| Editor and View Pattern [message #195788] |
Fri, 04 July 2008 07:57  |
I want to show two attributes in the same label and this works fine using
the following settings. But when I click on the label I only want to edit
one of the attributes. It works as I want it to do, but the data is not
saved. I've heard that you can remove one of the attributes in
MessageFormatParser but I have not found the correct one.
Diagram Label: Diagram Label Test
Edit Method: MESSAGE_FORMAT
Editor Pattern: {0}
Edit Pattern: {0}
Features: label : EString, label2 : EString
Read Only: false
View Method: MESSAGE_FORMAT
View Pattern: {0}:{1}
Tobias
| Re: Editor and View Pattern [message #196021 is a reply to message #195788] |
Tue, 08 July 2008 03:42  |
Originally posted by: jan.herriger.gmx.de
Hi Tobias,
i don't know exactly why, but the following works for me:
Editor Pattern: {0}
Edit Pattern: {0}{1}
View Pattern: {0} : {1}
Tobias Emitslöf schrieb:
> using the following settings. But when I click on the label I only want
> to edit one of the attributes. It works as I want it to do, but the data
> is not saved. I've heard that you can remove one of the attributes in
> Editor Pattern: {0}
> Edit Pattern: {0}
> Read Only: false
> Tobias
FUDForum. Page generated in 0.03533 seconds
