Home » Language IDEs » Java Development Tools (JDT) » ant not picking up JDTCompilerAdapter
ant not picking up JDTCompilerAdapter [message #197091] Sun, 27 February 2005 15:41 Go to next message
Originally posted by: dhall_sumant.hotmail.com
I am using Eclipse 3.0.1. I am trying to compile some java classes using
the Ant plugin. When I run the ant build.xml, I get the following message:
BUILD FAILED: build.xml:23: Compiler Adapter
'org.eclipse.jdt.core.JDTCompilerAdapter' can't be found.
I added the 'org.eclipse.jdt.core.JDTCompilerAdapter' jar file to the ant
runtime classpath properties under
Window->Preferences->Ant->Runtime->Classpath->Ant Home entries (Default).
I selected "Add external Jars"
When I run the build file now, the message is:
BUILD FAILED: build.xml:23: Cannot find the JDT compiler
Can someone please let me know how to fix the error?
thanks in advance,
Sumant
Re: ant not picking up JDTCompilerAdapter [message #197099 is a reply to message #197091] Sun, 27 February 2005 16:06 Go to previous messageGo to next message
To run the JDTCompiler outside of Eclipse you will need to add the two JARs
to the Ant runtime classpath:
jdtCompilerAdapter.jar and the jdtcore.jar
HTH
Darins
"Sumant Dhall" <dhall_sumant@hotmail.com> wrote in message
news:cvtbai$3qr$1@www.eclipse.org...
> thanks in advance,
> Sumant
Re: ant not picking up JDTCompilerAdapter [message #197206 is a reply to message #197099] Tue, 01 March 2005 01:13 Go to previous messageGo to next message
Thanks Darin! It works now.
> HTH
> Darins
>> thanks in advance,
>> Sumant
Re: ant not picking up JDTCompilerAdapter [message #221987 is a reply to message #197091] Mon, 09 January 2006 19:26 Go to previous messageGo to next message
I'm using Eclipse 3.2 M4, and am running into a similar problem : I'm trying
to deploy a plugin using the export wizard.
The following error pops out :
file:C:/Work/Merlin/Project/Implementation/org.eclipse.emf.c odegen.jeteditor
/build.xml:127: Compiler Adapter 'org.eclipse.jdt.core.JDTCompilerAdapter'
can't be found.
The Ant runtime path contains the following entry :
C:/Work/Merlin/Eclipse/configuration/org.eclipse.osgi/bundle s/145/1/.cp/jdtC
ompilerAdapter.jar.
Adding the org.eclipse.jdt.core_3.2.0.v_631.jar to the Ant runtime path
doesn't help.
There is nothing in the error log.
I'm really running out of ideas :( can someone please help me ?
Thanks in advance.
Joel.
"Sumant Dhall" <dhall_sumant@hotmail.com> a
Re: ant not picking up JDTCompilerAdapter [message #222075 is a reply to message #221987] Thu, 12 January 2006 08:57 Go to previous message
Just a little precision on this topic : I'm using JRE 1.5, and the plugin
was initially made with Eclipse 3.1.
Thanks in advance for any help/pointers, sorry if this is a silly question.
Bests,
Joel.
"Joel Cheuoua" <jcheuoua@wanadoo.fr> wrote in message
news:dpuv00$22h$1@utils.eclipse.org...
> Hello,
> trying
> can't be found.
> ompilerAdapter.jar.
> doesn't help.
> Thanks in advance.
> Joel.
Previous Topic:PDT export - build classpath problem
Next Topic:Migrating from JDOM
Current Time: Fri Nov 21 23:41:41 EST 2025
Powered by FUDForum. Page generated in 0.07390 seconds
