Home » Eclipse Projects » GEF » dragging a connector across a node anchors on the closer node
dragging a connector across a node anchors on the closer node [message #194048] Tue, 30 August 2005 10:04 Go to next message
For my application I am using a PolylineConnection, if I have three
nodes (same size)[implementing NodeEditPart] lined up horizontally (or
vertically), and make try to make a connection from the first node to
the third even though the connector snaps to the third node during
dragging, when I click the mouse to set the connector, the connector
'snaps back' on the second node.
The only way to avoid this, is to avoid having nodes aligning vertically
or horizontally.
Is this a known bug, or is there some setting that I am missing that I
should be enabling. I have noticed that test programs that use
connections that don't intersect the node don't have this behaviour, but
my application doesn't use that kind of representation.
/a
Re: dragging a connector across a node anchors on the closer node [message #194057 is a reply to message #194048] Tue, 30 August 2005 11:04 Go to previous message
Please disregard.
Alberto Ricart wrote:
> Hello,
> or horizontally.
> /a
Previous Topic:Connection endpoint problem
Next Topic:Add Command Problem
Current Time: Tue Oct 28 08:35:01 EDT 2025
Powered by FUDForum. Page generated in 1.03416 seconds
