Home » Modeling » GMF (Graphical Modeling Framework) » Cheat Sheet in Ganymede?
Cheat Sheet in Ganymede? [message #197154] Tue, 15 July 2008 13:38 Go to next message
Originally posted by: lwrage.sei.cmu.edu
Hi all,
I've downloaded "Eclipse Modeling Tools (includes Incubating
components)" assuming this contains all of GMF. However, when trying to
do the mindmap tutorial I noticed that the cheat sheets are missing.
The tutorial mentions an experimental SDK, so I tried to install that.
However, the Ganymede download adds a seemingly outdated update site URL
for GMF
( http://download.eclipse.org/modeling/gmf/update-site/release s/site.xml),
so I added the site
(http://download.eclipse.org/modeling/gmf/updates/releases/) manually.
After installing the experimental sdk, the cheat sheets are still not
there. So, how can I get them?
Lutz
Re: Cheat Sheet in Ganymede? [message #197165 is a reply to message #197154] Tue, 15 July 2008 14:01 Go to previous messageGo to next message
Hi Lutz,
It seems you've found a bug. Somehow, the oeg.doc.ui plug-in is not
included in any of our features. It was in the *.doc feature, but then
moved to the *.sdk feature due to a build complication. Then, it was
apparently lost in the shuffle when we refactored the *.sdk feature to
include the new *.tooling feature. I'll open a bug to correct this.
In the meantime, from the Help > Cheat Sheets... menu, use the "Enter the
URL of a cheat sheet:" option and paste in the following link to grab the
cheat sheet directly from CVS:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.gmf/doc /org.eclipse.gmf
..doc.ui/cheatsheets/tutorial.xml?root=Modeling_Project& revision=1.8&content-
type=text%2Fplain
You'll see a warning that not all actions/commands may work, as they are in
the *.doc.ui plug-in. So, you'll have to launch the referenced wizards
manually from the New dialog.
Rich
On 7/15/08 1:38 PM, in article g5inab$egi$1@build.eclipse.org, "Lutz Wrage"
<lwrage@sei.cmu.edu> wrote:
> Hi all,
> for GMF
> so I added the site
> Lutz
Re: Cheat Sheet in Ganymede? [message #197456 is a reply to message #197165] Wed, 16 July 2008 10:39 Go to previous message
Fixed https://bugs.eclipse.org/bugs/show_bug.cgi?id=240962
On 7/15/08 2:01 PM, in article C4A25E3A.1113D%richard.gronback@borland.com,
"Richard Gronback" <richard.gronback@borland.com> wrote:
> Hi Lutz,
> .doc.ui/cheatsheets/tutorial.xml?root=Modeling_Project&r evision=1.8&content-
> type=text%2Fplain
> Rich
>> Hi all,
>> for GMF
>> so I added the site
>> Thanks,
>> Lutz
Previous Topic:Label positioning
Next Topic:Label not centered
Current Time: Mon Jul 21 23:53:43 EDT 2025
Powered by FUDForum. Page generated in 0.25407 seconds
