Home » Eclipse Projects » DTP » Using DTP with PostgreSQL?
Using DTP with PostgreSQL? [message #18728] Sun, 02 July 2006 02:48 Go to next message
Is there any experience with DTP with PostgreSQL?
I tried to make connection using a generic JDBC driver which partially
succeeded. It showed some of the tablespaces , some of the tables but
never all of them. Clicking on things is resulted in CPU usage of 100%
and exceptions.
I really would like using a database development tool integrated in
Eclipse so any advise on how to get DTP working with PostgreSQL would be
appreciated.
TIA
Joost
Re: Using DTP with PostgreSQL? [message #18778 is a reply to message #18728] Sun, 02 July 2006 20:12 Go to previous messageGo to next message
Joost Kraaijeveld wrote:
yes..besides i'm able to use Derby, PostgreSQL does work correct as
well..for me..
ontop my http://pkgsrc-group.sourceforge.net NetBSD-Eclipse distro.
> and exceptions.
> appreciated.
i've got a stable build environment, and can supply you w/ copy
to fullfill your needs..
> TIA
> Joost
--Noud
Re: Using DTP with PostgreSQL? [message #19740 is a reply to message #18778] Mon, 24 July 2006 19:17 Go to previous message
This is a multipart message in MIME format.
--=_alternative 007FE6DA882571B5_=
Content-Type: text/plain; charset="US-ASCII"
The vendor doc for PostgreSQL might not have the complete data type
support on the version of PostgreSQL that you are connecting to. If this
is the case, you can contribute to
org.eclipse.datatools.connectivity.dbdefinition.genericJDBC_ 0.9.0.200605101\runtime\vendors\Generic
JDBC_1.0\Generic JDBC_1.0.xmi.
There is a widely discussed design issue, that "Generic JDBC database" is
used to connect to a database with minimum effort, however, in order to
support all data type for a specific database, this would call for a
specialized vendor, see following tutorial for details:
http://www.eclipse.org/datatools/project_modelbase/modelbase _doc/DTP%20Modelbase%20White%20paper.htm
Hope this help.
Der Ping
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">The vendor doc for PostgreSQL might
not have the complete data type support on the version of PostgreSQL that
you are connecting to. If this is the case, you can contribute to org.eclipse.datatools.connectivity.dbdefinition.genericJDBC_ 0.9.0.200605101\runtime\vendors\Generic
JDBC_1.0\Generic JDBC_1.0.xmi.</font>
<br>
<br><font size=2 face="sans-serif">There is a widely discussed design issue,
that &quot;Generic JDBC database&quot; is used to connect to a database
with minimum effort, however, in order to support all data type for a specific
database, this would call for a specialized vendor, see following tutorial
for details:</font>
<br>
<br><font size=2 face="sans-serif"> http://www.eclipse.org/datatools/project_modelbase/modelbase _doc/DTP%20Modelbase%20White%20paper.htm</font>
<br>
<br><font size=2 face="sans-serif">Hope this help.</font>
<br>
<br><font size=2 face="sans-serif">Der Ping</font>
<br>
--=_alternative 007FE6DA882571B5_=--
Re: Using DTP with PostgreSQL? [message #580507 is a reply to message #18728] Sun, 02 July 2006 20:12 Go to previous message
well..for me..
> and exceptions.
> appreciated.
> TIA
> Joost
--Noud
Re: Using DTP with PostgreSQL? [message #581147 is a reply to message #18778] Mon, 24 July 2006 19:17 Go to previous message
Hope this help.
Der Ping
<br>
for details:</font>
<br>
<br>
<br>
<br>
Previous Topic:Is DTP suitable for Oracle pl/sql development?
Next Topic:[Fwd: trouble creating updates for plugin]
Current Time: Thu Oct 23 16:58:20 EDT 2025
Powered by FUDForum. Page generated in 0.05049 seconds
