Home » Language IDEs » Java Development Tools (JDT) » Eclipse 2.1 Crashes Regularly - JVM Exit Code 134
Eclipse 2.1 Crashes Regularly - JVM Exit Code 134 [message #193722] Thu, 20 January 2005 15:54 Go to next message
Originally posted by: scott.nospam.telesoft.com
I've been running Eclipse 2.1 on my RedHat 9 box for a couple of years
now. It routinely crashes once or twice each week - sometimes more,
sometimes less. There's never been any rhyme or reason to what I'm
doing when it happens. I've had it happen during edit sessions, CVS
commit, switching between tabs, etc. It's all over the place. When it
crashes, I get the following output:
JVM terminated. Exit code=134
/usr/java/j2sdk1.4.2_03/bin/java
-Xmx192m
-cp /home/scott/eclipse/startup.jar org.eclipse.core.launcher.Main
-os linux
-ws gtk
-arch x86
-showsplash /home/scott/eclipse -showsplash 600
Has anyone else experienced this and if so, is there any resolution?
Thanks.
Re: Eclipse 2.1 Crashes Regularly - JVM Exit Code 134 [message #193737 is a reply to message #193722] Thu, 20 January 2005 19:18 Go to previous messageGo to next message
Originally posted by: p.beauvoir.bolton.ac.uk
That's Linux for you...
Try using an OS that works - like Windows.
"Scott Dudley" <scott@nospam.telesoft.com> wrote in message
news:csp5pu$2rf$1@www.eclipse.org...
> sometimes less. There's never been any rhyme or reason to what I'm doing
> when it happens. I've had it happen during edit sessions, CVS commit,
> switching between tabs, etc. It's all over the place. When it crashes, I
> -Xmx192m
> -os linux
> -ws gtk
> -arch x86
> Thanks.
Re: Eclipse 2.1 Crashes Regularly - JVM Exit Code 134 [message #193802 is a reply to message #193722] Fri, 21 January 2005 10:23 Go to previous messageGo to next message
Originally posted by: kcollins.pinksheets.com
I've run 2.1, all of the 3.0M series up 3.1M4 on Linux without any
crashes. I'm using Debian testing. I'm working with two other developers
using Linux (RedHat and Mepis) with 2.1 and 3.0, and they haven't had
any problems over the last year either.
You may consider upgrading to the latest stable version of the Gnome and
gtk libraries and see if that helps. It also wouldn't hurt to give
Eclipse more than 192m.
> -Xmx192m
> -os linux
> -ws gtk
> -arch x86
> Thanks.
Re: Eclipse 2.1 Crashes Regularly - JVM Exit Code 134 [message #193950 is a reply to message #193722] Sat, 22 January 2005 04:07 Go to previous messageGo to next message
Originally posted by: user.server.com
Does other Java applications also crash? If so, please check the memory in
your machine. Java is _very_ sensible about memory bugs.
Tom
Re: Eclipse 2.1 Crashes Regularly - JVM Exit Code 134 [message #194116 is a reply to message #193950] Mon, 24 January 2005 15:09 Go to previous messageGo to next message
> in your machine. Java is _very_ sensible about memory bugs.
> Tom
No other Java apps crash - just Eclipse.
Re: Eclipse 2.1 Crashes Regularly - JVM Exit Code 134 [message #194123 is a reply to message #193737] Mon, 24 January 2005 15:13 Go to previous messageGo to next message
That's why I run Linux - thanks, but no thanks. :-)
I've been running/using Windows since it's inception (when it was an app
running on DOS) and had already been a Unix user for 5 or 6 years prior.
So - as far as true operating systems go, and being knowledgeable of
both, I'll take any Unix hands-down over Windows.
Also - Eclipse is the only Java app with which I've experienced any
problems on this platform. I also run Oracle, Tomcat, Resin, etc. - no
prob.
>>-Xmx192m
>>-os linux
>>-ws gtk
>>-arch x86
>>Thanks.
Re: Eclipse 2.1 Crashes Regularly - JVM Exit Code 134 [message #194197 is a reply to message #194123] Tue, 25 January 2005 08:08 Go to previous message
Sorry if it came out wrong.
Irony.
Phil
news:ct3ktq$guc$1@www.eclipse.org...
> So - as far as true operating systems go, and being knowledgeable of both,
> prob.
>>>-Xmx192m
>>>-os linux
>>>-ws gtk
>>>-arch x86
>>>Thanks.
Previous Topic:Source lookup oddity
Next Topic:How to create IRuntimeClasspathEntry for folder in a project?
Current Time: Mon Jul 21 21:14:41 EDT 2025
Powered by FUDForum. Page generated in 0.23979 seconds
