Home » Eclipse Projects » GEF » Rendering SWT controls on GEF canvas
| Rendering SWT controls on GEF canvas [message #196606] |
Fri, 23 September 2005 06:58  |
Originally posted by: so.to.speak
I am planning to build a lightweight gui designer in GEF, but the point =
that's still fuzzy for me is rendering the controls in GEF canvas.
GEF seems to be fine for creating IFigure based diagrams and such stuff,=
but for rendering a textbox or checkbox etc... control in editor canvas,=
i =
need a better method than emulating the appearance of those controls. Th=
is =
method does not seem feasible.
I've found out that VE uses screen scrapping to do this, but it's =
implementatin does not look very lightweight.
Are there any alternatives other than using screen scraping for my task,=
or would anyone recommend a simpler approach or example to take a look a=
t? =
What are the best practices for providing this kind of functionality?
Best Regards
| Re: Rendering SWT controls on GEF canvas [message #197074 is a reply to message #196606] |
Thu, 29 September 2005 07:14   |
On Fri, 23 Sep 2005 13:58:15 +0300, "Furkan Demir" <so@to.speak>
wrote:
>Hi,
>but for rendering a textbox or checkbox etc... control in editor canvas, i
>need a better method than emulating the appearance of those controls. This
I am writing a diagram editor for a dialog modelling language. The
abstract dialog elements in my language may have concrete gui widgets
inside, in my case SWT controls. These controls are live in the
editor, in the sense that the user may interact with them and drives
the execution engine for the dialog model. Hence, scraping wasn't an
option.
In my implementation I have a special IFigure, imaginatively called
ControlFigure, which wraps an SWT control and manages its life cycle,
in cooperation with an EditPart. More specifically, the SWT control is
created at a time when the EditPart has a viewer, which is used as the
parent. When the ControlFigure or one of its parents are moved, the
SWT control is also moved. This is implemented by using a special
anchor for tracking movements. Since anchors use absolute coordinates,
they must listen to movements in a parent hierarchy (done by GEF for
you), so listening to and using the anchor is an easy way to move the
control appropriately. The swt control must also be destroyed, and
this is triggered by the EditPart's deactivate method (or the
fireDeactived method depending on your needs).
To sum up: The EditPart and a special IFigure cooperate to manage the
SWT control's life-cycle, the EditPart's viewer's control is the
parent control (Composite) of the SWT control and an anchor is used to
move the SWT control when one of the containing IFigure's move.
Hallvard
| Re: Rendering SWT controls on GEF canvas [message #197177 is a reply to message #197169] |
Thu, 29 September 2005 17:18  |
Sunil Kamath wrote:
> "David J. Orme" <djo@coconut-palm-software.com> wrote in message
>>XSWT is gradually migrating to VEP for its GUI builder, but you asked how
>>to build a GUI builder by directly manipulating SWT controls, and this
>>code shows how to do it.
> It wasn't me who asked for it :-).
Yeah, I noticed that after I posted.
> However, it all comes back to VEP finally, doesn't it?
Well, that's where the community is. And to quote Mike Milinkovich,
"It's the community, stupid." :-)
> I have built a GUI designer as well (http://eclipsensis.sf.net) and have
> "borrowed" VE's method for screen scraping.
> It is the best mechanism I have found for GUI design using native widgets
> (and I have tried a few - including the heavyweight approach).
> However, I have made some modifications and compromises, since I only intend
> to support Win32 platforms.
Nice project!
Puhlezze support Linux/GTK. ;-) (Which wouldn't have been a problem if
you'd used heavyweight controls. ;-)
BTW, we're always glad when other projects "borrow" our source. :-)
It's probably possible to adapt GEF to work with heavyweight visuals
just like it's been adpated to both the SWT tree and Draw2d. I'd love
to see somebody do that... (Furkan??)
Best,
Dave Orme
Visual Editor Project lead
http://www.db4o.com -- The Open-source Java Object Database
http://xswt.sf.net -- XML-based SWT page description language
Current Time: Sat Nov 08 23:35:54 EST 2025
Powered by FUDForum. Page generated in 0.04022 seconds
