Home » Eclipse Projects » DTP » Problem using Serena Plugin for Eclipse.
Problem using Serena Plugin for Eclipse. [message #18754] Sun, 02 July 2006 07:31 Go to next message
Hi, I'm new to PVCS. I'm trying to configure my IDE(Eclipse 3.0.1) with
ChangeMan Version Manager 8.1.
I got plugin folders from C:\Program Files\Serena\vm\Integrations\Eclipse
folder of Serena installation folder.
And i copied all following folders to my eclipse plugin
folder(ECLIPSE_HOME\plugins)
com.serena.team.core_3.0.1
com.serena.team.docs_3.0.1
com.serena.team.ui.vm_3.0.1
com.serena.team.ui_3.0.1
And i copied following folders to my eclipse features
folder(ECLIPSE_HOME\features)
com.serena.team_3.0.1
And i enabled Serena check box from Window>Customize Perspective window.
Then i try to Get Projects from Version Manager, i'm getting following error
Plug-in com.serena.team.ui.vm was unable to load class
com.serena.team.ui.vm.wizards.NewProjectWizard.
If i click any option under Serena Menu i'm getting "The Chosen operation is
not currently available".
Here is the LOG file from my workspace.
org.osgi.framework.BundleException: Exception in
org.eclipse.core.internal.compatibility.PluginActivator.star t() of bundle
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:975)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:937)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:421)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:293)
org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(EclipseClassLoader.java:110)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:371)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:402)
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(AbstractClassLoader.java:93)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:307)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:336)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1313)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:131)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:124)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:113)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:196)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java:193)
org.eclipse.ui.internal.PluginAction.createDelegate(PluginAc tion.java:114)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:247)
org.eclipse.ui.internal.WWinPluginAction.runWithEvent(WWinPl uginAction.java:206)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:915)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:866)
org.eclipse.jface.action.ActionContributionItem$7.handleEven t(ActionContributionItem.java:785)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:796)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2772)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2431)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1377)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1348)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:254)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688)
Caused by: org.eclipse.core.runtime.CoreException: Attempt to activate a
disabled plug-in: "com.serena.team.ui.vm".
org.eclipse.core.internal.plugins.PluginDescriptor.throwExce ption(PluginDescriptor.java:284)
org.eclipse.core.internal.plugins.PluginDescriptor.pluginAct ivationEnter(PluginDescriptor.java:260)
org.eclipse.core.internal.plugins.PluginDescriptor.doPluginA ctivation(PluginDescriptor.java:357)
org.eclipse.core.internal.plugins.PluginDescriptor.getPlugin (PluginDescriptor.java:328)
org.eclipse.core.internal.compatibility.PluginActivator.star t(PluginActivator.java:47)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$1 .run(BundleContextImpl.java:958)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:954)
... 42 more
Root exception:
org.eclipse.core.runtime.CoreException: Attempt to activate a disabled
!ENTRY org.eclipse.core.runtime 4 1 Jul 02, 2006 07:04:20.741
!MESSAGE Plug-in com.serena.team.ui.vm was unable to load class
com.serena.team.ui.vm.actions.SynchronizeAllAction.
!STACK 0
java.lang.ClassNotFoundException:
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:404)
!ENTRY org.eclipse.ui 4 4 Jul 02, 2006 07:04:20.741
!MESSAGE Could not create action delegate for id:
!STACK 0
-murthy
Re: Problem using Serena Plugin for Eclipse. [message #18842 is a reply to message #18754] Wed, 05 July 2006 17:27 Go to previous message
> I got plugin folders from C:Program FilesSerenavmIntegrationsEclipse
--clip----
Hi Murthy,
Not sure what to say here -- we don't have any experience with these
components. Would probably be better to direct you question to Serena
support.
HTH,
John Graham
Eclipse Data Tools Platform PMC Chair
Re: Problem using Serena Plugin for Eclipse. [message #580640 is a reply to message #18754] Wed, 05 July 2006 17:27 Go to previous message
--clip----
Hi Murthy,
support.
HTH,
John Graham
Previous Topic:New Data Set - Incomplete database results
Next Topic:Stored procedure list is empty
Current Time: Wed Jul 16 19:14:34 EDT 2025
Powered by FUDForum. Page generated in 0.04101 seconds
