Home » Eclipse Projects » GEF » draw2d-Figures no visible after changing from GEF3.0 to GEF 3.1
draw2d-Figures no visible after changing from GEF3.0 to GEF 3.1 [message #193706] Sat, 27 August 2005 05:34 Go to next message
Originally posted by: q5280338.mailstore.fernuni-hagen.de
Maybe there are older posts with the same problem (I haven't searched
for it)...
I wrote a plugin using the GraphicalEditorWithPalette containing
different draw2d-figures like "Ellipse", "RectangleFigure" and
"RoundedRectangle" and "PolylineConnections" between the figures.
Now I changed from Eclipse 3.0/GEF 3.0 to Eclipse 3.1/GEF 3.1 and the
figures are no longer visible. Only the connections are visible. I've
got the same result installing my plugin (version Eclipse/GEF 3.0)
under Eclipse/GEF 3.1.
I've checked both under Windows and Linux.
Klaus
Re: draw2d-Figures no visible after changing from GEF3.0 to GEF 3.1 [message #193717 is a reply to message #193706] Sat, 27 August 2005 08:00 Go to previous message
> for it)...
> got the same result installing my plugin (version Eclipse/GEF 3.0) under
> Eclipse/GEF 3.1.
> Thanks
> Klaus
Found a solution. It seems to be that in GEF 3.1 the default size of the
draw2d figures is with=hieght=0. Have to set the size!
Previous Topic:request and Action
Next Topic:Announcing UMLX 0.0.0
Current Time: Wed Jul 16 02:40:57 EDT 2025
Powered by FUDForum. Page generated in 0.34439 seconds
