Home » Newcomers » Newcomers » frequent rebuild of workspace
frequent rebuild of workspace [message #195825] Fri, 23 February 2007 12:07 Go to next message
Originally posted by: chadmichaeldavis.gmail.com
Eclipse recently started going into periodic rebuilds of the entire
workspace, seemingly triggered by my saving any resource in the project.
AFAIK, I'm using the built in java builder, and can't find any setttings
that seem to indicate I've set it to do a full build with each save.
Its kind of random anyway; it happens probably one out of 15 saves.
Anybody know what could cause this?
Re: frequent rebuild of workspace [message #195833 is a reply to message #195825] Fri, 23 February 2007 12:30 Go to previous messageGo to next message
Originally posted by: wegener.cboenospam.com
Check to see if any of your projects have build path errors. If so, resolve
the errors and see if that stops the behavior.
"chad" <chadmichaeldavis@gmail.com> wrote in message
news:ern6us$ssr$1@utils.eclipse.org...
Re: frequent rebuild of workspace [message #195840 is a reply to message #195833] Fri, 23 February 2007 12:51 Go to previous messageGo to next message
I don't have any other open projects. And this project doesn't have any
dependency on other projects either. Would this still cause a problem
like this?
Re: frequent rebuild of workspace [message #196130 is a reply to message #195840] Sun, 25 February 2007 19:57 Go to previous messageGo to next message
Originally posted by: eclipse5.rizzoweb.com
>> resolve
> like this?
Build path errors can be in the JAR dependencies, not only in
dependencies on other projects. Go to the Java Build Path of the Project
Properties and see if there are any problems reported.
You can also try Cleaning the entire project by selecting Project > Clean...
Hope this helps,
Eric
Re: frequent rebuild of workspace [message #196655 is a reply to message #196130] Tue, 27 February 2007 12:13 Go to previous message
> Clean...
I don't have missing resources on the build path, at least none that
eclipse is complaining about. I tried cleaning, I'll let you know if
that works.
Do you have an understanding of why cleaning would fix this? I
understand that it might "just work", but its a bit counterintuitive.
Chad
Previous Topic:Cannot Create DataSet
Next Topic:CORBA
Current Time: Sun Nov 09 04:22:50 EST 2025
Powered by FUDForum. Page generated in 0.08803 seconds
