Home » Language IDEs » ServerTools (WTP) » Where can I get javax.wsdl?
Where can I get javax.wsdl? [message #194828] Fri, 22 June 2007 20:14 Go to next message
I am using the org.eclipse.wst.wsdl plugin in my own plugin and I was
trying to call getInput() on a BindingInput. However, I got the error
"The type javax.wsdl.Input cannot be resolved. It is indirectly referenced
from required .class files"
Where can I get the version of this library/plugin that WTP is using?
Connie
Re: Where can I get javax.wsdl? [message #194836 is a reply to message #194828] Sat, 23 June 2007 09:43 Go to previous messageGo to next message
Originally posted by: valentinbaciu.hotmail.com
The javax.wsdl.* classes are part of the JWSDL API. The Eclipse WSDL model
implements the JWSDL intefaces.
What version of WTP are you using? If you're using WTP 1.5.* the
javax.wsdl.* classes are in a bundle called org.wsdl4j. If you're using WTP
2.0 the javax.wsdl.* classes are in a bundle called javax.wsdl. You will
have to add this bundle as a dependency in your bundle's manifest.
"Connie" <kkconcome@yahoo.com> wrote in message
news:d9aa20094eaa47d7834a9fd06511f1a5$1@www.eclipse.org...
> Hello,
> Connie
Re: Where can I get javax.wsdl? [message #194923 is a reply to message #194836] Mon, 25 June 2007 13:13 Go to previous message
>> Hello,
>> Thanks,
>> Connie
Thanks Valentin! I found it in org.wsdl4j.
Previous Topic:WTP 1.5 Problem with a webservice ... maybe because using a multidimensional string[][] as parameter
Next Topic:Some Webservice features are missed in my WTP+eclipse
Current Time: Sun Aug 31 12:06:25 EDT 2025
Powered by FUDForum. Page generated in 0.05228 seconds
