Home » Archived » Voicetools » Open Existing Workbench Error.
Open Existing Workbench Error. [message #18719] Thu, 22 May 2008 18:24 Go to next message
I am trying to open a pre-existing workbench in OpenVXML so I can edit an
existing application. When I open OpenVXML I am asked which workbench to
use. it opens and I see the project on the right and the componets on the
left, but the middle pane shows the error:
"Unable to create this part due to an internal error. Reason for the
failure: Unable to read file"
When I click Details I get...
org.eclipse.core.internal.resources.ResourceException: Resource is out of
sync with the file system: /Benchmark/CallDesign.xml.
org.eclipse.core.internal.localstore.FileSystemResourceManag er.read(FileSystemResourceManager.java:606)
at org.eclipse.core.internal.resources.File.getContents(File.ja va:290)
at org.eclipse.core.internal.resources.File.getContents(File.ja va:279)
org.eclipse.vtp.desktop.editors.core.impl.ApplicationEditor. init(ApplicationEditor.java:144)
at org.eclipse.ui.internal.EditorManager.createSite(EditorManag er.java:842)
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:583)
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:372)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:566)
org.eclipse.ui.internal.EditorAreaHelper.setVisibleEditor(Ed itorAreaHelper.java:263)
org.eclipse.ui.internal.EditorManager.setVisibleEditor(Edito rManager.java:1474)
at org.eclipse.ui.internal.EditorManager$5.run(EditorManager.ja va:1008)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:843)
org.eclipse.ui.internal.EditorManager.restoreState(EditorMan ager.java:1003)
org.eclipse.ui.internal.WorkbenchPage.restoreState(Workbench Page.java:2843)
org.eclipse.ui.internal.WorkbenchWindow.restoreState(Workben chWindow.java:1936)
at org.eclipse.ui.internal.Workbench.doRestoreState(Workbench.j ava:2873)
at org.eclipse.ui.internal.Workbench.access$14(Workbench.java:2 821)
at org.eclipse.ui.internal.Workbench$20.run(Workbench.java:1697 )
org.eclipse.ui.internal.Workbench.runStartupWithProgress(Wor kbench.java:1437)
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:1695)
at org.eclipse.ui.internal.Workbench.access$12(Workbench.java:1 666)
at org.eclipse.ui.internal.Workbench$18.run(Workbench.java:1545 )
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:1489)
org.eclipse.ui.internal.WorkbenchConfigurer.restoreState(Wor kbenchConfigurer.java:183)
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:702)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1101)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1863)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:422)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Any help would be appreciated!
thx.
Re: Open Existing Workbench Error. [message #18744 is a reply to message #18719] Thu, 22 May 2008 18:32 Go to previous message
This question gets asked often to our support, so I thought I would post it
into the VTP users group.
The "out of synch" error happens occasionally on the first time that you try
to open a workspace that has been transfered from another designer. If you
close eclipse and reopen the workspace will be in synch again.
Cheers!
jd
"Jerric Davis" <jerric@openmethods.com> wrote in message
news:g14rqq$i6e$1@build.eclipse.org...
> Hello,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> thx.
Re: Open Existing Workbench Error. [message #576803 is a reply to message #18719] Thu, 22 May 2008 18:32 Go to previous message
Cheers!
jd
> Hello,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> thx.
Previous Topic:Tomcat Application Deployment
Next Topic:Telera Property?
Current Time: Fri Nov 07 05:21:09 EST 2025
Powered by FUDForum. Page generated in 0.03657 seconds
