Home » Newcomers » Newcomers » Would like to get plugin installed location
Would like to get plugin installed location [message #195237] Tue, 20 February 2007 17:20 Go to next message
Originally posted by: subramanianj.schneider.com
I have installed Eclipse in directory(C:\Eclipse\eclipse\plugins) and
would like to get this path from my plugin code. I have tried
String location = DebugPlugin.getDefault().getStateLocation();
would return plugin location of workspace and not the installed location.
Could someone please help me getting installed location.
thanks
JP
Re: Would like to get plugin installed location [message #195303 is a reply to message #195237] Wed, 21 February 2007 02:49 Go to previous messageGo to next message
With this code :
URL url = FileLocator.find(MyPlugin.getDefault().getBundle(), new
Path(""), null);
try {
url = FileLocator.resolve(url);
}catch (IOException ioe){}
=> You have the plugin install path location...
With this code :
Platform.getInstallLocation().getURL().getPath()
=> You have Eclipse install path location
Sophie Andrieu
Re: Would like to get plugin installed location [message #195363 is a reply to message #195303] Wed, 21 February 2007 10:40 Go to previous messageGo to next message
Thanks Sophie. I have put my question wrong. Sorry that was my bad.
I have a my plugin called xxxPlugin and have file(xxx.properties) inside
that plugin and would like to read file(xxx.properties) in the
code(org.sni.eclipse.xxxAction) that exists in xxxPlugin.
xxxPlugin
--org.sni.eclipse
| - xxxAction
--xxx.properties
Could you please let me know, how to read that file.
Re: Would like to get plugin installed location [message #195370 is a reply to message #195363] Wed, 21 February 2007 10:51 Go to previous messageGo to next message
JP,
Try MyPlugin.getDefault().getBundle().getEntry("xxx.properties").
> inside that plugin and would like to read file(xxx.properties) in the
> xxxPlugin
> --org.sni.eclipse
> | - xxxAction
> --xxx.properties
Re: Would like to get plugin installed location [message #195423 is a reply to message #195370] Wed, 21 February 2007 14:24 Go to previous messageGo to next message
Thanks Ed.
Here is the code used to read resource file in plugin.
InputStream ios = myActivator.getDefault().getBundle().getResource(
"jp.properties").openStream();
BufferedReader in = new BufferedReader(new InputStreamReader(ios));
String inputLine;
while ((inputLine = in.readLine()) != null)
System.out.println(inputLine);
in.close();
Re: Would like to get plugin installed location [message #195484 is a reply to message #195423] Thu, 22 February 2007 03:04 Go to previous message
You can also use the following code (for a file named
'messages.properties' for example) :
ResourceBundle.getBundle("messages").getString(key)
Sophie
Previous Topic:TextMergeViewer
Next Topic:update the classpath
Current Time: Sun Aug 31 11:01:59 EDT 2025
Powered by FUDForum. Page generated in 0.11881 seconds
