| Re: Nightly builds now available! [message #19242 is a reply to message #18568] |
Mon, 02 February 2009 08:21   |
I pointed the eclipse update to
http://download.eclipse.org/technology/swtbot/dev-build/upda te-site/
It has found the 2 repository:
.../swtbot/dev-build/update-site/
.../swtbot/update-site/
When I check one and ask to install, Eclipse studies some dependencies
then asks me to confirm to install of the plugin. I confirmed it, Eclipse
does some work but finally ends up with this message error box.
None of the 2 instals succeded.
I uninstalled previous plugins (the 2.0.0.1164 net.sf. ...) before (note:
the update did work right to install this version). Shouldn't I?
My eclipse is
Version: 3.4.1
Build id: M20080911-1700
Bye, and thanks for this quick reply
Marc
Ketan Padegaonkar wrote:
> Which update site did you use, and what version are you on ?
> The eclipse license certificate is about to expire[1], and this issue
> may have been caused because of the same, I'll re-upload the binaries again.
> [1] - https://bugs.eclipse.org/bugs/show_bug.cgi?id=252879
> -- Ketan
> On 2/2/09 16:34, Marc wrote:
>> I'm trying to install it with the Eclipse Software Update but I got this
>> error:
>> An error occurred while collecting items to be installed
>> Problems downloading artifact: osgi.bundle,org.junit4,4.5.0.v20080911.
>> Error reading signed content:
>> C:DOCUME~1meLOCALS~1Temp2signatureFile51419.jar
>> Either the manifest file or the signature file has been tampered in this
>> jar: C:DOCUME~1meLOCALS~1Temp2signatureFile51419.jar
>> I did not follow you about the junit4.5 issue.
>> Does this error have to do with it?
>> I tried twice to install and it failed twice with this error, so it
>> might not be just a transfer error.
>> Thanks in advance.
| Re: Nightly builds now available! [message #20474 is a reply to message #19242] |
Fri, 06 February 2009 08:34   |
Hi Marc,
Could you try the latest builds ? I think I've fixed the issue with a
workaround (see my latest email on this)
-- Ketan
> Eclipse does some work but finally ends up with this message error box.
> (note: the update did work right to install this version). Shouldn't I?
> My eclipse is
> Version: 3.4.1
> Marc
>> again.
>> -- Ketan
>>> Hi,
>>> error:
>>> Thanks in advance.
| Re: Nightly builds now available! [message #20479 is a reply to message #20474] |
Fri, 06 February 2009 09:32   |
thanks for your work
Unfortunately, it still doesn't work. Same behavior as before.
However, during the week, I've tried from time to time to install the
plugin.
It has failed every time except once!
The 2.0.0.133 dev installed once (on feb. 4th by 10:00 gmt) on one machine.
I wanted to install it to a second machine. So just after this success,
I've tried to install it also on the second machine... it failed! (and is
still failing now).
On the machine it has worked once, i have a 2nd eclipse install ... which
fails also ...
argh, I'm no more sure of anything: network error, problem reading the
downloaded signature file or plugin config, plugin licence ? ...
I'll try to test the install at home and see if get the error.
Bye, Marc
FUDForum. Page generated in 0.10293 seconds
