Where is the documentation [message #197041] |
Mon, 23 October 2006 10:35  |
Originally posted by: trevor.l.torrez.accenture.com
Hi, I'm new to using birt.
We have plans to integrate birt into a custom web application, after
much fuss I got the servlet integrated into an example application in a
way that meshes with our continuous build process and dependency management.
I have a few questions about the framework in general. Aside from the
flash tutorials, where is the general documentation? I'm looking for
something along the lines of explaining the overall interactions of the
main components, ie: how do the modelapi, coreapi, dte-api
(data-engine?), report-engine-api, and other api's interact? What are
the main responsibilities and features of each? I have a few other
specific questions which I'll post as separate threads.
-t.
Re: Where is the documentation [message #197044 is a reply to message #197041] |
Mon, 23 October 2006 10:54   |
Originally posted by: m.kortas.net
Hi Trevor,
perhaps this is what you are looking for:
- http://help.eclipse.org/help31/index.jsp?
- http://wiki.eclipse.org/index.php/BIRT_Project
greetings
Michael
> -t.
Re: Where is the documentation [message #197048 is a reply to message #197044] |
Mon, 23 October 2006 11:34   |
Michael wrote:
> Hi Trevor,
> greetings
> Michael
>> a way that meshes with our continuous build process and dependency
>> management.
>> the main components, ie: how do the modelapi, coreapi, dte-api
>> Thanks,
>> -t.
That should do nicely; thanks. I didn't see the help31 link referenced
anywhere; or did i just miss it?
-t.
Re: Where is the documentation [message #197735 is a reply to message #197044] |
Wed, 25 October 2006 20:24  |
The help31 link has documentation for BIRT 2.0, which is now out of date.
You should use the help that installs with BIRT. The BIRT Report Developer
Guide section explains how to use the Report Designer UI. The reference
materials are now split into separate sections, BIRT Programmer Reference
and BIRT Charting Programmer Reference.
Jane Tatchell
BIRT documentation lead
"Michael" <m@kortas.net> wrote in message
news:0eab1b1cc48f19c63e5e63ec1ebab5e4$1@www.eclipse.org...
> Hi Trevor,
> greetings
> Michael
>> We have plans to integrate birt into a custom web application, after much
>> fuss I got the servlet integrated into an example application in a way
>> Thanks,
>> -t.
FUDForum. Page generated in 0.06067 seconds
