Home » Archived » Riena » Riena and database
Riena and database [message #18540] Thu, 08 January 2009 16:00 Go to next message
Originally posted by: gxquarel.txin.it
On wiki I can't find examples about a minimal Riena application with a table
for editing a table retrieved from a database (maybe with Eclipselink).
Is there a plan for this?
Giovanni
Re: Riena and database [message #18548 is a reply to message #18540] Fri, 09 January 2009 09:33 Go to previous messageGo to next message
> Thanks
> Giovanni
Hi Giovanni,
May be through EclipseLink, I particularly use Hibernate+Spring, these
bundles and many other libraries are available on "SpringSource Enterprise
Bundle Repository" (http://www.springsource.com /repository/app /) for
OSGi.
Ekkes (http://ekkes-corner.blogspot.com/) projected its solution thus
(Riena+ EasyBeans+Hibernate) More details in its blog.
In summary all work of handling (operations CRUD) in persistence layer is
done via of Riena communication, see at "Riena Getting started" on wiki.
You registers a service OSGi (a Facade Pattern - GOF) and views have
access to this facade by Riena communication.
Re: Riena and database [message #18556 is a reply to message #18548] Fri, 09 January 2009 09:42 Go to previous messageGo to next message
Jose Carlos de Missias wrote:
table
>> Thanks
>> Giovanni
> Hi Giovanni,
> OSGi.
I am sorry, when I spoke in "Riena communication" wanted refer to
"Remote Services".
I am preparing an example for publication in "Riena Snippits"
Re: Riena and database [message #18564 is a reply to message #18540] Mon, 12 January 2009 07:44 Go to previous message
> Thanks
> Giovanni
Hi Giovanni,
as Jose is mentioning you can use any persistence layer that you like. We havnt come around yet to write an example but
the plan of course is to have some thin layer of support for EclipseLink and also probably for Hibernate (since it is so
popular). Havnt done it yet because of limited ressources and there are so many other things to come clear in Riena.
Jose is also right that you should keep you database logic and access layer on the server and access and transfer the
objects using Rienas Remote Services. If you have really large object nets there is component ObjectTransaction that
might be helpful (still lacks a sample and documentation). ObjectTransactions is about monitoring and tracking changes
in large object nets and then being able to only transfer the changed values over the wire (Remote Service connection).
So you could read a large customer record (several hundred properties) and if only a handful are changed they are
tracked on the client, before you transfer you create an extract from the ObjectTransaction, on the server you read the
original object net, apply the extract (the changes) to the extract and you have the modified object net on the server
which you can then persist. Helps you save bandwidth and transfer time.
As I said we have no sample or documentation of ObjectTransaction. BUT.....we have really many many JUnit Tests for them
that show you how they can be used.
Does that help ? If not please let me know.....
christian campo
Re: Riena and database [message #577782 is a reply to message #18540] Fri, 09 January 2009 09:33 Go to previous message
> Thanks
> Giovanni
Hi Giovanni,
OSGi.
Re: Riena and database [message #577793 is a reply to message #18548] Fri, 09 January 2009 09:42 Go to previous message
table
>> Thanks
>> Giovanni
> Hi Giovanni,
> OSGi.
"Remote Services".
Re: Riena and database [message #577808 is a reply to message #18540] Mon, 12 January 2009 07:44 Go to previous message
> Thanks
> Giovanni
Hi Giovanni,
christian campo
Previous Topic:Riena and database
Next Topic:Riena Release Candidate 1.0.0.RC1 available for download
Current Time: Sun Aug 31 23:51:43 EDT 2025
Powered by FUDForum. Page generated in 0.04109 seconds
