 February 2002 11:00  |
February 18, 2002
EASIE(tm) JBoss 2.4.4/3.0Alpha Plugin (Early Access 1)
Genuitec announces the Early Access 1 release of the EASIE JBoss Plugin.
This plugin is one of a series of application and web server plugins
for the Eclipse 2.0 IDE. EASIE JBoss Plugin extends the Eclipse IDE to
include user controls for managing a JBoss 2.4.4/3.0Alpha instance from
within Eclipse runtime and debug contexts. The plug-in is built on top of
Genuitec's Eclipse Application Server Integration Environment, (EASIE), a
framework for interfacing Eclipse with Java/J2EE application servers.
Early Access Features:
1) Easy plugin configuration
2) Start JBoss Server in Eclipse debug context
3) Graceful shutdown of JBoss Server
4) Monitor JBoss output from Eclipse console
5) Fix-and-Go debugging of EJBs, Servlets, and Controller logic using JDK
1.4 HotSwap feature
6) How-To documentation
Features remaining in development for 1.0 Release:
1) Auto deployment of EJBs and Web Applications
2) Tutorial and Examples
EASIE JBoss Plugin is free for personal and commercial use. Visit
http://www.genuitec.com/products.htm for download instructions.
EASIE Weblogic Plugin version 1.0ea3 is also available immediately.
EASIE Webspere Plugin version 1.0ea1 is scheduled for release on Friday,
2/22/2002.
Other EASIE plugins soon to be released include Orion/Oracle 9i.
Genuitec, L.L.C.
| Re: [ANN] JBoss plug-in for Eclipse now available [message #18831 is a reply to message #18808] |
Mon, 18 February 2002 11:37   |
Originally posted by: jthompson.allezconsulting.com
I have been able to get the plug-in to work properly. However, I am unable
to use the Fix-and-Go feature, I had this problem when I was working with
JBoss externally too. I have and EAR being deployed, I have break points
set and I can reach them and debug, howerver when I update the code, I get
an error, saying it was unable to update the code and that it is out of
sync.
Any help on what I am doing wrong would be greatly appreciated.
Jake T.
"Todd Williams" <todd@genuitec.com> wrote in message
news:a4r859$f33$1@rogue.oti.com...
> February 18, 2002
JDK
> 1.4 HotSwap feature
> 2/22/2002.
> Genuitec, L.L.C.
| Re: [ANN] JBoss plug-in for Eclipse now available [message #18942 is a reply to message #18831] |
Mon, 18 February 2002 13:52   |
Jake,
I'm not familiar with the problem you're reporting. As a place to start, we
published an EJB debugging tutorial at the website
(http://www.genuitec.com/products.htm) recently that you might want to take
a look at. Although the tutorial was written using the Weblogic plug-in,
the same set of steps and results have been tested with the JBoss plug-in
also. If you'd like to go through the tutorial with the JBoss plug-in, drop
an email to easie@genuitec.com , reference this posting, and request a
modified client and build script for JBoss to make life a little easier.
Before doing even that though, I would check is that my software environment
(Eclipse 2.0 build, JDK 1.4 version) are the same or later than as those
listed in the tutorial.
Todd
"Jake Thompson" <jthompson@allezconsulting.com> wrote in message
news:a4raaa$g5p$1@rogue.oti.com...
unable
> sync.
> Jake T.
> > February 18, 2002
of
a
> JDK
> > 1.4 HotSwap feature
> > 2/22/2002.
> > Genuitec, L.L.C.
| Re: [ANN] JBoss plug-in for Eclipse now available [message #18964 is a reply to message #18942] |
Mon, 18 February 2002 13:56   |
I think my proble, is that I am used to the "production" deployment of a
single ear, that contains everything, from the feedback I have gotten, I
cannot update this way, so instead I need to configure jboss to use the
eclipse build directory for the class files.
Jake T.
news:a4ri6i$jjv$1@rogue.oti.com...
> Jake,
we
take
drop
environment
> Todd
> unable
with
points
get
> > sync.
> > Thanks,
> > Jake T.
> > > February 18, 2002
Plugin.
from
> of
(EASIE),
> a
using
> > JDK
> > > 1.4 HotSwap feature
Friday,
> > > 2/22/2002.
> > > Genuitec, L.L.C.
| Re: [ANN] JBoss plug-in for Eclipse now available [message #18986 is a reply to message #18942] |
Mon, 18 February 2002 16:37   |
Ok, solution:
Make sure that if you are using ant, you are putting the eclipse compiled
class files into the jar's and not a ant/javac set of class files.
Thanks all,
Jake T.
> Jake,
we
take
drop
environment
> Todd
> unable
with
points
get
> > sync.
> > Thanks,
> > Jake T.
> > > February 18, 2002
Plugin.
from
> of
(EASIE),
> a
using
> > JDK
> > > 1.4 HotSwap feature
Friday,
> > > 2/22/2002.
> > > Genuitec, L.L.C.
| Re: [ANN] JBoss plug-in for Eclipse now available [message #19676 is a reply to message #19631] |
Wed, 20 February 2002 17:21  |
Neil,
JBoss has a very nice classpath extension mechanism that is configurable in
the
jboss.conf file. Have a look at the one in the 'catalina' directory and
compare
it to the one in the 'default' directory. You'll need to add Cocoon's jars
the
same way the catalina configuration adds Tomcat's jars.
Hope that helps,
Todd
"Neil Guinto" <nguinto@mincron.com> wrote in message
news:a50pul$o0n$1@rogue.oti.com...
> I liked to know how can I add dirs/jars on the startup classpath? The
> reason I asked is we are using JBoss together with Cocoon. Appreciate any
> help.
> > February 18, 2002
of
a
> JDK
> > 1.4 HotSwap feature
> > 2/22/2002.
> > Genuitec, L.L.C.
Current Time: Sun Nov 16 02:05:54 EST 2025
Powered by FUDForum. Page generated in 0.05588 seconds
