Home » Eclipse Projects » Eclipse Platform » Eclipse/Ant/javac and fork=true
Eclipse/Ant/javac and fork=true [message #196596] Tue, 17 February 2004 17:42 Go to next message
OS:Windows XP
Eclipse: 3.0M6
I have an ant build.xml file with the following target:
<target name="build" depends="init">
<!-- Make the destination directory -->
<mkdir dir="${build.dest}" />
<!-- Compile the source files & copy the support files -->
<javac fork="yes" classpath="${classpath}"
srcdir="${build.src}"
destdir="${build.dest}"
debug="${debug}"
optimize="${optimize}"
excludes="**/*~"/>
</target>
If I run ant (v 1.6) from the command line the above javac task is
processed just fine. However, if I run ant from inside Eclipse the
above target fails with the following error:
[javac] javac: invalid flag: C:\Documents
If I remove the fork="yes" from the above the build runs as expected.
I'm looking for an *easy* way to deal with this. For various reasons
my team wants to keep the fork=yes and I would like to be able to have
my Eclipse workspaces located anywhere on the file system and not
require paths that do not contain spaces (a rediculous restriction in
2004).
I'm hoping there is something obvious I'm missing in configuration and
was hoping someone out there could help, or is this a bug in Eclipse?
Shane
Re: Eclipse/Ant/javac and fork=true [message #196628 is a reply to message #196596] Tue, 17 February 2004 18:40 Go to previous messageGo to next message
This could be a bug in Eclipse...I will check shortly.
How are you running the Ant build within Eclipse; in the same VM as Eclipse
or in a separate VM? Have you tried both?
Have you tried running from the commandline in the exact same location that
your workspace is in (to remove the possibility of an Ant bug)?
Darins
<sholder@chipdata.com> wrote in message news:smh9ib0j.fsf@chipdata.com...
> OS:Windows XP
> Eclipse: 3.0M6
> debug="${debug}"
> excludes="**/*~"/>
> </target>
> 2004).
> Shane
Re: Eclipse/Ant/javac and fork=true [message #197405 is a reply to message #196628] Wed, 18 February 2004 17:27 Go to previous messageGo to next message
Originally posted by: hhzz60.hotmail.com
Always put quotes around directories that contain spaces. This will allow
the ant script to work inside and outside of eclipse (with or without
forking).
"Darin Swanson" <Darin_Swanson@us.ibm.com> wrote in message
news:c0u8ap$vu6$1@eclipse.org...
Eclipse
that
> Darins
> > OS:Windows XP
> > Eclipse: 3.0M6
> > debug="${debug}"
> > excludes="**/*~"/>
> > </target>
> > 2004).
> > Shane
Re: Eclipse/Ant/javac and fork=true [message #197838 is a reply to message #196628] Thu, 19 February 2004 11:22 Go to previous messageGo to next message
"Darin Swanson" <Darin_Swanson@us.ibm.com> writes:
Assuming you're talking about the "Run Ant..."/JRE tab I just tried
both options of "Run in the same JRE as the workspace" and "Alternate
JRE" (no additional arguments) with the same outcome. (FWIW I'm
running 1.4.2.01 SDK).
CD'ing to my workspace/project directory and running ant on the
commandline yeilds a successful build of the project.
Shane
Re: Eclipse/Ant/javac and fork=true [message #197842 is a reply to message #197405] Thu, 19 February 2004 11:25 Go to previous messageGo to next message
"Kurt" <hhzz60@hotmail.com> writes:
> forking).
I thought I had, the classpath is set to "${classpath}" how many do I
need? :)
>> > debug="${debug}"
>> > excludes="**/*~"/>
Re: Eclipse/Ant/javac and fork=true [message #197849 is a reply to message #197842] Thu, 19 February 2004 11:55 Go to previous message
If you could take the time to log a bug report against Platform Ant I can
take a look.
Please include all the details like a sample buildfile, a sample classpath
etc.
Darins
<sholder@chipdata.com> wrote in message news:brnvhw8e.fsf@chipdata.com...
allow
> > forking).
> need? :)
> >> > debug="${debug}"
> >> > excludes="**/*~"/>
Previous Topic:new search view
Next Topic:Associate Editor with File extension like *.bz.xsd"
Current Time: Mon Sep 01 02:41:43 EDT 2025
Powered by FUDForum. Page generated in 0.04264 seconds
