Home » Archived » Maven Integration (M2E) » Re: [m2eclipse-user] Tycho: Eclipse plugin dependency resolution from local repository
| Re: [m2eclipse-user] Tycho: Eclipse plugin dependency resolution from local repository [message #18676] |
Tue, 21 October 2008 13:25  |
Originally posted by: igor.ifedorenko.com
m2spring@springdot.org wrote:
> Let me clarify that httpclient is just an example.
> Making it and my other 3rd party artifacts to be OSGi bundles is the easy
> part.
> I've planned to deploy them then to my group repository.
> However, for my internally developed artifacts it's a different story.
> All of them are Eclipse plugins.
> I want to build them through a CI framework (probably Continuum) and
> deploy them also to the group repository.
> Then, members of my team can work on individual plugins and the plugins'
> OSGi dependencies
> (as expressed in MANIFEST.MF) are resolved from the group repository.
> That's my plan in a nutshell. Having a target platform in this picture
> where a base set of plugins are resolved from is fine, too.
Actually, this is the primary use case for "target platform management"
feature we're adding to tycho and I would be very interested to know how
well (or not so well) it works for your projects. There is no user
documentation yet, but here is relatively detailed description of how
this works.
In the just announced tycho 0.3.0-DEV-1756, build target platform can be
specified using dependencyManagement pom.xml section. It is possible to
specify path to local eclipse installation using dependency with system
scope, but more interestingly, it is also possible to specify
eclipse-feature and eclipse-plugin artifacts using maven
groupId/artifactId/version coordinates.
At build time, tycho will resolve all eclipse-feature artifacts
(transitively) and eclipse-plugin artifacts (non-transitively) from
maven repositories and target platform used during the build will
include features/bundles both from local eclipse-installation and from
maven repositories. Build results can be installed/deployed into maven
local/remote repositories by invoking regular "install" or "deploy"
build phases.
So in your scenario, CI framework can run "tycho/bin/mvn deploy" for set
of related projects and everything is expected to work "the maven way"
assuming dependencyManagement is configured properly. We are using
Hudson, btw, but I guess Continuum should work too.
You can see this in action in integration test [1]. The test first runs
build01 to install a feature and couple of bundles into local maven
repository. Then it runs build02 which uses the feature and bundles from
the first build. You can see specification of build02 target platform in
pom.xml [2].
Please note that -Dtycho.targetPlatform OVERRIDES target platform in
pom.xml. In other words, target platform specified in
dependencyManagement sections will be ignored if -Dtycho.targetPlatform
is specified on command line or via settings.xml/pom.xml. (I should have
added a warning, I guess)
Also note that there is no PDE integration yet. We can talk about using
tycho build target platform in PDE if you're happy with how it works on
command line.
[1]
http://svn.sonatype.org/m2eclipse/tycho/trunk/tycho-its/proj ects/tycho164/
[2]
http://svn.sonatype.org/m2eclipse/tycho/trunk/tycho-its/proj ects/tycho164/build02/pom.xml
>> but I am open for suggestions
>> about how to make consumption of plain JARs in tycho builds easier.
> I wouldn't cater to consuming plain Jars in general with Tycho.
> I would target OSGi bundles only instead.
> If there was a way to map an OSGi dependency into a Maven coordinate,
> and Maven/Tycho was able to resolve the OSGi dependency from a Maven
> repository,
> that might make the consumption of OSGi bundles easier.
I think I know what you mean and I might have some ideas how to
implement it, although not necessary exactly as you describe it here. I
can't be more specific at the moment, but stay tuned ;-).
Igor
| Re: [m2eclipse-user] Tycho: Eclipse plugin dependency resolution from local repository [message #21746 is a reply to message #18676] |
Sun, 08 February 2009 12:41   |
Originally posted by: wrobinson.gsu.edu
If I understand correctly, tycho can do the following:
1. Read the required Eclipse plugins from the manifest
2. Search and download a required plugin from a maven repository during
compilation
I have installed an eclipse plugin into a maven repository and I can
view/download. You can find it here:
http://wrserver1.cis.gsu.edu:9080/artifactory/
It is referenced in the dependencyManagement section as follows.
<dependencyManagement>
<dependencies>
<dependency>
<groupId>org.reqmon</groupId>
<artifactId>org.reqmon.emf.ocl.compiler</artifactId>
<version>1.0.1-SNAPSHOT</version>
<type>eclipse-plugin</type>
</dependency>
</dependencies>
</dependencyManagement>
I have attempted this with both SNAPSHOT and normal release versions (e.g.,
1.0.0)
Each time I run tycho 0.3.0-DEV-1983, it always complains
org.apache.maven.reactor.MavenExecutionException: Bundle
org.reqmon.emf.ocl.compiler.ui cannot be resolved
Resolution errors:
Bundle org.reqmon.emf.ocl.compiler.ui - Missing Constraint:
Require-Bundle: org.reqmon.emf.ocl.compiler; bundle-version="1.0.1"
The maven repository is correctly configured using the ./m2/settings.xml.
(Additionally, I have updated the conf/settings.xml file in tycho.)
Any suggestions?
"Igor Fedorenko" <igor@ifedorenko.com> wrote in message
news:gdl3a9$pt7$1@build.eclipse.org...
>> part.
>> OSGi dependencies
> this works.
> build phases.
> pom.xml [2].
> command line.
> [1]
> [2]
>> repository,
> Igor
| Re: [m2eclipse-user] Tycho: Eclipse plugin dependency resolution from local repository [message #21791 is a reply to message #21746] |
Sun, 08 February 2009 21:06   |
After reading a bit further, I discovered that I didn't specify the
parent/module pom's properly. After creating a parent with the (seemly
properly) dependencyManagement, then I get this error:
"d:\program files\tycho\bin\mvn" -Dtycho.targetPlatform="D:/Program
Files/eclipse" compile
[INFO] snapshot org.reqmon:org.reqmon.compiler.POM:1.0.0-SNAPSHOT: checking
for updates from http://wrserver1.cis.gsu.edu:9080/artifactory/repo
[WARNING] repository metadata for: 'snapshot
org.reqmon:org.reqmon.compiler.POM:1.0.0-SNAPSHOT' could not be retrieved
from repository: http://wrserver1.cis.gsu.edu:9080/artifactory/repo due to
an error: Unsupported Protocol: '': Cannot find wagon which supports the
requested protocol:
[INFO] Repository 'http://wrserver1.cis.gsu.edu:9080/artifactory/repo' will
be blacklisted
for updates from http://repository.sonatype.org/content/groups/public
from repository: http://repository.sonatype.org/content/groups/public due to
requested protocol:
[INFO] Repository 'http://repository.sonatype.org/content/groups/public'
will be blacklisted
requested protocol:
be blacklisted
requested protocol:
will be blacklisted
[ERROR]
To diagnose, I ran it with mvn (not tycho) to see if it might download
something. I changed the project type to jar (rather than eclipse-plugin).
Then, I do get a download.
[DEBUG] org.reqmon:org.reqmon.emf.ocl.compiler.ui:jar:1.0.0-SNAPSHOT
(selected for null)
[DEBUG] Trying repository wrserver1.cis.gsu.edu
Downloading:
http://wrserver1.cis.gsu.edu:9080/artifactory/repo/org/reqmo n/org.reqmon.emf.ocl.compiler/1.0.0/org.reqmon.emf.ocl.compi ler-1.0.0.pom
[DEBUG] Artifact resolved
[DEBUG] org.reqmon:org.reqmon.emf.ocl.compiler:jar:1.0.0:compile (selected
for compile)
For some reason, my tycho doesn't download for dependencyManagement.
Any ideas?
<wrobinson@gsu.edu> wrote in message news:gmn5h9$90s$1@build.eclipse.org...
> compilation
> <dependencies>
> <dependency>
> </dependency>
> </dependencies>
> (e.g., 1.0.0)
> Resolution errors:
> Any suggestions?
>>> easy
>>> part.
>>> OSGi dependencies
>> this works.
>> build phases.
>> pom.xml [2].
>> command line.
>> [1]
>> [2]
>>> repository,
>> Regards,
>> Igor
| Re: [m2eclipse-user] Tycho: Eclipse plugin dependency resolution from local repository [message #21836 is a reply to message #21791] |
Mon, 09 February 2009 09:41   |
There is a chance Tycho does not work properly when installed to a path
with spaces. Can you move tycho to, say, d:\tycho and see if the problem
still exists?
Also, -Dtycho.targetPlatform *overrides* dendencyManagement section in
your pom.xml. You need to specify eclipse installation as dependency
with packaging=eclipse-installation and scope=system in pom.xml
Igor
> checking for updates from
> retrieved from repository:
> http://wrserver1.cis.gsu.edu:9080/artifactory/repo due to an error:
> Unsupported Protocol: '': Cannot find wagon which supports the requested
> protocol:
> will be blacklisted
> http://repository.sonatype.org/content/groups/public due to an error:
> protocol:
> will be blacklisted
> protocol:
> will be blacklisted
> protocol:
> will be blacklisted
> [ERROR]
> eclipse-plugin). Then, I do get a download.
> (selected for null)
> Downloading:
> (selected for compile)
> Any ideas?
>> during compilation
>> <dependencies>
>> <dependency>
>> </dependency>
>> </dependencies>
>> (e.g., 1.0.0)
>> Resolution errors:
>> ./m2/settings.xml. (Additionally, I have updated the conf/settings.xml
>> file in tycho.)
>> Any suggestions?
>>>> easy
>>>> part.
>>>> plugins'
>>>> OSGi dependencies
>>> this works.
>>> build phases.
>>> pom.xml [2].
>>> command line.
>>> [1]
>>> [2]
>>>> repository,
>>> Regards,
>>> Igor
| Re: [m2eclipse-user] Tycho: Eclipse plugin dependency resolution from local repository [message #21881 is a reply to message #21836] |
Mon, 09 February 2009 11:50   |
It turns out that spaces in the maven path are not a problem, in this case.
The problem was my multi-project layout. My parent and child (modules)
projects are in the same directory. (I didn't want to use subdirectory child
modules because of source control issues. )
See this:
http://www.waltercedric.com/java-j2ee-mainmenu-53/361-maven- build-system/1363-maven-multi-module-support-in-m2eclipse.ht ml
I followed the tip in the above link to include the relativePath in the
child module:
<relativePath>../org.reqmon.compiler.POM/pom.xml</relativePath >
That solved the problem. :-)
news:49904089.3050901@ifedorenko.com...
> still exists?
> your pom.xml. You need to specify eclipse installation as dependency with
> Igor
>> to an error: Unsupported Protocol: '': Cannot find wagon which supports
>> the requested protocol:
>> will be blacklisted
>> will be blacklisted
>> will be blacklisted
>> will be blacklisted
>> [ERROR]
>> (selected for null)
>> Downloading:
>> Any ideas?
>>> compilation
>>> <dependencies>
>>> <dependency>
>>> </dependency>
>>> </dependencies>
>>> (e.g., 1.0.0)
>>> Resolution errors:
>>> file in tycho.)
>>> Any suggestions?
>>>>> easy
>>>>> part.
>>>>> plugins'
>>>>> OSGi dependencies
>>>>> picture
>>>> how
>>>> this works.
>>>> be
>>>> build phases.
>>>> set
>>>> from
>>>> in
>>>> pom.xml [2].
>>>> have
>>>> command line.
>>>> [1]
>>>> [2]
>>>>> repository,
>>>> Regards,
>>>> Igor
Current Time: Sat Nov 08 20:01:59 EST 2025
Powered by FUDForum. Page generated in 0.14056 seconds
