Home » Eclipse Projects » Plugin Development Environment (PDE) » Queries on Headless PDE Build
| Queries on Headless PDE Build [message #18789] |
Mon, 01 September 2008 08:42  |
Hi All,
I have some queries related to the Headless build mechanism(PDE Build) in
Eclipse. Please find the queried below. I would be happy to know some
comments/views on the same.
1. After running a headless build, some plug-ins gets jared and others
don't. On what criterion is the artifact generation(jar/folder) decided?
Have I missed something in the manifest that is responsible for the above
behavior?
2. Is there a difference in the way headless and non-headless builds
works? I build a plug-in in headless and non-headless mode, this was my
observation - In non-headless, a folder is generated and in headless a jar
file is generated. To be more specific, the plug-in I am trying to build
contains a number of XSL files along with Java code.
Thanks in advance.
Neeraj Bhusare
| Re: Queries on Headless PDE Build [message #19035 is a reply to message #18789] |
Wed, 03 September 2008 10:11   |
The shape of the resulting artifact (jar/folder) is determined by the
feature containing the plug-in.
In the feature.xml editor, on the Plug-ins tab under Plug-in Details,
look at "Unpack the plug-in archive after installation". This
corresponds to an 'unpack="true"' attribute in the xml. Unpack=true
results in a folder, unpack=false results in a jar. The default value
is true.
During export, the value is determined by the "Package plug-ins as
individual JAR archives" checkbox on the Options tab of the export wizard.
-Andrew
Neeraj Bhusare wrote:
> Hi All,
> in Eclipse. Please find the queried below. I would be happy to know some
> above behavior?
> jar file is generated. To be more specific, the plug-in I am trying to
> build contains a number of XSL files along with Java code.
> Thanks in advance.
> Neeraj Bhusare
| Re: Queries on Headless PDE Build [message #44950 is a reply to message #19035] |
Wed, 04 February 2009 10:29   |
Originally posted by: jiaoxw.css.com.cn
于 2008-9-3 22:11, Andrew Niefer 写道:
> results in a folder, unpack=false results in a jar. The default value is
> true.
> -Andrew
>> Hi All,
>> some comments/views on the same.
>> decided? Have I missed something in the manifest that is responsible
>> for the above behavior?
>> my observation - In non-headless, a folder is generated and in
>> headless a jar file is generated. To be more specific, the plug-in I
>> am trying to build contains a number of XSL files along with Java
>> code. Thanks in advance. Regards,
>> Neeraj Bhusare
Hi Andrew:
I tried unpack=true,but it doesn't work when I use ant build
script.When I enter into the plugins directory,my depended plugins
packed in jar,but I want it is a directory.How can I do this?
sunway
| Re: Queries on Headless PDE Build [message #46256 is a reply to message #44950] |
Tue, 10 February 2009 10:32  |
Hi sunway,
> Hi Andrew:
> sunway
did you find a solution for this problem? I do have the same problem to
solve,
Thomas E.-E.
| Re: Queries on Headless PDE Build [message #578417 is a reply to message #18789] |
is true.
-Andrew
> Hi All,
> above behavior?
> Thanks in advance.
> Neeraj Bhusare
| Re: Queries on Headless PDE Build [message #591369 is a reply to message #19035] |
> true.
> -Andrew
>> Hi All,
>> Neeraj Bhusare
Hi Andrew:
sunway
| Re: Queries on Headless PDE Build [message #591750 is a reply to message #44950] |
Hi sunway,
> Hi Andrew:
> sunway
solve,
Thomas E.-E.
Current Time: Wed Nov 05 10:45:58 EST 2025
Powered by FUDForum. Page generated in 0.03981 seconds
