Error with Ubuntu Feisty [message #18581] |
Wed, 09 May 2007 15:15  |
Originally posted by: info.adaniels.nl
After upgrading from ubuntu edgy to feisty, a number of eclipse plugins
broke, one of witch PDT. I've got no clue where to look, also because I
know nothing of java.
I'm running Eclipse 2.2 (with all updates and patches) and a freshly
installed PDT.
I've read a post of eclipse broken in kubuntu because it didn't run well
with java 1.6, but apparently I'm running java 1.4.2.
java version "1.4.2"
gij (GNU libgcj) version 4.1.2 (Ubuntu 4.1.2-0ubuntu5)
I get the following error in the PHP explorer window.
Unable to create view: NOT_SUPPORTED_ERR: The implementation does not
support the requested type of object or operation.
org.w3c.dom.DOMException: NOT_SUPPORTED_ERR: The implementation does not
org.apache.xerces.dom.CoreDOMImplementationImpl.createLSPars er(Unknown
Source)
gnu.xml.dom.DomDocumentBuilderFactory.newDocumentBuilder(lib gcj.so.70)
org.eclipse.php.internal.core.project.options.PHPProjectOpti ons.loadOptions(Unknown
Source)
org.eclipse.php.internal.core.project.options.PHPProjectOpti ons. <init>(Unknown
Source)
at org.eclipse.php.internal.core.project.PHPNature.getOptions(U nknown
Source)
org.eclipse.php.internal.core.project.options.PHPProjectOpti ons.forProject(Unknown
Source)
org.eclipse.php.internal.ui.treecontent.IncludePathTreeConte nt.getChildren(Unknown
Source)
org.eclipse.php.internal.ui.StandardPHPElementContentProvide r.getChildren(Unknown
Source)
org.eclipse.php.internal.ui.explorer.ExplorerPart$ExplorerTr eeViewer.isExpandable(Unknown
Source)
org.eclipse.jface.viewers.AbstractTreeViewer.isExpandable(Ab stractTreeViewer.java:1900)
org.eclipse.jface.viewers.AbstractTreeViewer.updatePlus(Abst ractTreeViewer.java:2487)
org.eclipse.jface.viewers.AbstractTreeViewer.createTreeItem( AbstractTreeViewer.java:754)
org.eclipse.jface.viewers.AbstractTreeViewer$1.run(AbstractT reeViewer.java:731)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
Please let me know if any additional information is needed.
Thanks for any help,
Arnold
Re: Error with Ubuntu Feisty [message #18610 is a reply to message #18581] |
Thu, 10 May 2007 07:06   |
Originally posted by: pavel.kunc.google.com
I had the same issue (mostly) I think the problem is that you you GNU java
instead of Sun Java... I wasn't able to run PDT under GIJ.
All you can fixing I think by installing Sun java 5. Than you need to
change system to use Sun java s the main and also need to alter eclipse
config files...
Nice how to you can find here:
http://ubuntuguide.org/wiki/Ubuntu:Edgy#How_to_install_Java_ Integrated_Development_Environment_.28Eclipse.29
It's for edgy, but it works for Feisty also.
Let me know if it works for you.
Pavel
On Wed, 09 May 2007 21:15:10 +0200, Arnold <info@adaniels.nl> wrote:
> installed PDT.
> support the requested type of object or operation. at
> Source)
> at
> at
> Source)
> at
> Source)
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> Arnold
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Re: Error with Ubuntu Feisty [message #18613 is a reply to message #18610] |
Thu, 10 May 2007 11:17   |
Originally posted by: smserg.bk.ru
In ubuntu feisty sun java 6 also available.
Works ok for me :)
Pavel Kunc wrote:
> java instead of Sun Java... I wasn't able to run PDT under GIJ.
> config files...
> Regards
> Pavel
>> plugins broke, one of witch PDT. I've got no clue where to look, also
>> because I know nothing of java.
>> installed PDT.
>> well with java 1.6, but apparently I'm running java 1.4.2.
>> not support the requested type of object or operation. at
>> Source)
>> at
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> at
>> at
>> at
>> at
>> Arnold
> --Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Re: Error with Ubuntu Feisty [message #19226 is a reply to message #19212] |
Thu, 10 May 2007 13:32  |
I belive that version of Java doesn't matter here. Important is to use Sun
java and not GNU one....
And of course installation is the same with different packages.
Pavel
On Thu, 10 May 2007 19:08:42 +0200, Adam Randall
<adam@lockdownnetworks.com> wrote:
> On Thu, 10 May 2007 18:17:53 +0300
>> Works ok for me :)
> Same here, Ubuntu Feisty w/JRE 6, Eclipse 3.2.2 and one of the nightlies
> of PDT
> Adam.
FUDForum. Page generated in 0.04595 seconds
