Home » Eclipse Projects » Remote Application Platform (RAP) » Problrm with layout / embedded groups
| Problrm with layout / embedded groups [message #18636] |
Thu, 19 April 2007 06:28  |
Hi All,
I suspect a bug on the layout management :
The case is a Group 'wGroup02' and a TabFolder 'wTabFolder' embedded in
a parent Group 'wGroup01'.
It behaves like if the components written under wGroup02, wTabFolder
were in reality created under wGroup01. It is especially visible because
the border of wGroup02, wTabBorder don't surround their children
components (a result is rather ugly !) like if the size calculation failed.
To Illustrate, I enhance the Demo (controls part), with changes in
ButtonTab.java :
After the lines :
label.setText( "Enter some text and press Return" );
final Text text = new Text( group, RWT.BORDER | RWT.SINGLE );
I add :
// T. Wing extra code
final Group groupTWing = new Group ( group, RWT.NONE );
groupTWing.setText( "Default Button" );
groupTWing.setLayout( new GridLayout( 1, false ) );
Label labelTwing = new Label( groupTWing, RWT.NONE );
groupTWing.setText( "from T. Wing" );
final Text textTWing = new Text(groupTWing,RWT.BORDER|RWT.SINGLE );
The code goes on with :
defaultButton = new Button( group, style | RWT.PUSH );
You can execute and observe the default behaviour.
What do you think ? DO I do a mistake anywhere ?
Thanks in advance for your help,
Thomas
| Re: Problrm with layout / embedded groups [message #19009 is a reply to message #18686] |
Fri, 20 April 2007 01:53   |
Hi Ralf,
Thomas is right, there is exists a bug when computing the size of a group.
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=182310 for details. You
may want to take a look at the bugzilla entry, there is a very simple code
snippet and a screenshot attached.
Have a nice day,
Stefan.
"Ralf Sternberg" <rsternberg@innoopract.com> schrieb im Newsbeitrag
news:f07hhf$4eq$1@build.eclipse.org...
> Hi Thomas,
>> The case is a Group 'wGroup02' and a TabFolder 'wTabFolder' embedded in a
>> It behaves like if the components written under wGroup02, wTabFolder were
>> in reality created under wGroup01. It is especially visible because the
>> border of wGroup02, wTabBorder don't surround their children components
> we tried out your code and for us the result looks correct. The additional
> Group appears inside the parent Group, containing the (invisible) Label
> and the Text field. The Label is invisible as there is no text or image
> set. Instead you overwrite the title of the Group "groupTWing".
> I suppose this line should read
> labelTwing.setText( "from T. Wing" );
> Could this explain the unexpected layout?
> Ralf
| Re: Problrm with layout / embedded groups [message #19278 is a reply to message #18902] |
Fri, 20 April 2007 04:53   |
Originally posted by: rsternberg.innoopract.com
Hi Thomas,
> Thanks for wou quick answer ... and sorry for the mistake in the code.
> I changed it in
> // groupTWing.setLayoutData( new RowData( 200, 60 ) );
> groupTWing.setText( "Twing Group" );
> // Label labelTwing = new Label( groupTWing, RWT.NONE );
> // labelTwing.setText( "from T. Wing" );
> final Text textTWing = new Text( groupTWing, RWT.BORDER | RWT.SINGLE );
> And the result is in the first part of the joined document.
> As I said I'm trying to take a GUI from RCP to RAP.
> I made minimum changes, only on listeners (Double clic, ...) and for
> functionnalities not yet cover covered by RAP (Cell Modifier,
> SetItemCount, ...), but the main task was to change swt/jface import to
> rap !
> The problem is when executing and I also join a screen got frol RCP, and
> the same with RAP. It's what I tried to expose by enhancing the demo
> software.
> Best regards,
> Thomas
> I also join the version of my RAP plugins.
thanks for the screenshots. They make it easier to understand your problem.
Generally speaking, size computations are still not perfect and will
undergo a revision during the development of the RWT theme management
(part of the M4 milestone).
However, the computation of the Group size has been fixed as of March,
19. I see from your plugins screenshot that your version of the RWT
plugin dates from March, 02. I'd recommend that you check out the latest
version from CVS which should fix many of your layout problems already.
If you prefer milestone builds, you can also wait for the M3 which will
be released by end of next week.
Ralf
| Re: Problrm with layout / embedded groups [message #19334 is a reply to message #19009] |
Fri, 20 April 2007 05:12  |
Hi Stephan,
Thanks for the pointer, I must have missed this bug report.
The problem was the missing computeTrim method in the Group widget. This
has been fixed as of 2007-03-19. Please try if your code works with the
latest version of RAP from CVS.
Cheers, Ralf
Current Time: Fri Nov 07 16:43:38 EST 2025
Powered by FUDForum. Page generated in 0.03092 seconds
